path: root/drivers/mmc/host/Kconfig
2012-03-28Merge tag 'mmc-merge-for-3.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC updates from Chris Ball: Core: * Support for MMC 4.5 Data Tag feature -- we tag REQ_META, so devices that support Data Tag will provide increased throughput for metadata. * Faster detection of card removal on I/O errors. Drivers: * dw_mmc now supports eMMC Power Off Notify, has PCI support, and implements pre_req and post_req for asynchronous requests. * omap_hsmmc now supports device tree. * esdhc now has power management support. * sdhci-tegra now supports Tegra30 devices. * sdhci-spear now supports hibernation. * tmio_mmc now supports using a GPIO for card detection. * Intel PCH now supports 8-bit bus transfers. * tag 'mmc-merge-for-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (53 commits) mmc: sh_mmcif: simplify bitmask macros mmc: sh_mobile_sdhi: support modular mmc-core with non-standard hotplug mmc: sh_mobile_sdhi: add a callback for board specific init code mmc: tmio: cosmetic: prettify the tmio_mmc_set_ios() function mmc: sh_mobile_sdhi: do not manage PM clocks manually mmc: tmio_mmc: remove unused sdio_irq_enabled flag mmc: tmio_mmc: power status flag doesn't have to be exposed in platform data mmc: sh_mobile_sdhi: pass card hotplug GPIO number to TMIO MMC mmc: tmio_mmc: support the generic MMC GPIO card hotplug helper mmc: tmio: calculate the native hotplug condition only once mmc: simplify mmc_cd_gpio_request() by removing two parameters mmc: sdhci-pci: allow 8-bit bus width for Intel PCH mmc: sdhci: check interrupt flags in ISR again mmc: sdhci-pci: Add MSI support mmc: core: warn when card doesn't support HPI mmc: davinci: Poll status for small size transfers mmc: davinci: Eliminate spurious interrupts mmc: omap_hsmmc: Avoid a regulator voltage change with dt mmc: omap_hsmmc: Convert hsmmc driver to use device tree mmc: sdhci-pci: add SDHCI_QUIRK2_HOST_OFF_CARD_ON for Medfield SDIO ...
2012-03-25mmc: Support of PCI mode in the dw_mmc driverShashidhar Hiremath
Support of PCI mode for the dw_mmc driver. This Patch adds the support for the scenario where the Synopsys Designware IP is present on the PCI bus. The patch adds the minimal modifications necessary for the driver to work on PCI platform. Also added separate files for PCI and PLATFORM modes of operation. Signed-off-by: Shashidhar Hiremath <shashidharh@vayavyalabs.com> Acked-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-03-08Merge branch 'next/cleanup-s3c24xx' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup * 'next/cleanup-s3c24xx' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (24 commits) ARM: S3C24XX: remove call to s3c24xx_setup_clocks ARM: S3C24XX: add get_rate for clk_p on S3C2416/2443 ARM: S3C24XX: add get_rate for clk_h on S3C2416/2443 ARM: S3C24XX: remove XXX_setup_clocks method from S3C2443 ARM: S3C24XX: remove obsolete S3C2416_DMA option ARM: S3C24XX: Reuse S3C2443 dma for S3C2416 ARM: S3C24XX: Fix indentation of dma-s3c2443 ARM: S3C24XX: Move device setup files to mach directory ARM: S3C24XX: Consolidate Simtec extensions ARM: S3C24XX: move simtec-specific code to mach directory ARM: S3C24XX: Move common-smdk code to mach directory ARM: S3C24XX: Move s3c2443-clock.c to mach-s3c24xx ARM: s3c2410_defconfig: update s3c2410_defconfig ARM: S3C2443: move mach-s3c2443/* into mach-s3c24xx/ ARM: S3C2440: move mach-s3c2440/* into mach-s3c24xx/ ARM: S3C2416: move mach-s3c2416/* into mach-s3c24xx/ ARM: S3C2412: move mach-s3c2412/* into mach-s3c24xx/ ARM: S3C2410: move mach-s3c2410/* into mach-s3c24xx/ ARM: S3C24XX: change the ARCH_S3C2410 to ARCH_S3C24XX ARM: S3C2410: move s3c2410_baseclk_add to clock.h ...
