path: root/drivers/mmc
2013-11-26mmc: omap: Fix I2C dependency and make driver usable with device treeTony Lindgren
Some features can be configured by the companion I2C chips, which may not be available at the probe time. Fix the issue by returning -EPROBE_DEFER when the MMC controller slots are not configured. While at it, let's also add minimal device tree support so omap24xx platforms can use this driver without legacy mode since we claim to support device tree for mach-omap2 based systems. Although adding the minimal device tree support is not strictly a fix, it does remove one of the last blockers for dropping a bunch of legacy platform data for mach-omap2. Cc: linux-mmc@vger.kernel.org Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-11-26mmc: omap: Fix DMA configuration to not rely on device idTony Lindgren
We are wrongly relying on device id for the DMA configuration which can lead to wrong DMA channel being selected. Fix the issue by using the standard resources like we should. Cc: linux-mmc@vger.kernel.org Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-11-20Merge tag 'pm+acpi-2-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management updates from Rafael Wysocki: - ACPI-based device hotplug fixes for issues introduced recently and a fix for an older error code path bug in the ACPI PCI host bridge driver - Fix for recently broken OMAP cpufreq build from Viresh Kumar - Fix for a recent hibernation regression related to s2disk - Fix for a locking-related regression in the ACPI EC driver from Puneet Kumar - System suspend error code path fix related to runtime PM and runtime PM documentation update from Ulf Hansson - cpufreq's conservative governor fix from Xiaoguang Chen - New processor IDs for intel_idle and turbostat and removal of an obsolete Kconfig option from Len Brown - New device IDs for the ACPI LPSS (Low-Power Subsystem) driver and ACPI-based PCI hotplug (ACPIPHP) cleanup from Mika Westerberg - Removal of several ACPI video DMI blacklist entries that are not necessary any more from Aaron Lu - Rework of the ACPI companion representation in struct device and code cleanup related to that change from Rafael J Wysocki, Lan Tianyu and Jarkko Nikula - Fixes for assigning names to ACPI-enumerated I2C and SPI devices from Jarkko Nikula * tag 'pm+acpi-2-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (24 commits) PCI / hotplug / ACPI: Drop unused acpiphp_debug declaration ACPI / scan: Set flags.match_driver in acpi_bus_scan_fixed() ACPI / PCI root: Clear driver_data before failing enumeration ACPI / hotplug: Fix PCI host bridge hot removal ACPI / hotplug: Fix acpi_bus_get_device() return value check cpufreq: governor: Remove fossil comment in the cpufreq_governor_dbs() ACPI / video: clean up DMI table for initial black screen problem ACPI / EC: Ensure lock is acquired before accessing ec struct members PM / Hibernate: Do not crash kernel in free_basic_memory_bitmaps() ACPI / AC: Remove struct acpi_device pointer from struct acpi_ac spi: Use stable dev_name for ACPI enumerated SPI slaves i2c: Use stable dev_name for ACPI enumerated I2C slaves ACPI: Provide acpi_dev_name accessor for struct acpi_device device name ACPI / bind: Use (put|get)_device() on ACPI device objects too ACPI: Eliminate the DEVICE_ACPI_HANDLE() macro ACPI / driver core: Store an ACPI device pointer in struct acpi_dev_node cpufreq: OMAP: Fix compilation error 'r & ret undeclared' PM / Runtime: Fix error path for prepare PM / Runtime: Update documentation around probe|remove|suspend cpufreq: conservative: set requested_freq to policy max when it is over policy max ...
