path: root/drivers/mtd/inftlmount.c
2012-01-09mtd: introduce mtd_block_markbad interfaceArtem Bityutskiy
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09mtd: introduce mtd_block_isbad interfaceArtem Bityutskiy
2012-01-09mtd: introduce mtd_read interfaceArtem Bityutskiy
2012-01-09mtd: introduce mtd_erase interfaceArtem Bityutskiy
This patch is part of a patch-set which changes the MTD interface from 'mtd->func()' form to 'mtd_func()' form. We need this because we want to add common code to to all drivers in the mtd core level, which is impossible with the current interface when MTD clients call driver functions like 'read()' or 'write()' directly. At this point we just introduce a new inline wrapper function, but later some of them are expected to gain more code. E.g., the input parameters check should be moved to the wrappers rather than be duplicated at many drivers. This particular patch introduced the 'mtd_erase()' interface. The following patches add all the other interfaces one by one. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-09-11mtd: spelling fixesBrian Norris
Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
2011-09-11mtd: cleanup last uses of MTD_DEBUG config macrosBrian Norris
Some messages that were tied to CONFIG_MTD_DEBUG_VERBOSE can now simply be enabled using dynamic debugging features, if necessary. There's no need for special debugging functions here. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
2011-09-11mtd: cleanup style on pr_debug messagesBrian Norris
2011-09-11mtd: replace DEBUG() with pr_debug()Brian Norris
Start moving away from the MTD_DEBUG_LEVEL messages. The dynamic debugging feature is a generic kernel feature that provides more flexibility. (See Documentation/dynamic-debug-howto.txt) Also fix some punctuation, indentation, and capitalization that went along with the affected lines. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
2010-08-08mtd: Remove obsolete <mtd/compatmac.h> includeDavid Woodhouse
2010-08-08mtd: Update copyright noticesDavid Woodhouse
2010-02-26mtd: inftl: misplaced parenthesis in find_boot_recordRoel Kluin
The parenthesis was misplaced, upon error a one was shown. [dwmw2: Fix the code not to do the assignment within the if() statement] Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-20[MTD] we don't need no misc devicesDavid Brownell
Remove <linux/miscdevice.h> from various drivers which don't actually use any of its contents. There are still a number of these left in arch-specific bits of the tree. (Found by diffing results of "grep -rl" for linux/miscdevice.h and for misc_register, examining the differences, and verifying removals with a build test.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-12-10[MTD] update internal API to support 64-bit device sizeAdrian Hunter
MTD internal API presently uses 32-bit values to represent device size. This patch updates them to 64-bits but leaves the external API unchanged. Extending the external API is a separate issue for several reasons. First, no one needs it at the moment. Secondly, whether the implementation is done with IOCTLs, sysfs or both is still debated. Thirdly external API changes require the internal API to be accepted first. Note that although the MTD API will be able to support 64-bit device sizes, existing drivers do not and are not required to do so, although NAND base has been updated. In general, changing from 32-bit to 64-bit values cause little or no changes to the majority of the code with the following exceptions: - printk message formats - division and modulus of 64-bit values - NAND base support - 32-bit local variables used by mtdpart and mtdconcat - naughtily assuming one structure maps to another in MEMERASE ioctl Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] proper prototypes for inftl_{read,write}_oob()Adrian Bunk
This patch adds proper prototypes for inftl_{read,write}_oob() in include/linux/mtd/inftl.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-08-01[MTD] drivers/mtd/inftlmount.c: kmalloc + memset conversion to kcallocMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-29[MTD] Rework the out of band handling completelyThomas Gleixner
Hopefully the last iteration on this! The handling of out of band data on NAND was accompanied by tons of fruitless discussions and halfarsed patches to make it work for a particular problem. Sufficiently annoyed by I all those "I know it better" mails and the resonable amount of discarded "it solves my problem" patches, I finally decided to go for the big rework. After removing the _ecc variants of mtd read/write functions the solution to satisfy the various requirements was to refactor the read/write _oob functions in mtd. The major change is that read/write_oob now takes a pointer to an operation descriptor structure "struct mtd_oob_ops".instead of having a function with at least seven arguments. read/write_oob which should probably renamed to a more descriptive name, can do the following tasks: - read/write out of band data - read/write data content and out of band data - read/write raw data content and out of band data (ecc disabled) struct mtd_oob_ops has a mode field, which determines the oob handling mode. Aside of the MTD_OOB_RAW mode, which is intended to be especially for diagnostic purposes and some internal functions e.g. bad block table creation, the other two modes are for mtd clients: MTD_OOB_PLACE puts/gets the given oob data exactly to/from the place which is described by the ooboffs and ooblen fields of the mtd_oob_ops strcuture. It's up to the caller to make sure that the byte positions are not used by the ECC placement algorithms. MTD_OOB_AUTO puts/gets the given oob data automaticaly to/from the places in the out of band area which are described by the oobfree tuples in the ecclayout data structre which is associated to the devicee. The decision whether data plus oob or oob only handling is done depends on the setting of the datbuf member of the data structure. When datbuf == NULL then the internal read/write_oob functions are selected, otherwise the read/write data routines are invoked. Tested on a few platforms with all variants. Please be aware of possible regressions for your particular device / application scenario Disclaimer: Any whining will be ignored from those who just contributed "hot air blurb" and never sat down to tackle the underlying problem of the mess in the NAND driver grown over time and the big chunk of work to fix up the existing users. The problem was not the holiness of the existing MTD interfaces. The problems was the lack of time to go for the big overhaul. It's easy to add more mess to the existing one, but it takes alot of effort to go for a real solution. Improvements and bugfixes are welcome! Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] Remove silly MTD_WRITE/READ macrosThomas Gleixner
Most of those macros are unused and the used ones just obfuscate the code. Remove them and fixup all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Remove read/write _ecc variantsThomas Gleixner
MTD clients are agnostic of FLASH which needs ECC suppport. Remove the functions and fixup the callers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-07Merge master.kernel.org:/pub/scm/linux/kernel/git/tglx/mtd-2.6Linus Torvalds
Some manual fixups for clashing kfree() cleanups etc.
2005-11-07[PATCH] check for failed kmalloc in inftlmount.cGreg Ungerer
The INFTL mount code contains a kmalloc() followed by a memset() without handling a possible memory allocation failure. Signed-off-by: <panagiotis.issaris@mech.kuleuven.ac.be> Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[MTD] core: Clean up trailing white spacesThomas Gleixner
2005-11-06[MTD] Missing check on kmalloc return in INFTL mount.David Woodhouse
Signed-off-by: Youssef Hmamouche <hyoussef@gmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
