path: root/drivers/mmc
2011-01-14mmc: sdhci-of: fix build on non-powerpc platformsRob Herring
Explicitly include err.h, of_address.h and of_irq.h. Make use of machine_is() conditional on PPC. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (39 commits) mmc: davinci: add support for SDIO irq handling mmc: fix division by zero in MMC core mmc: tmio_mmc: fix CMD irq handling mmc: tmio_mmc: handle missing HW interrupts mfd: sh_mobile_sdhi: activate SDIO IRQ for tmio_mmc mmc: tmio_mmc: implement SDIO IRQ support mfd: sdhi: require the tmio-mmc driver to bounce unaligned buffers mmc: tmio_mmc: silence compiler warnings mmc: tmio_mmc: implement a bounce buffer for unaligned DMA mmc: tmio_mmc: merge the private header into the driver mmc: tmio_mmc: fix PIO fallback on DMA descriptor allocation failure mmc: tmio_mmc: allow multi-element scatter-gather lists mmc: Register debugfs dir before calling card probe function. mmc: MMC_BLOCK_MINORS should depend on MMC_BLOCK. mmc: Explain why we make adjacent mmc_bus_{put,get} calls during rescan. mmc: Fix sd/sdio/mmc initialization frequency retries mmc: fix mmc_set_bus_width_ddr() call without bus-width-test cap mmc: dw_mmc: Add Synopsys DesignWare mmc host driver. mmc: add sdhci-tegra driver for Tegra SoCs mmc: sdhci: add quirk for max len ADMA descriptors ...
2011-01-10Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (29 commits) of/flattree: forward declare struct device_node in of_fdt.h ipmi: explicitly include of_address.h and of_irq.h sparc: explicitly cast negative phandle checks to s32 powerpc/405: Fix missing #{address,size}-cells in i2c node powerpc/5200: dts: refactor dts files powerpc/5200: dts: Change combatible strings on localbus powerpc/5200: dts: remove unused properties powerpc/5200: dts: rename nodes to prepare for refactoring dts files of/flattree: Update dtc to current mainline. of/device: Don't register disabled devices powerpc/dts: fix syntax bugs in bluestone.dts of: Fixes for OF probing on little endian systems of: make drivers depend on CONFIG_OF instead of CONFIG_PPC_OF of/flattree: Add of_flat_dt_match() helper function of_serial: explicitly include of_irq.h of/flattree: Refactor unflatten_device_tree and add fdt_unflatten_tree of/flattree: Reorder unflatten_dt_node of/flattree: Refactor unflatten_dt_node of/flattree: Add non-boottime device tree functions of/flattree: Add Kconfig for EARLY_FLATTREE ... Fix up trivial conflict in arch/sparc/prom/tree_32.c as per Grant.
2011-01-09mmc: davinci: add support for SDIO irq handlingAlagu Sankar
This patch adds support for handling SDIO interrupt on DaVinci MMC/SD controller. The patch has been tested on DM355 and DA850 EVMs with Marvell Libertas based SDIO wireless LAN card. Signed-off-by: Alagu Sankar <alagusankar@embwise.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: fix division by zero in MMC coreLinus Walleij
The card is not always clocked and the clock frequency zero is perfectly legal, thus this code in mmc_set_data_timeout() may cause a division by zero. It will be triggered more often if you're using software clock gating but can be triggered under other conditions too. Reported-by: Pierre Tardy <tardyp@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Reviewed-by: Chris Ball <cjb@laptop.org> Cc: <stable@kernel.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: tmio_mmc: fix CMD irq handlingArnd Hannemann
With current code card insert/eject interrupts will acknowledge outstanding commands. Normally this seems to be no problem, however if the hardware gets stuck and no interrupts for CMD_TIMEOUT or CMD_RESPEND are generated, then inserting and ejecting cards will falsely acknowledge outstanding commands from the core. This patch changes the behavior so that CMDs are only acked, if CMD_TIMEOUT or CMD_RESPEND is received. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: tmio_mmc: handle missing HW interruptsArnd Hannemann
