path: root/drivers/net/at1700.c
2010-12-21drivers/net/*.c: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. Signed-off-by: Joe Perches <joe@perches.com>
2010-11-09drivers/net: normalize TX_TIMEOUTEric Dumazet
Some network drivers use old TX_TIMEOUT definitions, assuming HZ=100 of old kernels. Convert these definitions to include HZ, since HZ can be 1000 these days. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-11at1700: fix double free_irqKulikov Vasiliy
free_irq() is called both in net_close() and cleanup_card(). Since it is requested in at1700_probe1(), leave free_irq() only in cleanup_card() for balance. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part3Jiri Pirko
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-3945.h drivers/net/wireless/iwlwifi/iwl-tx.c drivers/net/wireless/iwlwifi/iwl3945-base.c
2009-07-26at1700: Read buffer overflowroel kluin
loop bound looks to be wrong, for an array of length 8 Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27netdev: convert at1700 to net_device_opsStephen Hemminger
Remove unneeded memset (alloc_etherdev does it already). Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/at1700.c: fix sparse warning: symbol shadows an earlier oneHannes Eder
Impact: Move variable declaration to a more inner scope. Fix this sparse warning: drivers/net/at1700.c:846:21: warning: symbol 'i' shadows an earlier one drivers/net/at1700.c:831:13: originally declared here Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03netdev: remove pathetic compile-command linesAlexey Dobriyan
-m486, -O6 are partircularly amusing. Remove some other useless lines near as well. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-17/drivers/net/at1700.c replaced init_module&cleanup_module with ↵Jon Schindler
module_init&module_exit Replaced init_module and cleanup_module with static functions and module_init/module_exit. Signed-off-by: Jon Schindler <jkschind@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28[netdrvr] checkpatch cleanupsJeff Garzik
2008-01-28drivers/net: Add missing "space"Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET] drivers/net: statistics cleanup #1 -- save memory and shrink codeJeff Garzik
We now have struct net_device_stats embedded in struct net_device, and the default ->get_stats() hook does the obvious thing for us. Run through drivers/net/* and remove the driver-local storage of statistics, and driver-local ->get_stats() hook where applicable. This was just the low-hanging fruit in drivers/net; plenty more drivers remain to be updated. [ Resolved conflicts with napi_struct changes and fix sunqe build regression... -DaveM ] Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04[PATCH] trivial missing __init in drivers/net/*Al Viro
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19[PATCH] at1700 section fixAndrew Morton
WARNING: drivers/net/at1700.o - Section mismatch: reference to .init.text:at1700_probe from .text between 'init_module' (at offset 0x75) and 'net_get_stats' Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-06-27drivers/net/at1700: remove incorrect commentKomuro
"Allied Telesis RE1000 Plus" is not supported at all by kernel 2.6.12. Signed-off-by: komurojun-mbn@nifty.com
