Pull x86 paravirt update from Ingo Molnar:
"Various paravirtualization related changes - the biggest one makes
guest support optional via CONFIG_HYPERVISOR_GUEST"
* 'x86-paravirt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, wakeup, sleep: Use pvops functions for changing GDT entries
x86, xen, gdt: Remove the pvops variant of store_gdt.
x86-32, gdt: Store/load GDT for ACPI S3 or hibernation/resume path is not needed
x86-64, gdt: Store/load GDT for ACPI S3 or hibernate/resume path is not needed.
x86: Make Linux guest support optional
x86, Kconfig: Move PARAVIRT_DEBUG into the paravirt menu
This driver requests and remaps a memory region as configured in the
device tree. It serves memory from this region via the genalloc API. It
optionally enables the SRAM clock.
Other drivers can retrieve the genalloc pool from a phandle pointing to
this drivers' device node in the device tree.
The allocation granularity is hard-coded to 32 bytes for now, to make the
SRAM driver useful for the 6502 remoteproc driver. There is overhead for
bigger SRAMs, where only a much coarser allocation granularity is needed:
At 32 bytes minimum allocation size, a 256 KiB SRAM needs a 1 KiB bitmap
to track allocations.
[akpm@linux-foundation.org: fix Kconfig text, make sram_init static]
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Reviewed-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Michal Simek <monstr@monstr.eu>
Cc: Dong Aisheng <dong.aisheng@linaro.org>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Huang Shijie <shijie8@gmail.com>
Cc: Javier Martin <javier.martin@vista-silicon.com>
Cc: Matt Porter <mporter@ti.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Rob Herring <rob.herring@calxeda.com>
This driver was merged in 2.6.38 but never actually compiled because
it depends on the <mach/pcie.h> header that has not made it into the
kernel. Starting with Linux-3.10, this results in "allyesconfig"
build errors, since spear13xx can now be enabled with the default
"multiplatform" platform on ARM. Let's mark it as broken for now.
If it doesn't get fixed, we can drop it completely.
Cc: Pratyush Anand <pratyush.anand@st.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Viresh Kumar <viresh.kumar@st.com>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
This module accepts a single 'irq' parameter, which it should register for.
Its sole purpose is to help with debugging of IRQ sharing problems, by
force-enabling IRQ that would otherwise be disabled.
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Put all config options needed to run Linux as a guest behind a
CONFIG_HYPERVISOR_GUEST menu so that they don't get built-in by default
but be selectable by the user. Also, make all units which depend on
x86_hyper, depend on this new symbol so that compilation doesn't fail
when CONFIG_HYPERVISOR_GUEST is disabled but those units assume its
presence.
Sort options in the new HYPERVISOR_GUEST menu, adapt config text and
drop redundant select.
Link: http://lkml.kernel.org/r/1362428421-9244-3-git-send-email-bp@alien8.de
Cc: Dmitry Torokhov <dtor@vmware.com>
Cc: K. Y. Srinivasan <kys@microsoft.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver patches from Greg Kroah-Hartman:
"Here's the big char/misc driver patches for 3.9-rc1.
Nothing major here, just lots of different driver updates (mei,
hyperv, ipack, extcon, vmci, etc.).
All of these have been in the linux-next tree for a while."
* tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (209 commits)
w1: w1_therm: Add force-pullup option for "broken" sensors
w1: ds2482: Added 1-Wire pull-up support to the driver
vme: add missing put_device() after device_register() fails
extcon: max8997: Use workqueue to check cable state after completing boot of platform
extcon: max8997: Set default UART/USB path on probe
extcon: max8997: Consolidate duplicate code for checking ADC/CHG cable type
extcon: max8997: Set default of ADC debounce time during initialization
extcon: max8997: Remove duplicate code related to set H/W line path
extcon: max8997: Move defined constant to header file
extcon: max77693: Make max77693_extcon_cable static
extcon: max8997: Remove unreachable code
extcon: max8997: Make max8997_extcon_cable static
extcon: max77693: Remove unnecessary goto statement to improve readability
extcon: max77693: Convert to devm_input_allocate_device()
extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming style
CREDITS: update email and address of Harald Hoyer
extcon: arizona: Use MICDET for final microphone identification
extcon: arizona: Always take the first HPDET reading as the final one
extcon: arizona: Clear _trig_sts bits after jack detection
extcon: arizona: Don't HPDET magic when headphones are enabled
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial patches from Greg Kroah-Hartman:
"Here's the big tty/serial driver patches for 3.9-rc1.
