path: root/drivers/net/bnx2x_main.c
2010-03-15bnx2x: change smp_mb() comment to conform the trueStanislaw Gruszka
Access to fp->tx_bp_prod is protected by __netif_tx_lock, smp_mb() is not needed for that. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15bnx2x: remove not necessary compiler barrierStanislaw Gruszka
Access to fp->tx_bd_prod is protected by __netif_tx_lock, so we do not need any barrier for that. Update of fp->tx_bd_cons in bnx2x_tx_int() is not protected by lock, but barrier() nor smb_mb() in bnx2x_tx_avail() not guarantee we will see values that is written on other cpu. Ordering issues between netif_tx_stop_queue(), netif_tx_queue_stopped(), fp->tx_bd_cons = bd_cons and bnx2x_tx_avail() are already handled by smp_mb() in bnx2x_tx_int() and bnx2x_start_xmit(). Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15bnx2x: use smp_mb() to keep ordering of read write operationsStanislaw Gruszka
Since we want to keep ordering of write to fp->bd_tx_cons and netif_tx_queue_stopped(txq), what is read of txq->state, we have to use general memory barrier. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-28bnx2x: Tx barriers and locksVladislav Zolotarov
[Resending with the proper subject. Sorry for the mess. ] This patch is based on the RFC of Stanislaw Gruszka. More specifically it fixes two possible races: - One, described by Stanislaw, may lead to permanent disabling of the Tx queue. This is fixed by adding the smp_wmb() to propagate the BD consumer change towards the memory. - Second may lead to bnx2x_start_xmit() returning NETDEV_TX_BUSY. This is fixed by taking a tx_lock() before rechecking the number of available Tx BDs. thanks, vlad Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part3Jiri Pirko
Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17drivers/net/bnx2x: Use (pr|netdev|netif)_<level> macro helpersJoe Perches
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Convert struct bnx2x member msglevel to msg_enable for netif_msg_<foo> macros Remove #define PFX Use pr_<level> Use netdev_<level> Use netif_<level> Coalesce long formats Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: version number and dateVladislav Zolotarov
Updated release version and date: 1.52.1-6 and 2010/02/16 Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: Use firmware 5.2.13Vladislav Zolotarov
Switch to the new firmware version (5.2.13). Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: fix in 57710 self-testVladislav Zolotarov
Bug fix: Use the last unicast entry in CAM in bnx2x_test_int(). Relevant for 57710 only. Author: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: Do not allow enabling LRO if disable_tpa=1Vladislav Zolotarov
Bug fix: Do not allow enabling LRO if disable_tpa=1. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: clean up in case of error in bnx2x_init_hw()Vladislav Zolotarov
Bug fix: clean up MCP state in case of error in bnx2x_init_hw(). Author: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: Properly release allocated MSI-X/MSI vectorsVladislav Zolotarov
Bug fix: Properly release allocated MSI-X/MSI vectors if ifup failed due to lack of memory. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28netdev: remove HAVE_ leftoversAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/benet/be_cmds.h include/linux/sysctl.h
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-25bnx2x: Initialize cnic status block during chip resetMichael Chan
When the device is reset during MTU change, ring size change, or self test, etc, the cnic status block needs to be properly initialized if cnic is registered. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18bnx2x: Don't set netdev->trans_startVladislav Zolotarov
Setting dev->trans_start caused spurious watchdog warnings. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17bnx2x: Handle Rx and Tx together in NAPIVladislav Zolotarov
Put Tx and Rx DPC to be handled in the NAPI: - Saves status blocks. - Moves the Tx work from hardIRQ to NAPI. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10bnx2x: version 1.52.1-4Eilon Greenstein
2009-11-10bnx2x: Change coalescing granularity to 4usEilon Greenstein
2009-11-10bnx2x: Remove misleading error printEilon Greenstein
Failing to allocate MSI-X vectors is not an error and should not be printed as such Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10bnx2x: GSO implies CSUM offloadEilon Greenstein
Making sure that whenever the FW/HW is configured for GSO, it is also configured to CSUM offload Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10bnx2x: declare MODULE_FIRMWAREBen Hutchings
Replace run-time string formatting with preprocessor string manipulation. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05bnx2x: version 1.52.1-3Yaniv Rosner
Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05bnx2x: Fix CL73 autoneg issuesYaniv Rosner
- Advertise 1G KX4 in CL73 when 1G speed capability is enabled - Add flow-control negotiation over CL73 - External loopback test on Serdes should be done in FORCE mode, since in CL73 it is unable to link up with the same core using AUTONEG - Fix bnx2x_set_led function to support CL73 link leds Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Update to version 1.52.1-1Eilon Greenstein