2012-03-03ARM: S3C24XX: change the ARCH_S3C2410 to ARCH_S3C24XXKukjin Kim
This patch changes the ARCH name to "ARCH_S3C24XX" for Samsung S3C2410, S3C2412, S3C2413, S3C2416, S3C2440, S3C2442, S3C2443, and S3C2450 SoCs so that we can merge the mach-xxx directories and plat-s3c24xx dir. to just one mach-s3c24xx for them. I think this should be sent to upstream via samsung tree because this touches many samsung stuff. Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Greg Kroah-Hartman <gregkh@suse.de> [for the gadget part:] Acked-by: Felipe Balbi <balbi@ti.com> [for the framebuffer (video) part:] Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> [For the watchdog-part:] Acked-by: Wim Van Sebroeck <wim@iguana.be> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2012-01-24drivers: misc: Remove MISC_DEVICES config optionFabio Estevam
MISC_DEVICES option alone does not select any kernel code and can cause dependency build warnings, such as: warning: (KS8851 && AX88796_93CX6 && RTL8180 && RTL8187 && ADM8211 && RT2400PCI && RT2500PCI && RT61PCI && RT2800PCI && R8187SE) selects EEPROM_93CX6 which has unmet direct dependencies (MISC_DEVICES) As the current drivers/misc/Kconfig stands, it is only possible to select the drivers below if MISC_DEVICES option is selected: source "drivers/misc/c2port/Kconfig" source "drivers/misc/eeprom/Kconfig" source "drivers/misc/cb710/Kconfig" source "drivers/misc/iwmc3200top/Kconfig" source "drivers/misc/ti-st/Kconfig" source "drivers/misc/lis3lv02d/Kconfig" source "drivers/misc/carma/Kconfig" source "drivers/misc/altera-stapl/Kconfig" So remove MISC_DEVICES option so that nothing is dependant on it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-03Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (37 commits) MIPS: O32: Provide definition of registers ta0 .. ta3. MIPS: perf: Add Octeon support for hardware perf. MIPS: perf: Add support for 64-bit perf counters. MIPS: perf: Reorganize contents of perf support files. MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.c MIPS: Add accessor macros for 64-bit performance counter registers. MIPS: Add probes for more Octeon II CPUs. MIPS: Add more CPU identifiers for Octeon II CPUs. MIPS: XLR, XLS: Add comment for smp setup MIPS: JZ4740: GPIO: Check correct IRQ in demux handler MIPS: JZ4740: GPIO: Simplify IRQ demuxer MIPS: JZ4740: Use generic irq chip MIPS: Alchemy: remove all CONFIG_SOC_AU1??? defines MIPS: Alchemy: kill au1xxx.h header MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? defines MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header dep MIPS: Alchemy: Redo PCI as platform driver MIPS: Alchemy: more base address cleanup MIPS: Alchemy: rewrite USB platform setup. MIPS: Alchemy: abstract USB block control register access ... Fix up trivial conflicts in: arch/mips/alchemy/devboards/db1x00/platform.c drivers/ide/Kconfig drivers/mmc/host/au1xmmc.c drivers/video/Kconfig sound/mips/Kconfig
2011-10-26mmc: sdhci-esdhc-imx: add basic imx6q usdhc supportShawn Guo
This patch adds the basic support for imx6q usdhc, which is a derivative of esdhc controller. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-10-26mmc: Kconfig: remove i.MX individual SoC dependencySascha Hauer
The individual SoC dependency in Kconfig hardly scales anymore. Instead of having such a fine grained dependency just depend on ARCH_MXC and risk that the uninformed user has to look in the help text to figure out which driver is the correct one. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-10-24MIPS: Alchemy: remove all CONFIG_SOC_AU1??? definesManuel Lauss
Now that no driver any longer depends on the CONFIG_SOC_AU1??? symbols, it's time to get rid of them: Move some of the platform devices to the boards which can use them, Rename a few (unused) constants in the header, Replace them with MIPS_ALCHEMY in the various Kconfig files. Finally delete them altogether from the Alchemy Kconfig file. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2707/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-20mmc: kconfig: remove EXPERIMENTAL from the DMA selection of atmel-mciNicolas Ferre
This driver has been used for years with this option enabled. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20mmc: host: delete obsolete sdhci-pxa.cZhangfei Gao