More tty port rework and fixes from Jiri here, as well as lots of
individual serial driver updates and fixes.
* tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits)
tty: mxser: improve error handling in mxser_probe() and mxser_module_init()
serial: imx: fix uninitialized variable warning
serial: tegra: assume CONFIG_OF
TTY: do not update atime/mtime on read/write
lguest: select CONFIG_TTY to build properly.
ARM defconfigs: add missing inclusions of linux/platform_device.h
fb/exynos: include platform_device.h
ARM: sa1100/assabet: include platform_device.h directly
serial: imx: Fix recursive locking bug
pps: Fix build breakage from decoupling pps from tty
tty: Remove ancient hardpps()
pps: Additional cleanups in uart_handle_dcd_change
pps: Move timestamp read into PPS code proper
pps: Don't crash the machine when exiting will do
pps: Fix a use-after free bug when unregistering a source.
pps: Use pps_lookup_dev to reduce ldisc coupling
pps: Add pps_lookup_dev() function
tty: serial: uartlite: Support uartlite on big and little endian systems
tty: serial: uartlite: Fix sparse and checkpatch warnings
serial/arc-uart: Miscll DT related updates (Grant's review comments)
Fix up trivial conflicts, mostly just due to the TTY config option
clashing with the EXPERIMENTAL removal.
The option allows you to remove TTY and compile without errors. This
saves space on systems that won't support TTY interfaces anyway.
bloat-o-meter output is below.
The bulk of this patch consists of Kconfig changes adding "depends on
TTY" to various serial devices and similar drivers that require the TTY
layer. Ideally, these dependencies would occur on a common intermediate
symbol such as SERIO, but most drivers "select SERIO" rather than
"depends on SERIO", and "select" does not respect dependencies.
bloat-o-meter output comparing our previous minimal to new minimal by
removing TTY. The list is filtered to not show removed entries with awk
'$3 != "-"' as the list was very long.
add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350)
function old new delta
chr_dev_init 166 170 +4
allow_signal 80 82 +2
static.__warned 143 142 -1
disallow_signal 63 62 -1
__set_special_pids 95 94 -1
unregister_console 126 121 -5
start_kernel 546 541 -5
register_console 593 588 -5
copy_from_user 45 40 -5
sys_setsid 128 120 -8
sys_vhangup 32 19 -13
do_exit 1543 1526 -17
bitmap_zero 60 40 -20
arch_local_irq_save 137 117 -20
release_task 674 652 -22
static.spin_unlock_irqrestore 308 260 -48
Signed-off-by: Joe Millenbach <jmillenbach@gmail.com>
Reviewed-by: Jamey Sharp <jamey@minilop.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
This patch adds support for bitstream configuration (programming /
loading) of the Lattice ECP3 FPGA's via the SPI bus.
Here an example on my custom MPC5200 based board:
$ echo 1 > /sys/class/firmware/spi0.0/loading
$ cat fpga_a4m2k.bit > /sys/class/firmware/spi0.0/data
$ echo 0 > /sys/class/firmware/spi0.0/loading
leads to these messages:
lattice-ecp3 spi0.0: FPGA Lattice ECP3-35 detected
lattice-ecp3 spi0.0: Configuring the FPGA...
lattice-ecp3 spi0.0: FPGA succesfully configured!
Acked-by: Ming Lei <ming.lei@canonical.com>
Reviewed-by: Grant Likely <grant.likely@secretlab.ca>
VMCI head config patch Adds all the necessary files to enable building of the VMCI
module with the Linux Makefiles and Kconfig systems. Also adds the header files used
for building modules against the driver.
Signed-off-by: George Zhang <georgezhang@vmware.com>
Acked-by: Andy king <acking@vmware.com>
Acked-by: Dmitry Torokhov <dtor@vmware.com>
Not very useful on non AT91/AVR32 platforms but it provides
more build coverage and prepares for ARM multiplatform.
Also fixes a truncated warning that would come when
building on a 64-bit arch.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Pull pwm changes from Thierry Reding:
"All legacy PWM providers have now been moved to the PWM subsystem.
The plan for 3.8 is to adapt all board files to provide a lookup table
for PWM devices in order to get rid of the global namespace.
