path: root/drivers/net/atl1c
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-02-23atl1[ce]: fix sparse warningsstephen hemminger
The dmaw_block is an enum and max_pay_load is u32. Therefore sparse gives warning about comparison of unsigned and signed value. Resolve by using min_t to force cast. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-15Merge branch 'master' into for-nextJiri Kosina
2011-02-11atl1c: Do not call device_init_wakeup() in atl1c_probe()Rafael J. Wysocki
The atl1c driver shouldn't call device_init_wakeup() in its probe routine with the second argument equal to 1, because for PCI devices the wakeup capability setting is initialized as appropriate by the PCI subsystem. Remove the potentially harmful call. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-04Merge branch 'master' of ↵David S. Miller
2011-02-02atl1c: Add missing PCI device IDChuck Ebbert
Commit 8f574b35f22fbb9b5e5f1d11ad6b55b6f35f4533 ("atl1c: Add AR8151 v2 support and change L0s/L1 routine") added support for a new adapter but failed to add it to the PCI device table. Signed-Off-By: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20atl1c: remove private #define.françois romieu
Either unused or duplicates from mii.h. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Chris Snook <chris.snook@gmail.com> Cc: Jie Yang <jie.yang@atheros.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19Comment typo fixes for 'descriptor'Justin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-22atl1c: Do not use legacy PCI power managementRafael J. Wysocki
The atl1c driver uses the legacy PCI power management, so it has to do some PCI-specific things in its ->suspend() and ->resume() callbacks and they are not done correctly. Convert atl1c to the new PCI power management framework and make it let the PCI subsystem handle all of the PCI-specific aspects of device handling during system power transitions. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16net: Fix drivers advertising HW_CSUM feature to use csum_startMichał Mirosław
Some drivers are using skb_transport_offset(skb) instead of skb->csum_start for NETIF_F_HW_CSUM offload. This does not matter now, but if someone implements checksumming of encapsulated packets then this will break silently. TSO output paths are left as they are, since they are for IP+TCP only (might be worth converting though). Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-21atl1c: Fix hardware type check for enabling OTP CLKBen Hutchings
Commit 496c185c9495629ef1c65387cb2594578393cfe0 "atl1c: Add support for Atheros AR8152 and AR8152" added the condition: if (hw->nic_type == athr_l1c || hw->nic_type == athr_l2c_b) for enabling OTP CLK, and the condition: if (hw->nic_type == athr_l1c || hw->nic_type == athr_l2c) for disabling OTP CLK. Since the two previously defined hardware types are athr_l1c and athr_l2c, the latter condition appears to be the correct one. Change the former to match. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24atl1c: make functions staticstephen hemminger
The up/down are only used in this file. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Don't check for vlan group before vlan_tx_tag_present.Jesse Gross
Many (but not all) drivers check to see whether there is a vlan group configured before using a tag stored in the skb. There's not much point in this check since it just throws away data that should only be present in the expected circumstances. However, it will soon be legal and expected to get a vlan tag when no vlan group is configured, so remove this check from all drivers to avoid dropping the tags. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-28drivers/net/atl1c: Remove double testJulia Lawall
The nic_type field is compared to athr_l2c twice. The sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @expression@ expression E; @@ ( * E || ... || E | * E && ... && E ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-21atl1c: use net_device_stats from struct net_deviceEric Dumazet
struct net_device has its own struct net_device_stats member, so use this one instead of a private copy in the atl1c_adapter struct. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01atl1c: Add AR8151 v2 support and change L0s/L1 routineJie Yang
Add AR8151 v2.0 Gigabit 1000 support Change jumbo frame size to 6K Update L0s/L1 rountine when link speed is 100M or 1G, set L1 link timer to 4 for l1d_2 and l2c_b2 set L1 link timer to 7 for l2c_b, set L1 link timer to 0xF for others. Update atl1c_suspend routine just refactory the function, add atl1c_phy_power_saving routine, when Wake On Lan enable, this func will be called to save power, it will reautoneg PHY to 10/100M speed depend on the link partners link capability. Update atl1c_configure_des_ring do not use l2c_b default SRAM configuration. Signed-off-by: Jie Yang <Jie.Yang@atheros.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30net: remove redundant codeEric Dumazet
eth_type_trans(skb, netdev) does the "skb->dev = netdev;" initialization, we can remove it from various network drivers. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part3Jiri Pirko
2010-02-16atl1c: Add support for Atheros AR8152 and AR8152Luis R. Rodriguez
