path: root/drivers/net/caif
2014-12-22caif: Fix napi poll list corruptionHerbert Xu
The commit d75b1ade567ffab085e8adbbdacf0092d10cd09c (net: less interrupt masking in NAPI) breaks caif. It is now required that if the entire budget is consumed when poll returns, the napi poll_list must remain empty. However, like some other drivers caif tries to do a last-ditch check and if there is more work it will call napi_schedule and then immediately process some of this new work. Should the entire budget be consumed while processing such new work then we will violate the new caller contract. This patch fixes this by not touching any work when we reschedule in caif. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-15net: set name_assign_type in alloc_netdev()Tom Gundersen
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert all users to pass NET_NAME_UNKNOWN. Coccinelle patch: @@ expression sizeof_priv, name, setup, txqs, rxqs, count; @@ ( -alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs) +alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs) | -alloc_netdev_mq(sizeof_priv, name, setup, count) +alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count) | -alloc_netdev(sizeof_priv, name, setup) +alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup) ) v9: move comments here from the wrong commit Signed-off-by: Tom Gundersen <teg@jklm.no> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17caif: delete unnecessary field initializationJulia Lawall
On success, the function netdev_alloc_skb initializes the dev field of its result to its first argument, so this doesn't have to be done in the calling context. The semantic patch that fixes this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression skb,privn,e; @@ skb = netdev_alloc_skb(privn,...); ... when strict ( -skb->dev = privn; | ?skb = e ) // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-16drivers/net: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. This covers everything under drivers/net except for wireless, which has been submitted separately. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-17virtio: use size-based config accessors.Rusty Russell
This lets the transport do endian conversion if necessary, and insulates the drivers from the difference. Most drivers can use the simple helpers virtio_cread() and virtio_cwrite(). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-09-04caif: add a sanity check to the tty nameDan Carpenter
"tty->name" and "name" are a 64 character buffers. My static checker complains because we add the "cf" on the front so it look like we are copying a 66 character string into a 64 character buffer. Also if the name is larger than IFNAMSIZ (16) it triggers a BUG_ON() inside the call to alloc_netdev(). This is all under CAP_SYS_ADMIN so it's not a security fix, it just adds a little robustness. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-09drivers/net: caif: fix wrong rtnl_is_locked() usageKonstantin Khlebnikov
rtnl_is_locked() doesn't check who holds this lock, it just tells that it's locked right now. if caif::ldisc_close really can be called under rtrnl_lock then it should release net device in other context because there is no way to grab rtnl_lock without deadlock. This patch adds work which releases these devices. Also this patch fixes calling dev_close/unregister_netdevice without rtnl_lock from caif_ser_exit(). Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Dmitry Tarnyagin <dmitry.tarnyagin@lockless.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-11caif: CAIF_VIRTIO should depend on HAS_DMAGeert Uytterhoeven
If NO_DMA=y: drivers/built-in.o: In function `cfv_destroy_genpool': drivers/net/caif/caif_virtio.c:364: undefined reference to `dma_free_coherent' drivers/built-in.o: In function `cfv_create_genpool': drivers/net/caif/caif_virtio.c:397: undefined reference to `dma_alloc_coherent' Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Dmitry Tarnyagin <dmitry.tarnyagin@lockless.no> Cc: David S. Miller <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-02Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio & lguest updates from Rusty Russell: "Lots of virtio work which wasn't quite ready for last merge window. Plus I dived into lguest again, reworking the pagetable code so we can move the switcher page: our fixmaps sometimes take more than 2MB now..." Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename. Hopefully correctly resolved. * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits) caif_virtio: Remove bouncing email addresses lguest: improve code readability in lg_cpu_start. virtio-net: fill only rx queues which are being used lguest: map Switcher below fixmap. lguest: cache last cpu we ran on. lguest: map Switcher text whenever we allocate a new pagetable. lguest: don't share Switcher PTE pages between guests. lguest: expost switcher_pages array (as lg_switcher_pages). lguest: extract shadow PTE walking / allocating. lguest: make check_gpte et. al return bool. lguest: assume Switcher text is a single page. lguest: rename switcher_page to switcher_pages. lguest: remove RESERVE_MEM constant. lguest: check vaddr not pgd for Switcher protection. lguest: prepare to make SWITCHER_ADDR a variable. virtio: console: replace EMFILE with EBUSY for already-open port virtio-scsi: reset virtqueue affinity when doing cpu hotplug virtio-scsi: introduce multiqueue support virtio-scsi: push vq lock/unlock into virtscsi_vq_done virtio-scsi: pass struct virtio_scsi to virtqueue completion function ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-05-01caif_virtio: Remove bouncing email addressesSjur Brændeland
