This patch is a little improvement. If user use the
command shown as below, we should print the info [1]
instead of [2]. The eth0 exists actually, and it may
confuse user.
$ echo "eth0" > /sys/class/net/bond4/bonding/slaves
[1] "bond4: no command found in slaves file - use +ifname or -ifname"
[2] "write error: No such device"
Signed-off-by: Tonghao Zhang <xiangxia.m.yue@gmail.com>
I made a dumb mistake when I summed up the slave stats, obviously slaves
can come and go which would make the master stats unreliable.
Count and export the master stats separately.
Fixes: a258aeacd7f0 ("bonding: add support for xstats and export 3ad stats")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
This patch adds support for extended statistics (xstats) call to the
bonding. The first user would be the 3ad code which counts the following
events:
- LACPDU Rx/Tx
- LACPDU unknown type Rx
- LACPDU illegal Rx
- Marker Rx/Tx
- Marker response Rx/Tx
- Marker unknown type Rx
All of these are exported via netlink as separate attributes to be
easily extensible as we plan to add more in the future.
Similar to how the bridge and other xstats exports, the structure
inside is:
[ IFLA_STATS_LINK_XSTATS ]
-> [ LINK_XSTATS_TYPE_BOND ]
-> [ BOND_XSTATS_3AD ]
-> [ 3ad stats attributes ]
With this structure it's easy to add more stat types later.
Count the following types of 3ad packets per slave:
- rx/tx lacpdu
- rx/tx marker
- rx/tx marker response
- rx illegal lacpdus (right now counted on wrong length)
- rx unknown lacpdu type
- rx unknown marker type
The counters are using atomic64 since this is not fast path.
Since the received lacpdu is accessed via skb_header_pointer() in
bond_3ad_lacpdu_recv() we no longer need to check for skb->len's length.
If the returned lacpdu pointer is not null that should be enough.
No functional changes, adjust the style of bond_3ad_rx_indication to
prepare it for the stats changes:
- reduce indentation by returning early on wrong length
- remove extra new lines between switch cases
- add marker local variable and use it to reduce line length
- rearrange local variables in reverse xmas tree
- separate final return
A network device stack with multiple layers of bonding devices can
trigger a false positive lockdep warning. Adding lockdep nest levels
fixes this. Update the level on both enslave and unlink, to avoid the
following series of events ..
ip netns add test
ip netns exec test bash
ip link set dev lo addr 00:11:22:33:44:55
ip link set dev lo down
ip link add dev bond1 type bond
ip link add dev bond2 type bond
ip link set dev lo master bond1
ip link set dev bond1 master bond2
ip link set dev bond1 nomaster
ip link set dev bond2 master bond1
.. from still generating a splat:
[ 193.652127] ======================================================
[ 193.658231] WARNING: possible circular locking dependency detected
[ 193.664350] 4.20.0 #8 Not tainted
[ 193.668310] ------------------------------------------------------
[ 193.674417] ip/15577 is trying to acquire lock:
[ 193.678897] 00000000a40e3b69 (&(&bond->stats_lock)->rlock#3/3){+.+.}, at: bond_get_stats+0x58/0x290
[ 193.687851]
but task is already holding lock:
[ 193.693625] 00000000807b9d9f (&(&bond->stats_lock)->rlock#2/2){+.+.}, at: bond_get_stats+0x58/0x290
[ 193.851092] lock_acquire+0xa7/0x190
[ 193.855138] _raw_spin_lock_nested+0x2d/0x40
[ 193.859878] bond_get_stats+0x58/0x290
[ 193.864093] dev_get_stats+0x5a/0xc0
[ 193.868140] bond_get_stats+0x105/0x290
[ 193.872444] dev_get_stats+0x5a/0xc0
[ 193.876493] rtnl_fill_stats+0x40/0x130
[ 193.880797] rtnl_fill_ifinfo+0x6c5/0xdc0
[ 193.885271] rtmsg_ifinfo_build_skb+0x86/0xe0
[ 193.890091] rtnetlink_event+0x5b/0xa0
[ 193.894320] raw_notifier_call_chain+0x43/0x60
[ 193.899225] netdev_change_features+0x50/0xa0
[ 193.904044] bond_compute_features.isra.46+0x1ab/0x270
[ 193.909640] bond_enslave+0x141d/0x15b0
[ 193.913946] do_set_master+0x89/0xa0
[ 193.918016] do_setlink+0x37c/0xda0
[ 193.921980] __rtnl_newlink+0x499/0x890
[ 193.926281] rtnl_newlink+0x48/0x70
[ 193.930238] rtnetlink_rcv_msg+0x171/0x4b0
[ 193.934801] netlink_rcv_skb+0xd1/0x110
[ 193.939103] rtnetlink_rcv+0x15/0x20
[ 193.943151] netlink_unicast+0x3b5/0x520
[ 193.947544] netlink_sendmsg+0x2fd/0x3f0
[ 193.951942] sock_sendmsg+0x38/0x50
[ 193.955899] ___sys_sendmsg+0x2ba/0x2d0
[ 193.960205] __x64_sys_sendmsg+0xad/0x100
[ 193.964687] do_syscall_64+0x5a/0x460
[ 193.968823] entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fixes: 7e2556e40026 ("bonding: avoid lockdep confusion in bond_get_stats()")
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
There are two statements that are indented too much by one space each,
fix these.
