path: root/drivers/misc/ti-st
2013-02-21Merge tag 'char-misc-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg Kroah-Hartman: "Here's the big char/misc driver patches for 3.9-rc1. Nothing major here, just lots of different driver updates (mei, hyperv, ipack, extcon, vmci, etc.). All of these have been in the linux-next tree for a while." * tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (209 commits) w1: w1_therm: Add force-pullup option for "broken" sensors w1: ds2482: Added 1-Wire pull-up support to the driver vme: add missing put_device() after device_register() fails extcon: max8997: Use workqueue to check cable state after completing boot of platform extcon: max8997: Set default UART/USB path on probe extcon: max8997: Consolidate duplicate code for checking ADC/CHG cable type extcon: max8997: Set default of ADC debounce time during initialization extcon: max8997: Remove duplicate code related to set H/W line path extcon: max8997: Move defined constant to header file extcon: max77693: Make max77693_extcon_cable static extcon: max8997: Remove unreachable code extcon: max8997: Make max8997_extcon_cable static extcon: max77693: Remove unnecessary goto statement to improve readability extcon: max77693: Convert to devm_input_allocate_device() extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming style CREDITS: update email and address of Harald Hoyer extcon: arizona: Use MICDET for final microphone identification extcon: arizona: Always take the first HPDET reading as the final one extcon: arizona: Clear _trig_sts bits after jack detection extcon: arizona: Don't HPDET magic when headphones are enabled ...
2013-01-25Merge 3.8-rc5 into tty-nextGreg Kroah-Hartman
This resolves a number of tty driver merge issues found in linux-next Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-22Revert "drivers/misc/ti-st: remove gpio handling"Luciano Coelho
This reverts commit eccf2979b2c034b516e01b8a104c3739f7ef07d1. The reason is that it broke TI WiLink shared transport on Panda. Also, callback functions should not be added to board files anymore, so revert to implementing the power functions in the driver itself. Additionally, changed a variable name ('status' to 'err') so that this revert compiles properly. Cc: stable <stable@vger.kernel.org> [3.7] Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21Revert "drivers/misc/ti-st: remove gpio handling"Luciano Coelho
This reverts commit eccf2979b2c034b516e01b8a104c3739f7ef07d1. The reason is that it broke TI WiLink shared transport on Panda. Also, callback functions should not be added to board files anymore, so revert to implementing the power functions in the driver itself. Additionally, changed a variable name ('status' to 'err') so that this revert compiles properly. Cc: stable <stable@vger.kernel.org> [3.7] Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-18tty: Added a CONFIG_TTY option to allow removal of TTYJoe Millenbach
The option allows you to remove TTY and compile without errors. This saves space on systems that won't support TTY interfaces anyway. bloat-o-meter output is below. The bulk of this patch consists of Kconfig changes adding "depends on TTY" to various serial devices and similar drivers that require the TTY layer. Ideally, these dependencies would occur on a common intermediate symbol such as SERIO, but most drivers "select SERIO" rather than "depends on SERIO", and "select" does not respect dependencies. bloat-o-meter output comparing our previous minimal to new minimal by removing TTY. The list is filtered to not show removed entries with awk '$3 != "-"' as the list was very long. add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350) function old new delta chr_dev_init 166 170 +4 allow_signal 80 82 +2 static.__warned 143 142 -1 disallow_signal 63 62 -1 __set_special_pids 95 94 -1 unregister_console 126 121 -5 start_kernel 546 541 -5 register_console 593 588 -5 copy_from_user 45 40 -5 sys_setsid 128 120 -8 sys_vhangup 32 19 -13 do_exit 1543 1526 -17 bitmap_zero 60 40 -20 arch_local_irq_save 137 117 -20 release_task 674 652 -22 static.spin_unlock_irqrestore 308 260 -48 Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reviewed-by: Jamey Sharp <jamey@minilop.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17misc: st_core: Error triggered by convert "char" to "int"channing
