path: root/drivers/mmc
2006-10-24[PATCH] missing includes of io.hAl Viro
2006-10-10[PATCH] passing pointer to setup_timer() should be via unsigned longAl Viro
2006-10-09[PATCH] tifm __iomem annotations, NULL noise removalAl Viro
2006-10-06[PATCH] mmc: multi sector write transfersPierre Ossman
SD cards extend the protocol by allowing the host to query a card how many blocks were successfully stored on the medium. This allows us to safely write chunks of blocks at once. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04[PATCH] mmc: properly use the new multi block-write error handlingPierre Ossman
Use the new multi block-write error reporting flag and properly tell the block layer how much data was transferred before the error. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] mmc: use own work queuePierre Ossman
The MMC layer uses the standard work queue for doing card detection. As this queue is shared with other crucial subsystems, the effects of a long (and perhaps buggy) detection can cause the system to be unusable. E.g. the keyboard stops working while the detection routine is running. The solution is to add a specific mmc work queue to run the detection code in. This is similar to how other subsystems handle detection (a full kernel thread is the most common theme). Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] mmc: avoid some resets without cardPierre Ossman
Some Ricoh controllers only respect a full reset when there is no card in the slot. As we wait for the reset to complete, we must avoid even requesting those resets on the buggy controllers. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] mmc: fix MMIO vs memory races in sdhciPierre Ossman
Sprinkle some mmiowb() where needed (writeX() before unlock()). Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] mmc: driver for TI FlashMedia card reader - Kconfig/MakefileAlex Dubov
Signed-off-by: Alex Dubov <oakad@yahoo.com> Cc: Daniel Qarras <dqarras@yahoo.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] mmc: driver for TI FlashMedia card reader - sourceAlex Dubov
Driver for TI Flash Media card reader. At present, only MMC/SD cards are supported. [akpm@osdl.org: cleanups, build fixes] Signed-off-by: Alex Dubov <oakad@yahoo.com> Cc: Daniel Qarras <dqarras@yahoo.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] mmc (mainly): add "or later" clause to licence statement.Pierre Ossman
Clarify my (Pierre's) position on which GPL versions apply. The patch only touches the source files where I am the only major author. The people who have made the minor commits to the files have been contacted and have no issues with this change. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] Split struct request ->flags into two partsJens Axboe
Right now ->flags is a bit of a mess: some are request types, and others are just modifiers. Clean this up by splitting it into ->cmd_type and ->cmd_flags. This allows introduction of generic Linux block message types, useful for sending generic Linux commands to block devices. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-28Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (130 commits) [ARM] 3856/1: Add clocksource for Intel IXP4xx platforms [ARM] 3855/1: Add generic time support [ARM] 3873/1: S3C24XX: Add irq_chip names [ARM] 3872/1: S3C24XX: Apply consistant tabbing to irq_chips [ARM] 3871/1: S3C24XX: Fix ordering of EINT4..23 [ARM] nommu: confirms the CR_V bit in nommu mode [ARM] nommu: abort handler fixup for !CPU_CP15_MMU cores. [ARM] 3870/1: AT91: Start removing static memory mappings [ARM] 3869/1: AT91: NAND support for DK and KB9202 boards [ARM] 3868/1: AT91 hardware header update [ARM] 3867/1: AT91 GPIO update [ARM] 3866/1: AT91 clock update [ARM] 3865/1: AT91RM9200 header updates [ARM] 3862/2: S3C2410 - add basic power management support for AML M5900 series [ARM] kthread: switch arch/arm/kernel/apm.c [ARM] Off-by-one in arch/arm/common/icst* [ARM] 3864/1: Refactore sharpsl_pm [ARM] 3863/1: Add Locomo SPI Device [ARM] 3847/2: Convert LOMOMO to use struct device for GPIOs [ARM] Use CPU_CACHE_* where possible in asm/cacheflush.h ...
