path: root/drivers/misc/pti.c
2012-04-18misc: add missing __devexit_p() annotationsArnd Bergmann
Drivers that refer to a __devexit function in an operations structure need to annotate that pointer with __devexit_p so it is replaced with a NULL pointer when the section gets discarded. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: remove re-assignments to tty_driver membersJiri Slaby
All num, magic and owner are set by alloc_tty_driver. No need to re-set them on each allocation site. pti driver sets something different to what it passes to alloc_tty_driver. It is not a bug, since we don't use the lines parameter in any way. Anyway this is fixed, and now we do the right thing. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-08TTY: remove minor_num from tty_driverJiri Slaby
It was added back in 2004 and never used for anything real. Remove the only assignment in the tree as well. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-02TTY: use tty_standard_installJiri Slaby
Use the helper in the rest of the tty drivers. This is a simple replacement. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-09-14drivers/misc/pti.c: give 'comm' function scope in ↵Jesper Juhl
pti_control_frame_built_and_sent() In drivers/misc/pti.c::pti_control_frame_built_and_sent() we assign 'comm' to 'thread_name_p' if (!thread_name). The problem is that 'comm' then goes out of scope and later we use 'thread_name_p' which now refers to an out-of-scope variable. To fix that, simply move 'comm' up to have function scope. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: J Freyensee <james_p_freyensee@linux.intel.com> Cc: Jeremy Rocher <rocher.jeremy@gmail.com> Cc: Sergei Trofimovich <slyfox@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25drivers/misc/pti.c: add missing includesSergei Trofimovich
Found on allmodconfig build (ARCH=alpha) drivers/misc/pti.c: In function 'get_id': drivers/misc/pti.c:249: error: implicit declaration of function 'kmalloc' drivers/misc/pti.c: In function 'pti_char_write': drivers/misc/pti.c:658: error: implicit declaration of function 'copy_from_user' Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: J Freyensee <james_p_freyensee@linux.intel.com> Cc: Jeremy Rocher <rocher.jeremy@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (26 commits) amba pl011: workaround for uart registers lockup n_gsm: fix the wrong FCS handling pch_uart: add missing comment about OKI ML7223 pch_uart: Add MSI support tty: fix "IRQ45: nobody cared" PTI feature to allow user to name and mark masterchannel request. 0 for o PTI Makefile bug. tty: serial: samsung.c remove legacy PM code. SERIAL: SC26xx: Fix link error. serial: mrst_max3110: initialize waitqueue earlier mrst_max3110: Change max missing message priority. tty: s5pv210: Add delay loop on fifo reset function for UART tty/serial: Fix XSCALE serial ports, e.g. ce4100 serial: bfin_5xx: fix off-by-one with resource size drivers/tty: use printk_ratelimited() instead of printk_ratelimit() tty: n_gsm: Added refcount usage to gsm_mux and gsm_dlci structs tty: n_gsm: Add raw-ip support tty: n_gsm: expose gsmtty device nodes at ldisc open time pch_phub: Fix register miss-setting issue serial: 8250, increase PASS_LIMIT ...
2011-07-25Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: updated Documentation/ja_JP/SubmittingPatches debugfs: add documentation for debugfs_create_x64 uio: uio_pdrv_genirq: Add OF support firmware: gsmi: remove sysfs entries when unload the module Documentation/zh_CN: Fix messy code file email-clients.txt driver core: add more help description for "path to uevent helper" driver-core: modify FIRMWARE_IN_KERNEL help message driver-core: Kconfig grammar corrections in firmware configuration DOCUMENTATION: Replace create_device() with device_create(). DOCUMENTATION: Update overview.txt in Doc/driver-model. pti: pti_tty_install documentation mispelling.
2011-07-01PTI feature to allow user to name and mark masterchannel request.J Freyensee
This feature addition provides a new parameter in pti_request_masterchannel() to allow the user to provide their own name to mark the request when the trace is viewed in a PTI SW trace viewer (like MPTA). If a name is not provided and NULL is provided, the 'current' process name is used. API function header documentation documents this. Signed-off-by: Jeremy Rocher <rocher.jeremy@gmail.com> Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07pti: pti_tty_install documentation mispelling.J Freyensee
This patch tidies up the documentation for pti_tty_install() function. Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07pti: PTI semantics fix in pti_tty_cleanup.J Freyensee
This patch fixes a semantics issue in the pti_tty_cleanup() routine. Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07pti: ENXIO error case memory leak PTI fix.J Freyensee
This patch fixes a memory leak that can occur in the error case ENXIO is returned in the pti_tty_install() routine. Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07pti: double-free security PTI fixJ Freyensee
This patch fixes a double-free error that will not always be seen unless /dev/pti char interface is stressed. Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-13Intel PTI implementaiton of MIPI 1149.7.J Freyensee
The PTI (Parallel Trace Interface) driver directs trace data routed from various parts in the system out through an Intel Penwell PTI port and out of the mobile device for analysis with a debugging tool (Lauterbach or Fido). Though n_tracesink and n_tracerouter line discipline drivers are used to extract modem tracing data to the PTI driver and other parts of an Intel mobile solution, the PTI driver can be used independent of n_tracesink and n_tracerouter. You should select this driver if the target kernel is meant for an Intel Atom (non-netbook) mobile device containing a MIPI P1149.7 standard implementation. Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