When doing excessive hotplug, e.g., repeated insert/eject operations, the hardware may get confused to a point where no CMDTIMEOUT/CMDRESPEND interrupts are generated any more. As a result requests get stuck, e.g.: [ 360.351562] INFO: task kworker/u:0:5 blocked for more than 120 seconds. [ 360.351562] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 360.359375] kworker/u:0 D c020c2b4 0 5 2 0x00000000 [ 360.367187] Backtrace: [ 360.367187] [<c020bfb0>] (schedule+0x0/0x340) from [<c020c480>] (schedule_timeout+0x20/0x190) [ 360.375000] r8:c702fd70 r7:00000002 r6:c702e000 r5:c702fdc4 r4:7fffffff [ 360.375000] r3:c701e040 [ 360.382812] [<c020c460>] (schedule_timeout+0x0/0x190) from [<c020be78>] (wait_for_common+0xc4/0x150) [ 360.390625] r6:c702e000 r5:c702fdc4 r4:7fffffff [ 360.390625] [<c020bdb4>] (wait_for_common+0x0/0x150) from [<c020bfac>] (wait_for_completion+0x18/0x1c) [ 360.398437] [<c020bf94>] (wait_for_completion+0x0/0x1c) from [<c0185590>] (mmc_wait_for_req+0x214/0x234) [ 360.406250] [<c018537c>] (mmc_wait_for_req+0x0/0x234) from [<c01889d0>] (mmc_sd_switch+0xfc/0x114) [ 360.414062] r7:c702fe4c r6:c702fe20 r5:c7179800 r4:00fffff0 [ 360.421875] [<c01888d4>] (mmc_sd_switch+0x0/0x114) from [<c0187f70>] (mmc_sd_setup_card+0x260/0x384) [ 360.429687] [<c0187d10>] (mmc_sd_setup_card+0x0/0x384) from [<c01885e0>] (mmc_sd_init_card+0x13c/0x1e0) [ 360.437500] [<c01884a4>] (mmc_sd_init_card+0x0/0x1e0) from [<c01887a8>] (mmc_attach_sd+0x124/0x1a8) [ 360.445312] r8:c02db404 r7:ffffff92 r6:c702ff34 r5:c6007da8 r4:c6007c00 [ 360.453125] [<c0188684>] (mmc_attach_sd+0x0/0x1a8) from [<c0185140>] (mmc_rescan+0x248/0x2f0) [ 360.460937] r5:c6007da8 r4:c6007c00 [ 360.468750] [<c0184ef8>] (mmc_rescan+0x0/0x2f0) from [<c00467f0>] (process_one_work+0x1ec/0x318) [ 360.476562] r7:c6007da8 r6:00000000 r5:c710ec00 r4:c701bde0 [ 360.484375] [<c0046604>] (process_one_work+0x0/0x318) from [<c0047fb0>] (worker_thread+0x1b0/0x2cc) [ 360.492187] [<c0047e00>] (worker_thread+0x0/0x2cc) from [<c004b338>] (kthread+0x8c/0x94) [ 360.500000] [<c004b2ac>] (kthread+0x0/0x94) from [<c0037fc4>] (do_exit+0x0/0x590) [ 360.507812] r7:00000013 r6:c0037fc4 r5:c004b2ac r4:c7021f00 This patch addresses this problem by introducing timeouts for outstanding interrupts. If a hardware interrupt is missing, a soft reset will be performed to bring the hardware back to a working state. Tested with the SDHI hardware block in sh7372 / AP4EVB. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: tmio_mmc: implement SDIO IRQ supportArnd Hannemann
This patch implements SDIO IRQ support for mfds which announce the TMIO_MMC_SDIO_IRQ flag for tmio_mmc. If MMC_CAP_SDIO_IRQ is also set SDIO IRQ signalling is activated. Tested with a b43-based wireless SDIO card and sh_mobile_sdhi. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: tmio_mmc: silence compiler warningsArnd Hannemann
with "mmc: tmio: implement a bounce buffer for unaligned DMA" gcc generates the following warnings: drivers/mmc/host/tmio_mmc.c:654:6: warning: 'ret' may be used uninitialized in this function drivers/mmc/host/tmio_mmc.c:730:6: warning: 'ret' may be used uninitialized in this function This patch fixes these by setting ret to -EINVAL in the affected code paths. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: tmio_mmc: implement a bounce buffer for unaligned DMAGuennadi Liakhovetski
For example, with SDIO WLAN cards, some transfers happen with buffers at odd addresses, whereas the SH-Mobile DMA engine requires even addresses for SDHI. This patch extends the tmio driver with a bounce buffer, that is used for single entry scatter-gather lists both for sending and receiving. If we ever encounter unaligned transfers with multi-element sg lists, this patch will have to be extended. For now it just falls back to PIO in this and other unsupported cases. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: tmio_mmc: merge the private header into the driverGuennadi Liakhovetski
drivers/mmc/host/tmio_mmc.h is only used by drivers/mmc/host/tmio_mmc.c, this needlessly complicates source-code handling. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: tmio_mmc: fix PIO fallback on DMA descriptor allocation failureGuennadi Liakhovetski
