path: root/drivers/misc/atmel-ssc.c
2007-10-17Driver for the Atmel on-chip SSC on AT32AP and AT91Hans-Christian Egtvedt
The Synchronous Serial Controller (SSC) on Atmel microprocessors are capable of tranceiving many frame based protocols, like I2S. Tested on the AT32AP7000/ATSTK1000. This driver is used in the ALSA sound driver for the AT73C213 external DAC on the ATSTK1000 development board for AVR32. This sound driver will be submitted soon. Hardware documentation can be found in the AT32AP7000 data sheet, which can be downloaded from http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 [akpm@linux-foundation.org: init spinlock at compile time] Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Brownell <david-b@pacbell.net> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Patrice Vilchez <patrice.vilchez@rfo.atmel.com> Cc: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