Delete obsolete sdhci-pxa.c, which was previously shared amongst the entire PXA series. Instead we now use sdhci-pxav3.c for mmp2 and sdhci-pxav2.c for pxa9xx. Signed-off-by: Zhangfei Gao <zhangfei.gao@marvell.com> Acked-by: Philip Rakity <prakity@marvell.com> Acked-by: Mark F. Brown <mark.brown314@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20mmc: host: split up sdhci-pxa, create sdhci-pxav2.cZhangfei Gao
sdhci-pltfm driver for PXAV2 SoCs, such as pxa910. Signed-off-by: Zhangfei Gao <zhangfei.gao@marvell.com> Signed-off-by: Jun Nie <njun@marvell.com> Signed-off-by: Qiming Wu <wuqm@marvell.com> Acked-by: Philip Rakity <prakity@marvell.com> Acked-by: Mark F. Brown <mark.brown314@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20mmc: host: split up sdhci-pxa, create sdhci-pxav3.cZhangfei Gao
sdhci-pltfm driver for PXAV3 SoCs, such as MMP2. Signed-off-by: Zhangfei Gao <zhangfei.gao@marvell.com> Signed-off-by: Philip Rakity <prakity@marvell.com> Acked-by: Philip Rakity <prakity@marvell.com> Acked-by: Mark F. Brown <mark.brown314@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20mmc: sdhci: change sdhci-pltfm into a moduleShawn Guo
There are a couple of problems left from the sdhci pltfm and OF consolidation changes. * When building more than one sdhci-pltfm based drivers in the same image, linker will give multiple definition error on the sdhci-pltfm helper functions. For example right now, building sdhci-of-esdhc and sdhci-of-hlwd together is a valid combination from Kconfig view. * With the current build method, there is error with building the drivers as module, but module installation fails with modprobe. The patch fixes above problems by changing sdhci-pltfm into a module. To avoid EXPORT_SYMBOL on so many big endian IO accessors, it moves these accessors into sdhci-pltfm.h as the 'static inline' functions. As a result, sdhci.h needs to be included in sdhci-pltfm.h, and in turn can be removed from individual drivers which already include sdhci-pltfm.h. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20mmc: sdhci: make sdhci-of device drivers self registeredShawn Guo
The patch turns the sdhci-of-core common stuff into helper functions added into sdhci-pltfm.c, and makes sdhci-of device drviers self registered using the same pair of .probe and .remove used by sdhci-pltfm device drivers. As a result, sdhci-of-core.c and sdhci-of.h can be eliminated with those common things merged into sdhci-pltfm.c and sdhci-pltfm.h respectively. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20mmc: sdhci: make sdhci-pltfm device drivers self registeredShawn Guo
The patch turns the common stuff in sdhci-pltfm.c into functions, and add device drivers their own .probe and .remove which in turn call into the common functions, so that those sdhci-pltfm device drivers register itself and keep all device specific things away from common sdhci-pltfm file. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-05-24mmc: Add new VUB300 USB-to-SD/SDIO/MMC driverTony Olech
Add a driver for Elan Digital System's VUB300 chip which is a USB connected SDIO/SDmem/MMC host controller. A VUB300 chip enables a USB 2.0 or USB 1.1 connected host computer to use SDIO/SD/MMC cards without the need for a directly connected, for example via PCI, SDIO host controller. Signed-off-by: Anthony F Olech <tony.olech@elandigitalsystems.com> [cjb: various punctuation and style fixes] Tested-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-05-24mmc: sdhci: change CONFIG of MMC_SDHCI_TEGRA from 'tristate' to 'bool'Shawn Guo
This config option is used to decide whether tegra sdhci support should be build into the sdhci-platform module. So setting it 'm' is nonsense, since we can't build part of an module as a module. The effect for 'm' will probably be the same as for 'n'. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-28mmc: SDHI should depend on SUPERH || ARCH_SHMOBILEGuennadi Liakhovetski
Fix build breakage on platforms, not providing readsw and writesw functions, e.g., on x86(_64). Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-25mmc: tmio: convert the SDHI MMC driver from MFD to a platform driverGuennadi Liakhovetski