The easiest way to fall back to PIO, when a DMA descriptor allocation fails is to disable DMA on the controller but continue with the current request in PIO mode. This way tmio_mmc_start_dma() can become void, since it cannot be failing any more. The current version is also broken: it is testing a wrong pointer and thus failing to recognise, that a descriptor allocation wasn't successful. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: tmio_mmc: allow multi-element scatter-gather listsGuennadi Liakhovetski
The driver is capable of handling multi-element sg lists in both PIO and DMA modes. In DMA mode this also allows to use the DMA sg capability more efficiently and almost doubles the throughput. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: Register debugfs dir before calling card probe function.Viresh Kumar
This way, the probe function may register debugfs files if it wants to. This fixes a bug with mmc_test where mmc_test_register_file_test() is called before the card's debugfs dir exists, and so it fails. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Tested-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: MMC_BLOCK_MINORS should depend on MMC_BLOCK.Chris Ball
Signed-off-by: Chris Ball <cjb@laptop.org> Tested-by: Chris Ball <cjb@laptop.org> Acked-by: Olof Johansson <olof@lixom.net>
2011-01-08mmc: Explain why we make adjacent mmc_bus_{put,get} calls during rescan.Chris Ball
2011-01-08mmc: Fix sd/sdio/mmc initialization frequency retriesAndy Ross
Rewrite and clean up mmc_rescan() to properly retry frequencies lower than 400kHz. Failures can happen both in sd_send_* calls and mmc_attach_*. Break out "mmc_rescan_try_freq" from the frequency selection loop. Symmetrize claim/release logic in mmc_attach_* API, and move the sd_send_* calls there to make mmc_rescan easier to read. Signed-off-by: Andy Ross <andy.ross@windriver.com> Reviewed-and-Tested-by: Hein Tibosch <hein_tibosch@yahoo.es> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: fix mmc_set_bus_width_ddr() call without bus-width-test capTakashi Iwai
With the bus-width test patch, mmc_set_bus_width*() isn't called properly when the driver doesn't set MMC_CAP_BUS_WIDTH and no DDR mode. This patch fixes the regression by moving the call up before the cap test. Signed-off-by: Takashi Iwai <tiwai@suse.de> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: dw_mmc: Add Synopsys DesignWare mmc host driver.Will Newton
This adds the mmc host driver for the Synopsys DesignWare mmc host controller, found in a number of embedded SoC designs. Signed-off-by: Will Newton <will.newton@imgtec.com> Reviewed-by: Matt Fleming <matt@console-pimps.org> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: add sdhci-tegra driver for Tegra SoCsOlof Johansson
SDHCI driver for Tegra. This driver plugs in as a new variant of sdhci-pltfm, using the platform data structure passed in to specify the GPIOs to use for card detect, write protect and card power enablement. Original driver (of which only the header file is left): Signed-off-by: Yvonne Yip <y@palm.com> The rest, which has been rewritten by now: Signed-off-by: Olof Johansson <olof@lixom.net> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: sdhci: add quirk for max len ADMA descriptorsOlof Johansson
Some controllers misparse segment length 0 as being 0, not 65536. Add a quirk to deal with it. Signed-off-by: Olof Johansson <olof@lixom.net> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: check for > 1 clk_requests when disabling gatingLinus Walleij
Since we make sure the clock is enabled in the mmc_host_clk_exit() function we should expect a reference counter of 1, not 0. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Tested-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: sdhci-s3c: Support controllers with no internal clock dividerJeongbae Seo
This patch supports controllers with no internal clock divider in SDHCI, such as the s5pc210 board. The external clock divider can be used to make a proper clock because SDHCI doesn't support internal clock divider by itself. If external clock divider type is selected, some functions related to clock control will be overrided by other functions. The current clock control index is added to let you know which clock bus is used for SDHCI when overriding functions. Checking functions are added into sdhci_s3c_consider_clock, because the clock divider step is different from that of host controller. Signed-off-by: Jeongbae Seo <jeongbae.seo@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: sdhci-s3c: Support additional host capabilitiesJeongbae Seo