Subsequently, users of the legacy pwm_request() and pwm_free()
functions can be migrated to the new pwm_get() and pwm_put()
functions. Once this has been completed, the legacy API and the
compatibility code in the core can be removed.
In addition to the above, these changes also add support for
configuring the polarity of a PWM signal (currently only supported on
ECAP and EHRPWM) and include a much needed rework of the i.MX driver.
Managed functions to obtain and release a PWM device (devm_pwm_get()
and devm_pwm_put()) have been added and the pwm-backlight driver has
been updated to use them. If the PWM subsystem hasn't been enabled,
dummy functions are provided that allow the subsystem to safely
compile out.
Some common checks on input parameters have been moved to the core and
removed from the drivers. Finally, a small fix corrects the
description of the PWM specifier's second cell in the device tree
representation."
* tag 'for-3.7-rc1' of git://gitorious.org/linux-pwm/linux-pwm: (23 commits)
pwm: dt: Fix description of second PWM cell
pwm: Check for negative duty-cycle and period
pwm: Add Ingenic JZ4740 support
MIPS: JZ4740: Export timer API
pwm: Move PUV3 PWM driver to PWM framework
unicore32: pwm: Use managed resource allocations
unicore32: pwm: Remove unnecessary indirection
unicore32: pwm: Use module_platform_driver()
unicore32: pwm: Properly remap memory-mapped registers
pwm-backlight: Use devm_pwm_get() instead of pwm_get()
pwm: Move AB8500 PWM driver to PWM framework
pwm: Fix compilation error when CONFIG_PWM is not defined
pwm: i.MX: fix clock lookup
pwm: i.MX: use per clock unconditionally
pwm: i.MX: add devicetree support
pwm: i.MX: Use module_platform_driver
pwm: i.MX: add functions to enable/disable pwm.
pwm: i.MX: remove unnecessary if in pwm_[en|dis]able
pwm: i.MX: factor out SoC specific functions
pwm: pwm-tiehrpwm: Add support for configuring polarity of PWM
This commit moves the driver to drivers/pwm and converts it to the new
PWM framework.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Arun Murthy <arun.murthy@stericsson.com>
As discussed at the kernel summit this year, CONFIG_EXPERIMENTAL means
nothing, so let's get rid of it.
Cc: Tomas Winkler <tomas.winkler@intel.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Paul Bolle <pebolle@tiscali.nl>
Pull PWM subsystem from Thierry Reding:
"The new PWM subsystem aims at collecting all implementations of the
legacy PWM API and to eventually replace it completely.
The subsystem has been in development for over half a year now and
many drivers have already been converted. It has been in linux-next
for a couple of weeks and there have been no major issues so I think
it is ready for inclusion in your tree."
Arnd Bergmann <arnd@arndb.de>:
"Very much Ack on the new subsystem. It uses the interface
declarations as the previously separate pwm drivers, so nothing
changes for now in the drivers using it, although it enables us to
change those more easily in the future if we want to.
This work is also one of the missing pieces that are required to
eventually build ARM kernels for multiple platforms, which is
currently prohibited (amongs other things) by the fact that you cannot
have more than one driver exporting the pwm functions."
Tested-and-acked-by: Alexandre Courbot <acourbot@nvidia.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Philip, Avinash <avinashphilip@ti.com> # TI's AM33xx platforms
Acked-By: Alexandre Pereira da Silva <aletes.xgr@gmail.com> # LPC32XX
Acked-by: Sachin Kamat <sachin.kamat@linaro.org>
Fix up trivial conflicts with other cleanups and DT updates.