Give interested parties an opportunity to veto an impending HW address
change.
Signed-off-by: Petr Machata <petrm@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
Before NETDEV_CHANGEADDR, bond driver should emit NETDEV_PRE_CHANGEADDR,
and allow consumers to veto the address change. To propagate further the
return code from NETDEV_PRE_CHANGEADDR, give the function that
implements address change a return value.
A follow-up patch will add a notifier type NETDEV_PRE_CHANGEADDR, which
allows vetoing of MAC address changes. One prominent path to that
notification is through dev_set_mac_address(). Therefore give this
function an extack argument, so that it can be packed together with the
notification. Thus a textual reason for rejection (or a warning) can be
communicated back to the user.
Use DEFINE_SHOW_ATTRIBUTE macro to simplify the code.
Signed-off-by: Yangtao Li <tiny.windzz@gmail.com>
Several conflicts, seemingly all over the place.
I used Stephen Rothwell's sample resolutions for many of these, if not
just to double check my own work, so definitely the credit largely
goes to him.
The NFP conflict consisted of a bug fix (moving operations
past the rhashtable operation) while chaning the initial
argument in the function call in the moved code.
The net/dsa/master.c conflict had to do with a bug fix intermixing of
making dsa_master_set_mtu() static with the fixing of the tagging
attribute location.
cls_flower had a conflict because the dup reject fix from Or
overlapped with the addition of port range classifiction.
__set_phy_supported()'s conflict was relatively easy to resolve
because Andrew fixed it in both trees, so it was just a matter
of taking the net-next copy. Or at least I think it was :-)
Joe Stringer's fix to the handling of netns id 0 in bpf_sk_lookup()
intermixed with changes on how the sdif and caller_net are calculated
in these code paths in net-next.
The remaining BPF conflicts were largely about the addition of the
__bpf_md_ptr stuff in 'net' overlapping with adjustments and additions
to the relevant data structure where the MD pointer macros are used.
In order to pass extack together with NETDEV_PRE_UP notifications, it's
necessary to route the extack to __dev_open() from diverse (possibly
indirect) callers. One prominent API through which the notification is
invoked is dev_open().
Therefore extend dev_open() with and extra extack argument and update
all users. Most of the calls end up just encoding NULL, but bond and
team drivers have the extack readily available.
Reviewed-by: David Ahern <dsahern@gmail.com>
Previously when unbinding a slave the 802.3ad implementation only told
partner that the port is not suitable for aggregation by setting the port
aggregation state from aggregatable to individual. This is not enough. If the
physical layer still stays up and we only unbinded this port from the bond there
is nothing in the aggregation status alone to prevent the partner from sending
traffic towards us. To ensure that the partner doesn't consider this
port at all anymore we should also disable collecting and distributing to
signal that this actor is going away. Also clear AD_STATE_SYNCHRONIZATION to
ensure partner exits collecting + distributing state.
I have tested this behaviour againts Arista EOS switches with mlx5 cards
(physical link stays up even when interface is down) and simulated
the same situation virtually Linux <-> Linux with two network namespaces
running two veth device pairs. In both cases setting aggregation to
individual doesn't alone prevent traffic from being to sent towards this
port given that the link stays up in partners end. Partner still keeps
it's end in collecting + distributing state and continues until timeout is
reached. In most cases this means we are losing the traffic partner sends
towards our port while we wait for timeout. This is most visible with slow
periodic time (LACP rate slow).
Other open source implementations like Open VSwitch and libreswitch, and
vendor implementations like Arista EOS, seem to disable collecting +
distributing to when doing similar port disabling/detaching/removing change.
With this patch kernel implementation would behave the same way and ensure
partner doesn't consider our actor viable anymore.
