path: root/drivers/mtd/nand/sharpsl.c
2008-02-03drivers/mtd/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2006-07-15MTD: [NAND] Fix the sharpsl driver after breakage from a core conversionRichard Purdie
The CNE bits are inverted on the device and writeb function is missing a NOT operation. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-29[MTD] NAND: Fix broken sharpsl driverThomas Gleixner
Remove the not longer supported NO_VIRTBLOCKS flag and remove an unused variable while at it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] NAND Replace oobinfo by ecclayoutThomas Gleixner
The nand_oobinfo structure is not fitting the newer error correction demands anymore. Replace it by struct nand_ecclayout and fixup the users all over the place. Keep the nand_oobinfo based ioctl for user space compability reasons. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Refactor NAND hwcontrol to cmd_ctrlThomas Gleixner
The hwcontrol function enforced a step by step state machine for any kind of hardware chip access. Let the hardware driver know which control bits are set and inform it about a change of the control lines. Let the hardware driver write out the command and address bytes directly. This gives a peformance advantage for address bus controlled chips and simplifies the quirks in the hardware drivers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] NAND modularize ECCThomas Gleixner
First step of modularizing ECC support. - Move ECC related functionality into a seperate embedded data structure - Get rid of the hardware dependend constants to simplify new ECC models Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-16[MTD NAND] Make various initfuncs static, remove #ifdef MODULE from exitfuncsDavid Woodhouse
We all inherited the same error from the original NAND board driver which got copied and changed. Fix them all at once... Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-14[MTD] Fix module refcounting in NAND board drivers.David Woodhouse
The _board_ driver needs to be mtd->owner, and it in turn pins the nand.ko module. Fix them all to actually do that, and fix nand.ko not to overwrite it -- and also to check that the caller sets it, if the caller is a module. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-13[MTD NAND] Indent all of drivers/mtd/nand/*.c.David Woodhouse
It was just too painful to deal with. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-04-18MTD: Correct Poodle partition sizeRichard Purdie
Correct the MTD NAND partition size for Poodle (Sharp Zaurus SL-5600) Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2005-11-07[MTD] NAND: Clean up trailing white spacesThomas Gleixner
2005-11-06[MTD] NAND sharpsl.c: Add support for akita and borzoi modelsRichard Purdie
The Sharp Zaurus akita and borzoi models are large page flash devices. This patch adds support for them to the sharpsl MTD NAND driver but keeps the oob layout and bad block positions compatible with the Sharp Zaurus 2.4 kernel and ROM bootloader. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-09-17[PATCH] MTD: Update SharpSL partition definitionsRichard Purdie
Add partition definitions for the new Sharp Zaurus models Spitz (SL-C3000), Akita (SL-C1000) and Borzoi (SL-C3100) Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-06[MTD] NAND: sharpsl.c set correct file permissionsThomas Gleixner
2005-05-23[MTD] NAND SharpSL fix default partition sizeRichard Purdie
Correct Poodle default partition size Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