When st driver decodes protocol index received from raw data, it does a value convert from "char" to "int". Because it's sign extension from bit8 to bit32, the "int" value maybe minus, in another word, the protocol index might be minus, but driver doesn't filter such case and may continue access memory pointed by this minus index. This patch is to change the variable type of index from "int" to "unsigned char", so that it avoids do such kind of type conversion. cc: liu chuansheng <chuansheng.liu@intel.com> Signed-off-by: channing <chao.bi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26misc/st_kim: Free resources in the error path of probe()Matthias Kaehlcke
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-24drivers:misc: ti-st: fix potential NULL pointer dereference in st_register()Wei Yongjun
Remove the pointless NULL dereference above the NULL test. dpatch engine is used to auto generate this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16drivers/misc/ti-st: check chip_awake NULL checkMatthias Kaehlcke
Before calling on any of the platform hooks, shared transport driver checks for the validity of the platform hooks as to whether it is provided or not. A wrong function was being checked for, before the chip_awake hook was called by the HCI-LL sleep logic handler. This patch corrects the check. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16drivers/misc/ti-st: fix read fw version cmdPavan Savoy
If the read firmware version response from the chip is split into multiple frames of UART buffer being received by the host, the TI-ST driver as of today is unable to put the pieces of response together unlike other responses. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16drivers/misc/ti-st: use cpu friendly completionsPavan Savoy
Be nice to CPU and don't hog the resources, use a nice wait_for_interruptible timeout for completions instead of wait_for_timeout which is non-interruptible. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16drivers/misc/ti-st: chip_disable on timeoutPavan Savoy
If the communication with the WiLink breaks down for whatever reasons & the ti-st driver is unable to un-install the line-discipline during clean-up in st_kim_stop, the GPIO should be held low (BT_EN=0) & the platform's chip disable hook shall also be called. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16drivers/misc/ti-st: remove sparse warningsPavan Savoy
remove sparse warnings by assigning right storage specifiers to functions and also clean-up the declarations in the include/linux/ti_wilink_st.h Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16drivers/misc/ti-st: remove gpio handlingPavan Savoy
A platform hook to enable/disable the chip was introduced to perform specific activities to power-up and power-down the WL chip. Moving the power-up/down sequence also there makes more sense, since different platforms have begun to have their own ways to power-up/down the chip. This patch removes all of the gpio handling done by the driver in st_kim_start/st_kim_stop & any of the gpio request done in the probe function. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-30drivers/misc/ti-st/st_core.c: missing NULL checkAlan Cox
Addresses https://bugzilla.kernel.org/show_bug.cgi?44431 Reported-by: <rucsoftsec@gmail.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-24MISC: convert drivers/misc/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/misc/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Ira W. Snyder <iws@ovro.caltech.edu> Cc: Pavan Savoy <pavan_savoy@ti.com> Cc: Donggeun Kim <dg77.kim@samsung.com> Acked-By: Pratyush Anand <pratyush.anand@st.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Pratyush Anand <pratyush.anand@st.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-04drivers:misc: ti-st: DEBUG uart, baud rate modsPavan Savoy
To debug different UARTs at different baud-rates connected to the WiLink connectivity combo-chipset, this patch enables the debugging code so that upon boot different UARTs at different baud-rates can be tried out to verify the interface with WiLink. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-04drivers:misc: ti-st: flush UART upon fw failurePavan Savoy
Upon failure to read firmware version from chip or upon failure in responses to firmware download the UART needs to be flushed of its existing buffers so that the UIM can restart UART properly. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-04drivers:misc: ti-st: protect registrationsPavan Savoy