This patch adds support for additional host capabilities like SD/MMC high speed, SDHCI bus width, etc. Signed-off-by: Jeongbae Seo <jeongbae.seo@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: sdhci: Enable bus-width test for JMicron controllersTakashi Iwai
Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: Test bus-width for old MMC devicesAries Lee
Some old MMC devices fail with the 4/8 bits the driver tries to use exclusively. This patch adds a test for the given bus setup and falls back to the lower bit mode (until 1-bit mode) when the test fails. [Major rework and refactoring by tiwai] [Quirk addition and many fixes by prakity] Signed-off-by: Aries Lee <arieslee@jmicron.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Philip Rakity <prakity@marvell.com> Tested-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: fix detection of memory part of SD-combo card with broken SDIOMichal Miroslaw
In case of failure, mmc_attach_sdio() will power off the SD bus. Power it up and reinitialize before trying SD memory detection. Reported-by: Sahitya Tummala <stummala@codeaurora.org> Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: sdio: don't reinitialize nonremovable powered-resumed cardsOhad Ben-Cohen
Upon system resume, SDIO core must reinitialize cards that were powered off during suspend. If the card had its power kept during suspend (and thus it is 'powered-resumed'), SDIO core performs only a limited reinitializing, mainly needed to make sure that the card wasn't removed/replaced. If a __nonremovable__ card is powered-resumed, we can safely skip the reinitializing phase. Note: 9b966aa (mmc: sdio: fully reconfigure oldcard on resume) removed the bus width reconfiguration since mmc_sdio_init_card already does it. It is brought back now in case mmc_sdio_init_card is skipped. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: sdio: don't power up cards on system suspendOhad Ben-Cohen
Initial SDIO runtime PM implementation took a conservative approach of powering up cards (and fully reinitializing them) on system suspend, just before the suspend handlers of the relevant drivers were executed. To avoid redundant power and reinitialization cycles, this patch removes this behavior: if a card is already powered off when system suspend kicks in, it is left at that state. If a card is active when a system sleep starts, everything is straightforward and works exactly like before. But if the card was already suspended before the sleep began, then when the MMC core powers it back up on resume, its run-time PM status has to be updated to reflect the actual post-system sleep status. The technique to do that is borrowed from the I2C runtime PM implementation (for more info see Documentation/power/runtime_pm.txt). Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: skip detection of nonremovable cards on rescanOhad Ben-Cohen
mmc_rescan() checks whether registered cards are still present before skipping them, by calling the bus-specific ->detect() handler. With buses that support runtime PM, the card may be powered off at this point, so they need to be powered on and fully reinitialized before ->detect() executes. This whole process is redundant with nonremovable cards; in those cases, we can safely skip calling ->detect() and implicitly assume its success. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: Add support for JMicron 388 SD/MMC controllerTakashi Iwai