2013-11-18Merge tag 'mmc-updates-for-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC updates from Chris Ball: "MMC highlights for 3.13: Core: - Improve runtime PM support, remove mmc_{suspend,resume}_host(). - Add MMC_CAP_RUNTIME_RESUME, for delaying MMC resume until we're outside of the resume sequence (in runtime_resume) to decrease system resume time. Drivers: - dw_mmc: Support HS200 mode. - sdhci-eshdc-imx: Support SD3.0 SDR clock tuning, DDR on IMX6. - sdhci-pci: Add support for Intel Clovertrail and Merrifield" * tag 'mmc-updates-for-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (108 commits) mmc: wbsd: Silence compiler warning mmc: core: Silence compiler warning in __mmc_switch mmc: sh_mmcif: Convert to clk_prepare|unprepare mmc: sh_mmcif: Convert to PM macros when defining dev_pm_ops mmc: dw_mmc: exynos: Revert the sdr_timing assignment mmc: sdhci: Avoid needless loop while handling SDIO interrupts in sdhci_irq mmc: core: Add MMC_CAP_RUNTIME_RESUME to resume at runtime_resume mmc: core: Improve runtime PM support during suspend/resume for sd/mmc mmc: core: Remove redundant mmc_power_up|off at runtime callbacks mmc: Don't force card to active state when entering suspend/shutdown MIPS: db1235: Don't use MMC_CLKGATE mmc: core: Remove deprecated mmc_suspend|resume_host APIs mmc: mmci: Move away from using deprecated APIs mmc: via-sdmmc: Move away from using deprecated APIs mmc: tmio: Move away from using deprecated APIs mmc: sh_mmcif: Move away from using deprecated APIs mmc: sdricoh_cs: Move away from using deprecated APIs mmc: rtsx: Remove redundant suspend and resume callbacks mmc: wbsd: Move away from using deprecated APIs mmc: pxamci: Remove redundant suspend and resume callbacks ...
2013-11-14ACPI / driver core: Store an ACPI device pointer in struct acpi_dev_nodeRafael J. Wysocki
Modify struct acpi_dev_node to contain a pointer to struct acpi_device associated with the given device object (that is, its ACPI companion device) instead of an ACPI handle corresponding to it. Introduce two new macros for manipulating that pointer in a CONFIG_ACPI-safe way, ACPI_COMPANION() and ACPI_COMPANION_SET(), and rework the ACPI_HANDLE() macro to take the above changes into account. Drop the ACPI_HANDLE_SET() macro entirely and rework its users to use ACPI_COMPANION_SET() instead. For some of them who used to pass the result of acpi_get_child() directly to ACPI_HANDLE_SET() introduce a helper routine acpi_preset_companion() doing an equivalent thing. The main motivation for doing this is that there are things represented by struct acpi_device objects that don't have valid ACPI handles (so called fixed ACPI hardware features, such as power and sleep buttons) and we would like to create platform device objects for them and "glue" them to their ACPI companions in the usual way (which currently is impossible due to the lack of valid ACPI handles). However, there are more reasons why it may be useful. First, struct acpi_device pointers allow of much better type checking than void pointers which are ACPI handles, so it should be more difficult to write buggy code using modified struct acpi_dev_node and the new macros. Second, the change should help to reduce (over time) the number of places in which the result of ACPI_HANDLE() is passed to acpi_bus_get_device() in order to obtain a pointer to the struct acpi_device associated with the given "physical" device, because now that pointer is returned by ACPI_COMPANION() directly. Finally, the change should make it easier to write generic code that will build both for CONFIG_ACPI set and unset without adding explicit compiler directives to it. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> # on Haswell Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Aaron Lu <aaron.lu@intel.com> # for ATA and SDIO part
2013-11-14Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Included in this series are: 1. BE8 (modern big endian) changes for ARM from Ben Dooks 2. big.Little support from Nicolas Pitre and Dave Martin 3. support for LPAE systems with all system memory above 4GB 4. Perf updates from Will Deacon 5. Additional prefetching and other performance improvements from Will. 6. Neon-optimised AES implementation fro Ard. 7. A number of smaller fixes scattered around the place. There is a rather horrid merge conflict in tools/perf - I was never notified of the conflict because it originally occurred between Will's tree and other stuff. Consequently I have a resolution which Will forwarded me, which I'll forward on immediately after sending this mail. The other notable thing is I'm expecting some build breakage in the crypto stuff on ARM only with Ard's AES patches. These were merged into a stable git branch which others had already pulled, so there's little I can do about this. The problem is caused because these patches have a dependency on some code in the crypto git tree - I tried requesting