path: root/drivers/mfd
2013-01-28Merge tag 'mfd-for-linus-3.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD fixes from Samuel Ortiz: "This is the first pull request for MFD fixes for 3.8 We have some build failure fixes (twl4030, vexpress, abx500 and tps65910), some actual runtime oops and lockup fixes (rtsx, da9052), and some more hypothetical NULL pointers dereferences fixes for pcf50633 and max776xx. Then we also have additional rtsx fixes for a correct switch output voltage and clock divider correctness for rtl8411 (rtsx driver), and irqdomain fix for db8550-prcmu, and some more cosmetic fixes for arizona and wm5102." * tag 'mfd-for-linus-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: mfd: rtsx: Fix oops when rtsx_pci_sdmmc is not probed mfd: wm5102: Fix definition of WM5102_MAX_REGISTER mfd: twl4030: Don't warn about uninitialized return code mfd: da9052/53 lockup fix mfd: rtsx: Add clock divider hook mmc: rtsx: Call MFD hook to switch output voltage mfd: rtsx: Add output voltage switch hook mfd: Fix compile errors and warnings when !CONFIG_AB8500_BM mfd: vexpress: Export global functions to fix build error mfd: arizona: Check errors from regcache_sync() mfd: tc3589x: Use simple irqdomain mfd: pcf50633: Init pcf->dev before using it mfd: max77693: Init max77693->dev before using it mfd: max77686: Init max77686->dev before using it mfd: db8500-prcmu: Fix irqdomain usage mfd: tps65910: Select REGMAP_IRQ in Kconfig to fix build error mfd: arizona: Disable control interface reporting for WM5102 and WM5110
2013-01-27mfd: rtsx: Fix oops when rtsx_pci_sdmmc is not probedWei WANG
If rtsx_pci_sdmmc is not probed, function pointer pcr->slots[].card_event will point to NULL, and thus rtsx_pci_card_detect will reference a NULL pointer. Check card_event pointer before referencing it can avoid kernel panic. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-27mfd: wm5102: Fix definition of WM5102_MAX_REGISTERMark Brown
Updated in latest datasheet. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-27mfd: twl4030: Don't warn about uninitialized return codeArnd Bergmann
If the twl4030_write_script function gets called with a zero length argument, its return value does not get set. We know that all scripts have a nonzero length, but returning an error in case they ever do is probably appropriate. Without this patch, building omap2plus_defconfig results in: drivers/mfd/twl4030-power.c: In function 'load_twl4030_script': drivers/mfd/twl4030-power.c:414:5: error: 'err' may be used uninitialized in this function Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Reviewed-by: Amit Kucheria <amit.kucheria@linaro.org> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: "Kristo, Tero" <t-kristo@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-27mfd: da9052/53 lockup fixAshish Jangam
An issue has been reported where the PMIC either locks up or fails to respond following a system Reset. This could result in a second write in which the bus writes the current content of the write buffer to address of the last I2C access. The failure case is where this unwanted write transfers incorrect data to a critical register. This patch fixes this issue to by following any read or write with a dummy read to a safe register address. A safe register address is one where the contents will not affect the operation of the system. Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-27mfd: rtsx: Add clock divider hookWei WANG
Add callback function conv_clk_and_div_n to convert between SSC clock and its divider N. For rtl8411, the formula to calculate SSC clock divider N is different with the other card reader models. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-27mfd: rtsx: Add output voltage switch hookWei WANG
Different card reader has different method to switch output voltage, add this callback to let the card reader implement its individual switch function. This is needed as rtl8411 has a specific switch output voltage procedure. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-24mfd: vexpress-sysreg: Don't skip initialization on probePawel Moll
The vexpress-sysreg driver does not have to be initialized early, when the platform doesn't require this. Unfortunately in such case it wasn't initialized correctly - master site lookup and config bridge registration were missing. Fixed now. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2013-01-22mfd: Fix compile errors and warnings when !CONFIG_AB8500_BMLee Jones
drivers/mfd/ab8500-core.c:1015:21: error: ‘ab8500_bm_data’ undeclared here include/linux/mfd/abx500/ab8500-bm.h:445:13: warning: ‘ab8500_fg_reinit’ defined but not used include/linux/mfd/abx500/ab8500-bm.h:448:13: warning: ‘ab8500_charger_usb_state_changed’ defined but not used include/linux/mfd/abx500/ab8500-bm.h:451:29: warning: ‘ab8500_btemp_get’ defined but not used include/linux/mfd/abx500/ab8500-bm.h:455:12: warning: ‘ab8500_btemp_get_batctrl_temp’ defined but not used include/linux/mfd/abx500/ab8500-bm.h:463:12: warning: ‘ab8500_fg_inst_curr_blocking’ defined but not used include/linux/mfd/abx500/ab8500-bm.h:442:12: warning: ‘ab8500_fg_inst_curr_done’ defined but not used include/linux/mfd/abx500/ab8500-bm.h:447:26: warning: ‘ab8500_fg_get’ defined but not used Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-22mfd: vexpress: Export global functions to fix build errorGuenter Roeck
Compiling vexpress client drivers as module results in error messages such as ERROR: "__vexpress_config_func_get" [drivers/hwmon/vexpress.ko] undefined! ERROR: "vexpress_config_func_put" [drivers/hwmon/vexpress.ko] undefined! This is because the global functions in drivers/mfd/vexpress-config.c are not exported. Fix it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-22mfd: arizona: Check errors from regcache_sync()Mark Brown
