path: root/drivers/mtd/nand/ppchameleonevb.c
2006-09-22ioremap balanced with iounmap for drivers/mtd subsystemAmol Lad
ioremap must be balanced by an iounmap and failing to do so can result in a memory leak. Tested (compilation only) with: - allmodconfig - Modifying drivers/mtd/maps/Kconfig and drivers/mtd/nand/Kconfig to make sure that the changed file is compiling without warning Signed-off-by: Amol Lad <amol@verismonetworks.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-23[MTD] Refactor NAND hwcontrol to cmd_ctrlThomas Gleixner
The hwcontrol function enforced a step by step state machine for any kind of hardware chip access. Let the hardware driver know which control bits are set and inform it about a change of the control lines. Let the hardware driver write out the command and address bytes directly. This gives a peformance advantage for address bus controlled chips and simplifies the quirks in the hardware drivers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] NAND modularize ECCThomas Gleixner
First step of modularizing ECC support. - Move ECC related functionality into a seperate embedded data structure - Get rid of the hardware dependend constants to simplify new ECC models Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-14[MTD] Fix module refcounting in NAND board drivers.David Woodhouse
The _board_ driver needs to be mtd->owner, and it in turn pins the nand.ko module. Fix them all to actually do that, and fix nand.ko not to overwrite it -- and also to check that the caller sets it, if the caller is a module. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-13[MTD NAND] Indent all of drivers/mtd/nand/*.c.David Woodhouse
It was just too painful to deal with. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-07[MTD] NAND: Clean up trailing white spacesThomas Gleixner