Signed-off-by: Toni Peltonen <peltzi@peltzi.fi>
Signed-off-by: Jay Vosburgh <jay.vosburgh@canonical.com>
Acked-by: Jonathan Toppins <jtoppins@redhat.com>
Commit 4d2c0cda07448ea6980f00102dc3964eb25e241c set slave->link to
BOND_LINK_DOWN for 802.3ad bonds whenever invalid speed/duplex values
were read, to fix a problem with slaves getting into weird states, but
in the process, broke tracking of link failures, as going straight to
BOND_LINK_DOWN when a link is indeed down (cable pulled, switch rebooted)
means we broke out of bond_miimon_inspect()'s BOND_LINK_DOWN case because
!link_state was already true, we never incremented commit, and never got
a chance to call bond_miimon_commit(), where slave->link_failure_count
would be incremented. I believe the simple fix here is to mark the slave
as BOND_LINK_FAIL, and let bond_miimon_inspect() transition the link from
_FAIL to either _UP or _DOWN, and in the latter case, we now get proper
incrementing of link_failure_count again.
Fixes: 4d2c0cda0744 ("bonding: speed/duplex update at NETDEV_UP event")
CC: Mahesh Bandewar <maheshb@google.com>
CC: David S. Miller <davem@davemloft.net>
CC: netdev@vger.kernel.org
CC: stable@vger.kernel.org
Signed-off-by: Jarod Wilson <jarod@redhat.com>
The attribute IFLA_BOND_AD_ACTOR_SYSTEM is sent to user space having the
length of sizeof(bond->params.ad_actor_system) which is 8 byte. This
patch aligns the length to ETH_ALEN to have the same MAC address exposed
as using sysfs.
Fixes: f87fda00b6ed2 ("bonding: prevent out of bound accesses")
Signed-off-by: Tobias Jungel <tobias.jungel@gmail.com>
This fixes a problem introduced by:
commit 2cde6acd49da ("netpoll: Fix __netpoll_rcu_free so that it can hold the rtnl lock")
When using netconsole on a bond, __netpoll_cleanup can asynchronously
recurse multiple times, each __netpoll_free_async call can result in
more __netpoll_free_async's. This means there is now a race between
cleanup_work queues on multiple netpoll_info's on multiple devices and
the configuration of a new netpoll. For example if a netconsole is set
to enable 0, reconfigured, and enable 1 immediately, this netconsole
will likely not work.
Given the reason for __netpoll_free_async is it can be called when rtnl
is not locked, if it is locked, we should be able to execute
synchronously. It appears to be locked everywhere it's called from.
Generalize the design pattern from the teaming driver for current
callers of __netpoll_free_async.
CC: Neil Horman <nhorman@tuxdriver.com>
CC: "David S. Miller" <davem@davemloft.net>
Signed-off-by: Debabrata Banerjee <dbanerje@akamai.com>
RX queue config for bonding master could be different from its slave
device(s). With the commit 6a9e461f6fe4 ("bonding: pass link-local
packets to bonding master also."), the packet is reinjected into stack
with skb->dev as bonding master. This potentially triggers the
message:
"bondX received packet on queue Y, but number of RX queues is Z"
whenever the queue that packet is received on is higher than the
numrxqueues on bonding master (Y > Z).
Fixes: 6a9e461f6fe4 ("bonding: pass link-local packets to bonding master also.")
Reported-by: John Sperbeck <jsperbeck@google.com>
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
Syzkaller reported this on a slightly older kernel but it's still
applicable to the current kernel -
4.18.0-next-20180823+ #46 Not tainted
syz-executor4/26841 is trying to acquire lock:
00000000dd41ef48 ((wq_completion)bond_dev->name){+.+.}, at: flush_workqueue+0x2db/0x1e10 kernel/workqueue.c:2652
00000000768ab431 (rtnl_mutex){+.+.}, at: rtnl_lock net/core/rtnetlink.c:77 [inline]
00000000768ab431 (rtnl_mutex){+.+.}, at: rtnetlink_rcv_msg+0x412/0xc30 net/core/rtnetlink.c:4708
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (rtnl_mutex){+.+.}:
__mutex_lock_common kernel/locking/mutex.c:925 [inline]
__mutex_lock+0x171/0x1700 kernel/locking/mutex.c:1073
mutex_lock_nested+0x16/0x20 kernel/locking/mutex.c:1088
rtnl_lock+0x17/0x20 net/core/rtnetlink.c:77
bond_netdev_notify drivers/net/bonding/bond_main.c:1310 [inline]
bond_netdev_notify_work+0x44/0xd0 drivers/net/bonding/bond_main.c:1320
process_one_work+0xc73/0x1aa0 kernel/workqueue.c:2153
