path: root/drivers/net/Kconfig
2006-01-08[PATCH] fix Kconfig depends for cs89x0 (PNX010X support)Lennert Buytenhek
PNX010X support for CS89x0 should be conditional on NET_PCI, as it is an 'on board controller' and NET_PCI includes that category of NICs. Since ARCH_PNX0105 was recently changed to ARCH_PNX010X, incorporate that change as well while we're at it. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: dmitry pervushin <dpervushin@ru.mvista.com> Cc: <dsaxena@plexity.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-24[PATCH] spidernet: fix Kconfig after BPA->CELL renameJens Osterkamp
We changed the name of the Kconfig symbols along with the move to arch/powerpc. This one hunk got lost during the conversion. From: Jens.Osterkamp@de.ibm.com Cc: netdev@vger.kernel.org Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-01[PATCH] sky2: eliminate special case for EC-A1shemminger@osdl.org
Eliminate special case for EC-A1. The overhead isn't so great that having config option is worth it. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-18[PATCH] intel ixp2000 network driverLennert Buytenhek
The way the hardware and firmware work is that there is one shared RX queue and IRQ for a number of different network interfaces. Due to this, we would like to process received packets for every interface in the same NAPI poll handler, so we need a pseudo-device to schedule polling on. What the driver currently does is that it always schedules polling for the first network interface in the list, and processes packets for every interface in the poll handler for that first interface -- however, this scheme breaks down if the first network interface happens to not be up, since netif_rx_schedule_prep() checks netif_running(). sky2 apparently has the same issue, and Stephen Hemminger suggested a way to work around this: create a variant of netif_rx_schedule_prep() that does not check netif_running(). I implemented this locally and called it netif_rx_schedule_prep_notup(), and it seems to work well, but it's something that probably not everyone would be happy with. The ixp2000 is an ARM CPU with a high-speed network interface in the CPU itself (full duplex 4Gb/s or 10Gb/s depending on the IXP model.) The CPU package also contains 8 or 16 (again depending on the IXP model) 'microengines', which are somewhat primitive but very fast and efficient processor cores which can be used to offload various things from the main CPU. This driver makes the high-speed network interface in the CPU visible and usable as a regular linux network device. Currently, it only supports the Radisys ENP2611 IXP board, but adding support for other board types should be fairly easy. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-11Merge branch 'sky2'Jeff Garzik
2005-11-11[PATCH] smc91x: DB1200 support.Pete Popov
The following patch support the SMC9111 present on DB1200 boards. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-11Merge branch 'master'Jeff Garzik
2005-11-09Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-11-09[PATCH] IOC: And don't mark the things as broken Cowboy.Ralf Baechle
And don't mark the things as broken Cowboy. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-08[PPP]: add PPP MPPE encryption moduleMatt Domsch
From: Matt Domsch <Matt_Domsch@dell.com> The patch below implements the Microsoft Point-to-Point Encryption method as a PPP compressor/decompressor. This is necessary for Linux clients and servers to interoperate with Microsoft Point-to-Point Tunneling Protocol (PPTP) servers (either Microsoft PPTP servers or the poptop project) which use MPPE to encrypt data when creating a VPN. This patch differs from the kernel_ppp_mppe DKMS pacakge at pptpclient.sourceforge.net by utilizing the kernel crypto routines rather than providing its own SHA1 and arcfour implementations. Minor changes to ppp_generic.c try to prevent a link from disabling compression (in our case, the encryption) after it has started using compression (encryption). Feedback to <pptpclient-devel@lists.sourceforge.net> please. Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Cc: James Cameron <james.cameron@hp.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-05Merge branch 'master'Jeff Garzik
2005-11-05[PATCH] S2io: Multi buffer mode supportAnanda Raju
