path: root/drivers/net/3c509.c
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-013com: convert drivers to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/forcedeth.c
2009-06-013c509: Add missing EISA IDsMaciej W. Rozycki
Several EISA device IDs for 3c509 family network cards are missing from the driver, making the cards unusable in their EISA mode. Here's a fix to add them based on the EISA configuration files distributed by 3Com and our eisa.ids database. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-263c50x: convert printk() to pr_<foo>()Alexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-01net: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-07Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-agn.c drivers/net/wireless/iwlwifi/iwl3945-base.c
2009-02-063c509: Fix resume from hibernation for PnP mode.Ondrej Zary
From: Ondrej Zary <linux@rainbow-software.org> last year, I posted a patch which fixed hibernation on 3c509 cards. That was back in 2.6.24. It worked fine in 2.6.25. But then I stopped using hibernation (as it did not work with my new IT8212 RAID controller). Now I fixed it and noticed that 3c509 does not wake up properly anymore (in 2.6.28) - neither in PnP nor in ISA modes. ifconfig down/up makes the card work again in PnP mode. However, in ISA mode, ifconfig up ends with "No such device" error. Comparing the 3c509 driver between 2.6.25 and 2.6.28, there's only some statistics-related change. So the cause of the problem must be somewhere else. This patch makes the resume work in PnP mode, but it's still not enough for ISA mode. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-213c509: convert to net_device_opsStephen Hemminger
2008-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath5k/base.c net/8021q/vlan_core.c
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-01el3_common_init() should be __devinit, not __initAl Viro
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (52 commits) vlan: Use bitmask of feature flags instead of seperate feature bits fmvj18x_cs: add NextCom NC5310 rev B support xirc2ps_cs: re-initialize the multicast address in do_reset 3C509: rx_bytes should not be increased when alloc_skb failed NETFRONT: Use __skb_queue_purge() VIRTIO: Use __skb_queue_purge() phylib: do EXPORT_SYMBOL on get_phy_id netlink: Fix nla_parse_nested_compat() to call nla_parse() directly WAN: protect HDLC proto list while insmod/rmmod drivers/net/fs_enet: remove null pointer dereference S2io: Version update for napi and MSI-X patches S2io: Added napi support when MSIX is enabled. S2io: Move all the transmit completions to a single msi-x (alarm) vector drivers/net/ehea - remove unnecessary memset after kzalloc au1000_eth: remove useless check Blackfin EMAC Driver: Removed duplicated include <linux/ethtool.h> cpmac bugfixes and enhancements e1000e: use resource_size_t, not unsigned long, for phys addrs net/usb: add support for Apple USB Ethernet Adapter uli526x: add support for netpoll ...
2008-05-223C509: rx_bytes should not be increased when alloc_skb failedWang Chen
If alloc_skb failed, the recieved packet will be dropped. Do not increase rx_bytes for dropped packet. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-21misc drivers/net endianness noiseAl Viro
2008-04-293c509: use netstats in net_device structurePaulius Zaleckas
Use net_device_stats from net_device structure instead of local. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-283c509: convert to isa_driver and pnp_driverOndrej Zary
Convert 3c509 driver to isa_driver and pnp_driver. The result is that autoloading using udev and hibernation works with ISA PnP cards. It also adds hibernation support for non-PnP ISA cards. xcvr module parameter was removed as its value was not used. Tested using 3 ISA cards in various combinations of PnP and non-PnP modes. EISA and MCA only compile-tested. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-123c509: PnP resource management fixKrzysztof Helt
In order to release PnP resources a card type must be set to EL3_PNP. Previously, it was never set hence the PnP resources were not released and device was left in incorrect state. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-103c509: endiannessAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-09remove broken URLs from net drivers' outputMarkus Dahms
Remove broken URLs (www.scyld.com) from network drivers' logging output. URLs in comments and other strings are left intact. Signed-off-by: Markus Dahms <dahms@fh-brandenburg.de> Acked-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Alan Cox <alan@redhat.com> igned-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-283C509: Remove unnecessary include of <linux/pm_legacy.h>Robert P. J. Day
Remove the apparently redundant include of <linux/pm_legacy.h>. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-06drivers/net: eliminate irq handler impossible checks, needless castsJeff Garzik
- Eliminate check for irq handler 'dev_id==NULL' where the condition never occurs. - Eliminate needless casts to/from void* Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27[PATCH] EISA bus MODALIAS attributes supportMichael Tokarev
Add modalias attribute support for the almost forgotten now EISA bus and (at least some) EISA-aware modules. The modalias entry looks like (for an 3c509 NIC): eisa:sTCM5093 and the in-module alias like: eisa:sTCM5093* The patch moves struct eisa_device_id declaration from include/linux/eisa.h to include/linux/mod_devicetable.h (so that the former now #includes the latter), adds proper MODULE_DEVICE_TABLE(eisa, ...) statements for all drivers with EISA IDs I found (some drivers already have that DEVICE_TABLE declared), and adds recognision of __mod_eisa_device_table to scripts/mod/file2alias.c so that proper modules.alias will be generated. There's no support for /lib/modules/$kver/modules.eisamap, as it's not used by any existing tools, and because with in-kernel modalias mechanism those maps are obsolete anyway. The rationale for this patch is: a) to make EISA bus to act as other busses with modalias support, to unify driver loading b) to foget about EISA finally - with this patch, kernel (who still supports EISA) will be the only one who knows how to choose the necessary drivers for this bus ;) [akpm@osdl.org: fix the kbuild bit] Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Acked-the-net-bits-by: Jeff Garzik <jeff@garzik.org> Acked-the-tulip-bit-by: Valerie Henson <val_henson@linux.intel.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-19[PATCH] Remove powerpc specific parts of 3c509 driverStephen Rothwell
On powerpc and ppc, insl_ns and insl are identical as are outsl_ns and outsl, so remove the conditional use of insl_ns and outsl_ns. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-03-11[PATCH] 3c509: use proper suspend/resume APIPekka Enberg
Convert 3c509 driver to use proper suspend/resume API instead of the deprecated pm_register/pm_unregister. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-11[PATCH] 3c509: bus registration fixAndrew Morton
- Don't call eisa_driver_unregister() if eisa_driver_register() failed. - Properly propagate error values. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-11-13[PATCH] move pm_register/etc. to CONFIG_PM_LEGACY, pm_legacy.hJeff Garzik
Since few people need the support anymore, this moves the legacy pm_xxx functions to CONFIG_PM_LEGACY, and include/linux/pm_legacy.h. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-26[PATCH] document that 8139TOO supports 8129/8130Adrian Bunk
The 8129/8130 support is a sub-option that is not visible if the user hasn't enabled the 8139 support. Let's make it a bit easier for users to find the driver for their nic. Signed-off-by: Adrian Bunk <bunk@stusta.de>
