CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
If plat_nand loads and the platform_data is not properly set it will segfault.
Signed-off-by: John Crispin <blogic@openwrt.org>
Lantiq SoCs have a External Bus Unit (EBU) that is used to attach MTD media.
As we need to co-exist with PCI on the same bus, certain swapping settings must
be applied. Similar to the NOR map driver we need to apply a fix to make NAND
work. The easiest way is to use byte reads.
This patch sets the of_match_table field inside plat_nand's platform_driver.
We also add a struct mtd_part_parser_data pointer to make sure of_part parsing
works.
If an arch wants to support plat_nand via DT it needs to setup the
platform_nand_data and hook it into the platform_device.
Use cmdlinepart as the default partition parser and allow the arch setup code
to still use their own partition parsers.
The first 3 arguments of 'mtd_device_parse_register()' are pointers,
but many callers pass '0' instead of 'NULL'. Fix this globally. Thanks
to coccinelle for making it easy to do with the following semantic patch:
expression mtd, types, parser_data, parts, nr_parts;
-mtd_device_parse_register(mtd, 0, parser_data, parts, nr_parts)
+mtd_device_parse_register(mtd, NULL, parser_data, parts, nr_parts)
-mtd_device_parse_register(mtd, types, 0, parts, nr_parts)
+mtd_device_parse_register(mtd, types, NULL, parts, nr_parts)
-mtd_device_parse_register(mtd, types, parser_data, 0, nr_parts)
+mtd_device_parse_register(mtd, types, parser_data, NULL, nr_parts)
This patch converts the drivers in drivers/mtd/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Acked by: Haojian Zhuang <haojian.zhuang@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
Replace custom invocations of parse_mtd_partitions and mtd_device_register
with common mtd_device_parse_register call. This would bring: standard
handling of all errors, fallback to default partitions, etc.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Drop now unused set_parts from struct platform_nand_data. Also, while we are
at it, drop long unused priv field from platform_nand_data.
This patch works with the following three flags from two headers (nand.h
and bbm.h):
(1) NAND_USE_FLASH_BBT (nand.h)
(2) NAND_USE_FLASH_BBT_NO_OOB (nand.h)
(3) NAND_BBT_NO_OOB (bbm.h)
These flags are all related and interdependent, yet they were in
different headers. Flag (2) is simply the combination of (1) and (3) and
can be eliminated.
This patch accomplishes the following:
* eliminate NAND_USE_FLASH_BBT_NO_OOB (i.e., flag (2))
* move NAND_USE_FLASH_BBT (i.e., flag (1)) to bbm.h
It's important to note that because (1) and (3) are now both found in
bbm.h, they should NOT be used in the "nand_chip.options" field.
I removed a small section from the mtdnand DocBook because it referes to
NAND_USE_FLASH_BBT in nand.h, which has been moved to bbm.h.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS
preprocessor conditionals as partitioning is always available.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
This patch corrects a problem where gen_nand driver assumed there can be only
one chip and ignored the pdata->chip.nr_chips value.
Add a request_mem_region() before doing the ioremap(). Also, use the
resource_size macro instead of doing the end - start + 1 calc by hand.
Add optional callback to allow platform to initialize partitions.
Static partitions on a nand device could vary depending on the size of the
device. This patch allows an optional platform callback to be used to
setup this partition information at runtime.
Scan order is:
1) chip.part_probe_types
2) chip.set_parts
3) chip.partitions
4) full mtd device (fallback for no partitions)
Some of the existing nand drivers could possibly be replaced by the
plat_nand driver by using this patch. These include autcpu12.c and
ts7250.c drivers.
Add optional probe and remove callbacks to the plat_nand driver.
Some platforms may require additional setup, such as configuring the
memory controller, before the nand device can be accessed. This patch
provides an optional callback to handle this setup as well as a callback
to teardown the setup.
Tested-by: Alexander Clouter <alex@digriz.org.uk>
This patch adds (write|read)_buf callbacks to plat_nand.
The NAND on the TS-7800 provisioned by the FPGA allows readw() and
readl() to be used which gives a 2.5x speed up. To be able to use this
from the plat_nand driver a hook for read_buf (and also write_buf whilst
we are in there) need to be made available. This patch adds the hook.
Signed-off-by: Alexander Clouter <alex@digriz.org.uk>
With CONFIG_HOTPLUG=n, the following eror occurred during link:
local symbol 0: discarded in section `.devexit.text' from
drivers/built-in.o
It was caused by improper section reference. The __devexit_p()
should be added to the .remove function.
A pointer to plat_nand_probe is passed to the core via
platform_driver_register and so the function must not disappear when the
.init sections are discarded. Otherwise (if also having HOTPLUG=y)
unbinding and binding a device to the driver via sysfs will result in an
oops as does a device being registered late.
An alternative to this patch is using platform_driver_probe instead of
platform_driver_register plus removing the pointer to the probe function
from the struct platform_driver.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Hamish Moffatt <hamish@cloud.net.au>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Vitaly Wool <vitalywool@gmail.com>
CC: David Woodhouse <dwmw2@infradead.org>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This patch sets mtd->name to the platform bus ID in the plat_nand
driver, so that you can specify partitions readily with mtdparts=.
Currently it relies on nand_base filling in the name from the device,
which results in names like "NAND 256MiB 3,3V 8-bit", that you can't
use with cmdlineparts.
Signed-off-by: Hamish Moffatt <hamish@cloud.net.au>
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable MTD NAND
platform drivers, to re-enable auto loading.
NOTE: at91_nand for some reason disallows modular builds. I'm assuming that's
just an oversight that will be fixed.
[dbrownell@users.sourceforge.net: minor fix]
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
With CONFIG_MTD_PARTITIONS not set, got this:
drivers/mtd/nand/plat_nand.c:113: warning: unused variable 'pdata'
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
This patch adds support for generic platform NAND driver.
Updated after tglx's review/discussion in IRC #mtd channel.
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