worker_thread+0x189/0x13c0 kernel/workqueue.c:2296
kthread+0x35a/0x420 kernel/kthread.c:246
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:415
-> #1 ((work_completion)(&(&nnw->work)->work)){+.+.}:
process_one_work+0xc0b/0x1aa0 kernel/workqueue.c:2129
-> #0 ((wq_completion)bond_dev->name){+.+.}:
lock_acquire+0x1e4/0x4f0 kernel/locking/lockdep.c:3901
flush_workqueue+0x30a/0x1e10 kernel/workqueue.c:2655
drain_workqueue+0x2a9/0x640 kernel/workqueue.c:2820
destroy_workqueue+0xc6/0x9d0 kernel/workqueue.c:4155
__alloc_workqueue_key+0xef9/0x1190 kernel/workqueue.c:4138
bond_init+0x269/0x940 drivers/net/bonding/bond_main.c:4734
register_netdevice+0x337/0x1100 net/core/dev.c:8410
bond_newlink+0x49/0xa0 drivers/net/bonding/bond_netlink.c:453
rtnl_newlink+0xef4/0x1d50 net/core/rtnetlink.c:3099
rtnetlink_rcv_msg+0x46e/0xc30 net/core/rtnetlink.c:4711
netlink_rcv_skb+0x172/0x440 net/netlink/af_netlink.c:2454
rtnetlink_rcv+0x1c/0x20 net/core/rtnetlink.c:4729
netlink_unicast_kernel net/netlink/af_netlink.c:1317 [inline]
netlink_unicast+0x5a0/0x760 net/netlink/af_netlink.c:1343
netlink_sendmsg+0xa18/0xfc0 net/netlink/af_netlink.c:1908
sock_sendmsg_nosec net/socket.c:622 [inline]
sock_sendmsg+0xd5/0x120 net/socket.c:632
___sys_sendmsg+0x7fd/0x930 net/socket.c:2115
__sys_sendmsg+0x11d/0x290 net/socket.c:2153
__do_sys_sendmsg net/socket.c:2162 [inline]
__se_sys_sendmsg net/socket.c:2160 [inline]
__x64_sys_sendmsg+0x78/0xb0 net/socket.c:2160
do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290
Chain exists of:
(wq_completion)bond_dev->name --> (work_completion)(&(&nnw->work)->work) --> rtnl_mutex
Possible unsafe locking scenario:
CPU0 CPU1
lock(rtnl_mutex);
lock((work_completion)(&(&nnw->work)->work));
lock(rtnl_mutex);
lock((wq_completion)bond_dev->name);
*** DEADLOCK ***
1 lock held by syz-executor4/26841:
stack backtrace:
CPU: 1 PID: 26841 Comm: syz-executor4 Not tainted 4.18.0-next-20180823+ #46
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1c9/0x2b4 lib/dump_stack.c:113
print_circular_bug.isra.34.cold.55+0x1bd/0x27d kernel/locking/lockdep.c:1222
check_prev_add kernel/locking/lockdep.c:1862 [inline]
check_prevs_add kernel/locking/lockdep.c:1975 [inline]
validate_chain kernel/locking/lockdep.c:2416 [inline]
__lock_acquire+0x3449/0x5020 kernel/locking/lockdep.c:3412
RIP: 0033:0x457089
Code: fd b4 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 cb b4 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f2df20a5c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00007f2df20a66d4 RCX: 0000000000457089
RDX: 0000000000000000 RSI: 0000000020000180 RDI: 0000000000000003
RBP: 0000000000930140 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff
R13: 00000000004d40b8 R14: 00000000004c8ad8 R15: 0000000000000001
Commit b89f04c61efe ("bonding: deliver link-local packets with
skb->dev set to link that packets arrived on") changed the behavior
of how link-local-multicast packets are processed. The change in
the behavior broke some legacy use cases where these packets are
expected to arrive on bonding master device also.
This patch passes the packet to the stack with the link it arrived
on as well as passes to the bonding-master device to preserve the
legacy use case.
Fixes: b89f04c61efe ("bonding: deliver link-local packets with skb->dev set to link that packets arrived on")
Reported-by: Michal Soltys <soltys@ziu.info>
We want to allow NAPI drivers to no longer provide
ndo_poll_controller() method, as it has been proven problematic.
team driver must not look at its presence, but instead call
netpoll_poll_dev() which factorize the needed actions.
Cc: Jay Vosburgh <j.vosburgh@gmail.com>
Cc: Veaceslav Falico <vfalico@gmail.com>
Cc: Andy Gospodarek <andy@greyhouse.net>
Acked-by: Jay Vosburgh <jay.vosburgh@canonical.com>
The BTF conflicts were simple overlapping changes.
The virtio_net conflict was an overlap of a fix of statistics counter,
happening alongisde a move over to a bonafide statistics structure
rather than counting value on the stack.
syzbot found that the following sequence produces a LOCKDEP splat [1]
ip link add bond10 type bond
ip link add bond11 type bond
ip link set bond11 master bond10
To fix this, we can use the already provided nest_level.
