HDIO_GETGEO is implemented in most block drivers, and all of them have to
duplicate the code to copy the structure to userspace, as well as getting
the start sector. This patch moves that to common code [1] and adds a
->getgeo method to fill out the raw kernel hd_geometry structure. For many
drivers this means ->ioctl can go away now.
[1] the s390 block drivers are odd in this respect. xpram sets ->start
to 4 always which seems more than odd, and the dasd driver shifts
the start offset around, probably because of it's non-standard
sector size.
Cc: Jens Axboe <axboe@suse.de>
Cc: <mike.miller@hp.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo Giarrusso <blaisorblade@yahoo.it>
Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Markus Lidel <Markus.Lidel@shadowconnect.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
This is needs to be visible to other architectures using the AMBA
bus and peripherals.
Since the ARM AMBA bus is used on MIPS as well as ARM, we need
to make the bus available for other architectures to use. Move
the AMBA include files from include/asm-arm/hardware/ to
include/linux/amba/
add @uptodate argument to end_that_request_last() and @error
to rq_end_io_fn(). there's no generic way to pass error code
to request completion function, making generic error handling
of non-fs request difficult (rq->errors is driver-specific and
each driver uses it differently). this patch adds @uptodate
to end_that_request_last() and @error to rq_end_io_fn().
for fs requests, this doesn't really matter, so just using the
same uptodate argument used in the last call to
end_that_request_first() should suffice. imho, this can also
help the generic command-carrying request jens is working on.
Signed-off-by: tejun heo <htejun@gmail.com>
Signed-Off-By: Jens Axboe <axboe@suse.de>
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Leave the overloaded "hotplug" word to susbsystems which are handling
real devices. The driver core does not "plug" anything, it just exports
the state to userspace and generates events.
Signed-off-by: Kay Sievers <kay.sievers@suse.de>
Since MMCI currently uses PIO to read data, we have to take steps
to ensure data cache coherency on aliasing CPU caches. Add the
necessary flush_dcache_page() calls.
platform_device_register_simple() is going away, switch to
using platfrom_device_alloc() + platform_device_add(). Also
make sure that wbsd_driver gets unregistered when wbsd_init
fails.
Acked-by: Pierre Ossman <drzeus@drzeus.cx>
Select a block size for IO based on the read and write block size
combinations, and whether the card supports partial block reads
and/or partial block writes.
If we are able to satisfy block reads but not block writes, mark
the device read only.
It seems that clk_use() and clk_unuse() are additional complexity
which isn't required anymore. Remove them from the clock framework
to avoid the additional confusion which they cause, and update all
ARM machine types except for OMAP.
We were passing set_capacity() the capacity we calculated in terms of
the number of blocks on the card, which happened to be the right units
for 512-byte block cards. However, with 1024-byte block cards, we
end up setting the capacity to half the number of blocks. Fix this
by shifting by the appropriate amount.
Thanks to Todd Blumer for pointing this out.
Use get_capacity() to report the card capacity, rather than
recalculating it from the CSD information.
Finally, use our chosen IO block size for the SET_BLOCKLEN command
rather than the CSD read block size. Currently these are equivalent,
but will not be in the future.
It seems that people get confused about what is happening in
mmc_power_up(). Add a comment to make it clear why we have
a two stage process.
The routine reading the SCR wasn't paying proper attention to the
error codes returned from the driver.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
A review against MMC/SD specifications found some errors in the current
implementation.
New kernel, new patches, new version.
'cause I'm in it for the chicks. ;)
wbsd_*_remove() is declared as __devexit but __devexit_p isn't used
when taking their addresses.
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Patch from Uli Luckas
This is a simplification of patch 3116/1 as sugested by Russell King.
Signed-off-by: Uli Luckas <u.luckas@road-gmbh.de>
This is the remaining misc drivers/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in misc files in
drivers/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Aristeu Sergio Rozanski Filho <aris@cathedrallabs.org>
Acked-by: Roland Dreier <rolandd@cisco.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Len Brown <len.brown@intel.com>
Acked-by: "Antonino A. Daplas" <adaplas@gmail.com>
The printks that aren't for debugging should use the name of the controller,
not the driver name. Multiple MMC controllers aren't that common today, but
this is the right way to do things.
There is a broken if clause in the wbsd driver that can cause the
driver to try and configure the chip even though none is found. This
results in i/o on invalid ports.
Manual #include fixups for clashes - there may be some unnecessary
If a card doesn't support the "write block" command class then
any attempts to open the device should reflect this by denying
write access.
it should work on the Au1100 as well. Updated defconfig to include driver.
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
Proper handling of suspend/resume in the wbsd driver.
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
The wbsd driver's card detection routing is a bit of a mess. This
patch cleans up the routine and makes it a bit more comprihensible.
Remove timer that was left from earlier cleanup.
Clean out trailing whitespace caused by not-so-great editor since it
generates a lot of problems with editors configured to automatically
strip whitespace.
Convert wbsd to use the new delay functionality in mmc_detect_change()
rather than implementing its own timer.
Allow PXA platforms to pass an appropriate delay value to the
PXA MCI driver for delaying detection changes.
Signed-Off-By: Richard Purdie <rpurdie@rpsys.net>
Change mmc_detect_change() to take a delay argument such that
the detection of card insertions and removals can be delayed
according to the requirements of the host driver or platform.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Only show the scr file in sysfs for SD cards. Previously this was present
for all cards but had a contents of 0 for MMC cards.
Add support for Secure Digital specific features in the wbsd driver. Adds
support for read-only switch and wide bus transfers.
Add a write protection switch handling code to the PXA MMC driver so
that platform specific code can provide it if available.
Credit where credit is due.
Cc: David Brownell <david-b@pacbell.net>
Infrastructure for 4-bit bus transfers with SD cards.