On sh-mobile platforms the SDHI driver was using the tmio_mmc SD/SDIO MFD cell driver. Now that the tmio_mmc driver has been split into a core and a separate MFD glue, we can support SDHI natively without the need to emulate an MFD controller. This also allows to support systems with an on-SoC SDHI controller and a separate MFD with a TMIO core. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-25mmc: tmio: split core functionality, DMA and MFD glueGuennadi Liakhovetski
TMIO MMC chips contain an SD / SDIO IP core from Panasonic, similar to the one, used in MN5774 and other MN57xx controllers. These IP cores are included in many multifunction devices, in sh-mobile chips from Renesas, in the latter case they can also use DMA. Some sh-mobile implementations also have some other specialities, that MFD-based solutions don't have. This makes supporting all these features in a monolithic driver inconveniet and error-prone. This patch splits the driver into 3 parts: the core, the MFD glue and the DMA support. In case of a modular build, two modules will be built: mmc_tmio_core and mmc_tmio. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (53 commits) mmc: dw_mmc: support mmc power control with regulator mmc: dw_mmc: fix suspend/resume operation mmc: dw_mmc: add quirks for unreliable card detect, and capabilities mmc: tmio: fix address in kunmap_atomic() calls mmc: core: reset card voltage after power off mmc: core: export function mmc_do_release_host() mmc: sdio: remember new card RCA when redetecting card mmc: dw_mmc: Remove set-but-unused variable. mmc: sdhci-esdhc-imx: add card detect on custom GPIO for mx25/35 mmc: sdhci-esdhc: broken card detection is not a default quirk mmc: sdhci-esdhc-imx: add write protect on custom GPIO on mx25/35 mmc: msm_sdcc: remove needless cache flush after dma_unmap_sg() mmc: sh_mmcif: support aggressive clock gating mmc: check if mmc cards < 2GB do sector addressing mmc: core: comment on why sdio_reset is done at init time mmc: dw_mmc: support DDR mode mmc: via-sdmmc: Remove set-but-unused variable. mmc: cb710: Return err value in cb710_wait_while_busy() mmc: sdhci-pci: Remove set-but-unused variable. mmc: mxs-mmc: add mmc host driver for i.MX23/28 ...
2011-03-15mmc: mxs-mmc: add mmc host driver for i.MX23/28Shawn Guo
This adds the mmc host driver for Freescale MXS-based SoC i.MX23/28. The driver calls into mxs-dma via generic dmaengine api for both pio and data transfer. Thanks Chris Ball for the indentation patch. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-03-15mmc: mmc_mxc: Allow selection only for the correct platformsFabio Estevam
Currently MMC_MXC driver can be selected by all i.MX devices. Restrict its use only for the appropriate processors. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-27omap: Start using CONFIG_SOC_OMAPTony Lindgren
We want to have just CONFIG_ARCH_OMAP2, 3 and 4. The rest are nowadays just subcategories of these. Search and replace the following: ARCH_OMAP2420 SOC_OMAP2420 ARCH_OMAP2430 SOC_OMAP2430 ARCH_OMAP3430 SOC_OMAP3430 No functional changes. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Sourav Poddar <sourav.poddar@ti.com>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (39 commits) mmc: davinci: add support for SDIO irq handling mmc: fix division by zero in MMC core mmc: tmio_mmc: fix CMD irq handling mmc: tmio_mmc: handle missing HW interrupts mfd: sh_mobile_sdhi: activate SDIO IRQ for tmio_mmc mmc: tmio_mmc: implement SDIO IRQ support mfd: sdhi: require the tmio-mmc driver to bounce unaligned buffers mmc: tmio_mmc: silence compiler warnings mmc: tmio_mmc: implement a bounce buffer for unaligned DMA mmc: tmio_mmc: merge the private header into the driver mmc: tmio_mmc: fix PIO fallback on DMA descriptor allocation failure mmc: tmio_mmc: allow multi-element scatter-gather lists mmc: Register debugfs dir before calling card probe function. mmc: MMC_BLOCK_MINORS should depend on MMC_BLOCK. mmc: Explain why we make adjacent mmc_bus_{put,get} calls during rescan. mmc: Fix sd/sdio/mmc initialization frequency retries mmc: fix mmc_set_bus_width_ddr() call without bus-width-test cap mmc: dw_mmc: Add Synopsys DesignWare mmc host driver. mmc: add sdhci-tegra driver for Tegra SoCs mmc: sdhci: add quirk for max len ADMA descriptors ...