This patch also provides correct nesting for dev->addr_list_lock
[1]
WARNING: possible recursive locking detected
4.18.0-rc6+ #167 Not tainted
syz-executor751/4439 is trying to acquire lock:
(____ptrval____) (&(&bond->stats_lock)->rlock){+.+.}, at: spin_lock include/linux/spinlock.h:310 [inline]
(____ptrval____) (&(&bond->stats_lock)->rlock){+.+.}, at: bond_get_stats+0xb4/0x560 drivers/net/bonding/bond_main.c:3426
CPU0
lock(&(&bond->stats_lock)->rlock);
*** DEADLOCK ***
May be due to missing lock nesting notation
3 locks held by syz-executor751/4439:
#0: (____ptrval____) (rtnl_mutex){+.+.}, at: rtnl_lock+0x17/0x20 net/core/rtnetlink.c:77
#1: (____ptrval____) (&(&bond->stats_lock)->rlock){+.+.}, at: spin_lock include/linux/spinlock.h:310 [inline]
#1: (____ptrval____) (&(&bond->stats_lock)->rlock){+.+.}, at: bond_get_stats+0xb4/0x560 drivers/net/bonding/bond_main.c:3426
#2: (____ptrval____) (rcu_read_lock){....}, at: bond_get_stats+0x0/0x560 include/linux/compiler.h:215
stack backtrace:
CPU: 0 PID: 4439 Comm: syz-executor751 Not tainted 4.18.0-rc6+ #167
Call Trace:
print_deadlock_bug kernel/locking/lockdep.c:1765 [inline]
check_deadlock kernel/locking/lockdep.c:1809 [inline]
validate_chain kernel/locking/lockdep.c:2405 [inline]
__lock_acquire.cold.64+0x1fb/0x486 kernel/locking/lockdep.c:3435
lock_acquire+0x1e4/0x540 kernel/locking/lockdep.c:3924
__raw_spin_lock include/linux/spinlock_api_smp.h:142 [inline]
_raw_spin_lock+0x2a/0x40 kernel/locking/spinlock.c:144
dev_get_stats+0x10f/0x470 net/core/dev.c:8316
bond_get_stats+0x232/0x560 drivers/net/bonding/bond_main.c:3432
rtnl_fill_stats+0x4d/0xac0 net/core/rtnetlink.c:1169
rtnl_fill_ifinfo+0x1aa6/0x3fb0 net/core/rtnetlink.c:1611
rtmsg_ifinfo_build_skb+0xc8/0x190 net/core/rtnetlink.c:3268
rtmsg_ifinfo_event.part.30+0x45/0xe0 net/core/rtnetlink.c:3300
rtmsg_ifinfo_event net/core/rtnetlink.c:3297 [inline]
rtnetlink_event+0x144/0x170 net/core/rtnetlink.c:4716
notifier_call_chain+0x180/0x390 kernel/notifier.c:93
__raw_notifier_call_chain kernel/notifier.c:394 [inline]
raw_notifier_call_chain+0x2d/0x40 kernel/notifier.c:401
call_netdevice_notifiers_info+0x3f/0x90 net/core/dev.c:1735
call_netdevice_notifiers net/core/dev.c:1753 [inline]
netdev_features_change net/core/dev.c:1321 [inline]
netdev_change_features+0xb3/0x110 net/core/dev.c:7759
bond_compute_features.isra.47+0x585/0xa50 drivers/net/bonding/bond_main.c:1120
bond_enslave+0x1b25/0x5da0 drivers/net/bonding/bond_main.c:1755
bond_do_ioctl+0x7cb/0xae0 drivers/net/bonding/bond_main.c:3528
dev_ifsioc+0x43c/0xb30 net/core/dev_ioctl.c:327
dev_ioctl+0x1b5/0xcc0 net/core/dev_ioctl.c:493
sock_do_ioctl+0x1d3/0x3e0 net/socket.c:992
sock_ioctl+0x30d/0x680 net/socket.c:1093
vfs_ioctl fs/ioctl.c:46 [inline]
file_ioctl fs/ioctl.c:500 [inline]
do_vfs_ioctl+0x1de/0x1720 fs/ioctl.c:684
ksys_ioctl+0xa9/0xd0 fs/ioctl.c:701
__do_sys_ioctl fs/ioctl.c:708 [inline]
__se_sys_ioctl fs/ioctl.c:706 [inline]
__x64_sys_ioctl+0x73/0xb0 fs/ioctl.c:706
RIP: 0033:0x440859
Code: e8 2c af 02 00 48 83 c4 18 c3 0f 1f 80 00 00 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 3b 10 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007ffc51a92878 EFLAGS: 00000213 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 0000000000440859
RDX: 0000000020000040 RSI: 0000000000008990 RDI: 0000000000000003
RBP: 0000000000000000 R08: 00000000004002c8 R09: 00000000004002c8
R10: 00000000022d5880 R11: 0000000000000213 R12: 0000000000007390
R13: 0000000000401db0 R14: 0000000000000000 R15: 0000000000000000
As was recently discussed [1], let's avoid casting the const buf in
bonding_sysfs_store_option and use kstrndup/kfree instead.
