path: root/drivers/mmc/host/sdhci-esdhc.h
2012-09-04mmc: sdhci-esdhc: break out early if clock is 0Shawn Guo
Since commit 30832ab56 ("mmc: sdhci: Always pass clock request value zero to set_clock host op") was merged, esdhc_set_clock starts hitting "if (clock == 0)" where ESDHC_SYSTEM_CONTROL has been operated. This causes SDHCI card-detection function being broken. Fix the regression by moving "if (clock == 0)" above ESDHC_SYSTEM_CONTROL operation. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: <stable@vger.kernel.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-01-11mmc: sdhci-esdhc: Change delay after setting clock from 100ms to 1msTony Lin
1ms is enough for hardware to change the clock to stable. 100ms is too long in the tasklet. Signed-off-by: Tony Lin <tony.lin@freescale.com> CC: Xiaobo Xie <X.Xie@freescale.com> CC: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-25mmc: sdhci-esdhc: remove SDHCI_QUIRK_NO_CARD_NO_RESET from esdhcRichard Zhu
sdhci-esdhc-imx does not need SDHCI_QUIRK_NO_CARD_NO_RESET. Make it OF-specific. Signed-off-by: Richard Zhu <Hong-Xing.Zhu@freescale.com> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-17mmc: sdhci-esdhc: broken card detection is not a default quirkWolfram Sang
It can be worked around using a GPIO which will be done for i.MX later. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Tested-by: Marc Reilly <marc@cpdesign.com.au> Tested-by: Eric Benard <eric@eukrea.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: sdhci-of-esdhc: factor out common stuffWolfram Sang
Put everything which can be shared between the OF and platform version of this driver into a local .h file. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Eric BĂ©nard <eric@eukrea.com> [cjb: fix compile error: sdhci-esdhc.c->sdhci-esdhc.h] Signed-off-by: Chris Ball <cjb@laptop.org>