2006-09-28Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-mmc: [MMC] Don't check READY_FOR_DATA when reading [MMC] MMC_CAP_BYTEBLOCK flag for non-log2 block sizes capable hosts [MMC] Add multi block-write capability [MMC] Remove data->blksz_bits member [MMC] Convert mmci to use data->blksz rather than data->blksz_bits
2006-09-28[ARM] 3865/1: AT91RM9200 header updatesAndrew Victor
This is more preparation for adding support for the new Atmel AT91SAM9 processors. Changes include: - Replace AT91_BASE_* with AT91RM9200_BASE_* - Replace AT91_ID_* with AT91RM9200_ID_* - ROM, SRAM and UHP address definitions moved to at91rm9200.h. - The raw AT91_P[ABCD]_* definitions are now depreciated in favour of the GPIO API. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-26[PATCH] Alchemy: Delete unused pt_regs * argument from au1xxx_dbdma_chan_allocRalf Baechle
The third argument of au1xxx_dbdma_chan_alloc's callback function is not used anywhere. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-24[MMC] Don't check READY_FOR_DATA when readingRussell King
There's no point checking to see if the card is ready to accept data when we're reading from it - sending the command only wastes precious bus bandwidth. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-24[MMC] MMC_CAP_BYTEBLOCK flag for non-log2 block sizes capable hostsRussell King
Some MMC hosts can only handle log2 block sizes. Unfortunately, the MMC password support needs to be able to send non-log2 block sizes. Provide a capability so that the MMC password support can decide whether it should use this support or not. The unfortunate side effect of this host limitation is that any MMC card protected by a password which is not a log2 block size can not be accessed on a host which only allows a log2 block size. This change just adds the flag. The MMC password support code needs updating to use it (if and when it is finally submitted.) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-16[MMC] Add multi block-write capabilityRussell King
Add a capability flag for drivers to set when they can perform multi- block transfers to cards _and_ correctly report the number of bytes transferred should an error occur. The last point is very important - if a driver reports more bytes than were actually accepted by the card and an error occurs, there is the possibility for data loss. Pierre Ossman provided the patch for wbsd and sdhci. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-16[MMC] Remove data->blksz_bits memberRussell King
data->blksz_bits is unused now - remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-16[MMC] Convert mmci to use data->blksz rather than data->blksz_bitsRussell King
2006-09-07[MMC] Always use a sector size of 512 bytesPierre Ossman
Both MMC and SD specifications specify (although a bit unclearly in the MMC case) that a sector size of 512 bytes must always be supported by the card. Cards can report larger "native" size than this, and cards >= 2 GB even must do so. Most other readers use 512 bytes even for these cards. We should do the same to be compatible. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-07[MMC] Cleanup 385e3227d4d83ab13d7767c4bb3593b0256bf246Russell King
Rather than having two places which independently calculate the timeout for data transfers, make it a library function instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Pierre Ossman <drzeus@drzeus.cx>
2006-09-07[ARM] 3751/1: i.MX/MX1 SD/MMC use 512 bytes request for SCR readPavel Pisa
Patch from Pavel Pisa This is another approach to SDHC deficiency workaround. It seems, that previous solution based on 16 bytes (FIFO length size) read is still timing sensitive on genirq and fully preemptive kernels. The new solution is backuped by M9328 UM statement, that only 512 byte block are working properly and by 2.4.26 FreeScale's SDHC code. Jay Monkman reports significant improvement on code based on this driver after applying this change on MX21 as well. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-07[MMC] Fix SD timeout calculationPierre Ossman
Secure Digital cards use a different algorithm to calculate the timeout for data transfers. Using the MMC one works often, but not always. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-07[MMC] Another stray 'io' referencePierre Ossman
Another misuse of the global 'io' variable instead of the local 'base'. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-06[MMC] Fix base address configuration in wbsdPierre Ossman
There were some confusion about base I/O variables in the wbsd driver. Seems like things have been working on shear luck so far. The global 'io' variable (used when manually configuring the resources) was used instead of the local 'base' variable. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-06[ARM] 3744/1: MMC: mmcqd gets stuck when block queue is pluggedJuha [êölä
Patch from Juha [êölä When the block queue is plugged, mq->req must be set to NULL. Otherwise mq->req might be left non-NULL, even though mmcqd is not processing a request, thus preventing the MMC queue thread from being woken up when new requests do arrive. Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-13[MMC] Change SDHCI version error to a warningPierre Ossman
O2 Micro's controllers have a larger specification version value and are therefore denied by the driver. When bypassing this check they seem to work fine. This patch makes the code a bit more forgiving by changing the error to a warning. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-13[MMC] Fix incorrect register accessPierre Ossman