Concurrent access to UART2/combo-interface by multiple protocol drivers such as BT, FM and GPS caused issues during firmware download failure cases or cases when the firmware download took longer than usual. This was because of un-safe access to protos_registered & st_states. Protecting this will also make the registration complete callback un-safe for sleep. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-31drivers/misc: Add module.h to files who are really modular.Paul Gortmaker
These files really need the full module.h header file present, but were just getting it implicitly before. Fix it up in advance so we avoid build failures once the cleanup commit is present. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-22drivers:misc: ti-st: fix unexpected UART closePavan Savoy
If suppose the UIM were to die and hence UART were to close when the Bluetooth/FM or GPS is turned on, prep the ST for a state where-in if the UIM comes back up, Bluetooth/FM/GPS can be turned on. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22drivers:misc: ti-st: free skb on firmware downloadPavan Savoy
If during validation of the firmware download the data doesn't match what is expected out of the chip, this calls for a firmware download failure and a retry. Free the SKB which collects response during such scenarios. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22drivers:misc: ti-st: wait for completion at failPavan Savoy
When the line discipline install fails for reasons such as missing user-space UIM or broken communication between UIM and ST driver, then the ST attempts/retries to request for ldisc installation again. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22drivers:misc: ti-st: reinit completion before sendPavan Savoy
download firmware behaves differently at different times, when logs are enabled and the system is loaded, the wait_for_completion is able to wait for every send, However during other times the wait does not happen. So, for reliability reinitializing the completion before every send, makes sure the wait happens for every send. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22drivers:misc: ti-st: fail-safe on wrong pkt typeVijay Badawadagi
Texas Instrument's shared transport driver interpret incoming data from the UART based on the various protocol drivers registered to the driver such as btwilink driver or FM or GPS driver which provide logical channel IDs. In case of bad-behavior from chip such as HCI Event response for a GPS command or a HCI Event (h/w error event) for a FM response & In case of bad-behavior from UART driver such as dropping data bytes a fail-safe is required to avoid kernel panic. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Vijay Badawadagi <bvijay@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22drivers:misc: ti-st: reinit completion on ver readPavan Savoy
After the version information has been read, the completion which assists in wait_for_completion during the firmware send/wait sequence is being re-used and hence this needs to be re-initialised for fool proof firmware download retries. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22drivers:misc:ti-st: platform hooks for chip statesPavan Savoy
Certain platform specific or Host-WiLink Interface specific actions would be required to be taken when the chip is being enabled and after the chip is disabled such as configuration of the mux modes for the GPIO of host connected to the nshutdown of the chip or relinquishing UART after the chip is disabled. Similar actions can also be taken when the chip is in deep sleep or when the chip is awake. Performance enhancements such as configuring the host to run faster when chip is awake and slower when chip is asleep can also be made here. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22drivers:misc: ti-st: avoid a misleading dbg msgPavan Savoy
Previously the private data of each protocol registered to use ST was used to determine whether the protocol was registered to use shared transport or otherwise. However, now a flag is_registered is maintained to identify whether a protocol intends to use ST. Upon closing of the UART the error message relevant to this lack of un-registration was misleading and this patch fixes that. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07drivers:misc: ti-st: fix skipping of change remote baudShahar Lev
