path: root/drivers/mtd/maps/ixp2000.c
2013-04-05mtd: remove the ixp2000 map driverArtem Bityutskiy
This driver depends on CONFIG_IXP2000 which is not defined anywhere, which means this driver is dead. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-27mtd: do not use plain 0 as NULLArtem Bityutskiy
The first 3 arguments of 'mtd_device_parse_register()' are pointers, but many callers pass '0' instead of 'NULL'. Fix this globally. Thanks to coccinelle for making it easy to do with the following semantic patch: @@ expression mtd, types, parser_data, parts, nr_parts; @@ ( -mtd_device_parse_register(mtd, 0, parser_data, parts, nr_parts) +mtd_device_parse_register(mtd, NULL, parser_data, parts, nr_parts) | -mtd_device_parse_register(mtd, types, 0, parts, nr_parts) +mtd_device_parse_register(mtd, types, NULL, parts, nr_parts) | -mtd_device_parse_register(mtd, types, parser_data, 0, nr_parts) +mtd_device_parse_register(mtd, types, parser_data, NULL, nr_parts) ) Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09mtd: convert drivers/mtd/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/mtd/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-09-11mtd: ixp2000.c: use mtd_device_parse_registerDmitry Eremin-Solenikov
Replace custom invocations of parse_mtd_partitions and mtd_device_register with common mtd_device_parse_register call. This would bring: standard handling of all errors, fallback to default partitions, etc. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-25mtd: ixp: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-13drivers/mtd: Use kzallocJulia Lawall
Use kzalloc rather than the combination of kmalloc and memset. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,size,flags; statement S; @@ -x = kmalloc(size,flags); +x = kzalloc(size,flags); if (x == NULL) S -memset(x, 0, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-21trivial: fix typo "to to" in multiple filesAnand Gadiyar
Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-06mtd: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
CC: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-27[ARM] remove memzero()Russell King
As suggested by Andrew Morton, remove memzero() - it's not supported on other architectures so use of it is a potential build breaking bug. Since the compiler optimizes memset(x,0,n) to __memzero() perfectly well, we don't miss out on the underlying benefits of memzero(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] [MAPS] fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable MTD mapping platform drivers, to re-enable auto loading. NOTE oddness with physmap ... it's a legacy driver in some configs, which means it can't always support hotplugging. (Not that most of these mapping drivers would often be used as modules...) [dbrownell@users.sourceforge.net: bugfix, more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-27[MTD] Remove unused 'nr_banks' variable from ixp2000 map driverLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-17[DRIVER MODEL] Fix merge clashes with ARM ixp2000 / ixp4xx platformsRussell King
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/tglx/mtd-2.6Linus Torvalds
Some manual fixups for clashing kfree() cleanups etc.
2005-11-07[PATCH] kfree cleanup: drivers/mtdJesper Juhl
This is the drivers/mtd part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/mtd/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Joern Engel <joern@wohnheim.fh-wedel.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] maps: Clean up trailing white spacesThomas Gleixner
2005-11-07[MTD] maps ixp2000: fix compile warnings in ixp2000 map driverLennert Buytenhek
Fix two compile warnings that occur because of treating two 'unsigned long's as 'void *'s. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-29[ARM] Don't include mach-types.h unnecessarilyRussell King
It's pointless to include mach-types.h if you're not going to use anything from it. These references were removed as a result of: grep -lr 'asm/mach-types\.h' . | xargs grep -L 'machine_is_\|MACH_TYPE_\|MACHINE_START\|machine_type' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-05-23[MTD] ixp2000: Remove port setting codeLennert Buytenhek
Setting the slowport to 8-bit mode is something that ought to be done in the IXP2000 generic code, not in the MTD map driver. See the description for ARM patch 2493/1 for an explanation. http://www.arm.linux.org.uk/developer/patches/viewpatch.php?id=2493/1 Now that 2493/1 has been accepted and will be upstream soon, this doesn't need to be done in the map driver anymore. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