There was a writel() being used on a 16-bit register. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-03[PATCH] lockdep: annotate on-stack completions, mmcIngo Molnar
lockdep needs to have the waitqueue lock initialized for on-stack waitqueues implicitly initialized by DECLARE_COMPLETION(). Annotate mmc_wait_for_req()'s on-stack completion accordingly. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-mmc: [MMC] sdhci: remove duplicate error message [MMC] sdhci: force DMA on some controllers [MMC] sdhci: quirk for broken reset [MMC] sdhci: Add SDHCI controller ids
2006-07-02Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (44 commits) [ARM] 3541/2: workaround for PXA27x erratum E7 [ARM] nommu: provide a way for correct control register value selection [ARM] 3705/1: add supersection support to ioremap() [ARM] 3707/1: iwmmxt: use the generic thread notifier infrastructure [ARM] 3706/2: ep93xx: add cirrus logic edb9315a support [ARM] 3704/1: format IOP Kconfig with tabs, create more consistency [ARM] 3703/1: Add help description for ARCH_EP80219 [ARM] 3678/1: MMC: Make OMAP MMC work [ARM] 3677/1: OMAP: Update H2 defconfig [ARM] 3676/1: ARM: OMAP: Fix dmtimers and timer32k to compile on OMAP1 [ARM] Add section support to ioremap [ARM] Fix sa11x0 SDRAM selection [ARM] Set bit 4 on section mappings correctly depending on CPU [ARM] 3666/1: TRIZEPS4 [1/5] core ARM: OMAP: Multiplexing for 24xx GPMC wait pin monitoring ARM: OMAP: Fix SRAM to use MT_MEMORY instead of MT_DEVICE ARM: OMAP: Update dmtimers ARM: OMAP: Make clock variables static ARM: OMAP: Fix GPMC compilation when DEBUG is defined ARM: OMAP: Mux updates for external DMA and GPIO ...
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-mmc: [MMC] sdhci: version bump sdhci [MMC] sdhci: support controller specific quirks [MMC] sdhci: more DMA capabilities tests [MMC] sdhci: reset sdhci controller early [MMC] sdhci: check controller version [MMC] sdhci: check only relevant inhibit bits [MMC] sdhci: Test for invalid block size [MMC] sdhci: Avoid sdhci DMA boundaries [MMC] Fix sdhci PIO routines [MMC] sdhci: fix interrupt handling [MMC] sdhci: correct register order [MMC] sdhci: proper timeout handling [MMC] sdhci: fix sdhci reset timeout [MMC] sdhci: fix timeout loops in sdhci [MMC] sdhci: support for multiple voltages [MMC] sdhci: print device id [MMC] sdhci: check SDHCI base clock
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[MMC] sdhci: remove duplicate error messagePierre Ossman
When there is remaining blocks untransferred, we get two error messages saying almost the same thing. Make sure at most one is shown. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: force DMA on some controllersPierre Ossman
Some controllers incorrectly report that the cannot do DMA. Forcefully enable it for those that we know it works fine on. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: quirk for broken resetPierre Ossman
Some controllers fail to complete a reset unless you touch the clock register first. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: version bump sdhciPierre Ossman
New version number for sdhci driver. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: support controller specific quirksPierre Ossman
As some specific controllers will have bugs, we need a way to map special behaviour to certain hardware. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: more DMA capabilities testsPierre Ossman
Properly test for controller interface to see if it's DMA capable. As many controllers are misconfigured in this regard, also add debug parameters to force DMA support either way. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: reset sdhci controller earlyPierre Ossman
The specification states that the capabilities register might need a reset to get correct values after boot up. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: check controller versionPierre Ossman
Check the interface version of the controller and bail out if it's an unknown version. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: check only relevant inhibit bitsPierre Ossman
Conform to the sdhci specification as to which inhibit bits should be checked at different times. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: Test for invalid block sizePierre Ossman
The controller has an upper limit on the block size. Make sure we do not cross it. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: Avoid sdhci DMA boundariesPierre Ossman
The sdhci controllers will issue an interrupt when a configurable number of bytes have been transfered using DMA. The purpose is to handle multiple, scattered memory pages. Unfortunately, it requires that all transfers are completely aligned to memory pages, which we cannot guarantee. So we just disable the function. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] Fix sdhci PIO routinesPierre Ossman
The sdhci controllers operate with blocks, not bytes. The PIO routines must therefore make sure that the minimum unit transfered is a complete block. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[MMC] sdhci: fix interrupt handlingPierre Ossman
The specification says that interrupts should be cleared before the source is removed. We should also not set unknown bits. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