Before the incrementing of ptr in skip_change_remote_baud, it points to cur_action, but the increment is done by the size of nxt_action instead. This could cause ptr to not point to a bts_action structure, which is harmful for the increment of ptr done in download_firmware. Therefore, the skipping is first done for cur_action. Signed-off-by: Shahar Lev <shahar@wizery.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07st_kim: Handle case of no device found for ID 0Steven Rostedt
Running ktest.pl, I hit this bug: [ 19.780654] BUG: unable to handle kernel NULL pointer dereference at 0000000c [ 19.780660] IP: [<c112efcd>] dev_get_drvdata+0xc/0x46 [ 19.780669] *pdpt = 0000000031daf001 *pde = 0000000000000000 [ 19.780673] Oops: 0000 [#1] SMP [ 19.780680] Dumping ftrace buffer:^M [ 19.780685] (ftrace buffer empty) [ 19.780687] Modules linked in: ide_pci_generic firewire_ohci firewire_core evbug crc_itu_t e1000 ide_core i2c_i801 iTCO_wdt [ 19.780697] [ 19.780700] Pid: 346, comm: v4l_id Not tainted 2.6.39-test-02740-gcaebc16-dirty #4 /DG965MQ [ 19.780706] EIP: 0060:[<c112efcd>] EFLAGS: 00010202 CPU: 0 [ 19.780709] EIP is at dev_get_drvdata+0xc/0x46 [ 19.780712] EAX: 00000008 EBX: f1e37da4 ECX: 00000000 EDX: 00000000 [ 19.780715] ESI: f1c3f200 EDI: c33ec95c EBP: f1e37d80 ESP: f1e37d80 [ 19.780718] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 [ 19.780721] Process v4l_id (pid: 346, ti=f1e36000 task=f2bc2a60 task.ti=f1e36000) [ 19.780723] Stack: [ 19.780725] f1e37d8c c117d395 c33ec93c f1e37db4 c117a0f9 00000002 00000000 c1725e54 [ 19.780732] 00000001 00000007 f2918c90 f1c3f200 c33ec95c f1e37dd4 c1789d3d 22222222 [ 19.780740] 22222222 22222222 f2918c90 f1c3f200 f29194f4 f1e37de8 c178d5c4 c1725e54 [ 19.780747] Call Trace: [ 19.780752] [<c117d395>] st_kim_ref+0x28/0x41 [ 19.780756] [<c117a0f9>] st_register+0x29/0x562 [ 19.780761] [<c1725e54>] ? v4l2_open+0x111/0x1e3 [ 19.780766] [<c1789d3d>] fmc_prepare+0x97/0x424 [ 19.780770] [<c178d5c4>] fm_v4l2_fops_open+0x70/0x106 [ 19.780773] [<c1725e54>] ? v4l2_open+0x111/0x1e3 [ 19.780777] [<c1725e9b>] v4l2_open+0x158/0x1e3 [ 19.780782] [<c065173b>] chrdev_open+0x22c/0x276 [ 19.780787] [<c0647c4e>] __dentry_open+0x35c/0x581 [ 19.780792] [<c06498f9>] nameidata_to_filp+0x7c/0x96 [ 19.780795] [<c065150f>] ? cdev_put+0x57/0x57 [ 19.780800] [<c0660cad>] do_last+0x743/0x9d4 [ 19.780804] [<c065d5fc>] ? path_init+0x1ee/0x596 [ 19.780808] [<c0661481>] path_openat+0x10c/0x597 [ 19.780813] [<c05204a1>] ? trace_hardirqs_off+0x27/0x37 [ 19.780817] [<c0509651>] ? local_clock+0x78/0xc7 [ 19.780821] [<c0661945>] do_filp_open+0x39/0xc2 [ 19.780827] [<c1cabc76>] ? _raw_spin_unlock+0x4c/0x5d^M [ 19.780831] [<c0674ccd>] ? alloc_fd+0x19e/0x1b7 [ 19.780836] [<c06499ca>] do_sys_open+0xb7/0x1bd [ 19.780840] [<c0608eea>] ? sys_munmap+0x78/0x8d [ 19.780844] [<c0649b06>] sys_open+0x36/0x58 [ 19.780849] [<c1cb809f>] sysenter_do_call+0x12/0x38 [ 19.780852] Code: d8 2f 20 c3 01 83 15 dc 2f 20 c3 00 f0 ff 00 83 05 e0 2f 20 c3 01 83 15 e4 2f 20 c3 00 5d c3 55 89 e5 3e 8d 74 26 00 85 c0 74 28 <8b> 40 04 83 05 e8 2f 20 c3 01 83 15 ec 2f 20 c3 00 85 c0 74 13 ^M [ 19.780889] EIP: [<c112efcd>] dev_get_drvdata+0xc/0x46 SS:ESP 0068:f1e37d80 [ 19.780894] CR2: 000000000000000c [ 19.780898] ---[ end trace e7d1d0f6a2d1d390 ]--- The id of 0 passed to st_kim_ref() found no device, keeping pdev null, and causing pdev->dev cause a NULL pointer dereference. After having st_kim_ref() check for NULL, the st_unregister() function needed to be updated to handle the case that st_gdata was not set by the st_kim_ref(). Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-04Revert "tty: make receive_buf() return the amout of bytes received"Linus Torvalds
