Add an odd clock divider capability available from v5xx. It also involves
changing the clock divider calculation, and changing the switch-case
statement to use top-down fallthrough.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
The HSMCI operates at a rate of up to Master Clock divided by two.
Moreover previous calculation can cause overflows and so wrong
timeouts.
Cc: <stable@vger.kernel.org>
Pull slave-dmaengine update from Vinod Koul:
"This includes the cookie cleanup by Russell, the addition of context
parameter for dmaengine APIs, more arm dmaengine driver cleanup by
moving code to dmaengine, this time for imx by Javier and pl330 by
Boojin along with the usual driver fixes."
Fix up some fairly trivial conflicts with various other cleanups.
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (67 commits)
dmaengine: imx: fix the build failure on x86_64
dmaengine: i.MX: Fix merge of cookie branch.
dmaengine: i.MX: Add support for interleaved transfers.
dmaengine: imx-dma: use 'dev_dbg' and 'dev_warn' for messages.
dmaengine: imx-dma: remove 'imx_dmav1_baseaddr' and 'dma_clk'.
dmaengine: imx-dma: remove unused arg of imxdma_sg_next.
dmaengine: imx-dma: remove internal structure.
dmaengine: imx-dma: remove 'resbytes' field of 'internal' structure.
dmaengine: imx-dma: remove 'in_use' field of 'internal' structure.
dmaengine: imx-dma: remove sg member from internal structure.
dmaengine: imx-dma: remove 'imxdma_setup_sg_hw' function.
dmaengine: imx-dma: remove 'imxdma_config_channel_hw' function.
dmaengine: imx-dma: remove 'imxdma_setup_mem2mem_hw' function.
dmaengine: imx-dma: remove dma_mode member of internal structure.
dmaengine: imx-dma: remove data member from internal structure.
dmaengine: imx-dma: merge old dma-v1.c with imx-dma.c
dmaengine: at_hdmac: add slave config operation
dmaengine: add context parameter to prep_slave_sg and prep_dma_cyclic
dmaengine/dma_slave: introduce inline wrappers
dma: imx-sdma: Treat firmware messages as warnings instead of erros
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to hide new parameter from current users of affected interfaces.
Convert current users to use new wrappers instead of direct calls.
Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269].
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
Some callbacks are set too early -- i.e. we can have dma capabilities but
we can't get a dma channel. So wait to get the dma channel before setting
callbacks and change logs consequently.
[Should be applied to 3.2-stable.]
There are few existing user drivers of dw_dmac. They will break as soon as we
remove unused fields from struct dw_dma_slave. This patch focuses to fix these
user drivers to use dma_slave_config() routine.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Sometimes a software reset is needed. Then some registers are saved and
restored but the interrupt mask register is missing. It causes issues
with sdio devices whose interrupts are masked after reset.
Cc: stable <stable@vger.kernel.org>
resolved conflicts:
drivers/media/video/mx3_camera.c
fixup usage of dma direction by introducing dma_transfer_direction,
this patch moves mmc drivers to use new enum
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
This patch fixes a potential issue about PDC interrupts. For example we
have a ENDRX pending interrupt and a RXBUFF pending interrupt. We have
received the RXBUFF interrupt but the transfer is not finished (so we
didn't have time to give a new buffer to the PDC controller). Then we
will compute ENDRX interrupt and we will give a new buffer to the PDC
controller, just after we will compute the RXBUFF interrupt and give
one or two new buffers to the PDC controller but we are not sure that
the first buffer given has been filled. So in this situation we may
have "lost" one sg buffer. It's the same for transmission.
Assuming that a sg buffer size is a page size is false so use sg_dma_len.
A 4096 bytes can be required with two 2048-bytes sg buffer.
Rename atmci_start_command() to atmci_send_command() which is more
appropriate; atmci_start_command suggests we're sending a start command.
Add pdc support for atmel-mci. It makes at91-mci driver useless because it
was only used for the old atmel MCI core which has pdc but no dma support.
To allow removing at91-mci, the capabilities of the MCI core are detected
at runtime -- then the driver will use pio, pdc or dma transfers.
Warning: at91rm9200 is not supported, to support it we need to use swab32
on data but I have no board to test it.
Change atmci_readl and atmci_writel macros: remove string concatenation.
We can use these macros with registers which are not prefixed by ATMCI_.
This is the case if we want to write PDC registers which are common to
several devices so they are not prefixed with ATMCI_.