If the control bus is unrelabile we may hit errors during regcache_sync(), especially given that it tends to be one the most dense bursts of I/O in many systems. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-22mfd: tc3589x: Use simple irqdomainLinus Walleij
This fixes a regression in the TC3589x driver introduced in commit 15e27b1088245a2de3b7d09d39cd209212eb16af "mfd: Provide the tc3589x with its own IRQ domain" If a system with a TC3589x expander is booted and a base IRQ is passed from platform data, a legacy domain will be used. However, since the Ux500 is now switched to use SPARSE_IRQ, no descriptors get allocated on-the-fly, and we get a crash. Fix this by switching to using the simple irqdomain that will handle this uniformly and also allocates descriptors explicitly. Also fix two small whitespace errors in the vicinity while we're at it. Cc: stable@kernel.org Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-22mfd: pcf50633: Init pcf->dev before using itAxel Lin
Current code uses pcf->dev in the dev_err call before setting it to &client->dev. Fix it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-22mfd: max77693: Init max77693->dev before using itAxel Lin
Current code uses max77693->dev in the dev_err call before setting it to &i2c->dev. Fix it. This patch also includes below cleanups: - Move checking pdata earlier and show dev_err if no platform data found. - Remove unnecessary err_regmap goto label. - Unregister i2c devices if regmap init for muic fails. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-22mfd: max77686: Init max77686->dev before using itAxel Lin
Current code uses max77686->dev in the dev_err call before setting it to &i2c->dev. Fix it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-22mfd: db8500-prcmu: Fix irqdomain usageLinus Walleij
This fixes two issues with the DB8500 PRCMU irqdomain: - You have to state the irq base 0 to get a linear domain for the DT case from irq_domain_add_simple() - The irqdomain was not used to translate the initial irq request using irq_create_mapping() making the linear case fail as it was lacking a proper descriptor. I took this opportunity to fix two lines of whitespace errors in related code as I was anyway messing around with it. Cc: stable@kernel.org Acked-by Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-22mfd: tps65910: Select REGMAP_IRQ in Kconfig to fix build errorAnilKumar Ch
TPS65910 mfd driver uses functions that are only avaiable when REGMAP_IRQ is enabled. So "select REGMAP_IRQ" is added to mfd Kconfig to fix below build error: drivers/built-in.o: In function `tps65910_irq_exit': /media/anil/kernel/drivers/mfd/tps65910.c:265: undefined reference to `regmap_del_irq_chip' drivers/built-in.o: In function `tps65910_irq_init': /media/anil/kernel/drivers/mfd/tps65910.c:254: undefined reference to `regmap_add_irq_chip' drivers/built-in.o: In function `tps65910_i2c_probe': /media/anil/kernel/drivers/mfd/tps65910.c:509: undefined reference to `regmap_irq_get_domain' make: *** [vmlinux] Error 1 Signed-off-by: AnilKumar Ch <anilkumar@ti.com> Tested-by: Matt Porter <mporter@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-22mfd: arizona: Disable control interface reporting for WM5102 and WM5110Mark Brown
Rather than disabling the error reporting only for earlier revisions unconditionally disable it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-16mfd, TWL4030: TWL4030 need select REGMAP_I2CChuansheng Liu
Fix the build error: drivers/built-in.o: In function `twl_probe': drivers/mfd/twl-core.c:1256: undefined reference to `devm_regmap_init_i2c' make: *** [vmlinux] Error 1 Signed-off-by: liu chuansheng <chuansheng.liu@intel.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> [ Samuel is busy, taking it directly - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-03Drivers: mfd: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-20Merge tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC fixes from Olof Johansson: "This is a batch of fixes for arm-soc platforms, most of it is for OMAP but there are others too (i.MX, Tegra, ep93xx). Fixes warnings, some broken platforms and drivers, etc. A bit all over the map really." There was some concern about commit 68136b10 ("RM: sunxi: Change device tree naming scheme for sunxi"), but Tony says: "Looks like that's trivial to fix as needed, no need to rebuild the branch to fix that AFAIK. The fix can be done once Olof is available online again. Linus, I suggest that you go ahead and pull this if there are no other issues with this branch." * tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits) ARM: sunxi: Change device tree naming scheme for sunxi ARM: ux500: fix missing include ARM: u300: delete custom pin hog code ARM: davinci: fix build break due to missing include ARM: exynos: Fix warning due to missing 'inline' in stub ARM: imx: Move platform-mx2-emma to arch/arm/mach-imx/devices ARM i.MX51 clock: Fix regression since enabling MIPI/HSP clocks ARM: dts: mx27: Fix the AIPI bus for FEC ARM: OMAP2+: common: remove use of vram ARM: OMAP3/4: cpuidle: fix sparse and checkpatch warnings ARM: OMAP4: clock data: DPLLs are missing bypass clocks in their parent lists ARM: OMAP4: clock data: div_iva_hs_clk is a power-of-two divider ARM: OMAP4: Fix EMU clock domain always on ARM: OMAP4460: Workaround ABE DPLL failing to turn-on ARM: OMAP4: Enhance support for DPLLs with 4X multiplier ARM: OMAP4: Add function table for non-M4X dplls ARM: OMAP4: Update timer clock aliases ARM: OMAP: Move plat/omap-serial.h to include/linux/platform_data/serial-omap.h ARM: dts: Add build target for omap4-panda-a4 ARM: dts: OMAP2420: Correct H4 board memory size ...