2011-01-08mmc: dw_mmc: Add Synopsys DesignWare mmc host driver.Will Newton
This adds the mmc host driver for the Synopsys DesignWare mmc host controller, found in a number of embedded SoC designs. Signed-off-by: Will Newton <will.newton@imgtec.com> Reviewed-by: Matt Fleming <matt@console-pimps.org> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: add sdhci-tegra driver for Tegra SoCsOlof Johansson
SDHCI driver for Tegra. This driver plugs in as a new variant of sdhci-pltfm, using the platform data structure passed in to specify the GPIOs to use for card detect, write protect and card power enablement. Original driver (of which only the header file is left): Signed-off-by: Yvonne Yip <y@palm.com> The rest, which has been rewritten by now: Signed-off-by: Olof Johansson <olof@lixom.net> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: Add support for the Marvell Dove SDHCI controllerMike Rapoport
Implement an sdhci-pltfm driver for the controller found in the Marvell Dove SoC. Signed-off-by: Mike Rapoport <mike@compulab.co.il> CC: Saeed Bishara <saeed@marvell.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-03of: make drivers depend on CONFIG_OF instead of CONFIG_PPC_OFRob Herring
Some OF drivers could likely be used on non-powerpc OF based platforms, so fix the kconfig depends to be CONFIG_OF instead of CONFIG_PPC_OF. Compile tested on ARM and sparc. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (66 commits) mmc: add new sdhci-pxa driver for Marvell SoCs mmc: make number of mmcblk minors configurable mmc_spi: Recover from CRC errors for r/w operation over SPI. mmc: sdhci-pltfm: add -pltfm driver for imx35/51 mmc: sdhci-of-esdhc: factor out common stuff mmc: sdhci_pltfm: pass more data on custom init call mmc: sdhci: introduce get_ro private write-protect hook mmc: sdhci-pltfm: move .h file into appropriate subdir mmc: sdhci-pltfm: Add structure for host-specific data mmc: fix cb710 kconfig dependency warning mmc: cb710: remove debugging printk (info duplicated from mmc-core) mmc: cb710: clear irq handler on init() error path mmc: cb710: remove unnecessary msleep() mmc: cb710: implement get_cd() callback mmc: cb710: partially demystify clock selection mmc: add a file to debugfs for changing host clock at runtime mmc: sdhci: allow for eMMC 74 clock generation by controller mmc: sdhci: highspeed: check for mmc as well as sd cards mmc: sdhci: Add Moorestown device support mmc: sdhci: Intel Medfield support ...