AR8151 is a Gigabit Ethernet device. AR8152 devices are Fast Ethernet devices, there are two revisions, a 1.0 and a 2.0 revision. This has been tested against these devices: Driver Model-name vendor:device Type atl1c AR8131 1969:1063 Gigabit Ethernet atl1c AR8132 1969:1062 Fast Ethernet atl1c AR8151(v1.0) 1969:1073 Gigabit Ethernet atl1c AR8152(v1.1) 1969:2060 Fast Ethernet This device has no hardware available yet so it goes untested, but it should work: atl1c AR8152(v2.0) 1969:2062 Fast Ethernet Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/atl1c/atl1c_main.c: use %pM to show MAC addresshartleys
Use the %pM kernel extension to display the MAC address. The only difference in the output is that the MAC address is shown in the usual colon-separated hex notation. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: include/net/tcp.h
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-08atl1c:use common_task instead of reset_task and link_chg_taskJie Yang
use common_task instead of reset_task and link_chg_task, so it fix "call cancel_work_sync from the work itself". Signed-off-by: Jie Yang <jie.yang@atheros.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08atl1c:add pci map direction in atl1c_buffer flagsJie Yang
add pci map direction in atl1c_buffer flags, it is used when call pci_unmap apis. Signed-off-by: Jie Yang <jie.yang@atheros.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-18drivers/net/atl1c: remove exceptional & on function nameJulia Lawall
In this file, function names are otherwise used as pointers without &. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-07atl1c: change atl1c_buffer struct and restructure clean atl1c_buffer procedureJie Yang
change atl1c_buffer struct, use "u16 flags" instead of "u16 state" to store more infomation for atl1c_buffer, and restructure clean atl1c_buffer procedure, add common api atl1c_clean_buffer. Signed-off-by: Jie Yang <jie.yang@atheros.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27atl1c: duplicate atl1c_get_tpdJie Yang
remove duplicate atl1c_get_tpd, it may cause hardware to send wrong packets. Signed-off-by: Jie Yang <jie.yang@atheros.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22atl1c:remove compiling warningjie.yang@atheros.com
Set wol_ctrl_data to value 0, to remove compiling warning. Signed-off-by: Jie Yang <jie.yang@atheros.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-03netdev: Remove redundant checks for CAP_NET_ADMIN in MDIO implementationsBen Hutchings
dev_ioctl() already checks capable(CAP_NET_ADMIN) before calling the driver's implementation of MDIO ioctls. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02drivers: Kill now superfluous ->last_rx storesEric Dumazet
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Neil Horman <nhorman@txudriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02netdev: drivers should make ethtool_ops constStephen Hemminger
No need to put ethtool_ops in data, they should be const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-08-09atlx: strncpy does not null terminate stringRoel Kluin
strlcpy() will always null terminate the string. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Chris Snook <csnook@redhat.com> Cc: Jie Yang <jie.yang@atheros.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-01atl1c: return PCI_ERS_RESULT_DISCONNECT on permanent failureDean Nelson
PCI drivers that implement the struct pci_error_handlers' error_detected callback should return PCI_ERS_RESULT_DISCONNECT if the state passed in is pci_channel_io_perm_failure. This patch fixes the issue for atl1c. Signed-off-by: Dean Nelson <dnelson@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-16atl1c: misplaced parenthesisroel kluin
Fix misplaced parenthesis Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-16atl1c: add missing parenthesesroel kluin
Parentheses are required or the comparison occurs before the bitand. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25atl1*: add device_set_wakeup_enable to atl1*_set_wolBrandon Philips
Tell PCI core that atl1* device can wakeup the system when WOL is enabled by calling device_set_wakeup_enable. Joerg noted that his atl1e device WOL fine after enabling it with ethtool and changing /sys/class/net/eth0/device/power/wakeup to enabled Tested on atl1e: https://bugzilla.novell.com/show_bug.cgi?id=493214 Tested by: Joerg Reuter <jreuter@novell.com> Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11atl1c: WAKE_MCAST tested twice, not WAKE_UCASTRoel Kluin
The WAKE_MCAST bit is tested twice, the first should be WAKE_UCAST. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Jie Yang <jie.yang@atheros.com> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Chris Snook <csnook@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-01atl1c_main.c: add wait_for_idle routineJoe Perches
Slight refactoring of duplicated wait for idle checks Spelling fix Signed-off-by: Joe Perches <joe@perches.com> Acked-by: jie.yang@atheros.com Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: dont update dev->trans_startEric Dumazet
Second round of drivers for Gb cards (and NIU one I forgot in the 10GB round) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/scsi/fcoe/fcoe.c