2009-10-15bnx2x: Report the maximal available BW as link speedEilon Greenstein
The device is limited to the maximal BW allocation, so it should be displayed as the link speed to notify the user. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Do not call load/unload functionality from DCCEilon Greenstein
There is really no need to clear the MAC or the FW filtering rules - it was added for completion, but caused race conditions with load/unload. Removing this redundant code Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Adding FW mailbox mutexEilon Greenstein
DCC commands are not protected with the RTNL lock, so a mutex should be added Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Changing the Disabled state to a flagEilon Greenstein
When working with DCC, a function can be disabled or enabled (virtual link down or up). Using the function state introduced some race conditions with the load/unload flow. Using a separate flag to indicate that the function is disabled. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Allowing 0 as initial fairness valueEilon Greenstein
Value of zero was used to disable the fairness mechanism. Though the code (driver and FW) allowed changing the value at run time, it did not allow to do that if the mechanism was disabled to begin with. Fixed the FW to allow turning on and off the mechanism at run time. Fixed the code to read the value from the chip at the right sequence. Without this fix, if the initial value was set to zero, traffic could not run on the interface. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11bnx2x: Add main CNIC interface functions.Michael Chan
Add the main CNIC registration, callback, MAC addr. setup functions. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Shmulik Ravid - Rabinovitz <shmulikr@broadcom.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11bnx2x: Add hw init code to support iSCSI.Michael Chan
Add code to initialize hardware blocks used for iSCSI. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Shmulik Ravid - Rabinovitz <shmulikr@broadcom.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11bnx2x: Refactor MAC address setup code.Michael Chan
For iSCSI MAC address setup in later patches. Signed-off-by: Shmulik Ravid - Rabinovitz <shmulikr@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11bnx2x: Refactor bnx2x_sp_post().Michael Chan
Some of the SPQ (slow-path queue) operations will be used by the cnic code in later patches. Signed-off-by: Shmulik Ravid - Rabinovitz <shmulikr@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05net: Convert ethtool {get_stats, self_test}_count() ops to get_sset_count()Ben Hutchings
These string query operations were supposed to be replaced by the generic get_sset_count() starting in 2007. Convert the remaining implementations. Also remove calls to these operations to initialise drvinfo->n_stats. The ethtool core code already does that. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02netdev: drivers should make ethtool_ops constStephen Hemminger
No need to put ethtool_ops in data, they should be const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12bnx2x: update version to 1.52.1Eilon Greenstein
2009-08-12bnx2x: Whitespaces and commentsEilon Greenstein
2009-08-12bnx2x: Re-factor the initialization codeEilon Greenstein
Moving the code to a more logical place and beautifying it. No real change in behavior. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12bnx2x: Using PCI_DEVICE macroEilon Greenstein
2009-08-12bnx2x: Adding explicit castingEilon Greenstein
2009-08-12bnx2x: Using macro for phy addressEilon Greenstein
2009-08-12bnx2x: Missing smp_wmb for statistics state machineEilon Greenstein
2009-08-12bnx2x: Check unzip return codeEilon Greenstein
Without this check, when running out of memory, we will see PSOD's in bnx2x_init_fill() when doing a memset(). This is because at that time, bp->gunzip_buf is not pointing to a valid allocated space. Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12bnx2x: Remove the init_dmae field from bpEilon Greenstein
Moved the dmae_command from the heap to the stack. This will save 56 bytes per bnx2x structure. As a side benefit, we can also reduce the time the dmae_mutex is held. This is because do we not need to hold this mutex when setting up the dmae command. The memory where is dmae command is stored is not a shared resource and doesn not need to be protected. Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12bnx2x: Updating regdump_len at drvinfoEilon Greenstein
2009-08-12bnx2x: Move printing of version from probe to the initEilon Greenstein
Move printing of version from probe to the init function Rather then checking if this is the first module probe call to print the version of the driver only once, the statement is moved to the init function of the module where init is only called once Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