[1] http://lists.openwall.net/netdev/2018/07/22/25
For some time now, if you load the bonding driver and configure bond
parameters via sysfs using minimal config options, such as specifying
nothing but the mode, relying on defaults for everything else, modes
that cannot use arp monitoring (802.3ad, balance-tlb, balance-alb) all
wind up with both arp_interval=0 (as it should be) and miimon=0, which
means the miimon monitor thread never actually runs. This is particularly
problematic for 802.3ad.
For example, from an LNST recipe I've set up:
$ modprobe bonding max_bonds=0"
$ echo "+t_bond0" > /sys/class/net/bonding_masters"
$ ip link set t_bond0 down"
$ echo "802.3ad" > /sys/class/net/t_bond0/bonding/mode"
$ ip link set ens1f1 down"
$ echo "+ens1f1" > /sys/class/net/t_bond0/bonding/slaves"
$ ip link set ens1f0 down"
$ echo "+ens1f0" > /sys/class/net/t_bond0/bonding/slaves"
$ ethtool -i t_bond0"
$ ip link set ens1f1 up"
$ ip link set ens1f0 up"
$ ip link set t_bond0 up"
$ ip addr add 192.168.9.1/24 dev t_bond0"
$ ip addr add 2002::1/64 dev t_bond0"
This bond comes up okay, but things look slightly suspect in
/proc/net/bonding/t_bond0 output:
$ grep -i mii /proc/net/bonding/t_bond0
MII Status: up
MII Polling Interval (ms): 0
MII Status: up
MII Status: up
Now, pull a cable on one of the ports in the bond, then reconnect it, and
you'll see:
Slave Interface: ens1f0
MII Status: down
Speed: 1000 Mbps
Duplex: full
I believe this became a major issue as of commit 4d2c0cda0744, which for
802.3ad bonds, sets slave->link = BOND_LINK_DOWN, with a comment about
relying on link monitoring via miimon to set it correctly, but since the
miimon work queue never runs, the link just stays marked down.
If we simply tweak bond_option_mode_set() slightly, we can check for the
non-arp modes having no miimon value set, and insert BOND_DEFAULT_MIIMON,
which gets things back in full working order. This problem exists as far
back as 4.14, and might be worth fixing in all stable trees since, though
the work-around is to simply specify an miimon value yourself.
Reported-by: Bob Ball <ball@umich.edu>
Acked-by: Mahesh Bandewar <maheshb@google.com>
This patch makes it so that instead of passing a void pointer as the
accel_priv we instead pass a net_device pointer as sb_dev. Making this
change allows us to pass the subordinate device through to the fallback
function eventually so that we can keep the actual code in the
ndo_select_queue call as focused on possible on the exception cases.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Tested-by: Andrew Bowers <andrewx.bowers@intel.com>
The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
There is a timing issue under active-standy mode, when bond_enslave() is
called, bond->params.primary might not be initialized yet.
Any time the primary slave string changes, bond->force_primary should be
set to true to make sure the primary becomes the active slave.
Signed-off-by: Xiangning Yu <yuxiangning@gmail.com>
Pull networking updates from David Miller:
1) Add Maglev hashing scheduler to IPVS, from Inju Song.
2) Lots of new TC subsystem tests from Roman Mashak.
3) Add TCP zero copy receive and fix delayed acks and autotuning with
SO_RCVLOWAT, from Eric Dumazet.
4) Add XDP_REDIRECT support to mlx5 driver, from Jesper Dangaard
Brouer.
5) Add ttl inherit support to vxlan, from Hangbin Liu.
6) Properly separate ipv6 routes into their logically independant
components. fib6_info for the routing table, and fib6_nh for sets of
nexthops, which thus can be shared. From David Ahern.
7) Add bpf_xdp_adjust_tail helper, which can be used to generate ICMP
messages from XDP programs. From Nikita V. Shirokov.
8) Lots of long overdue cleanups to the r8169 driver, from Heiner
Kallweit.
9) Add BTF ("BPF Type Format"), from Martin KaFai Lau.
10) Add traffic condition monitoring to iwlwifi, from Luca Coelho.
11) Plumb extack down into fib_rules, from Roopa Prabhu.
12) Add Flower classifier offload support to igb, from Vinicius Costa
Gomes.
13) Add UDP GSO support, from Willem de Bruijn.
14) Add documentation for eBPF helpers, from Quentin Monnet.
15) Add TLS tx offload to mlx5, from Ilya Lesokhin.
16) Allow applications to be given the number of bytes available to read
on a socket via a control message returned from recvmsg(), from
Soheil Hassas Yeganeh.
17) Add x86_32 eBPF JIT compiler, from Wang YanQing.