Remove our (soon to be) bouncing email addresses, and update Dmitri's address. Dmitry will take over as maintainer for CAIF from now on. Cc: Vikram Arv <vikram.arv@stericsson.com> Cc: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com> Cc: Dmitry Tarnyagin <dmitry.tarnyagin@lockless.no> Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Dmity Tarnyagin <dmitry.tarnyagin@lockless.no>
2013-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c drivers/net/ethernet/emulex/benet/be.h include/net/tcp.h net/mac802154/mac802154.h Most conflicts were minor overlapping stuff. The be2net driver brought in some fixes that added __vlan_put_tag calls, which in net-next take an additional argument. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-25caif: spi: missing platform_driver_unregister() on error in cfspi_init_module()Wei Yongjun
Add the missing platform_driver_unregister() before return from cfspi_init_module() in the error handling case. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-23caif: Update Dmitry's email address.sjur.brandeland@stericsson.com
Dmitry's address will start bouncing in a few days, update to his new mail address. Cc: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com> Cc: Dmitry Tarnyagin <dmitry.tarnyagin@lockless.no> Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-23caif: Remove bouncing address for Daniel Martenssonsjur.brandeland@stericsson.com
cc: Daniel Martensson <Daniel.Martensson@stericsson.com> Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-23caif: Remove my bouncing email address.sjur.brandeland@stericsson.com
Remove my soon bouncing email address. Also remove the "Contact:" line in file header. The MAINTAINERS file is a better place to find the contact person anyway. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-02caif_virtio: fix error return code in cfv_create_genpool()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as returned elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-03-25CAIF: fix tty->warned build errorJiri Slaby
After commit 6865ff222cca ("TTY: do not warn about setting speed via SPD_*"), we are seeing a build error when DEBUG_FS is enabled: drivers/net/caif/caif_serial.c: In function 'update_tty_status': drivers/net/caif/caif_serial.c:94:11: error: 'struct tty_struct' has no member named 'warned' Fix the error by removing the reference to the variable as it was not set in the last decade (as documented in the changelog of the commit above). Signed-off-by: Jiri Slaby <jslaby@suse.cz> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Sjur Braendeland <sjur.brandeland@stericsson.com> Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-24caif_virtio: Check that vringh_config is not nullSjur Brændeland
Check that vringh_config is not NULL before using it. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-03-24caif_virtio: Use vringh_notify_enable correctlySjur Brændeland
Check on the correct return value from vringh_notify_enable_kern(). It returns false if more packets are available, not true. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-03-20caif_virtio: use simplified virtqueue accessors.Rusty Russell
We never add buffers with input and output parts, so use the new accessors. Cc: Sjur Brendeland <sjur.brandeland@stericsson.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-03-20caif_virtio: Introduce caif over virtioErwan Yvin
Add the CAIF Virtio shared memory driver for talking to a modem. This CAIF Link layer communicates to the modem over shared memory. It is implemented as a virtio_driver. The underlying virtio device is managed by the remoteproc framework. The Virtio queue is used for transmitting data to the modem, and the new vringh is used for receiving data. Genalloc is used for managing the shared memory used for TX data. The default dma-alloc-coherent allocator can only allocate whole pages, and this wastes too much shared memory. Flow control is implemented by stopping the TX-queues if the virtio queues go full or we run out of memory. Queued are reopened when queues are below the watermark. NAPI is used in RX path, and a dedicated tasklet is used for releasing TX buffers. Signed-off-by: Erwan Yvin <erwan.yvin@stericsson.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (minor fixes)
2013-03-18TTY: cleanup tty->hw_stopped usesJiri Slaby
tty->hw_stopped is set only by drivers to remember HW state. If it is never set to 1 in a particular driver, there is no need to check it in the driver at all. Remove such checks. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-17caif: remove caif_shmErwan Yvin
caif_shm is an old implementation caif_shm will be replaced by caif_virtio [ As explained by Linus Walleij: "U5500 used this, but was cancelled and the silicon did not reach anyone outside ST-Ericsson. Then for the next platforms, we have gone for the leaner & cleaner approach of using virtio, rpmesg and rproc." ] Signed-off-by: Erwan Yvin <erwan.yvin@stericsson.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sjur Brendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-09drivers:net: Remove unnecessary OOM messages after netdev_alloc_skbJoe Perches
