path: root/drivers/mtd/maps/physmap.c
2006-11-28[MTD] replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Yan Burman <yan_952@hotmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-28[MTD] Fix printk format warning in physmap. (resources again)Randy Dunlap
Fix printk format warning: drivers/mtd/maps/physmap.c:93: warning: long long unsigned int format, long unsigned int arg (arg 2) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-10-10[PATCH] mtd: remove several bogus casts to void * in iounmap() argumentAl Viro
2006-09-22[MTD] physmap: add power management supportLennert Buytenhek
Implement PM handling for physmap. Idea from Steven Scholz, patch by David Anders. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-27[MTD] Fix off-by-one error in physmap.cSascha Hauer
This patch fixes a simple off-by-one error in the mtd physmap driver. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-09[MTD] Prepare physmap for 64-bit-resourcesAndrew Morton
Fallout from the incoming 64-bit-resource stuff: drivers/mtd/maps/physmap.c: In function 'physmap_flash_probe': drivers/mtd/maps/physmap.c:94: warning: format '%.8lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' drivers/mtd/maps/physmap.c:94: warning: format '%.8lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' Cc: Vivek Goyal <vgoyal@in.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-14[MTD] Remove gratuitous inclusion of ARM-only header from physmap.cDavid Woodhouse
The physmap platform driver conversion added to physmap.c an include of asm/mach/flash.h which is 1) ARM-specific; and 2) isn't actually necessary. Remove it. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-07[MTD] Convert physmap to platform driverLennert Buytenhek
After dwmw2 let me know it ought to be done, I rewrote the physmap map driver to be a platform driver. I know zilch about the driver model, so I probably botched it in some way, but I've done some tests on an ixp23xx board which uses physmap, and it all seems to work. In order to not break existing physmap users, I've added some compat code that will instantiate a platform device iff CONFIG_MTD_PHYSMAP_LEN is defined and != 0. Also, I've changed the default value for CONFIG_MTD_PHYSMAP_LEN to zero, so that people who inadvertently compile in physmap (or new, platform-style, users of physmap) don't get burned. This works pretty well -- the new physmap driver is a drop-in replacement for the old one, and works on said ixp23xx board without any code changes needed. (This should hold as long as users don't touch 'physmap_map' directly.) Once all physmap users have been converted to instantiate their own platform devices, the compat code can go. (Or we decide that we can change all the in-tree users at the same time, and never merge the compat code.) Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-29[MTD] Make functions static, include header files with prototypesAdrian Bunk
This patch contains the following possible cleanups: - every file should #include the headers containing the prototypes for it's global functions - make needlessly global functions static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-07[MTD] maps: Clean up trailing white spacesThomas Gleixner
