path: root/drivers/net/3c59x.c
2007-10-17vortex_up should initialize "err"Badari Pulavarty
Simple compile warning fix. (against 2.6.23-git12) Thanks, Badari vortex_up() should initialize 'err' for a successful return. drivers/net/3c59x.c: In function `vortex_up': drivers/net/3c59x.c:1494: warning: `err' might be used uninitialized in this function Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-16WOL bugfix for 3c59x.cSteffen Klassert
Some NICs (3c905B) can not generate PME in power state PCI_D0, while others like 3c905C can. Call pci_enable_wake() with PCI_D3hot should give proper WOL for 3c905B. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Tested-by: Harry Coin <hcoin@n4comm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-103c59x: trivial endianness annotations, NULL noise removalAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[netdrvr] Stop using legacy hooks ->self_test_count, ->get_stats_countJeff Garzik
These have been superceded by the new ->get_sset_count() hook. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-103c59x: check return of pci_enable_device()Mark Hindley
Check return of pci_enable_device in vortex_up(). Also modify vortex_up to return error to callers. Handle failure of vortex_up in vortex_open and vortex_resume. Signed-off-by: Mark Hindley <mark@hindley.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-143c59x: fix duplex configurationSteffen Klassert
A special sequence of ifconfig up/down and plug/unplug the cable can break the duplex configuration of the driver. Setting vp->mii.full_duplex = vp->full_duplex in vortex_up should fix this. Addresses Bug 8575 3c59x duplex configuration broken http://bugzilla.kernel.org/show_bug.cgi?id=8575 Cc: Martin Buck <mb-tmp-ohtmvyyn.xreary.bet@gromit.dyndns.org> Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Cc: Natalie Protasevich <protasnb@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-31[NET]: ethtool_perm_addr only has one implementationMatthew Wilcox
All drivers implement ethtool get_perm_addr the same way -- by calling the generic function. So we can inline the generic function into the caller and avoid going through the drivers. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-103cSOHO100-TX needs EXTRA_PREAMBLESteffen Klassert
The 3cSOHO100-TX needs a mdio_sync() before mdio_read() to read the MII transceiver registers properly. Adding EXTRA_PREAMBLE to drv_flags of the 3cSOHO100-TX will force this. This problem exists already for years (I checked back to 2.6.8). Setting duplex for the 3cSOHO100-TX was more or less a random process. Till 2.6.15 it was more likely that the diver ends up in half duplex mode, after the code change in 2.6.16 it was more likely to end up in full duplex mode. I wonder why nobody noticed this earier. Hopefully addresses Bug 7454 3c59x (3cSOHO100-TX Hurricane) slow network bug http://bugzilla.kernel.org/show_bug.cgi?id=7454 and Bug 3654 3cSOHO100-TX: No MII transceiver present http://bugzilla.kernel.org/show_bug.cgi?id=3654 Cc: Jonas Sandberg <jonassa@gmail.com> Cc: Jon Sanchez <bugs@niluje.net> Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09remove broken URLs from net drivers' outputMarkus Dahms
Remove broken URLs (www.scyld.com) from network drivers' logging output. URLs in comments and other strings are left intact. Signed-off-by: Markus Dahms <dahms@fh-brandenburg.de> Acked-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Alan Cox <alan@redhat.com> igned-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-093c59x: Fix several modpost warningsRalf Baechle
WARNING: drivers/net/3c59x.o - Section mismatch: reference to .init.text: from .text between 'vortex_eisa_probe' (at offset 0x4580) and 'vortex_eisa_remove' WARNING: drivers/net/3c59x.o - Section mismatch: reference to .init.text: from .text between 'vortex_eisa_probe' (at offset 0x4584) and 'vortex_eisa_remove' WARNING: drivers/net/3c59x.o - Section mismatch: reference to .init.text: from .text between 'vortex_eisa_probe' (at offset 0x4588) and 'vortex_eisa_remove' WARNING: drivers/net/3c59x.o - Section mismatch: reference to .init.text: from .text between 'vortex_eisa_probe' (at offset 0x458c) and 'vortex_eisa_remove' Fixed by: o move definition of vortex_eisa_driver below the functions it references. o remove now unnecessary prototypes for vortex_eisa_probe and vortex_eisa_remove. o Make vortex_eisa_probe an __init function. o Make vortex_eisa_remove a __devexit function. o Wrap vortex_eisa_driver reference to vortex_eisa_remove with __devexit_p(). Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/3c59x.c | 28 +++++++++++++--------------- 1 file changed, 13 insertions(+), 15 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-063c59x: Handle pci_enable_device() failure while resumingDmitriy Monakhov
Handle pci_enable_device() failure while resuming, we can safely exit here. Signed-off-by: Monakhov Dmitriy <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-06NET-3c59x: turn local_save_flags() + local_irq_disable() into local_irq_save()Jiri Kosina
