path: root/drivers/mtd/maps/h720x-flash.c
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-03-31[PATCH] drivers/mtd: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] maps: Clean up trailing white spacesThomas Gleixner
