path: root/drivers/misc/pci_endpoint_test.c
2017-04-28misc: Add host side PCI driver for PCI test function deviceKishon Vijay Abraham I
Add PCI endpoint test driver that can verify base address register, legacy interrupt/MSI interrupt and read/write/copy buffers between host and device. The corresponding pci-epf-test function driver should be used on the EP side. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