a branch I can pull to resolve these, and all I got each time from the crypto people was "we'll revert our patches then" which would only make things worse since I still don't have the dependent patches. I've no idea what's going on there or how to resolve that, and since I can't split these patches from the rest of this pull request, I'm rather stuck with pushing this as-is or reverting Ard's patches. Since it should "come out in the wash" I've left them in - the only build problems they seem to cause at the moment are with randconfigs, and since it's a new feature anyway. However, if by -rc1 the dependencies aren't in, I think it'd be best to revert Ard's patches" I resolved the perf conflict roughly as per the patch sent by Russell, but there may be some differences. Any errors are likely mine. Let's see how the crypto issues work out.. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (110 commits) ARM: 7868/1: arm/arm64: remove atomic_clear_mask() in "include/asm/atomic.h" ARM: 7867/1: include: asm: use 'int' instead of 'unsigned long' for 'oldval' in atomic_cmpxchg(). ARM: 7866/1: include: asm: use 'long long' instead of 'u64' within atomic.h ARM: 7871/1: amba: Extend number of IRQS ARM: 7887/1: Don't smp_cross_call() on UP devices in arch_irq_work_raise() ARM: 7872/1: Support arch_irq_work_raise() via self IPIs ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode ARM: 7878/1: nommu: Implement dummy early_paging_init() ARM: 7876/1: clear Thumb-2 IT state on exception handling ARM: 7874/2: bL_switcher: Remove cpu_hotplug_driver_{lock,unlock}() ARM: footbridge: fix build warnings for netwinder ARM: 7873/1: vfp: clear vfp_current_hw_state for dying cpu ARM: fix misplaced arch_virt_to_idmap() ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdown ARM: 7847/1: mcpm: Factor out logical-to-physical CPU translation ARM: 7869/1: remove unused XSCALE_PMU Kconfig param ARM: 7864/1: Handle 64-bit memory in case of 32-bit phys_addr_t ARM: 7863/1: Let arm_add_memory() always use 64-bit arguments ARM: 7862/1: pcpu: replace __get_cpu_var_uses ARM: 7861/1: cacheflush: consolidate single-CPU ARMv7 cache disabling code ...
2013-11-14Merge branch 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull DMA mask updates from Russell King: "This series cleans up the handling of DMA masks in a lot of drivers, fixing some bugs as we go. Some of the more serious errors include: - drivers which only set their coherent DMA mask if the attempt to set the streaming mask fails. - drivers which test for a NULL dma mask pointer, and then set the dma mask pointer to a location in their module .data section - which will cause problems if the module is reloaded. To counter these, I have introduced two helper functions: - dma_set_mask_and_coherent() takes care of setting both the streaming and coherent masks at the same time, with the correct error handling as specified by the API. - dma_coerce_mask_and_coherent() which resolves the problem of drivers forcefully setting DMA masks. This is more a marker for future work to further clean these locations up - the code which creates the devices really should be initialising these, but to fix that in one go along with this change could potentially be very disruptive. The last thing this series does is prise away some of Linux's addition to "DMA addresses are physical addresses and RAM always starts at zero". We have ARM LPAE systems where all system memory is above 4GB physical, hence having DMA masks interpreted by (eg) the block layers as describing physical addresses in the range 0..DMAMASK fails on these platforms. Santosh Shilimkar addresses this in this series; the patches were copied to the appropriate people multiple times but were ignored. Fixing this also gets rid of some ARM weirdness in the setup of the max*pfn variables, and brings ARM into line with every other Linux architecture as far as those go" * 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits) ARM: 7805/1: mm: change max*pfn to include the physical offset of memory ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit() ARM: DMA-API: better handing of DMA masks for coherent allocations ARM: 7857/1: dma: imx-sdma: setup dma mask DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks DMA-API: dcdbas: update DMA mask handing DMA-API: dma: edma.c: no need to explicitly initialize DMA masks DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks DMA-API: crypto: remove last references to 'static struct device *dev' DMA-API: crypto: fix ixp4xx crypto platform device support DMA-API: others: use dma_set_coherent_mask() DMA-API: staging: use dma_set_coherent_mask() DMA-API: usb: use new dma_coerce_mask_and_coherent() DMA-API: usb: use dma_set_coherent_mask() DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent() DMA-API: net: octeon: use dma_coerce_mask_and_coherent() DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent() ...