drivers/net/3c59x.c::poll_vortex() contains local_irq_disable() after local_save_flags(). Turn it into local_irq_save(). Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27[PATCH] EISA bus MODALIAS attributes supportMichael Tokarev
Add modalias attribute support for the almost forgotten now EISA bus and (at least some) EISA-aware modules. The modalias entry looks like (for an 3c509 NIC): eisa:sTCM5093 and the in-module alias like: eisa:sTCM5093* The patch moves struct eisa_device_id declaration from include/linux/eisa.h to include/linux/mod_devicetable.h (so that the former now #includes the latter), adds proper MODULE_DEVICE_TABLE(eisa, ...) statements for all drivers with EISA IDs I found (some drivers already have that DEVICE_TABLE declared), and adds recognision of __mod_eisa_device_table to scripts/mod/file2alias.c so that proper modules.alias will be generated. There's no support for /lib/modules/$kver/modules.eisamap, as it's not used by any existing tools, and because with in-kernel modalias mechanism those maps are obsolete anyway. The rationale for this patch is: a) to make EISA bus to act as other busses with modalias support, to unify driver loading b) to foget about EISA finally - with this patch, kernel (who still supports EISA) will be the only one who knows how to choose the necessary drivers for this bus ;) [akpm@osdl.org: fix the kbuild bit] Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Acked-the-net-bits-by: Jeff Garzik <jeff@garzik.org> Acked-the-tulip-bit-by: Valerie Henson <val_henson@linux.intel.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-24Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (217 commits) net/ieee80211: fix more crypto-related build breakage [PATCH] Spidernet: add ethtool -S (show statistics) [NET] GT96100: Delete bitrotting ethernet driver [PATCH] mv643xx_eth: restrict to 32-bit PPC_MULTIPLATFORM [PATCH] Cirrus Logic ep93xx ethernet driver r8169: the MMIO region of the 8167 stands behin BAR#1 e1000, ixgb: Remove pointless wrappers [PATCH] Remove powerpc specific parts of 3c509 driver [PATCH] s2io: Switch to pci_get_device [PATCH] gt96100: move to pci_get_device API [PATCH] ehea: bugfix for register access functions [PATCH] e1000 disable device on PCI error drivers/net/phy/fixed: #if 0 some incomplete code drivers/net: const-ify ethtool_ops declarations [PATCH] ethtool: allow const ethtool_ops [PATCH] sky2: big endian [PATCH] sky2: fiber support [PATCH] sky2: tx pause bug fix drivers/net: Trim trailing whitespace [PATCH] ehea: IBM eHEA Ethernet Device Driver ... Manually resolved conflicts in drivers/net/ixgb/ixgb_main.c and drivers/net/sky2.c related to CHECKSUM_HW/CHECKSUM_PARTIAL changes by commit 84fa7933a33f806bbbaae6775e87459b1ec584c0 that just happened to be next to unrelated changes in this update.
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-12Merge branch 'tmp' into upstreamJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] 3c59x: snip changelog from source codeJeff Garzik
Driver source code is not the preferred place to store change history. Acked-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-03[PATCH] lockdep: annotate 3c59x.c disable_irq()Ingo Molnar
3c59x.c's vortex_timer() function knows that vp->lock can only be used by an irq context that it disabled - and can hence take the vp->lock without disabling hardirqs. Teach lockdep about this. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: [PATCH] i386: export memory more than 4G through /proc/iomem [PATCH] 64bit Resource: finally enable 64bit resource sizes [PATCH] 64bit Resource: convert a few remaining drivers to use resource_size_t where needed [PATCH] 64bit resource: change pnp core to use resource_size_t [PATCH] 64bit resource: change pci core and arch code to use resource_size_t [PATCH] 64bit resource: change resource core to use resource_size_t [PATCH] 64bit resource: introduce resource_size_t for the start and end of struct resource [PATCH] 64bit resource: fix up printks for resources in misc drivers [PATCH] 64bit resource: fix up printks for resources in arch and core code [PATCH] 64bit resource: fix up printks for resources in pcmcia drivers [PATCH] 64bit resource: fix up printks for resources in video drivers [PATCH] 64bit resource: fix up printks for resources in ide drivers [PATCH] 64bit resource: fix up printks for resources in mtd drivers [PATCH] 64bit resource: fix up printks for resources in pci core and hotplug drivers [PATCH] 64bit resource: fix up printks for resources in networks drivers [PATCH] 64bit resource: fix up printks for resources in sound drivers [PATCH] 64bit resource: C99 changes for struct resource declarations Fixed up trivial conflict in drivers/ide/pci/cmd64x.c (the printk that was changed by the 64-bit resources had been deleted in the meantime ;)
2006-06-27[PATCH] 64bit resource: fix up printks for resources in networks driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[netdrvr] Remove long-unused bits from Becker template driversJeff Garzik