* 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwm: (36 commits)
pwm: pwm-tiehrpwm: PWM driver support for EHRPWM
pwm: pwm-tiecap: PWM driver support for ECAP APWM
pwm: fix used-uninitialized warning in pwm_get()
pwm: add lpc32xx PWM support
pwm_backlight: pass correct brightness to callback
pwm: Use pr_* functions in pwm-samsung.c file
pwm: Convert pwm-samsung to use devm_* APIs
pwm: Convert pwm-tegra to use devm_clk_get()
pwm: pwm-mxs: Return proper error if pwmchip_remove() fails
pwm: pwm-bfin: Return proper error if pwmchip_remove() fails
pwm: pxa: Propagate pwmchip_remove() error
pwm: Convert pwm-pxa to use devm_* APIs
pwm: Convert pwm-vt8500 to use devm_* APIs
pwm: Convert pwm-imx to use devm_* APIs
pwm: Conflict with legacy PWM API
pwm: pwm-mxs: add pinctrl support
pwm: pwm-mxs: use devm_* managed functions
pwm: pwm-mxs: use global reset function stmp_reset_block
pwm: pwm-mxs: encode soc name in compatible string
pwm: Take over maintainership of the PWM subsystem
In order to avoid duplicate symbols with legacy PWM API implementations,
the new PWM framework needs to conflict with any of the existing legacy
implementations. This is done in two ways: for implementations provided
by drivers, a conflict is added to the driver to ensure it will have to
be ported to the PWM subsystem before it can coexist with other PWM
providers. For architecture-specific code, the conflict is added to the
PWM symbol to avoid confusion when a previously picked platform or
machine can no longer be selected because of the PWM subsystem being
included.
This hardware never became available to normal humans. Leaving this
driver imposes unwelcome maintenance costs for no clear benefit.
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Cc: Samuel Ortiz <samuel.ortiz@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging tree changes from Greg Kroah-Hartman:
"Here is the big staging tree pull request for the 3.5-rc1 merge
window.
Loads of changes here, and we just narrowly added more lines than we
added:
622 files changed, 28356 insertions(+), 26059 deletions(-)
But, good news is that there is a number of subsystems that moved out
of the staging tree, to their respective "real" portions of the
kernel.
Code that moved out was:
- iio core code
- mei driver
- vme core and bridge drivers
There was one broken network driver that moved into staging as a step
before it is removed from the tree (pc300), and there was a few new
drivers added to the tree:
- new iio drivers
- gdm72xx wimax USB driver
- ipack subsystem and 2 drivers
All of the movements around have acks from the various subsystem
maintainers, and all of this has been in the linux-next tree for a
while.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed up various trivial conflicts, along with a non-trivial one found
in -next and pointed out by Olof Johanssen: a clean - but incorrect -
merge of the arch/arm/boot/dts/at91sam9g20.dtsi file. Fix up manually
as per Stephen Rothwell.
* tag 'staging-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (536 commits)
Staging: bcm: Remove two unused variables from Adapter.h
Staging: bcm: Removes the volatile type definition from Adapter.h
Staging: bcm: Rename all "INT" to "int" in Adapter.h
Staging: bcm: Fix warning: __packed vs. __attribute__((packed)) in Adapter.h
Staging: bcm: Correctly format all comments in Adapter.h
Staging: bcm: Fix all whitespace issues in Adapter.h
Staging: bcm: Properly format braces in Adapter.h
Staging: ipack/bridges/tpci200: remove unneeded casts
Staging: ipack/bridges/tpci200: remove TPCI200_SHORTNAME constant
Staging: ipack: remove board_name and bus_name fields from struct ipack_device
Staging: ipack: improve the register of a bus and a device in the bus.
staging: comedi: cleanup all the comedi_driver 'detach' functions
staging: comedi: remove all 'default N' in Kconfig
staging: line6/config.h: Delete unused header
staging: gdm72xx depends on NET
staging: gdm72xx: Set up parent link in sysfs for gdm72xx devices
staging: drm/omap: initial dmabuf/prime import support
staging: drm/omap: dmabuf/prime mmap support
pstore/ram: Add ECC support
pstore/ram: Switch to persistent_ram routines
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg Kroah-Hartman:
"Here's the driver core, and other driver subsystems, pull request for
the 3.5-rc1 merge window.
Outside of a few minor driver core changes, we ended up with the
following different subsystem and core changes as well, due to
interdependancies on the driver core:
- hyperv driver updates
- drivers/memory being created and some drivers moved into it
- extcon driver subsystem created out of the old Android staging
switch driver code
- dynamic debug updates
- printk rework, and /dev/kmsg changes
All of this has been tested in the linux-next releases for a few weeks
with no reported problems.
Fix up conflicts in drivers/extcon/extcon-max8997.c where git noticed
that a patch to the deleted drivers/misc/max8997-muic.c driver needs to
be applied to this one.
* tag 'driver-core-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (90 commits)
uio_pdrv_genirq: get irq through platform resource if not set otherwise
memory: tegra{20,30}-mc: Remove empty *_remove()
printk() - isolate KERN_CONT users from ordinary complete lines
sysfs: get rid of some lockdep false positives
Drivers: hv: util: Properly handle version negotiations.
