path: root/drivers/net/cs89x0.c
2006-01-16[PATCH] cs89x0: credit Dmitry PervushinLennert Buytenhek
Credit Dmitry Pervushin for the PNX010X platform support. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] cs89x0: add ixdp2351 supportDeepak Saxena
This patch adds support for the Intel IXDP2351 to the CS89x0 driver. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] cs89x0: use u16 for device register dataLennert Buytenhek
cs89x0 inconsistently used 'int' and 'u32' for device register data. As the cs89x0 is a 16-bit chip, change the I/O accessors over to 'u16'. (Spotted by Deepak Saxena.) Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] cs89x0: use #elif instead of #else/#if/#endifLennert Buytenhek
2006-01-14[PATCH] cs89x0: credit Dmitry PervushinLennert Buytenhek
2006-01-11[PATCH] cs89x0: fix setting of ALLOW_DMALennert Buytenhek
There's an ifdef in cs89x0.c that seems to have been the wrong way round since it was merged (and noone seems to have noticed) -- the IXDP2x01 doesn't support ISA-style DMA, but when building for IXDP2x01, cs89x0's ALLOW_DMA is set to 1, and when building for another platform, ALLOW_DMA is set to 0. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: fix up after pnx0105 Kconfig symbol renamingLennert Buytenhek
The Kconfig symbol for pnx0105 was recently renamed to ARCH_PNX010X. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: switch {in,out}sw to {read,write}wordsLennert Buytenhek
Implement readwords/writewords that use readword/writeword, and switch the rest of the driver over to use these. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: cleanly implement ixdp2x01 and pnx0501 supportLennert Buytenhek
Implement suitable versions of the readword/writeword macros for ixdp2x01 and pnx0501. Handle the 32-bit spacing of the registers in these functions instead of in the header file. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: make {read,write}reg use {read,write}wordLennert Buytenhek
Make readreg/writereg use readword/writeword. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: swap {read,write}reg and {read,write}wordLennert Buytenhek
Reverse the order of readreg/writereg and readword/writeword in the file, so that we can make readreg/writereg use readword/writeword. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: convert {inw,outw} calls to {read,write}wordLennert Buytenhek
Switch all occurences of inw/outw in the driver over to readword/writeword. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] cs89x0: make {read,write}word take base_addrLennert Buytenhek
readword() and writeword() take a 'struct net_device *' and deref its ->base_addr member. Make them take the base_addr directly instead, so that we can switch the other occurences of inw/outw in the file over to readword/writeword as well. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-04[PATCH] ARM: Reverted 2919/1: CS8900A ethernet driver modifications for the ↵Russell King
Comdial MP1000 No longer maintained
2005-10-28[ARM] 2919/1: CS8900A ethernet driver modifications for the Comdial MP1000Jon Ringle
Patch from Jon Ringle This patch gives support for the CS8900A ethernet chip on the Comdial MP1000 Signed-off-by: Jon Ringle Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-26[PATCH] missing asm/irq.h (cs89x0)Al Viro
2005-09-09[PATCH] cs89x0: add netpoll supportDeepak Saxena
Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Matt Mackall <mpm@selenic.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] silence cs89x0Denis Vlasenko
cs89x0 talks a lot at boot. Seems like debug leftover. This patch downgrades printks to KERN_DEBUG. While we're at it, make these messages a bit less obscure. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] cs89x0: collect tx_bytes statisticsIan Campbell
Signed-off-by: Ian Campbell <icampbell@arcom.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] cs89x0.c: support for Philips' pnx0105 network adapterdmitry pervushin
This patch is to provide support for cs89x0-based network device on Philips' pnx0105 board. Signed-off-by: dmitry pervushin <dpervushin@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-05-12[netdrvr] Fix register_netdev() races in older ISA net drivers
