path: root/drivers/mtd/ftl.c
2008-12-10[MTD] Remove strange u_int32_t types from FTLDavid Woodhouse
2008-10-09Support 'discard sectors' operation.David Woodhouse
We can benefit from knowing that the file system no longer cares about the contents of certain sectors, by throwing them away immediately and then never having to garbage collect them, and using the extra free space to make our operations more efficient. Do so. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-25Merge branch 'linux-next' of git://git.infradead.org/~dedekind/ubi-2.6David Woodhouse
2008-06-24pcmcia: remove unused bulkmem.hMagnus Damm
The code in include/pcmcia/bulkmem.h was only kept for compatibility reasons. Therefore, move the remaining region_info_t definition to ds.h [linux@dominikbrodowski.net: do not modify the IOCTL, move definition to ds.h, and update changelog] Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[MTD] ftl.c: make code staticAdrian Bunk
This patch makes the following needlessly global code static: - ftl_freepart() - struct ftl_tr Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-28[MTD] replace kmalloc+memset with kzallocBurman Yan
Signed-off-by: Yan Burman <yan_952@hotmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-11-28[MTD] Allow variable block sizes in mtd_blkdevsRichard Purdie
Currently, mtd_blkdevs enforces a block size of 512, even if the drivers can seemingly request a different size. This patch fixes mtd_blkdevs so block sizes other than 512 work correctly. Signed-off-by: Richard Purdie <rpurdie@openedhand.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-29[MTD] Make functions static, include header files with prototypesAdrian Bunk
This patch contains the following possible cleanups: - every file should #include the headers containing the prototypes for it's global functions - make needlessly global functions static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-07[MTD] core: Clean up trailing white spacesThomas Gleixner
2005-09-10[PATCH] vfree and kfree cleanup in drivers/Jesper Juhl
This patch does a full cleanup of 'NULL checks before vfree', and a partial cleanup of calls to kfree for all of drivers/ - the kfree bit is partial in that I only did the files that also had vfree calls in them. The patch also gets rid of some redundant (void *) casts of pointers being passed to [vk]free, and a some tiny whitespace corrections also crept in. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-23[MTD] FTL Fix missing pointer assignmentHerbert Valerio Riedel
For the case that mtd partitions are enabled it would cause a 0-pointer dereferencing in mtdpart.c:mtd_erase_callback() Signed-off-by: Herbert Valerio Riedel <hvr@inso.tuwien.ac.at> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