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c. It was broken in so many ways, and results in random odd pty issues. It re-introduced the buggy schedule_work() in flush_to_ldisc() that can cause endless work-loops (see commit a5660b41af6a: "tty: fix endless work loop when the buffer fills up"). It also used an "unsigned int" return value fo the ->receive_buf() function, but then made multiple functions return a negative error code, and didn't actually check for the error in the caller. And it didn't actually work at all. BenH bisected down odd tty behavior to it: "It looks like the patch is causing some major malfunctions of the X server for me, possibly related to PTYs. For example, cat'ing a large file in a gnome terminal hangs the kernel for -minutes- in a loop of what looks like flush_to_ldisc/workqueue code, (some ftrace data in the quoted bits further down). ... Some more data: It -looks- like what happens is that the flush_to_ldisc work queue entry constantly re-queues itself (because the PTY is full ?) and the workqueue thread will basically loop forver calling it without ever scheduling, thus starving the consumer process that could have emptied the PTY." which is pretty much exactly the problem we fixed in a5660b41af6a. Milton Miller pointed out the 'unsigned int' issue. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Milton Miller <miltonm@bga.com> Cc: Stefan Bigler <stefan.bigler@keymile.com> Cc: Toby Gray <toby.gray@realvnc.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-04-29misc: fix ti-st build issuesRandy Dunlap
st_drv uses skb*() interfaces, so it should depend on NET. It also uses GPIO interfaces, so it should depend on GPIOLIB. st_kim.c uses syss_*() calls, so it should #include <linux/sysfs.h>. Fixes these observed build errors: ERROR: "skb_queue_purge" [drivers/misc/ti-st/st_drv.ko] undefined! ERROR: "skb_pull" [drivers/misc/ti-st/st_drv.ko] undefined! ERROR: "skb_queue_tail" [drivers/misc/ti-st/st_drv.ko] undefined! ERROR: "__alloc_skb" [drivers/misc/ti-st/st_drv.ko] undefined! ERROR: "kfree_skb" [drivers/misc/ti-st/st_drv.ko] undefined! ERROR: "skb_dequeue" [drivers/misc/ti-st/st_drv.ko] undefined! ERROR: "skb_put" [drivers/misc/ti-st/st_drv.ko] undefined! Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-22tty: make receive_buf() return the amout of bytes receivedFelipe Balbi
it makes it simpler to keep track of the amount of bytes received and simplifies how flush_to_ldisc counts the remaining bytes. It also fixes a bug of lost bytes on n_tty when flushing too many bytes via the USB serial gadget driver. Tested-by: Stefan Bigler <stefan.bigler@keymile.com> Tested-by: Toby Gray <toby.gray@realvnc.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-22drivers:misc:ti-st: remove rfkill dependencyPavan Savoy
rfkill is no longer used by Texas Instruments shared transport driver to communicate with user-space. This patch removes the dependency of rfkill to be enabled to build shared transport driver in the Kconfig. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-22drivers:misc:ti-st: handle delayed tty receivePavan Savoy
When certain technologies shutdown their interface without waiting for the acknowledgement from the chip. The receive_buf from the TTY would be invoked a while after the relevant technology is unregistered. This patch introduces a new flag "is_registered" which maintains the state of protocols BT, FM or GPS and thereby removes the need to clear the protocol data from ST when protocols gets unregistered. This fixes corner cases when HCI RESET is sent down from bluetooth stack and the receive_buf is called from tty after 250ms before which bluetooth would have unregistered from the system. OR - when FM application decides to close down the device without sending a power-off FM command resulting in some RDS data or interrupt data coming in after the driver is unregistered. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-09drivers:misc: ti-st: fix debugging codePavan Savoy
debug code in TI-ST driver can be enabled by #defining DEBUG in the first line of the code and in case debugfs is mounted, the 2 entries in /sys/kernel/debug/ti-st/ will also provide useful information. These 2 were broken because of the recent changes to the parsing logic and the registration mechanism of the protocol drivers, this patch fixes them. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: remove multiple gpio handlingPavan Savoy
TI shared transport driver previously intended to expose rfkill entries for each of the protocol gpio that the chip would have. However now in case such gpios exist, which requires to be enabled for a specific protocol, the responsibility lay on protocol driver. This patch removes the request/free of multiple gpios, rfkill struct references and also removes the chip_toggle function. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: fix hci-ll on wake_ind collisionPavan Savoy