18) Add AF_XDP sockets, with zerocopy support infrastructure as well.
From Björn Töpel.
19) Remove indirect load support from all of the BPF JITs and handle
these operations in the verifier by translating them into native BPF
instead. From Daniel Borkmann.
20) Add GRO support to ipv6 gre tunnels, from Eran Ben Elisha.
21) Allow XDP programs to do lookups in the main kernel routing tables
for forwarding. From David Ahern.
22) Allow drivers to store hardware state into an ELF section of kernel
dump vmcore files, and use it in cxgb4. From Rahul Lakkireddy.
23) Various RACK and loss detection improvements in TCP, from Yuchung
Cheng.
24) Add TCP SACK compression, from Eric Dumazet.
25) Add User Mode Helper support and basic bpfilter infrastructure, from
Alexei Starovoitov.
26) Support ports and protocol values in RTM_GETROUTE, from Roopa
Prabhu.
27) Support bulking in ->ndo_xdp_xmit() API, from Jesper Dangaard
Brouer.
28) Add lots of forwarding selftests, from Petr Machata.
29) Add generic network device failover driver, from Sridhar Samudrala.
* ra.kernel.org:/pub/scm/linux/kernel/git/davem/net-next: (1959 commits)
strparser: Add __strp_unpause and use it in ktls.
rxrpc: Fix terminal retransmission connection ID to include the channel
net: hns3: Optimize PF CMDQ interrupt switching process
net: hns3: Fix for VF mailbox receiving unknown message
net: hns3: Fix for VF mailbox cannot receiving PF response
bnx2x: use the right constant
Revert "net: sched: cls: Fix offloading when ingress dev is vxlan"
net: dsa: b53: Fix for brcm tag issue in Cygnus SoC
enic: fix UDP rss bits
netdev-FAQ: clarify DaveM's position for stable backports
rtnetlink: validate attributes in do_setlink()
mlxsw: Add extack messages for port_{un, }split failures
netdevsim: Add extack error message for devlink reload
devlink: Add extack to reload and port_{un, }split operations
net: metrics: add proper netlink validation
ipmr: fix error path when ipmr_new_table fails
ip6mr: only set ip6mr_table from setsockopt when ip6mr_new_table succeeds
net: hns3: remove unused hclgevf_cfg_func_mta_filter
netfilter: provide udp*_lib_lookup for nf_tproxy
qed*: Utilize FW 8.37.2.0
LAG upper event notifiers contain the tx type used by the LAG device.
Extend this to also include the hash policy used for tx types that
utilize hashing.
Signed-off-by: John Hurley <john.hurley@netronome.com>
Until the udp receive stack supports large packets (UDP GRO), GSO
packets must not loop from the egress to the ingress path.
Revert the change that added NETIF_F_GSO_UDP_L4 to various virtual
devices through NETIF_F_GSO_ENCAP_ALL as this included devices that
may loop packets, such as veth and macvlan.
Instead add it to specific devices that forward to another device's
egress path, bonding and team.
Fixes: 83aa025f535f ("udp: add gso support to virtual devices")
CC: Alexander Duyck <alexander.duyck@gmail.com>
Introduce an new common helper to avoid redundancy.
This reverts commit 1386c36b30388f46a95100924bfcae75160db715.
We don't want to encourage drivers to not report carrier status
correctly, therefore remove this commit.
In a mixed environment it may be difficult to tell if your hardware
support carrier, if it does not it can always report true. With a new
use_carrier option of 2, we can check both carrier and link status
sequentially, instead of one or the other
The rx load balancing provided by balance-alb is not mutually
exclusive with using hashing for tx selection, and should provide a decent
speed increase because this eliminates spinlocks and cache contention.
Replace homegrown mac addr checks with faster defs from etherdevice.h
Note that this will also prevent any rlb arp updates for multicast
addresses, however this should have been forbidden anyway.
arps for incomplete entries can't be sent anyway.
And use proc private data directly instead of doing a detour
through seq->private.
The bpf syscall and selftests conflicts were trivial
The r8169 change involved moving the added mdelay from 'net' into a
different function.
A TLS close bug fix overlapped with the splitting of the TLS state
into separate TX and RX parts. I just expanded the tests in the bug
fix from "ctx->conf == X" into "ctx->tx_conf == X && ctx->rx_conf
== X".
Use the skb_get_queue_mapping, skb_set_queue_mapping
and skb_rx_queue_recorded for skb queue_mapping in bonding
driver, but not use it directly.
The method ndo_start_xmit is defined as returning a
netdev_tx_t, which is a typedef for an enum type,
but the implementation in this driver returns an int.
There was a regression at some point from the intended functionality of
commit f60c3704e87d ("bonding: Fix alb mode to only use first level
vlans.")