JMicron 388 SD/MMC combo controller supports the 1.8V low-voltage for SD, but MMC doesn't work with the low-voltage, resulting in an error at probing. This patch adds the support for multiple voltage mask per device type, so that SD works with 1.8V while MMC forces 3.3V. Here new ocr_avail_* fields for each device are introduced, so that the actual OCR mask is switched dynamically. Also, the restriction of low-voltage in core/sd.c is removed when the bit is allowed explicitly via ocr_avail_sd mask. This patch was rewritten from scratch based on Aries' original code. Signed-off-by: Aries Lee <arieslee@jmicron.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: davinci_mmc: Remove unnecessary semicolonJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: sdhci: print SD Command and CAPABILITY_1 when dumping registersPhilip Rakity
More information should be shown when sdhci_dumpregs is called. Knowing the command is useful for debugging, and Capability 1 is useful for SD v3. Signed-off-by: Philip Rakity <prakity@marvell.com> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: Aggressive clock gating frameworkLinus Walleij
This patch modifies the MMC core code to optionally call the set_ios() operation on the driver with the clock frequency set to 0 (gate) after a grace period of at least 8 MCLK cycles, then restore it (ungate) before any new request. This gives the driver the option to shut down the MCI clock to the MMC/SD card when the clock frequency is 0, i.e. the core has stated that the MCI clock does not need to be generated. It is inspired by existing clock gating code found in the OMAP and Atmel drivers and brings this up to the host abstraction. Gating is performed before and after any MMC request. This patchset implements this for the MMCI/PL180 MMC/SD host controller, but it should be simple to switch OMAP/Atmel over to using this instead. mmc_set_{gated,ungated}() add variable protection to the state holders for the clock gating code. This is particularly important when ordinary .set_ios() calls would race with the .set_ios() call resulting from a delayed gate operation. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Reviewed-by: Chris Ball <cjb@laptop.org> Tested-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: sdhci: Disable ADMA on some O2Micro SD/MMC parts.Jennifer Li
This patch disables the broken ADMA on selected O2Micro devices. Signed-off-by: Jennifer Li <Jennifer.li@o2micro.com> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: mxcmmc: remove a unnecessary release_resource() callAxel Lin
Remove release_resource() after release_mem_region(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: mxcmmc: update the regulator support code to the latest APIAlberto Panizzo
This also fixes the build problem introduced by my previous patch due to unhandled API changes introduced by commit: 99fc513101 (mmc: Move regulator handling closer to core) Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: mxcmmc: Allow binding a regulator to manage the MMC card voltageAlberto Panizzo
This implementation is based on the pxamci.c driver and it will be used to support the mx31_3ds machine. Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: Add support for the Marvell Dove SDHCI controllerMike Rapoport
Implement an sdhci-pltfm driver for the controller found in the Marvell Dove SoC. Signed-off-by: Mike Rapoport <mike@compulab.co.il> CC: Saeed Bishara <saeed@marvell.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-07Merge branch 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits) usb: don't use flush_scheduled_work() speedtch: don't abuse struct delayed_work media/video: don't use flush_scheduled_work() media/video: explicitly flush request_module work ioc4: use static work_struct for ioc4_load_modules() init: don't call flush_scheduled_work() from do_initcalls() s390: don't use flush_scheduled_work() rtc: don't use flush_scheduled_work() mmc: update workqueue usages mfd: update workqueue usages dvb: don't use flush_scheduled_work() leds-wm8350: don't use flush_scheduled_work() mISDN: don't use flush_scheduled_work() macintosh/ams: don't use flush_scheduled_work() vmwgfx: don't use flush_scheduled_work() tpm: don't use flush_scheduled_work() sonypi: don't use flush_scheduled_work() hvsi: don't use flush_scheduled_work() xen: don't use flush_scheduled_work() gdrom: don't use flush_scheduled_work() ... Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c as per Tejun.
