path: root/drivers/net/3c509.c
2006-03-11[PATCH] 3c509: use proper suspend/resume APIPekka Enberg
Convert 3c509 driver to use proper suspend/resume API instead of the deprecated pm_register/pm_unregister. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-11[PATCH] 3c509: bus registration fixAndrew Morton
- Don't call eisa_driver_unregister() if eisa_driver_register() failed. - Properly propagate error values. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-11-13[PATCH] move pm_register/etc. to CONFIG_PM_LEGACY, pm_legacy.hJeff Garzik
Since few people need the support anymore, this moves the legacy pm_xxx functions to CONFIG_PM_LEGACY, and include/linux/pm_legacy.h. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-26[PATCH] document that 8139TOO supports 8129/8130Adrian Bunk
The 8129/8130 support is a sub-option that is not visible if the user hasn't enabled the 8139 support. Let's make it a bit easier for users to find the driver for their nic. Signed-off-by: Adrian Bunk <bunk@stusta.de>