Given the return value vlan_get_encap_level() we need to store the nest
level of the bond device, and then compare the vlan's encap level to
this. Without this, this check always fails and learning packets are
never sent.
In addition, this same commit caused a regression in the behavior of
balance_alb, which requires learning packets be sent for all interfaces
using the slave's mac in order to load balance properly. For vlan's
that have not set a user mac, we can send after checking one bit.
Otherwise we need send the set mac, albeit defeating rx load balancing
for that vlan.
Make sure multicast, broadcast, and zero mac's cannot be the output of rlb
updates, which should all be directed arps. Receive load balancing will be
collapsed if any of these happen, as the switch will broadcast.
After Commit 8a8efa22f51b ("bonding: sync netpoll code with bridge"), it
would set slave_dev npinfo in slave_enable_netpoll when enslaving a dev
if bond->dev->npinfo was set.
However now slave_dev npinfo is set with bond->dev->npinfo before calling
slave_enable_netpoll. With slave_dev npinfo set, __netpoll_setup called
in slave_enable_netpoll will not call slave dev's .ndo_netpoll_setup().
It causes that the lower dev of this slave dev can't set its npinfo.
One way to reproduce it:
# modprobe bonding
# brctl addbr br0
# brctl addif br0 eth1
# ifconfig bond0 192.168.122.1/24 up
# ifenslave bond0 eth2
# systemctl restart netconsole
# ifenslave bond0 br0
# ifconfig eth2 down
The netpoll won't really work.
This patch is to remove that slave_dev npinfo setting in bond_enslave().
Fixes: 8a8efa22f51b ("bonding: sync netpoll code with bridge")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Minor conflicts in drivers/net/ethernet/mellanox/mlx5/core/en_rep.c,
we had some overlapping changes:
1) In 'net' MLX5E_PARAMS_LOG_{SQ,RQ}_SIZE -->
MLX5E_REP_PARAMS_LOG_{SQ,RQ}_SIZE
2) In 'net-next' params->log_rq_size is renamed to be
params->log_rq_mtu_frames.
3) In 'net-next' params->hard_mtu is added.
Synchronous pernet_operations are not allowed anymore.
All are asynchronous. So, drop the structure member.
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
When dev_set_promiscuity(1) succeeds but dev_set_allmulti(1) fails,
dev_set_promiscuity(-1) should be done before going to the err path.
Otherwise, dev->promiscuity will leak.
Fixes: 7e1a1ac1fbaa ("bonding: Check return of dev_set_promiscuity/allmulti")
Acked-by: Andy Gospodarek <andy@greyhouse.net>
Beniamino found a crash when adding vlan as slave of bond which is also
the parent link:
ip link add bond1 type bond
ip link set bond1 up
ip link add link bond1 vlan1 type vlan id 80
ip link set vlan1 master bond1
The call trace is as below:
[<ffffffffa850842a>] queued_spin_lock_slowpath+0xb/0xf
[<ffffffffa8515680>] _raw_spin_lock+0x20/0x30
[<ffffffffa83f6f07>] dev_mc_sync+0x37/0x80
[<ffffffffc08687dc>] vlan_dev_set_rx_mode+0x1c/0x30 [8021q]
[<ffffffffa83efd2a>] __dev_set_rx_mode+0x5a/0xa0
[<ffffffffa83f7138>] dev_mc_sync_multiple+0x78/0x80
[<ffffffffc084127c>] bond_enslave+0x67c/0x1190 [bonding]
[<ffffffffa8401909>] do_setlink+0x9c9/0xe50
[<ffffffffa8403bf2>] rtnl_newlink+0x522/0x880
[<ffffffffa8403ff7>] rtnetlink_rcv_msg+0xa7/0x260
[<ffffffffa8424ecb>] netlink_rcv_skb+0xab/0xc0
[<ffffffffa83fe498>] rtnetlink_rcv+0x28/0x30
[<ffffffffa8424850>] netlink_unicast+0x170/0x210
[<ffffffffa8424bf8>] netlink_sendmsg+0x308/0x420
[<ffffffffa83cc396>] sock_sendmsg+0xb6/0xf0
This is actually a dead lock caused by sync slave hwaddr from master when
the master is the slave's 'slave'. This dead loop check is actually done
by netdev_master_upper_dev_link. However, Commit 1f718f0f4f97 ("bonding:
populate neighbour's private on enslave") moved it after dev_mc_sync.
This patch is to fix it by moving dev_mc_sync after master_upper_dev_link,
so that this loop check would be earlier than dev_mc_sync. It also moves
if (mode == BOND_MODE_8023AD) into if (!bond_uses_primary) clause as an
improvement.
Note team driver also has this issue, I will fix it in another patch.
Fixes: 1f718f0f4f97 ("bonding: populate neighbour's private on enslave")
Reported-by: Beniamino Galvani <bgalvani@redhat.com>
