path: root/drivers/net/bnx2x_reg.h
2010-04-19bnx2x: Parity errors handling for 57710 and 57711Vladislav Zolotarov
This patch introduces the parity errors handling code for 57710 and 57711 chips. HW is configured to stop all DMA transactions to the host and sending packets to the network once parity error is detected, which is meant to prevent silent data corruption. At the same time HW generates the attention interrupt to every function of the device where parity has been detected so that driver can start the recovery flow. The recovery is actually resetting the chip and restarting the driver on all active functions of the chip where the parity error has been reported. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-05bnx2x: Fix 10G mode in BCM8481/BCM84823Yaniv Rosner
Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05bnx2x: Enable FC when parallel-detect is usedYaniv Rosner
When parallel detect is used, flow-control is set to the req_fc_auto_adv instead of none. Motive: when 577xx is FC configuration is set to AUTO, while LP speed is set to FORCE mode and FC to force RX/TX, link would come up using parallel detect, and the FC will be set to NONE since FC capabilities were not negotiated, although the LP is setting FC to force RX/TX. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05bnx2x: Fix CL73 autoneg issuesYaniv Rosner
- Advertise 1G KX4 in CL73 when 1G speed capability is enabled - Add flow-control negotiation over CL73 - External loopback test on Serdes should be done in FORCE mode, since in CL73 it is unable to link up with the same core using AUTONEG - Fix bnx2x_set_led function to support CL73 link leds Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-21trivial: fix typo "for for" in multiple filesAnand Gadiyar
trivial: fix typo "for for" in multiple files Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-08-12bnx2x: Whitespaces and commentsEilon Greenstein
2009-08-12bnx2x: Removing unused definitionsEilon Greenstein
2009-08-12bnx2x: Re-factor the initialization codeEilon Greenstein
Moving the code to a more logical place and beautifying it. No real change in behavior. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12bnx2x: Adding XAUI CL73 autoneg supportEilon Greenstein
Adding CL73 support to the built in PHY in the 5771x device. Also supporting fallbacks to CL73 if the link partner does not respond. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12bnx2x: BCM8481 LED4 instead of LASIEilon Greenstein
The BCM8481 does not generate LASI interrupt for 10M, 100M and 1G link, so we are using LED4 output as the interrupt input to the 57711. This requires some adaptation in the link interrupt routines Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12bnx2x: Using the new FWEilon Greenstein
The new FW improves the packets per second rate. It required a lot of change in the FW which implies many changes in the driver to support it. It is now also possible for the driver to use a separate MSI-X vector for Rx and Tx - this also add some to the complicity of this change. All things said - after this patch, practically all performance matrixes show improvement. Though Vladislav Zolotarov is not signed on this patch, he did most of the job and deserves credit for that. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30bnx2x: Receive traffic that maches management filtering rulesEilon Greenstein
Due to lack of configuration, if the BMC configures the chip to pass all broadcast/multicast traffic to it, the host will not receive it. On top of fixing it, also make sure that in promiscuous mode, the host will receive the management traffic as well. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-21bnx2x: Supporting BCM8727 PHYEilon Greenstein
Adding support for BCM8727 - a dual port SFP+ PHY. That includes verification of the optic module vendor and part number - the list of approved modules resides on the nvram and the module is verified by the FW. Since not all users would like to use this verification feature, it can be disabled. The default behavior is to issue a warning if the module is not approved, but still allow using it - but it is also possible to disable the link if the module is not approved. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-21bnx2x: Stop management traffic in loopback testEilon Greenstein
Since management traffic cannot go on the wire while configured to loopback, simply stop it to avoid race condition when the MAC is set to loopback in the middle of a packet Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02bnx2x: Supporting new BCM8726 FWEilon Greenstein
Microcode download requires write of another register and read from "Limiting/LRM mode" register before setting Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02bnx2x: Misleading nameEilon Greenstein
As noted by Ben Hutchings <bhutchings@solarflare.com>, these are the capabilities offsets and not the ID itself Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: Using registers nameEilon Greenstein
2009-02-15bnx2x: Pre emphasis configurationEilon Greenstein
Supporting non-default pre-emphasis settings for the internal and some external PHYs Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: Using the HW 5th laneEilon Greenstein
This 1G interface (on top of the 4 lanes 10G interface) requires additional setting to work in CL45 Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: EMAC resetEilon Greenstein
The NIG_ENABLE does not reset the emac. Replace it with explicit reset Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: PHY lock listEilon Greenstein
Some dual port PHY require HW lock since they are used by both interfaces (different driver instances). Since this list is getting longer, update a parameter at load time instead of calculating it on runtime Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: Supporting BCM8726 PHYEilon Greenstein
Also adding the ability to recognize the optic module and disable it if it is not authorized for safety reasons - since this feature might upset some users which are willing to take the risk, it is optional and can be disabled by setting an nvram bit (or a trivial driver patch to set this bit). This dual port PHY requires special handling if the ports are swapped. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: GPIO accessoriesEilon Greenstein
A GPIO is used with the 8726 PHY. Adding the GPIO related functions in this Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: Flow control enhancementEilon Greenstein
Setting better HW thresholds and enabling FW capabilities for better enforcement. Also set the HW to more efficiently use the internal buffers if this is a single port design Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: Disabling interrupts after iSCSI-bootEilon Greenstein
Before initializing the chip after iSCSI boot, the interrupts of the function that was used to boot must be disabled. That means that the driver needs to set the chip as if it is the iSCSI PCI function - this bug is exposed only with MSI Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: MSI supportEilon Greenstein