Hi, This patch provides dynamic two buffer-mode and 3 buffer-mode options. Previously 2 buffer-mode was compilation option. Now with this patch applied one can load driver in 2 buffer-mode with module-load parameter ie. #insmod s2io.ko rx_ring_mode=2 This patch also provides 3 buffer-mode which provides header separation functionality. In 3 buffer-mode skb->data will have L2/L3/L4 headers and "skb_shinfo(skb)->frag_list->data" will have have L4 payload. one can load driver in 3 buffer-mode with same above module-load parameter ie. #insmod s2io.ko rx_ring_mode=3 Please review the patch. Signed-off-by: Ananda Raju <ananda.raju@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-04[PATCH] ARM: Reverted 2919/1: CS8900A ethernet driver modifications for the ↵Russell King
Comdial MP1000 No longer maintained
2005-10-29[PATCH] PPC 44x EMAC driver: add 440GR supportEugene Surovegin
Add PowerPC 440GR support Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28Merge branch 'master'Jeff Garzik
2005-10-28[PATCH] New PowerPC 4xx on-chip ethernet controller driverEugene Surovegin
This patch replaces current PowerPC 4xx EMAC driver with new, re-written from the scratch version. This patch is quite big (~234K) because there is virtualy 0% of common code between old and new version. New driver uses NAPI, it solves stability problems under heavy packet load and low memory, corrects chip register access and fixes numerous small bugs I don't even remember now. This patch has been tested on all supported in 2.6 PPC 4xx boards. It's been used in production for almost a year now on custom 4xx hardware. PPC32 specific parts are already upstream. Patch was acked by the current EMAC driver maintainer (Matt Porter). I will be maintaining this new version. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> -- Kconfig | 72 ibm_emac/Makefile | 13 ibm_emac/ibm_emac.h | 418 +++-- ibm_emac/ibm_emac_core.c | 3414 ++++++++++++++++++++++++---------------------- ibm_emac/ibm_emac_core.h | 313 ++-- ibm_emac/ibm_emac_debug.c | 377 ++--- ibm_emac/ibm_emac_debug.h | 63 ibm_emac/ibm_emac_mal.c | 674 +++++---- ibm_emac/ibm_emac_mal.h | 336 +++- ibm_emac/ibm_emac_phy.c | 335 ++-- ibm_emac/ibm_emac_phy.h | 105 - ibm_emac/ibm_emac_rgmii.c | 201 ++ ibm_emac/ibm_emac_rgmii.h | 68 ibm_emac/ibm_emac_tah.c | 111 + ibm_emac/ibm_emac_tah.h | 96 - ibm_emac/ibm_emac_zmii.c | 255 +++ ibm_emac/ibm_emac_zmii.h | 114 - 17 files changed, 4114 insertions(+), 2851 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28Add fs_enet ethernet network driver, for several embedded platforms.Pantelis Antoniou
2005-10-28[PATCH] Fix CS89x0 KConfig for IXDP2X01Deepak Saxena
IXDP2x01 systems can be built without PCI network cards, so we should not require NET_PCI to build CS89x0 on these systems. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] s2io: kconfig help fixAkinobu Mita
The documentation about s2io is available at Documentation/networking/s2io.txt. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
Minor manual fixups for gfp_t clashes.
2005-10-28[ARM] 2919/1: CS8900A ethernet driver modifications for the Comdial MP1000Jon Ringle
Patch from Jon Ringle This patch gives support for the CS8900A ethernet chip on the Comdial MP1000 Signed-off-by: Jon Ringle Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-18[PATCH] mipsnet: Virtual ethernet driver for MIPSsim.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/Kconfig | 8 + drivers/net/Makefile | 1 drivers/net/mipsnet.c | 371 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/mipsnet.h | 127 +++++++++++++++++ 4 files changed, 507 insertions(+) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-04Merge branch 'upstream-fixes'Jeff Garzik
2005-10-03[PATCH] net/Kconfig: convert pocket_adapter ISA to PARPORTGrant Coady
This patch changes pocket and parallel adaptors to depend on PARPORT instead of ISA in order to get the option in newer SuperIO based systems. Signed-off-by: Grant Coady <gcoady@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-03Merge branch 'upstream-fixes'Jeff Garzik
2005-09-27[NET]: Add Sun Cassini driver.David S. Miller
Written by Adrian Sun (asun@darksunrising.com). Ported to 2.6.x by Tom 'spot' Callaway <tcallawa@redhat.com>. Further cleaned up and integrated by David S. Miller Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-23[netdrvr] delete CONFIG_PHYCONTROLJeff Garzik
2005-09-23[netdrvr gianfar] use new phy layerAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-21Merge /spare/repo/linux-2.6/Jeff Garzik
2005-09-14[PATCH] Add rapidio net driverMatt Porter
Adds an "Ethernet" driver which sends Ethernet packets over the standard RapidIO messaging. This depends on the core RIO patch for mailbox/doorbell access. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] skge: gmac register access errors in dual portStephen Hemminger
