Previously CAIF supported maximum transfer size of ~4050.
The transfer size is now calculated dynamically based on the
link layers mtu size.
Signed-off-by: Sjur Braendeland@stericsson.com
I added newlines after the declarations in caif_serial.c. This is
normal kernel style, although I can't see anywhere it's documented.
We don't use the "ser" variable so I've removed it.
Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com>
Changes:
o Added permission checks for installing. CAP_SYS_ADMIN and
CAP_SYS_TTY_CONFIG can install the ldisc.
o Check if allocation of skb was successful.
Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com>
I don't think this can be abused in this case but do things properly.
Signed-off-by: Alan Cox <alan@linux.intel.com>
write is optional for a tty device. Check that we have a write op rather
than calling NULL.
Add CAIF Serial driver. This driver is implemented as a line discipline.
caif_serial uses the following module parameters:
ser_use_stx - specifies if STart of frame eXtension is in use.
ser_loop - sets the interface in loopback mode.