2013-11-12Merge branches 'fixes', 'mmci' and 'sa11x0' into for-nextRussell King
2013-11-08mmc: wbsd: Silence compiler warningUlf Hansson
The commit "mmc: wbsd: Move away from using deprecated APIs" introduced a compiler warning, let's silence it. Cc: Pierre Ossman <pierre@ossman.eu> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-11-08mmc: core: Silence compiler warning in __mmc_switchUlf Hansson
2013-11-08mmc: sh_mmcif: Convert to clk_prepare|unprepareUlf Hansson
Previously only clk_enable|disable were being used. Adapt properly to the clock API, by also using clk_prepare|unprepare. Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-11-08mmc: sh_mmcif: Convert to PM macros when defining dev_pm_opsUlf Hansson
Use SET_SYSTEM_SLEEP_PM_OPS to simplify code. Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-11-08mmc: dw_mmc: exynos: Revert the sdr_timing assignmentYuvaraj Kumar C D
e6c784eded7b3 ("mmc: dw_mmc: exynos: move the exynos private init") was wrongly assigning ddr_timing value to sdr_timing. This patch fixes this by reverting the sdr_timing assignment statement to the earlier location. Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com> Acked-by: Seungwon Jeon <tgih.jun@samsung.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-11-08mmc: sdhci: Avoid needless loop while handling SDIO interrupts in sdhci_irqAlexey Neyman
Ignore Card Interrupt bit in the interrupt status if we already know that mmc_signal_sdio_irq() is going to be called at the end of sdhci_irq(). This avoids a needless loop in sdhci_irq() repeatedly reading interrupt status and doing nothing. Signed-off-by: Alexey Neyman <stilor@att.net> Acked-by: Dong Aisheng <b29396@freescale.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-31ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculationsSantosh Shilimkar
DMA bounce limit is the maximum direct DMA'able memory beyond which bounce buffers has to be used to perform dma operations. MMC queue layr relies on dma_mask but its calculation is based on max_*pfn which don't have uniform meaning across architectures. So make use of dma_max_pfn() which is expected to return the DMAable maximum pfn value across architectures. Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-31DMA-API: mmc: sdhci-acpi: use dma_coerce_mask_and_coherent()Russell King
The code sequence: dev->dma_mask = &dev->coherent_dma_mask; dev->coherent_dma_mask = dma_mask; bypasses the architectures check on the DMA mask. It can be replaced with dma_coerce_mask_and_coherent(), avoiding the direct initialization of this mask. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-30mmc: core: Add MMC_CAP_RUNTIME_RESUME to resume at runtime_resumeUlf Hansson
In some environments it is to prefer to postpone the resume of the card device until runtime_resume is being carried out, since it will mean a signficant decrease of the total system resume time. The reason of the decreased resume time is simply because of the actual re-initalization of the card, which typically takes hundreds of milliseconds, is performed outside the resume sequence and wont thus affect it. For removable card, the detect work tries to re-detect the card to make sure it is still present, as a part of that sequence the card will also be runtime_resumed and thus also fully resumed. For a non-removable card, typically a mmc blk request will trigger a runtime_resume and thus fully resume the card. This also means the first request will likely suffer from an inital latency since the re-initialization of the card needs to be performed. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: core: Improve runtime PM support during suspend/resume for sd/mmcUlf Hansson
The card device is considered as in-active after it has been suspended. To prevent any further runtime PM requests in suspend state, we then disable runtime PM. After the card device has been resumed, we shall consider it as active, like we also do after a probe sequence. When resumed, we can safely enable runtime PM again. This will make sure the PM core can request the card device to go to in-active state after a resume has been completed. Previously we had to wait for new pm_runtime_get->pm_runtime_put cycle to be executed. Additionally, once a resume has been carried out, update the last busy mark. At the moment this will have no effect but if the PM core will respect autosuspend enabled devices, when it directly triggers a runtime_suspend from a runtime_idle, it will mean the card device will be scheduled for a delayed runtime_suspend instead of done immediately. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: core: Remove redundant mmc_power_up|off at runtime callbacksUlf Hansson
