path: root/drivers/net/depca.c
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-05[DRIVER MODEL] Fix depcaRussell King
Release code in driver modules is a potential cause of oopsen. The device may be in use by a userspace process, which will keep a reference to the device. If the module is unloaded, the module text will be freed. Subsequently, when the last reference is dropped, the release code will be called, which no longer exists. Use generic platform device allocation/release code in modules. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