Drivers: hv: Get rid of an unnecessary check in vmbus_prep_negotiate_resp()
memory: tegra{20,30}-mc: Use dev_err_ratelimited()
driver core: Add dev_*_ratelimited() family
Driver Core: don't oops with unregistered driver in driver_find_device()
printk() - restore prefix/timestamp printing for multi-newline strings
printk: add stub for prepend_timestamp()
ARM: tegra30: Make MC optional in Kconfig
ARM: tegra20: Make MC optional in Kconfig
ARM: tegra30: MC: Remove unnecessary BUG*()
ARM: tegra20: MC: Remove unnecessary BUG*()
printk: correctly align __log_buf
ARM: tegra30: Add Tegra Memory Controller(MC) driver
ARM: tegra20: Add Tegra Memory Controller(MC) driver
printk() - restore timestamp printing at console output
printk() - do not merge continuation lines of different threads
This patch remove old max8997-muic drvier because of newly Extcon framework.
Extcon framework manages the external connector, so add extcon-max8997 driver
by using Extcon interface to support MUIC feature of Maxim 8997 PMIC instead
of max8997-muic driver(drivers/misc/max8997-muic.c).
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
It's been cleaned up, and there's nothing else left to do, so move it
out of staging into drivers/misc/ where all can use it now.
Cc: Oren Weil <oren.jer.weil@intel.com>
Cc: Alan Cox <alan@linux.intel.com>
The bmp18x chip family comes in an I2C respectively SPI variant.
Hence, the bmp085 driver was split to support both buses.
Tested-by: Zhengguang Guo <zhengguang.guo@bosch-sensortec.com>
Reviewed-by: Stefan Nilsson <stefan.nilsson@unixphere.com>
Signed-off-by: Eric Andersson <eric.andersson@unixphere.com>
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
MISC_DEVICES option alone does not select any kernel code and can cause dependency build warnings, such as:
warning: (KS8851 && AX88796_93CX6 && RTL8180 && RTL8187 && ADM8211 && RT2400PCI && RT2500PCI && RT61PCI && RT2800PCI && R8187SE) selects EEPROM_93CX6 which has unmet direct dependencies (MISC_DEVICES)
As the current drivers/misc/Kconfig stands, it is only possible to select the drivers below if MISC_DEVICES option is selected:
source "drivers/misc/c2port/Kconfig"
source "drivers/misc/eeprom/Kconfig"
source "drivers/misc/cb710/Kconfig"
source "drivers/misc/iwmc3200top/Kconfig"
source "drivers/misc/ti-st/Kconfig"
source "drivers/misc/lis3lv02d/Kconfig"
source "drivers/misc/carma/Kconfig"
source "drivers/misc/altera-stapl/Kconfig"
So remove MISC_DEVICES option so that nothing is dependant on it.
The MUIC function in MAX8997 device can be used as
a USB port detector and switch.
This patch supports the MUIC feature of MAX8997.
Signed-off-by: Donggeun Kim <dg77.kim@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
ML7831 is companion chip for Intel Atom E6xx series.
Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com>
Cc: stable <stable@vger.kernel.org>
* 'next/fixes' of git://git.linaro.org/people/arnd/arm-soc: (28 commits)
ARM: pxa/cm-x300: properly set bt_reset pin
ARM: mmp: rename SHEEVAD to GPLUGD
ARM: imx: Fix typo 'MACH_MX31_3DS_MXC_NAND_USE_BBT'
ARM: i.MX28: shift frac value in _CLK_SET_RATE
plat-mxc: iomux-v3.h: implicitly enable pull-up/down when that's desired
ARM: mx5: fix clock usage for suspend
ARM: pxa: use correct __iomem annotations
ARM: pxa: sharpsl pm needs SPI
ARM: pxa: centro and treo680 need palm27x
ARM: pxa: make pxafb_smart_*() empty when not enabled
ARM: pxa: select POWER_SUPPLY on raumfeld
ARM: pxa: pxa95x is incompatible with earlier pxa
ARM: pxa: CPU_FREQ_TABLE is needed for CPU_FREQ
ARM: pxa: pxa95x/saarb depends on pxa3xx code
ARM: pxa: allow selecting just one of TREO680/CENTRO
ARM: pxa: export symbols from pxa3xx-ulpi
ARM: pxa: make zylonite_pxa*_init declaration match code
ARM: pxa/z2: fix building error of pxa27x_cpu_suspend() no longer available
ARM: at91: add defconfig for at91sam9g45 family
ARM: at91: remove dependency for Atmel PWM driver selector in Kconfig
Remove dependency line which was not including the SAM9G45.