2011-01-07Merge branch 'master' of ↵Paul Mundt
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 into rmobile-latest Conflicts: arch/arm/mach-shmobile/Kconfig Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-06Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (416 commits) ARM: DMA: add support for DMA debugging ARM: PL011: add DMA burst threshold support for ST variants ARM: PL011: Add support for transmit DMA ARM: PL011: Ensure IRQs are disabled in UART interrupt handler ARM: PL011: Separate hardware FIFO size from TTY FIFO size ARM: PL011: Allow better handling of vendor data ARM: PL011: Ensure error flags are clear at startup ARM: PL011: include revision number in boot-time port printk ARM: vexpress: add sched_clock() for Versatile Express ARM i.MX53: Make MX53 EVK bootable ARM i.MX53: Some bug fix about MX53 MSL code ARM: 6607/1: sa1100: Update platform device registration ARM: 6606/1: sa1100: Fix platform device registration ARM i.MX51: rename IPU irqs ARM i.MX51: Add ipu clock support ARM: imx/mx27_3ds: Add PMIC support ARM: DMA: Replace page_to_dma()/dma_to_page() with pfn_to_dma()/dma_to_pfn() mx51: fix usb clock support MX51: Add support for usb host 2 arch/arm/plat-mxc/ehci.c: fix errors/typos ...
2011-01-06Merge branch 'for-linus' of git://codeaurora.org/quic/kernel/davidb/linux-msmLinus Torvalds
* 'for-linus' of git://codeaurora.org/quic/kernel/davidb/linux-msm: (35 commits) mmc: msm_sdcc: Check for only DATA_END interrupt to end a request mmc: msm_sdcc: Fix bug in PIO mode when data size is not word aligned mmc: msm_sdcc: Reset SDCC in case of data transfer errors mmc: msm_sdcc: Add prog done interrupt support mmc: msm_sdcc: Fix possible circular locking dependency warning MSM: Add USB support for MSM7x30 MSM: Add USB suport for QSD8x50 msm: initial framebuffer support msm: add handling for clocks tagged as CLK_MINMAX msm: trout: change name of pmdh_clk to mddi_clk msm: add CLK_MINMAX to pmdh_clk msm: trout: add gpio_to_irq msm: iommu: Use the correct memory allocation flag msm_serial: Remove redundant unlikely() msm: iommu: Miscellaneous code cleanup msm: iommu: Support cache-coherent memory access msm: iommu: Definitions for extended memory attributes msm: iommu: Kconfig dependency for the IOMMU API msm: iommu: Check if device is already attached msm: iommu: Kconfig item for cacheable page tables ...
2011-01-05Merge branches 'mmci' and 'pl011-dma' into develRussell King
2011-01-05Merge branches 'rmobile/mmcif', 'rmobile/ag5' and 'rmobile/mackerel' into ↵Paul Mundt
2011-01-05mmc: sh_mmcif: make DMA support by the driver unconditionalGuennadi Liakhovetski
Simplify the driver by removing the possibility to build it without the DMA support and remove the respective Kconfig parameter. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-03of: Fixes for OF probing on little endian systemsRob Herring
Fixes for sdhci-of and ipmi drivers. Auditing all drivers using of_get_property did not find other occurrences likely to be used on LE platforms. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-03of: make drivers depend on CONFIG_OF instead of CONFIG_PPC_OFRob Herring
Some OF drivers could likely be used on non-powerpc OF based platforms, so fix the kconfig depends to be CONFIG_OF instead of CONFIG_PPC_OF. Compile tested on ARM and sparc. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-30ARM: mmci: Clean up MMCI announcement printkRussell King
Make the MMCI announcement printk say which primecell part number has been found. Display the revision as an unsigned decimal, and display only the first 8 hex digits of the base address unless it's larger. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