Symbols such as PCI_USES_IO, PCI_ADDR0, etc. originated from Donald Becker's net driver template, but have been long unused. Remove. In a few drivers, this allows the further eliminate of the pci_flags (or just plain flags) member in the template driver probe structure. Most of this logic is simply open-coded in most drivers, since it never changes. Made a few other cleanups while I was in there, too: * constify, __devinitdata several PCI ID tables * replace table terminating entries such as "{0,}," and "{NULL}," with a more-clean "{ }". Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-20[SPARC]: Kill __irq_itoa().David S. Miller
This ugly hack was long overdue to die. It was a way to print out Sparc interrupts in a more freindly format, since IRQ numbers were arbitrary opaque 32-bit integers which vectored into PIL levels. These 32-bit integers were not necessarily in the 0-->NR_IRQS range, but the PILs they vectored to were. The idea now is that we will increase NR_IRQS a little bit and use a virtual<-->real IRQ number mapping scheme similar to PowerPC. That makes this IRQ printing hack irrelevant, and furthermore only a handful of drivers actually used __irq_itoa() making it even less useful. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-31[PATCH] 3c59x: fix networking for 10base2 NICsSteffen Klassert
The "3c59x: use mii_check_media" patch introduced a netif_carrier_off in vortex_up. 10base2 stoped working because of this. This is removed. Tx/Rx reset is back in vortex_up because the 3c900B-Combo stops working after changing from half duplex to full duplex when Tx/Rx reset is done with vortex_timer. Also brought back some mii stuff to be sure that it does not break something else. Thanks to Pete Clements <clem@clem.clem-digital.net> for reporting and testing. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] "3c59x collision statistics fix" fixAndrew Morton
The pre-2.6.16 patch "3c59x collision statistics fix" accidentally caused vortex_error() to not run iowrite16(TxEnable, ioaddr + EL3_CMD) if we got a maxCollisions interrupt but MAX_COLLISION_RESET is not set. Thanks to Pete Clements <clem@clem.clem-digital.net> for reporting and testing. Acked-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: minor cleanupsSteffen Klassert
Remove some whitespaces and codingstyle issues. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: remove per-driver versioningSteffen Klassert
Remove per-driver versioning. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: use ethtool_op_get_linkSteffen Klassert
Use ethtool_op_get_link instead of vortex_get_link. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: carriercheck for forced mediaSteffen Klassert
Handle netif_carrier_{on,of} also if media is forced to 10baseT/100baseTx. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: decrease polling intervalSteffen Klassert
Set the polling interval for media changes to 5 seconds if link is down and 60 seconds if link is up. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: use mii_check_mediaSteffen Klassert
Check for media changes and netif_carrier by using mii_check_media() if mii is used. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] EISA: tidy-up driver_register() return valueBjorn Helgaas
Remove the assumption that driver_register() returns the number of devices bound to the driver. In fact, it returns zero for success or a negative error value. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Jeff Garzik <jgarzik@pobox.com> Acked-by: Marc Zyngier <maz@misterjones.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-03Merge branch 'net-const'Jeff Garzik
2006-03-03Massive net driver const-ification.Arjan van de Ven
2006-02-07Merge branch 'master'Jeff Garzik
2006-02-03[PATCH] 3c59x: collision statistic fixSteffen Klassert
Count the total number of packets with collisions during transmission in vp->stats.collisions. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-17[PATCH] drivers/net/*: use time_after() and friendsMarcelo Feitoza Parisi
They deal with wrapping correctly and are nicer to read. Also make jiffies-holding variables unsigned long. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-07[PATCH] 3c59x: don't enable scatter/gather w/o checksum supportStephen Hemminger
It is not valid to enable scatter/gather without hardware checksum support of some kind. (akpm: applies only to the old boomerang cards). Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] 3c59x: enable use of memory-mapped PCI I/OJohn W. Linville
Add capability for 3c59x driver to use memory-mapped PCI I/O resources. This may improve performance for those devices so equipped. This will be the default behaviour for IS_CYCLONE and IS_TORNADO devices. Additionally, it can be enabled/disabled individually for up to MAX_UNITS number of devices via the use_mmio module option or for all units via the global_use_mmio option. The use_mmio option overrides the global_use_mmio option for those devices specified. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] 3c59x: correct rx_dropped countingJohn W. Linville
Only increment rx_dropped in case of lack of resources (i.e. not for frames with errors). Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] 3c59x: support ETHTOOL_GPERMADDRJohn W. Linville
Add support for ETHTOOL_GPERMADDR to 3c59x. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