Where file-transfer stops/pauses in between, is result of a HCI-LL anamoly in ST LL driver. ST LL did not copy the contents of WaitQ into the TxQ, when a WAKEUP_IND collision happened. Make also sure, that the copying mechanism is safe, by wrapping it around spin locks inside st_int_recv(). This was easily reproduced when the sleep timeout was reduced to 100ms for HCI-LL. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: firmware download optimizationPavan Savoy
To fasten the process of firmware download, the chip allows disabling of the command complete event generation from host. In these cases, only few very essential commands would have the command complete events and hence the wait associated with them. So now the driver would wait for a command complete event, only when it comes across a wait event during firmware parsing. This would also mean we need to skip not just the change baud rate command but also the wait for it. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: set right debug levels for logsPavan Savoy
pr_debug-ing few pr_infos from the data paths such as tty receive and write so as to reduce debugs when we have higher logging levels enabled undef VERBOSE in receive to avoid huge logs when log level 8 is set. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: fix error codesPavan Savoy
set-right the error codes that the shared transport driver returns. Instead of magic numbers like -1, return relevant codes such as ETIMEDOUT or EIO, EAGAIN when wait times out or uart write bytes don't match expected value or when registration fails and needs to be attempted again. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: move from rfkill to sysfsPavan Savoy
The communication between ST KIM and UIM was interfaced over the /dev/rfkill device node. Move the interface to a simpler less abusive sysfs entry mechanism and document it in Documentation/ABI/testing/ under sysfs-platform-kim. Shared transport driver would now read the UART details originally received by bootloader or firmware as platform data. The data read will be shared over sysfs entries for the user-space UIM or other n/w manager/plugins to be read, and assist the driver by opening up the UART, setting the baud-rate and installing the line discipline. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-04drivers:misc: ti-st: register with channel IDsPavan Savoy
The architecture of shared transport had begun with individual protocols like bluetooth, fm and gps telling the shared transport what sort of protocol they are and then expecting the ST driver to parse the incoming data from chip and forward data only relevant to the protocol drivers. This change would mean each protocol drivers would also send information to ST driver as to how to intrepret their protocol data coming out of the chip. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-14drivers: misc: ti-st: fix review commentsPavan Savoy
Based on comments from Jiri Slaby, drop the register storage specifier, remove the unused code, cleanup the const to non-const type casting. Also make the line discipline ops structure static, since its a singleton, unmodified structure which need not be in heap. Reported-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-06misc: ti-st: Kconfig & Makefile for TI_STPavan Savoy
Add the Kconfig and the Makefile for the TI_ST driver. TI_ST driver is the line discipline driver for the Texas Instrument's WiLink chipsets. Also add the ti-st folder to list of drivers under drivers/misc. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-06staging: ti-st: move TI_ST from staging to misc/Pavan Savoy
move the 3 source files st_core.c, st_kim.c and st_ll.c from staging to drivers/misc/. Texas Instrument's WiLink 7 chipset packs wireless technologies like Bluetooth, FM, GPS and WLAN into a single die. Among these the Bluetooth, FM Rx/Tx and GPS are interfaced to a apps processor over a single UART. This line discipline driver allows various protocol drivers such as Bluetooth BlueZ driver, FM V4L2 driver and GPS simple character device driver to communicate with its relevant core in the chip. Each protocol or technologies use a logical channel to communicate with chip. Bluetooth uses the HCI-H4 [channels 1-4], FM uses a CH-8 and GPS a CH-9 protocol. The driver also constitutes the TI HCI-LL Power Management protocol which use channels 30-33. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