Emitting netdev_alloc_skb and netdev_alloc_skb_ip_align OOM messages is unnecessary as there is already a dump_stack after allocation failures. Other trivial changes around these removals: Convert a few comparisons of pointer to 0 to !pointer. Change flow to remove unnecessary label. Remove now unused variable. Hoist assignment from if. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-21Merge tag 'tty-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial patches from Greg Kroah-Hartman: "Here's the big tty/serial driver patches for 3.9-rc1. More tty port rework and fixes from Jiri here, as well as lots of individual serial driver updates and fixes. All of these have been in the linux-next tree for a while." * tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits) tty: mxser: improve error handling in mxser_probe() and mxser_module_init() serial: imx: fix uninitialized variable warning serial: tegra: assume CONFIG_OF TTY: do not update atime/mtime on read/write lguest: select CONFIG_TTY to build properly. ARM defconfigs: add missing inclusions of linux/platform_device.h fb/exynos: include platform_device.h ARM: sa1100/assabet: include platform_device.h directly serial: imx: Fix recursive locking bug pps: Fix build breakage from decoupling pps from tty tty: Remove ancient hardpps() pps: Additional cleanups in uart_handle_dcd_change pps: Move timestamp read into PPS code proper pps: Don't crash the machine when exiting will do pps: Fix a use-after free bug when unregistering a source. pps: Use pps_lookup_dev to reduce ldisc coupling pps: Add pps_lookup_dev() function tty: serial: uartlite: Support uartlite on big and little endian systems tty: serial: uartlite: Fix sparse and checkpatch warnings serial/arc-uart: Miscll DT related updates (Grant's review comments) ... Fix up trivial conflicts, mostly just due to the TTY config option clashing with the EXPERIMENTAL removal.
2013-02-04caif: Remove unnecessary alloc/OOM messagesJoe Perches
alloc failures already get standardized OOM messages and a dump_stack. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-18tty: Added a CONFIG_TTY option to allow removal of TTYJoe Millenbach
The option allows you to remove TTY and compile without errors. This saves space on systems that won't support TTY interfaces anyway. bloat-o-meter output is below. The bulk of this patch consists of Kconfig changes adding "depends on TTY" to various serial devices and similar drivers that require the TTY layer. Ideally, these dependencies would occur on a common intermediate symbol such as SERIO, but most drivers "select SERIO" rather than "depends on SERIO", and "select" does not respect dependencies. bloat-o-meter output comparing our previous minimal to new minimal by removing TTY. The list is filtered to not show removed entries with awk '$3 != "-"' as the list was very long. add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350) function old new delta chr_dev_init 166 170 +4 allow_signal 80 82 +2 static.__warned 143 142 -1 disallow_signal 63 62 -1 __set_special_pids 95 94 -1 unregister_console 126 121 -5 start_kernel 546 541 -5 register_console 593 588 -5 copy_from_user 45 40 -5 sys_setsid 128 120 -8 sys_vhangup 32 19 -13 do_exit 1543 1526 -17 bitmap_zero 60 40 -20 arch_local_irq_save 137 117 -20 release_task 674 652 -22 static.spin_unlock_irqrestore 308 260 -48 Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reviewed-by: Jamey Sharp <jamey@minilop.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: move low_latency to tty_portJiri Slaby
One point is to have less places where we actually need tty pointer. The other is that low_latency is bound to buffer processing and buffers are now in tty_port. So it makes sense to move low_latency to tty_port too. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-24caif: fix NULL pointer checkAlan Cox
Reported-by: <rucsoftsec@gmail.com> Resolves-bug: http://bugzilla.kernel.org/show_bug?44441 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-29caif-hsi: Fix merge issues.Sjur Brændeland
Fix the failing merge in net-next by reverting the last net-next merge for caif_hsi.c and then merge in the commit: "caif-hsi: Bugfix - Piggyback'ed embedded CAIF frame lost" from the net repository. The commit:"caif-hsi: Add missing return in error path" from net repository was dropped, as it changed code previously removed in the net-next repository. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/caif/caif_hsi.c drivers/net/usb/qmi_wwan.c The qmi_wwan merge was trivial. The caif_hsi.c, on the other hand, was not. It's a conflict between 1c385f1fdf6f9c66d982802cd74349c040980b50 ("caif-hsi: Replace platform device with ops structure.") in the net-next tree and commit 39abbaef19cd0a30be93794aa4773c779c3eb1f3 ("caif-hsi: Postpone init of HIS until open()") in the net tree. I did my best with that one and will ask Sjur to check it out. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25caif-hsi: Remove use of module parametersSjur Brændeland