Homogenize namespace to atmci.
Take care of slots while going to suspend state.
Reviewed-by: Felipe Balbi <balbi@ti.com>
Haavard's e-mail address at Atmel is no longer valid.
Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com>
Use the new dmaengine helpers to make the code more readable.
Fixes the following:
- It is perfectly legal for the dma_map_sg() to return fewer
entries than were passed in.
- Supply the returned numer of (possibly coalesced) entries to
the device_pre_slave_sg() function.
- Use the proper original sg_len when unmapping the sglist
in the error path.
As established for the MMCI, it is proper to map the DMA buffers
on the DMA engine which is the one actually performing the DMA.
Based on report made by Yauhen in:
"MMC: Fix multiblock SDIO transfers in AT91 MCI" patch,
I report those changes to the brother driver: atmel-mci.
So, this patch sets SDIO transfer types: SDIO block and SDIO byte
transfers instead of using ordinary MMC block transfers.
It is checking opcode for SDIO CMD53 and setting transfer
type in MCI_CMDR register properly.
Reported-by: Yauhen Kharuzhy <yauhen.kharuzhy@promwad.com>
Cc: <stable@kernel.org>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
We have deprecated the distinction between hardware and physical
segments in the block layer. Consolidate the two limits into one in
drivers/mmc/.
[cjb: rebased patch against Linus]
Cc: <linux-mmc@vger.kernel.org>
Atmel-mci support for SDIO interrupts. This adds the enable_sdio_irq()
function and the configuration of sdio irq mask per slot. With this irq
mask information, we keep the idea of multiple slot per sd/mmc host (not
only A and B). MMC_CAP_SDIO_IRQ is added according to slot configuration.
A new little function is added to run mmc_signal_sdio_irq() during
interrupt handling routine.
Signed-off-by: Anders Grahn <anders.grahn@hd-wireless.se>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Enable high speed support for atmel-mci driver. This support is dependent
of the revision of the IP and, of course, the capacity of the SD card
used.
Reviewed-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Cc: Maciej Sosnowski <maciej.sosnowski@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
DMAENGINE: extend the control command to include an arg
async_tx: trim dma_async_tx_descriptor in 'no channel switch' case
DMAENGINE: DMA40 fix for allocation of logical channel 0
DMAENGINE: DMA40 support paused channel status
dmaengine: mpc512x: Use resource_size
DMA ENGINE: Do not reset 'private' of channel
ioat: Remove duplicated devm_kzalloc() calls for ioatdma_device
ioat3: disable cacheline-unaligned transfers for raid operations
ioat2,3: convert to producer/consumer locking
ioat: convert to circ_buf
DMAENGINE: Support for ST-Ericssons DMA40 block v3
async_tx: use of kzalloc/kfree requires the include of slab.h
dmaengine: provide helper for setting txstate
DMAENGINE: generic channel status v2
DMAENGINE: generic slave control v2
dma: timb-dma: Update comment and fix compiler warning
dma: Add timb-dma
DMAENGINE: COH 901 318 fix bytesleft
DMAENGINE: COH 901 318 rename confusing vars
This adds an argument to the DMAengine control function, so that
we can later provide control commands that need some external data
passed in through an argument akin to the ioctl() operation
prototype.
[dan.j.williams@intel.com: fix up some missed conversions]
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
In debugfs, printing of command response reports resp[2] twice: fix it to
resp[3].
Disable data error interrupts while we are actually recording that there
is not such errors. This will prevent, in some cases, the warning message
printed at new request queuing (in atmci_start_request()).
The removing of an SD card in certain circumstances can lead to a kernel
oops if we do not make sure that the "data" field of the host structure is
valid. This patch adds a test in atmci_dma_cleanup() function and also
calls atmci_stop_dma() before throwing away the reference to data.
Two parameters were swapped in the calls to atmci_init_slot().
Reported-by: Anders Grahn <anders.grahn@hd-wireless.se>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Convert the device_terminate_all() operation on the
DMA engine to a generic device_control() operation
which can now optionally support also pausing and
resuming DMA on a certain channel. Implemented for the
COH 901 318 DMAC as an example.
[dan.j.williams@intel.com: update for timberdale]
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Li Yang <leoli@freescale.com>
Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Cc: Magnus Damm <damm@opensource.se>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Joe Perches <joe@perches.com>
Cc: Roland Dreier <rdreier@cisco.com>
This new revision of the IP adds some improvements to the MCI already
present in several Atmel SOC.
