path: root/drivers/misc/tifm_7xx1.c
2007-06-01misc/tifm_7xx1: replace deprecated irq flagJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08disable socket power in adapter driver instead of media oneAlex Dubov
Socket power must be fully controlled by adapter driver. This also prevents unnecessary power-off of the socket when media driver is unloaded, yet media remains in the socket. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01tifm: add missing include for DMA_32BIT_MASKAndrew Morton
sparc64: drivers/misc/tifm_7xx1.c: In function `tifm_7xx1_probe': drivers/misc/tifm_7xx1.c:294: error: `DMA_32BIT_MASK' undeclared Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01tifm: layout fixes, small changes to comments and printfsAlex Dubov
Cosmetic changes to the code. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01tifm_7xx1: fix adapter resume functionAlex Dubov
Fixes to the adapter resume function to correctly handle all possible cases: 1. Card is removed during suspend 2. Card is inserted during suspend into previously empty socket 3. Card is replaced during suspend by same or different media type card. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01tifm: move common device management tasks from tifm_7xx1 to tifm_coreAlex Dubov
Some details of the device management (create, add, remove) are really belong to the tifm_core, as they are not hardware specific. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01tifm: move common adapter management tasks from tifm_7xx1 to tifm_coreAlex Dubov
Some details of the adapter management (create, add, remove) are really belong to the tifm_core, as they are not hardware specific. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01tifm_7xx1: improve card detection routineAlex Dubov
Remove unneeded conditions and change a sleeping regime a little in the card type detection routine. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01tifm: replace per-adapter kthread with freezeable workqueueAlex Dubov
Freezeable workqueue makes sure that adapter work items (device insertions and removals) would be handled after the system is fully resumed. Previously this was achieved by explicit freezing of the kthread. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01tifm: simplify bus match and uevent handlersAlex Dubov
Remove code duplicating the kernel functionality and clean up data structures involved in driver matching. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-01tifm: hide details of interrupt processing from socket driversAlex Dubov
Instead of passing transformed value of adapter interrupt status to socket drivers, implement two separate callbacks - one for card events and another for dma events. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-04tifm_7xx1: prettifyAlex Dubov
Fix some spaces and tabs. No semantic changes are introduced. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-02-04tifm_7xx1: recognize device 0xac8f as supportedAlex Dubov
This patch also adds symbolic defines for supported pci ids. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-02-04tifm_7xx1: switch from workqueue to kthreadAlex Dubov
As there's only one work item (media_switcher) to handle and it's effectively serialized with itself, I found it more convenient to use kthread instead of workqueue. This also allows for a working implementation of suspend/resume, which were totally broken in the past version. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-02-04tifm_7xx1: Merge media insert and media remove functionsAlex Dubov
Hardware does not say whether card was inserted or removed when reporting socket events. Moreover, during suspend, media can be removed or switched to some other card type without notification. Therefore, for each socket in the change set the following is performed: 1. If there's active device in the socket it's unregistered 2. Media detection is performed 3. If detection recognizes supportable media, new device is registered This patch also alters some macros and variable names to enhance clarity. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-02-04tifm_7xx1: simplify eject functionAlex Dubov
Eject function can take advantage of the socket_id field instead of explicit pointer comparison. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-02-04Add dummy_signal_irq function to save check in ISRAlex Dubov
2007-02-04Remove unused return value from signal_irq callbackAlex Dubov
2007-02-04tifm_sd: restructure initialization, removal and command handlingAlex Dubov
In order to support correct suspend and resume several changes were needed: 1. Switch from work_struct to tasklet for command handling. When device suspend is called workqueues are already frozen and can not be used. 2. Separate host initialization code from driver's probe and don't rely on interrupts for host initialization. This, in turn, addresses two problems: a) Resume needs to re-initialize the host, but can not assume that device interrupts were already re-armed. b) Previously, probe will return successfully before really knowing the state of the host, as host interrupts were not armed in time. Now it uses polling to determine the real host state before returning. 3. Separate termination code from driver's remove. Termination may be caused by resume, if media changed type or became unavailable during suspend. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-09[PATCH] tifm __iomem annotations, NULL noise removalAl Viro
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04[PATCH] mmc: driver for TI FlashMedia card reader - sourceAlex Dubov
Driver for TI Flash Media card reader. At present, only MMC/SD cards are supported. [akpm@osdl.org: cleanups, build fixes] Signed-off-by: Alex Dubov <oakad@yahoo.com> Cc: Daniel Qarras <dqarras@yahoo.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