Enabling MSI on top of MSI-X and INTA. Also changing the module parameter to allow choosing INTA or MSI even when MSI-X is available. The default status block should not be reversed for endianity. Since MSI can issue re-configuration, the interrupt disable function now requires mmiowb Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15bnx2x: New FWEilon Greenstein
This is the FW blob and the relevant definitions without any logic. It also contains the minimal mandatory code changes to work with this FW but it does not contain enabling of the new features that this FW provides. This FW is needed for: - More efficient multi-queue - per queue statistics - Big-endian issue with MSI - Improved pause response Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-19bnx2x: Version updateEilon Greenstein
Updating the version and the year of updated files Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13bnx2x: Spelling mistakesEilon Greenstein
Spelling mistakes Spelling has to L's in it... Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13bnx2x: Pause settingsYaniv Rosner
Pause settings - 1G pause was not working due to missing write to the emac block (TX_MODE_FLOW_EN) - The flow control should use the negotiated result (after autoneg) so we should save both the requested autoneg and the result - The HW credits with flow control at 1G speed were not optimized and caused low throughput - It is recommended to turn off flow control if the MTU is bigger than 5000B due to internal buffers size Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13bnx2x: Link order with external PHYYaniv Rosner
Link order with external PHY When external PHY exists (second chip with the PHY to translate to another physical medium) the link with the eternal PHY and the network should be established before setting the link between the 5771x and the PHY. This is the right order and it is important when using autoneg - the link to the network should use the autoneg and the link between the two chips should be forced to the network result. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13bnx2x: PBA Table Page Alignment WorkaroundEilon Greenstein
PBA Table Page Alignment Workaround The PBA table starts on the middle of the page and that's causing very low performance with virtualization. The solution is not to update via the BAR directly but via chip access to the same memory Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13bnx2x: HW attention lockEilon Greenstein
HW attention lock Making sure that only one function will handle the HW attention. This makes the device parameter aeu_mask redundant so it is removed Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13bnx2x: HW lock mechanismYitchak Gertner
HW lock mechanism Enhancing the HW lock to work per function and not only per port - this is needed for the next patch that protects races over HW attention detection between the different functions. At this chance, changing the functions names to be more inline with the current naming convention Signed-off-by: Yitchak Gertner <gertner@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13bnx2x: Load/Unload under trafficVladislav Zolotarov
Load/Unload under traffic Few issues were found when loading and unloading under traffic: - When receiving Tx interrupt call netif_wake_queue if the queue is stopped but the state is open - Check that interrupts are enabled before doing anything else on the msix_fp_int function - In nic_load, enable the interrupts only when needed and ready for it - Function stop_leading returns status since it can fail - Add 1ms delay when unloading the driver to validate that there are no open transactions that already started by the FW - Splitting the "has work" function into Tx and Rx so the same function will be used on unload and interrupts - Do not request for WoL if only resetting the device (save the time that it takes the FW to set the link after reset) - Fixing the device reset after iSCSI boot and before driver load - all internal buffers must be cleared before the driver is loaded Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13bnx2x: StatisticsYitchak Gertner
Statistics - Making sure that each drop is accounted for in the driver statistics - Clearing the FW statistics when driver is loaded to prevent inconsistency with HW statistics - Once error is detected (bnx2x_panic_dump), stop the statistics before other actions (currently it is stopped last and can corrupt the data) - Adding HW checksum error counter to the statistics - Removing unused variable stats_ticks - Using macros instead of magic numbers to indicate which statistics are shared per port and which are per function Signed-off-by: Yitchak Gertner <gertner@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-23bnx2x: Add support for BCM57711 HWEilon Greenstein
Supporting the 57711 and 57711E - refers to in the code as E1H. The 57710 is referred to as E1. To support the new members in the family, the bnx2x structure was divided to 3 parts: common, port and function. These changes caused some rearrangement in the bnx2x.h file. A set of accessories macros were added to make access to the bnx2x structure more readable Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-23bnx2x: New link codeYaniv Rosner
New Link code: Moving all the link related code (including the calculations, the initialization of the MAC and PHY and the external PHY's code) into a separated file. The changes from the code that used to be part of bnx2x.c (now called bnx2x_main.c) are: - Using separate structures for link inputs and link outputs to clearly identify what was configured and what is the outcome - Adding code to read external PHY FW version and print it as part of ethtool -i - Adding code to upgrade external PHY FW from ethtool -E with special magic number - Changing the link down indication to ERR level - Adding a lock on all PHY access to prevent an interrupt and setting changes to overlap - Adding support for emulation and FPGA (small chunk of code that really helps in the lab) - Adding support for 1G on BCM8706 PHY - Adding clear debug print incase of fan failure (the PHY type is now "failure") Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: Correct Link managementEliezer Tamir
Properly protect PHY access between two devices on the same board with a HW lock. Use GPIO to clear all previous configurations before changing link parameters. Shut down the external PHY in case of fan failure. Reducing the MDC/MDIO clock to 2.5MHz due to problems with some devices. Resolve the flow control response according to autoneg with external PHY. Unmasking all PHY interrupts in single write to prevent a race in the interrupts order. LASI indication fixes to work with peculiarities of PHYs. Disable MAC RX to avoid a HW bug when closing the MAC under traffic. Disable parallel detection on HiGig due to HW limitation. Updating the shared memory structure to work with the current bootcode. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28add bnx2x driver for BCM57710Eliezer Tamir