Commit "mmc: core: Push common suspend|resume code into each bus_ops" moved the responsibility for doing mmc_power_up|off into each suspend/resume bus_ops. When using MMC_CAP_AGGRESSIVE_PM, through the runtime callbacks, calls to mmc_power_up|off became redundant. When removing them, we are also able to remove the calls to mmc_claim|release_host, thus simplifing code a bit more. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: Don't force card to active state when entering suspend/shutdownUlf Hansson
By adding a card state that records if it is suspended or resumed, we can accept asyncronus suspend/resume requests for the mmc and sd bus_ops. MMC_CAP_AGGRESSIVE_PM, will at request inactivity through the runtime bus_ops callbacks, execute a suspend of the the card. In the state were this has been done, we can receive a suspend request for the mmc bus, which for sd and mmc forced the card to active state by a pm_runtime_get_sync. In other words, the card was resumed and then immediately suspended again, completely unnecessary. Since the suspend/resume bus_ops callbacks for sd and mmc are now capable of handling asynchronous requests, we no longer need to force the card to active state before executing suspend. Evidently preventing the above sequence for MMC_CAP_AGGRESSIVE_PM. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: core: Remove deprecated mmc_suspend|resume_host APIsUlf Hansson
The are no more users of the deprecated mmc_suspend|resume_host API, so let's remove it. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: mmci: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: via-sdmmc: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Bruce Chang <brucechang@via.com.tw> Cc: Harald Welte <HaraldWelte@viatech.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: tmio: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: sh_mmcif: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: sdricoh_cs: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Sascha Sommer <saschasommer@freenet.de> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Sascha Sommer <saschasommer@freenet.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: rtsx: Remove redundant suspend and resume callbacksUlf Hansson
Suspend and resume of cards are handled by the protocol layer and consequently the mmc_suspend|resume_host APIs are marked as deprecated. While moving away from using the deprecated APIs, there are nothing left to be done for the suspend and resume callbacks, so remove them. Cc: Wei WANG <wei_wang@realsil.com.cn> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: wbsd: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Pierre Ossman <pierre@ossman.eu> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: pxamci: Remove redundant suspend and resume callbacksUlf Hansson
Suspend and resume of cards are handled by the protocol layer and consequently the mmc_suspend|resume_host APIs are marked as deprecated. While moving away from using the deprecated APIs, there are nothing left to be done for the suspend and resume callbacks, so remove them. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: s3cmci: Remove redundant suspend and resume callbacksUlf Hansson
Suspend and resume of cards are handled by the protocol layer and consequently the mmc_suspend|resume_host APIs are marked as deprecated. While moving away from using the deprecated APIs, there are nothing left to be done for the suspend and resume callbacks, so remove them. Cc: Ben Dooks <ben-linux@fluff.org> Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: wmt-sdmmc: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Tony Prisk <linux@prisktech.co.nz> Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: mxcmmc: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: mxs-mmc: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: omap: Remove redundant suspend and resume callbacksUlf Hansson
Suspend and resume of cards are handled by the protocol layer and consequently the mmc_suspend|resume_host APIs are marked as deprecated. While moving away from using the deprecated APIs, there are nothing left to be done for the suspend and resume callbacks, so remove them. Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: tifm_sd: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: sdhci: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: vub300: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are handled by the protocol layer and consequently the mmc_suspend|resume_host APIs are marked as deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Tony Olech <tony.olech@elandigitalsystems.com> Cc: linux-usb@vger.kernel.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: mvsdio: Remove redundant suspend and resume callbacksUlf Hansson