[arnd: added dependency on HAVE_CLK to avoid breaking other machines]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
[mchehab@redhat.com: Fix a merge conflict]
Signed-off-by: Igor M. Liplianin <liplianin@netup.ru>
allmodconfig compile fails on s390 because of the new PTI driver:
drivers/misc/pti.c:407:3: error: implicit declaration of function 'pci_iounmap'
drivers/misc/pti.c:410:3: error: implicit declaration of function 'pci_release_region'
Add a 'depends on PCI' statement so it doesn't get compiled.
Cc: J Freyensee <james_p_freyensee@linux.intel.com>
Signed-off-by: Tracey Dent <tdent48227@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
The FSA9480 is a USB port accessory detector and switch. This patch adds
support the FSA9480 USB Switch.
[akpm@linux-foundation.org: make a couple of things static]
Cc: Greg KH <greg@kroah.com>
As stated in drivers/mfd/cs5535-mfd.c, the mfd driver exposes the BARs
which then make the GPIO, MFGPT, ACPI, etc. all visible to the system.
So the dependencies of the MFGPT stuff have changed, and most people
expect Kconfig to bring in the necessary dependencies. Without them, the
module fails to load and most people don't understand why because the
details of the rewrite aren't captured anywhere most people who know to
look.
This dependency needs to be reflected in Kconfig.
Signed-off-by: Philip A. Prindeville <philipp@redfish-solutions.com>
Acked-by: Alexandros C. Couloumbis <alex@ozo.com>
Acked-by: Andres Salomon <dilinger@queued.net>
Cc: <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits)
serial: 8250_pci: add support for Cronyx Omega PCI multiserial board.
tty/serial: Fix break handling for PORT_TEGRA
tty/serial: Add explicit PORT_TEGRA type
n_tracerouter and n_tracesink ldisc additions.
Intel PTI implementaiton of MIPI 1149.7.
Kernel documentation for the PTI feature.
export kernel call get_task_comm().
tty: Remove to support serial for S5P6442
pch_phub: Support new device ML7223
8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter
ASoC: Update cx20442 for TTY API change
pch_uart: Support new device ML7223 IOH
parport: Use request_muxed_region for IT87 probe and lock
tty/serial: add support for Xilinx PS UART
n_gsm: Use print_hex_dump_bytes
drivers/tty/moxa.c: Put correct tty value
TTY: tty_io, annotate locking functions
TTY: serial_core, remove superfluous set_task_state
TTY: serial_core, remove invalid test
Char: moxa, fix locking in moxa_write
Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and
drivers/tty/serial/Makefile.
I did the hci_ldisc thing as an evil merge, cleaning things up.
This driver allows userspace to access the data processing FPGAs on the
OVRO CARMA board. It has two modes of operation:
1) random access
This allows users to poke any DATA-FPGA registers by using mmap to map
the address region directly into their memory map.
2) correlation dumping
When correlating, the DATA-FPGA's have special requirements for getting
the data out of their memory before the next correlation. This nominally
happens at 64Hz (every 15.625ms). If the data is not dumped before the
next correlation, data is lost.
The data dumping driver handles buffering up to 1 second worth of
correlation data from the FPGAs. This lowers the realtime scheduling
requirements for the userspace process reading the device.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
The PTI (Parallel Trace Interface) driver directs
trace data routed from various parts in the system out
through an Intel Penwell PTI port and out of the mobile
device for analysis with a debugging tool (Lauterbach or Fido).
Though n_tracesink and n_tracerouter line discipline drivers
are used to extract modem tracing data to the PTI driver
and other parts of an Intel mobile solution, the PTI driver
can be used independent of n_tracesink and n_tracerouter.
You should select this driver if the target kernel is meant for
an Intel Atom (non-netbook) mobile device containing a MIPI
P1149.7 standard implementation.
Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com>
Support new device OKI SEMICONDUCTOR ML7223 IOH(Input/Output Hub).