Some new registers are added and a particular way of handling DMA
interaction lead to a new sequence in function call which is backward
compatible: On MCI2, we must set the DMAEN bit to enable the DMA
handshaking interface. This must happen before the data transfer command
is sent.
A new function is able to differentiate MCI2 code and is based on
knowledge of processor id (cpu_is_xxx()).
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Allow the use of another DMA controller driver in atmel-mci sd/mmc driver.
This adds a generic dma_slave pointer to the mci platform structure where
we can store DMA controller information. In atmel-mci we use information
provided by this structure to initialize the driver (with new helper
functions that are architecture dependant).
This also adds at32/avr32 chip modifications to cope with this new access
method.
* 'for-linus' of git://neil.brown.name/md: (97 commits)
md: raid-1/10: fix RW bits manipulation
md: remove unnecessary memset from multipath.
md: report device as congested when suspended
md: Improve name of threads created by md_register_thread
md: remove sparse warnings about lock context.
md: remove sparse waring "symbol xxx shadows an earlier one"
async_tx/raid6: add missing dma_unmap calls to the async fail case
ioat3: fix uninitialized var warnings
drivers/dma/ioat/dma_v2.c: fix warnings
raid6test: fix stack overflow
ioat2: clarify ring size limits
md/raid6: cleanup ops_run_compute6_2
md/raid6: eliminate BUG_ON with side effect
dca: module load should not be an error message
ioat: driver version 4.0
dca: registering requesters in multiple dca domains
async_tx: remove HIGHMEM64G restriction
dmaengine: sh: Add Support SuperH DMA Engine driver
dmaengine: Move all map_sg/unmap_sg for slave channel to its client
fsldma: Add DMA_SLAVE support
Unification of the atmel-mci driver to support the AT91 processors MCI
interface. The atmel-mci driver currently supports the AVR32 and this
patch adds AT91 support.
Add read/write proof selection switch dependent on chip availability of
this feature.
To use this new driver on a at91 the platform driver for your board needs
to be updated.
[nicolas.ferre@atmel.com indent, Kconfig comment and one printk modification]
Signed-off-by: Rob Emanuele <rob@emanuele.us>
Cc: Andrew Victor <linux@maxim.org.za>
Dan Williams wrote:
... DMA-slave clients request specific channels and know the hardware
details at a low level, so it should not be too high an expectation to
push dma mapping responsibility to the client.
Also this patch includes DMA_COMPL_{SRC,DEST}_UNMAP_SINGLE support for
dw_dmac driver.
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Same patch as before, modified to use bool. Also adds description of
the new field in struct atmel_mci that I missed in the first patch.
This patch adds Atmel MCI support for inverted detect pins.
Signed-off-by: Jonas Larsson <jonas.larsson@martinsson.se>
Acked-by: Pierre Ossman <pierre@ossman.eu>
This fixes a bug when setting the sdc_reg for 4-bit bus width
transactions.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
The conversion of atmel-mci to dma_request_channel missed the
initialization of the channel dma_slave information. The filter_fn passed
to dma_request_channel is responsible for initializing the channel's
private data. This implementation has the additional benefit of enabling
a generic client-channel data passing mechanism.
Reviewed-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (22 commits)
ioat: fix self test for multi-channel case
dmaengine: bump initcall level to arch_initcall
dmaengine: advertise all channels on a device to dma_filter_fn
dmaengine: use idr for registering dma device numbers
dmaengine: add a release for dma class devices and dependent infrastructure
ioat: do not perform removal actions at shutdown
iop-adma: enable module removal
iop-adma: kill debug BUG_ON
iop-adma: let devm do its job, don't duplicate free
dmaengine: kill enum dma_state_client
dmaengine: remove 'bigref' infrastructure
dmaengine: kill struct dma_client and supporting infrastructure
dmaengine: replace dma_async_client_register with dmaengine_get
atmel-mci: convert to dma_request_channel and down-level dma_slave
dmatest: convert to dma_request_channel
dmaengine: introduce dma_request_channel and private channels
net_dma: convert to dma_find_channel
dmaengine: provide a common 'issue_pending_all' implementation
dmaengine: centralize channel allocation, introduce dma_find_channel
dmaengine: up-level reference counting to the module level
DMA_NAK is now useless. We can just use a bool instead.
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
All users have been converted to either the general-purpose allocator,
dma_find_channel, or dma_request_channel.