Suspend and resume of cards are handled by the protocol layer and consequently the mmc_suspend|resume_host APIs are marked as deprecated. While moving away from using the deprecated APIs, there are nothing left to be done for the suspend and resume callbacks, so remove them. Cc: Nicolas Pitre <nico@fluxnic.net> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: msm_sdcc: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Additionally, remove dead code which also used the deprecated APIs. Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: linux-arm-msm@vger.kernel.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: David Brown <davidb@codeaurora.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: jz4740: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: dw_mmc: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Seungwon Jeon <tgih.jun@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: davinci_mmc: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Sekhar Nori <nsekhar@ti.com> Cc: Manjunathappa, Prakash <prakash.pm@ti.com> Cc: davinci-linux-open-source@linux.davincidsp.com Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: cb710: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: bfin_sdh: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Sonic Zhang <sonic.zhang@analog.com> Cc: uclinux-dist-devel@blackfin.uclinux.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: au1xmmc: Move away from using deprecated APIsUlf Hansson
Suspend and resume of cards are being handled from the protocol layer and consequently the mmc_suspend|resume_host APIs are deprecated. This means we can simplify the suspend|resume callbacks by removing the use of the deprecated APIs. Cc: Manuel Lauss <manuel.lauss@googlemail.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: atmel-mci: Remove redundant suspend and resume callbacksUlf Hansson
Suspend and resume of cards are handled by the protocol layer and consequently the mmc_suspend|resume_host APIs are marked as deprecated. While moving away from using the deprecated APIs, there are nothing left to be done for the suspend and resume callbacks, so remove them. Cc: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: core: Signal wakeup event at card insert/removalUlf Hansson
We want to give user space provision to fully consume a card insert/remove event, when the event was caused by a wakeup irq. By signaling the wakeup event for a time of 5 s for devices configured as wakeup capable, we likely will be prevent a sleep long enough to let user space consume the event. To enable this feature, host drivers must thus configure their devices as wakeup capable. This is a reworked implementation of the old wakelocks for the mmc subsystem, originally authored by Colin Cross and San Mehat for the Android kernel. Zoran Markovic shall also be given cred for recently re-trying to upstream this feature. Cc: San Mehat <san@google.com> Cc: Colin Cross <ccross@android.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Zoran Markovic <zoran.markovic@linaro.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Reviewed-by: Zoran Markovic <zoran.markovic@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: core: Collect common code for card ocr validationUlf Hansson
Since mmc_select_voltage now only gets called from the attach sequence, it makes sense to move the out of spec validations of the card ocr into this function. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: core: Prevent violation of specs while initializing cardsUlf Hansson
According to eMMC/SD/SDIO specs, the VDD (VCC) voltage level must be maintained during the initialization sequence. If we want/need to tune the voltage level, a complete power cycle of the card must be executed. Most host drivers conforms to the specifications by only allowing to change VDD voltage level at the MMC_POWER_UP state, but some also cares about MMC_POWER_ON state, which they should'nt. This patch will not break those drivers, but they could clean up code to better reflect what is expected from the protocol layer. A big re-work of the mmc_select_voltage function is done to only change VDD voltage level if the host supports MMC_CAP2_FULL_PWR_CYCLE. Otherwise only validation of the host and card ocr mask will be done. A very nice side-effect of this patch is that we now don't need to reset the negotiated ocr mask at the mmc_power_off function, since now it will actually reflect the present voltage level, which safely can be used at the next power up and re-initialization. Moreover, we then only need to execute mmc_select_voltage from the attach sequence. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-10-30mmc: core: Move cached value of the negotiated ocr mask to card structUlf Hansson
The negotiated ocr mask is directly related to the card. Once a card gets removed, the mask shall be dropped. By moving the cache of the ocr mask from the host struct to the card struct we have accomplished this. Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