The ML7223 IOH is for MP(Media Phone) use.
The ML7223 is companion chip for Intel Atom E6xx series.
The ML7223 is completely compatible for Intel EG20T PCH.
Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com>
This is a configurable gadget. can be configured by configfs interface.
Any IP available at PCIE bus can be programmed to be used by host
controller.It supoorts both INTX and MSI.
By default, the gadget is configured for INTX and SYSRAM1 is mapped to
BAR0 with size 0x1000
Signed-off-by: Pratyush Anand <pratyush.anand@st.com>
The lis3lv02d drivers aren't hardware monitoring drivers, so the don't
belong to drivers/hwmon. Move them to drivers/misc, short of a better
home.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
Acked-by: Eric Piel <eric.piel@tremplin-utc.net>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Tested-by: Eric Piel <eric.piel@tremplin-utc.net>
Tested-by: Takashi Iwai <tiwai@suse.de>
Add ML7213 device information.
ML7213 is companion chip of Intel Atom E6xx series for IVI(In-Vehicle Infotainment).
ML7213 is completely compatible for Intel EG20T PCH.
Since we don't have a PWM API every PWM driver ends up exporting its
own version and we need to limit the platforms we try to build them on
in order to avoid multiple definitions. As the AB8500 is normally a
companion chip for the U8500 CPU depend on that architecture.
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net>
This patch adds a Pulse Width Modulation driver for Analog Baseband
Chip AB8500.
Signed-off-by: Arun Murthy <arun.murthy@stericsson.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Mike Rapoport <mike@compulab.co.il>
This merges the staging-next tree to Linus's tree and resolves
some conflicts that were present due to changes in other trees that were
affected by files here.
Do not enable this Kconfig menu by default since it contains devices not
present on the majority of systems.
This is becoming a pain and a waste of time especially when doing a bunch
of kernel builds on different systems daily and have to answer "make
oldconfig" prompts for strange devices.
Signed-off-by: Borislav Petkov <bp@alien8.de>
Cc: Michael Hennerich <michael.hennerich@analog.com>
Cc: Andres Salomon <dilinger@collabora.co.uk>
Cc: Jean Delvare <khali@linux-fr.org>
This adds support for the ADPS9802ALS sensor.
Cleanup by Alan Cox
- move mutexes to cover more things
- report I/O errors back to user space
- report range and values in LUX
Signed-off-by: Anantha Narayanan <anantha.narayanan@intel.com>
[The 4K and 64K in the hw spec actually means 4095 (12bit) and 65535 (16bit).]
Signed-off-by: Hong Liu <hong.liu@intel.com>
[Updated to match the ALS light API interface convention from Samu]
Signed-off-by: Alan Cox <alan@linux.intel.com>
The LS driver will read the latest Lux measurement based upon the light
brightness and will report the LUX output through sysfs interface.
This hardware isn't quite the same as the ISL29003 so has a different
driver.
[akpm@linux-foundation.org: put PM code under #ifdef CONFIG_PM]
Signed-off-by: Kalhan Trisal <kalhan.trisal@intel.com>
[Runtime power management support added]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
[Fixes to runtime PM]
Signed-off-by: Liu Hong <hong.liu@intel.com>
[Cleanups and added checks for I2C errors, reworked the API to match the
saner one agreed for other sensors]
This is a driver for Avago APDS990X combined ALS and proximity sensor.
Interface is sysfs based. The driver uses interrupts to provide new data.
The driver supports pm_runtime and regulator frameworks.
See Documentation/misc-devices/apds990x.txt for details
Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com>
This is a driver for ROHM BH1770GLC and OSRAM SFH7770 combined ALS and
proximity sensor.
See Documentation/misc-devices/bh1770glc.txt for details
Add support for AD5270, AD5271, AD5272, AD5274 digital potentiometers.
Add 20-TP feature for AD5291 and AD5292 parts, and update feature list.
AD5291 rdac read back must be shifted by two.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Chris Verges <chrisv@cyberswitching.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
This driver supports iLO, iLO2 and iLO3. However, comments and Kconfig
reference only iLO and iLO2. Let's just call it "iLO" to avoid having to
update strings for each iLO generation. This is similar to the change made
to hpwdt in commit 36e3ff44cebd7e46756dec88f30c982bebefdab7.
Signed-off-by: dann frazier <dannf@hp.com>