Remove use of module parameters on caif hsi device, as rtnl configuration parameters are already supported. All caif hsi configuration data is put in cfhsi_config, and default values in hsi_default_config. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25caif-hsi: Replace platform device with ops structure.Sjur Brændeland
Remove use of struct platform_device, and replace it with struct cfhsi_ops. Updated variable names in the same spirit: cfhsi_get_dev to cfhsi_get_ops, cfhsi->dev to cfhsi->ops and, cfhsi->dev.drv to cfhsi->ops->cb_ops. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25caif-hsi: Add rtnl supportSjur Brændeland
Add RTNL support for managing the caif hsi interface. The HSI HW interface is no longer registering as a device, instead we use symbol_get to get hold of the HSI API. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25caif-hsi: Remove uncecessary assignmentsSjur Brændeland
Remove assignment at declaration when not needed. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericssion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25caif-hsi: Use netdev_X instead of dev_X for printingSjur Brændeland
Replace dev_X with the corresponding netdev_X print function when applicable. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericssion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25caif-hsi: changed test on aggregation_timeoutKim Lilliestierna XX
Aggregation_timeout is an unsigned long, a test for less than zero can never become true, compare with zero instead. Signed-off-by: Kim Lilliestierna <kim.xx.lilliestierna@stericsson.com> Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25caif-hsi: Removed dead codeKim Lilliestierna XX
Simplify logic and remove dead code. Signed-off-by: Kim Lilliestierna <kim.xx.lilliestierna@stericsson.com> Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25caif-hsi: Add missing return in error pathSjur Brændeland
Fix a missing return, causing access to freed memory. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-25caif-hsi: Bugfix - Piggyback'ed embedded CAIF frame lostPer Ellefsen
When receiving a piggyback'ed descriptor containing an embedded frame, but no payload, the embedded frame was lost. Signed-off-by: Per Ellefsen <per.ellefsen@stericsson.com> Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-21caif: include linux/io.hArnd Bergmann
The caif_shmcore requires io.h in order to use ioremap, so include that explicitly to compile in all configurations. Also add a note about the use of ioremap(), which is not a proper way to map a DMA buffer into kernel space. It's not completely clear what the intention is for using ioremap, but it is clear that the result of ioremap must not simply be accessed using kernel pointers but should use readl/writel or memcopy_{to,from}io. Assigning the result of ioremap to a regular pointer that can also be set to something else is not ok. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13caif-hsi: Postpone init of HSI until open()sjur.brandeland@stericsson.com
Do the initialization of the HSI interface when the interface is opened, instead of upon registration. When the interface is closed the HSI interface is de-initialized, allowing other modules to use the HSI interface. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13caif-hsi: Remove stop/start of queue.sjur.brandeland@stericsson.com
CAIF HSI is currently a virtual device. Stopping/starting the queues is wrong on a virtual device. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13caif-hsi: robust frame aggregation for HSIDmitry Tarnyagin
Implement aggregation algorithm, combining more data into a single HSI transfer. 4 different traffic categories are supported: 1. TC_PRIO_CONTROL .. TC_PRIO_MAX (CTL) 2. TC_PRIO_INTERACTIVE (VO) 3. TC_PRIO_INTERACTIVE_BULK (VI) 4. TC_PRIO_BESTEFFORT, TC_PRIO_BULK, TC_PRIO_FILLER (BEBK) Signed-off-by: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13caif_hsi: use dev_dbg not dev_err for reportingKim Lilliestierna XX
Use dev_dbg instead of dev_err for reporting in cfhsi_wakeup_cb. Signed-off-by: Kim Lilliestierna <kim.xx.lilliestierna@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13caif-hsi: Free flip_buffer at shutdownsjur.brandeland@stericsson.com
Fix memory leak of RX flip-buffer. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-05simple_open: automatically convert to simple_open()Stephen Boyd
Many users of debugfs copy the implementation of default_open() when they want to support a custom read/write function op. This leads to a proliferation of the default_open() implementation across the entire tree. Now that the common implementation has been consolidated into libfs we can replace all the users of this function with simple_open(). This replacement was done with the following semantic patch: <smpl> @ open @ identifier open_f != simple_open; identifier i, f; @@ -int open_f(struct inode *i, struct file *f) -{ ( -if (i->i_private) -f->private_data = i->i_private; | -f->private_data = i->i_private; ) -return 0; -} @ has_open depends on open @ identifier fops; identifier open.open_f; @@ struct file_operations fops = { ... -.open = open_f, +.open = simple_open, ... }; </smpl> [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-03-06caif-hsi: Set default MTU to 4096Sjur Brændeland
Default MTU for CAIF HSI was wrongly set to 15 * 4092 bytes. The patch sets default MTU size to 4096. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
