path: root/drivers/net/chelsio
2010-06-03chelsio: Remove remnants of CONFIG_CHELSIO_T1_COUGARRoland Dreier
CONFIG_CHELSIO_T1_COUGAR cannot be set (it appears nowhere in any Kconfig files), and the code it protects could never build (cspi.h was never added to the kernel tree). Therefore it's pretty safe to remove all vestiges of this dead code. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14drivers: net: use skb_headlen()Eric Dumazet
replaces (skb->len - skb->data_len) occurrences by skb_headlen(skb) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13chelsio: Fix build warning.David S. Miller
GCC warns that: drivers/net/chelsio/sge.c:463:11: warning: operation on 's->port' may be undefined Better to eliminate the side effects in the calculation and express what was intended here. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13chelsio: use the DMA state API instead of the pci equivalentsFUJITA Tomonori
This replace the PCI DMA state API (include/linux/pci-dma.h) with the DMA equivalents since the PCI DMA state API will be obsolete. No functional change. For further information about the background: http://marc.info/?l=linux-netdev&m=127037540020276&w=2 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-26drivers/net/chelsio: Use pr_<level>, netif_msg_<type>Joe Perches
Convert CH_<level> and CH_DBG uses to pr_<level> and netif equivalents Remove CH_<level> and CH_DBG macro definitions Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17chelsio: convert to use netdev_for_each_mc_addrJiri Pirko
2010-02-16percpu: add __percpu sparse annotations to net driversTejun Heo
Add __percpu sparse annotations to net drivers. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-03this_cpu: Straight transformationsChristoph Lameter
Use this_cpu_ptr and __this_cpu_ptr in locations where straight transformations are possible because per_cpu_ptr is used with either smp_processor_id() or raw_smp_processor_id(). cc: David Howells <dhowells@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> cc: Ingo Molnar <mingo@elte.hu> cc: Rusty Russell <rusty@rustcorp.com.au> cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: dont update dev->trans_start in 10GB driversEric Dumazet
Followup of commits 9d21493b4beb8f918ba248032fefa393074a5e2b and 08baf561083bc27a953aa087dd8a664bb2b88e8e (net: tx scalability works : trans_start) (net: txq_trans_update() helper) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Multi queue drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers (vxge & tehuti) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-20cxgb: set phy's mdio dev before the phy init sequenceDivy Le Ray
mdio's dev field needs to be set before mdio ops occur. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-20chelsio: Use generic XENPAK LASI register definitionsBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29chelsio: Use generic MDIO definitions and mdio_mii_ioctl()Ben Hutchings
Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-13drivers/net: replace BUG() with BUG_ON() if possibleAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-26chelsio: remove some pointless conditionals before kfree_skb()Wei Yongjun
Remove some pointless conditionals before kfree_skb(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-26net: Fix warning fallout from recent NAPI interface changes.David S. Miller
When we removed the network device argument from several NAPI interfaces in 908a7a16b852ffd618a9127be8d62432182d81b4 ("net: Remove unused netdev arg from some NAPI interfaces.") several drivers now started getting unused variable warnings. This fixes those up. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/hp-plus.c drivers/net/wireless/ath5k/base.c drivers/net/wireless/ath9k/recv.c net/wireless/reg.c
2008-11-23drivers/net/chelsio/sge.c: remove redundant argument commentsQinghuang Feng
remove redundant argument comments Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20netdev: add more functions to netdevice opsStephen Hemminger
This patch moves neigh_setup and hard_start_xmit into the network device ops structure. For bisection, fix all the previously converted drivers as well. Bonding driver took the biggest hit on this. Added a prefetch of the hard_start_xmit in the fast path to try and reduce any impact this would have. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19cxgb2: convert to net_device_opsStephen Hemminger
Convert this driver to network device ops. Compile teseted only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16netdevice chelsio: Convert directly reference of netdev->privWang Chen
Several netdev share one adapter here. We use netdev->ml_priv of the netdevs point to the first netdev's priv. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-11cxgb: delete non NAPI code from the driver.Francois Romieu
Compile-tested only. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28annotate chelsioAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28drivers/net/chelsio/: #if 0 unused functionsAdrian Bunk
This patch #if 0's the following unused functions: - espi.c:t1_espi_set_misc_ctrl() - sge.c:t1_sched_set_max_avail_bytes() - sge.c:t1_sched_set_drain_bits_per_us() Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28drivers/net/chelsio: Add missing "space"Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-04cxgb - revert file mode changes.Divy Le Ray
revert inavertant file mode changes Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01cxgb - fix statsDivy Le Ray
Fix MAC stats accounting. Fix get_stats. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01cxgb - fix NAPIDivy Le Ray
netif_rx_complete() should be called only when work_done < budget. Signed-off-by: Divy Le ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01cxgb - fix T2 GSODivy Le Ray
The patch ensures that a GSO skb has enough headroom to push an encapsulating cpl_tx_pkt_lso header. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-15[CHELSIO]: Fix skb->dev setting.Divy Le Ray
eth_type_trans() now sets skb->dev. Access skb->def after it gets set. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10chelsio: sparse warning fixes (old cxgb2)Stephen Hemminger
Fix problems detected by sparse: 1. whole chunk of MAC code was for defined and never used 2. hook for running ext intr in workqueue wasn't being used Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ETHTOOL] Provide default behaviors for a few ethtool sub-ioctlsJeff Garzik
For the operations get-tx-csum get-sg get-tso get-ufo the default ethtool_op_xxx behavior is fine for all drivers, so we permit op==NULL to imply the default behavior. This provides a more uniform behavior across all drivers, eliminating ethtool(8) "ioctl not supported" errors on older drivers that had not been updated for the latest sub-ioctls. The ethtool_op_xxx() functions are left exported, in case anyone wishes to call them directly from a driver-private implementation -- a not-uncommon case. Should an ethtool_op_xxx() helper remain unused for a while, except by net/core/ethtool.c, we can un-export it at a later date. [ Resolved conflicts with set/get value ethtool patch... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03network drivers: eliminate unneeded kill_vid codeStephen Hemminger
Many drivers had code that did kill_vid, but they weren't doing vlan filtering. With new API the stub is unneeded unless device sets NETIF_F_HW_VLAN_FILTER. Bad habit: I couldn't resist fixing a couple of nearby style things in acenic, and forcedeth. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-24chelsio parenthesis fixMariusz Kozlowski
Hello, Balanance parenthesis in chelsio header file. Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> drivers/net/chelsio/suni1x10gexp_regs.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28chelsio: use const for virtual functionsStephen Hemminger
There are several uses of _ops structure in this driver that can be converted to const. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