Merge of four previous patches and the Kconfig fix * Remove debug printk's * whitespace cleanup and version number change * clear interrupts, reset phy, and reset hardware on shutdown * ignore 64bit counter overflow interrupts * fix a couple of places where second port could clobber state of first port. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14Merge /spare/repo/linux-2.6/ Jeff Garzik
2005-09-11[PATCH] m68knommu: config support for FEC eth of 523x Coldfire processor familyGreg Ungerer
Add configuration support for the FEC ethernet controller in the Freescale 523x processor family. Also add and option to configure the second FEC controller on some Freescale processors. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-06[PATCH] net: add driver for the NIC on Cell BladesJens Osterkamp
This patch adds a driver for a new 1000 Mbit ethernet NIC. It is integrated on the south bridge that is used for our Cell Blades. The code gets the MAC address from the Open Firmware device tree, so it won't compile on platforms other than ppc64. This is the first public release, so I don't expect the first version to get merged, but I'd aim for integration within the 2.6.13 time frame. Cc: Utz Bacher <utz.bacher@de.ibm.com> Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05[PATCH] (15/22) Kconfig fix (82596)Al Viro
driver is non-modular Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05[PATCH] sis190: basic sis191 supportFrancois Romieu
The sis191 is the gigabit brother of the sis190. SiS's driver suggests that the register set is backward compatible: this should hopefully give a basic driver. The device should allow the usual features from a modern ethernet adapter (802.1q, SG, Jumbo frames, TSO, checksum offload). So far the relevant register layout is not documented. SiS's driver does not provide these features either (at least not for Linux). Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-31[ARM] 2866/1: add i.MX set_mctrl / get_mctrl functionsSascha Hauer
Patch from Sascha Hauer This patch adds support for setting and getting RTS / CTS via set_mtctrl / get_mctrl functions. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-29/spare/repo/netdev-2.6 branch 'chelsio'Jeff Garzik
2005-08-29Merge /spare/repo/linux-2.6/Jeff Garzik
2005-08-29/spare/repo/netdev-2.6 branch 'sis190'Jeff Garzik
2005-08-24Merge upstream into 'upstream' branch of netdev-2.6.git.Jeff Garzik
Hand fix merge conflict in drivers/net/tokenring/Kconfig.
2005-08-23[PATCH] Kconfig fix (emac dependencient)Al Viro
emac doesn't build modular; ibm_emac_debug doesn't build at all (missing headers). Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-19[PATCH] SIS190 must select MIIAdrian Bunk
SIS190 must select MII since it's using it. While I was editing the Kconfig entry, I also converted the spaces to tabs. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-17[PATCH] sky2: new experimental Marvell Yukon2 driverStephen Hemminger
New driver for the Marvell Yukon2 Gigabit Ethernet chipset. This driver is based on the skge driver, but using the logic from the SysKonnect version of the sk98lin driver. It should support all the Yukon2 chipsets that are available in many current Intel and AMD motherboards. The driver does support ethtool, tx and rx checksum, and tcp segmentation offload. But it has only been tested for a short while and is known to stop receiving under heavy load. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30This patch adds a PHY Abstraction Layer to the Linux Kernel, enablingAndy Fleming
ethernet drivers to remain as ignorant as is reasonable of the connected PHY's design and operation details. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-30[PATCH] sis190: resurrectionFrancois Romieu
Raise the sis190 driver from the dead The driver handles the integrated network device found on SiS 965L chipset. It follows the classical (non-napi) interrupt-driven model and provides minimal ethtool support. The code comes from a heavy cleanup/rewrite of the original code which was removed from the kernel on 14/04/2004. Since the r8169 driver does not work too bad and there will probably be (at least) a few months of improvements/testing/fixing, I made the code as close as possible to the r8169 one. Pascal Chapperon <pascal.chapperon@wanadoo.fr> deserves some special credit for testing and bug-catching. Many thanks to Lars Vahlenberg as well. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-27[NET]: Move in_aton from net/ipv4/utils.c to net/core/utils.cMatt Mackall
Move in_aton to allow netpoll and pktgen to work without the rest of the IPv4 stack. Fix whitespace and add comment for the odd placement. Delete now-empty net/ipv4/utils.c Re-enable netpoll/netconsole without CONFIG_INET Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