2010-10-26at91/atmel-mci: inclusion of sd/mmc driver in at91sam9g45 chip and boardNicolas Ferre
This adds the support of atmel-mci sd/mmc driver in at91sam9g45 devices and board files. This also configures the DMA controller slave interface for at_hdmac dmaengine driver. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-10-25mmc: add new sdhci-pxa driver for Marvell SoCsZhangfei Gao
Support Marvell PXA168/PXA910/MMP2 SD Host Controller. Signed-off-by: Zhangfei Gao <zhangfei.gao@marvell.com> Acked-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: sdhci-pltfm: add -pltfm driver for imx35/51Wolfram Sang
This driver adds basic support for the esdhc-core found on e.g. imx35/51, as a platform driver. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Tested-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: fix cb710 kconfig dependency warningRandy Dunlap
Fix kconfig dependency warning to satisfy dependencies: warning: (MMC_CB710 && MMC && PCI) selects CB710_CORE which has unmet direct dependencies (MISC_DEVICES && PCI) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: USB SD Host Controller (USHC) driverDavid Vrabel
Add a driver for USB SD Host Controller devices. These devices are Cypress Astoria chips with firmware compliant with issue 2 of CSR's USHC specification. [cjb: adapt to block layer deprecation of max_{hw,phys}_segs] Signed-off-by: David Vrabel <david.vrabel@csr.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-08-20s5pc110: SDHCI-s3c support on s5pc110Kyungmin Park
s5pc110 (aka s5pv210) uses the same SDHCI IP. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13Merge branch 'msm-mmc_sdcc' of ↵Linus Torvalds
git://codeaurora.org/quic/kernel/dwalker/linux-msm * 'msm-mmc_sdcc' of git://codeaurora.org/quic/kernel/dwalker/linux-msm: mmc: msm_sdcc: Rename config MMC_MSM7X00A to MMC_MSM mmc: msm_sdcc: Compile the driver for msm7x30 mmc: msm: fix up build breakage on !PM
2010-08-11sdhci-pltfm: add support for CNS3xxx SoC devicesAnton Vorontsov
There's nothing special, just SoC-specific ops and quirks. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com> Cc: Ben Dooks <ben@simtec.co.uk> Cc: Richard R?jfors <richard.rojfors@pelagicore.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mmc: msm_sdcc: Rename config MMC_MSM7X00A to MMC_MSMSahitya Tummala
SD/MMC host controller driver is same for all MSM and QSD platforms. Hence, rename the config to reflect the same. Signed-off-by: Sahitya Tummala <stummala@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2010-08-09mmc: msm_sdcc: Compile the driver for msm7x30Sahitya Tummala
The controller base address is referred from platform resource instead of using #defines. This fixes the compilation error when driver is compiled for msm7x30. Signed-off-by: Sahitya Tummala <stummala@codeaurora.org> Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2010-08-05MMC: Add support for the controller on JZ4740 SoCs.Lars-Peter Clausen
Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Matt Fleming <matt@console-pimps.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Matt Fleming <matt@console-pimps.org> Cc: linux-mmc@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1463/ Patchwork: https://patchwork.linux-mips.org/patch/1523/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-06-09mmc: msm: fix compile error on MSM7x30Daniel Walker
MSM7x30 isn't supported in this driver yet. If ones tried to compile it in with MSM7x30 configure you get, linux-2.6/drivers/mmc/host/msm_sdcc.c: In function 'msmsdcc_fifo_addr': linux-2.6/drivers/mmc/host/msm_sdcc.c:165: error: 'MSM_SDC1_PHYS' undeclared (first use in this function) linux-2.6/drivers/mmc/host/msm_sdcc.c:165: error: (Each undeclared identifier is reported only once linux-2.6/drivers/mmc/host/msm_sdcc.c:165: error: for each function it appears in.) linux-2.6/drivers/mmc/host/msm_sdcc.c:167: error: 'MSM_SDC2_PHYS' undeclared (first use in this function) linux-2.6/drivers/mmc/host/msm_sdcc.c:169: error: 'MSM_SDC3_PHYS' undeclared (first use in this function) linux-2.6/drivers/mmc/host/msm_sdcc.c:171: error: 'MSM_SDC4_PHYS' undeclared (first use in this function) So we add a Kconfig check to prevent this. Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
2010-05-27sdhci-spear: ST SPEAr based SDHCI controller glueViresh KUMAR
Add a glue layer to support the sdhci driver on the ST SPEAr platform. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Cc: <shiraz.hashim@st.com> Cc: Linus Walleij <linus.ml.walleij@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27mmc: add support MMCIF for SuperHYusuke Goda
MMCIF is the MMC Host Interface in SuperH. Signed-off-by: Yusuke Goda <yusuke.goda.sx@renesas.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-07mfd/mmc: SDHI Kconfig updateMagnus Damm
Enable the sh_mobile_sdhi mfd driver on SH-Mobile ARM processors. While at it, make CONFIG_TMIO_MMC depend on CONFIG_MFD_SH_MOBILE_SDHI. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-06mmc: bfin_sdh: drop redundant MMC depend stringMike Frysinger
The host/Kconfig file is only included when MMC is selected. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mmc: Atmel host kconfig cleanup for everyone elseNicolas Ferre
This prevents those without an Atmel chip having a line in kernel configuration which says "Atmel SD/MMC Driver" without any option. Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