2012-12-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull second round of input updates from Dmitry Torokhov: "As usual, there are a couple of new drivers, input core now supports managed input devices (devres), a slew of drivers now have device tree support and a bunch of fixes and cleanups." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (71 commits) Input: walkera0701 - fix crash on startup Input: matrix-keymap - provide a proper module license Input: gpio_keys_polled - switch to using gpio_request_one() Input: gpio_keys - switch to using gpio_request_one() Input: wacom - fix touch support for Bamboo Fun CTH-461 Input: xpad - add a few new VID/PID combinations Input: xpad - minor formatting fixes Input: gpio-keys-polled - honor 'autorepeat' setting in platform data Input: tca8418-keypad - switch to using managed resources Input: tca8418_keypad - increase severity of failures in probe() Input: tca8418_keypad - move device ID tables closer to where they are used Input: tca8418_keypad - use dev_get_platdata() to retrieve platform data Input: tca8418_keypad - use a temporary variable for parent device Input: tca8418_keypad - add support for shared interrupt Input: tca8418_keypad - add support for device tree bindings Input: remove Compaq iPAQ H3600 (Bitsy) touchscreen driver Input: bu21013_ts - add support for Device Tree booting Input: bu21013_ts - move GPIO init and exit functions into the driver Input: bu21013_ts - request regulator that actually exists ARM: ux500: Strip out duplicate touch screen platform information ...
2012-12-17Merge tag 'omap-for-v3.8/fixes-for-merge-window-v4-signed' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes From Tony Lindgren: These patches fixes a build error caused by a merge conflict with the fb code, few timer warnings, and longer term regressions for tfp410 and omap h4 ethernet. Also included is a GPIO mode fix for the legacy mux code. * tag 'omap-for-v3.8/fixes-for-merge-window-v4-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP2+: common: remove use of vram ARM: OMAP: Move plat/omap-serial.h to include/linux/platform_data/serial-omap.h ARM: dts: Add build target for omap4-panda-a4 ARM: dts: OMAP2420: Correct H4 board memory size mfd: omap-usb-host: get rid of cpu_is_omap..() macros ARM: OMAP: Remove debug-devices.c ARM: OMAP2420: Fix ethernet support for OMAP2420 H4 OMAP2+: mux: Fixed gpio mux mode analysis OMAP: board-files: fix i2c_bus for tfp410 ARM: OMAP2+: Fix sparse warnings in timer.c ARM: AM335x: Fix warning in timer.c ARM: OMAP2+: Fix realtime_counter_init warning in timer.c
2012-12-16Merge tag 'mfd-3.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFS update from Samuel Ortiz: "This is the MFD patch set for the 3.8 merge window. We have several new drivers, most of the time coming with their sub devices drivers: - Austria Microsystem's AS3711 - Nano River's viperboard - TI's TPS80031, AM335x TS/ADC, - Realtek's MMC/memstick card reader - Nokia's retu We also got some notable cleanups and improvements: - tps6586x got converted to IRQ domains. - tps65910 and tps65090 moved to the regmap IRQ API. - STMPE is now Device Tree aware. - A general twl6040 and twl-core cleanup, with moves to the regmap I/O and IRQ APIs and a conversion to the recently added PWM framework. - sta2x11 gained regmap support. Then the rest is mostly tiny cleanups and fixes, among which we have Mark's wm5xxx and wm8xxx patchset." Far amount of annoying but largely trivial conflicts. Many due to __devinit/exit removal, others due to one or two of the new drivers also having come in through another tree. * tag 'mfd-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (119 commits) mfd: tps6507x: Convert to devm_kzalloc mfd: stmpe: Update DT support for stmpe driver mfd: wm5102: Add readback of DSP status 3 register mfd: arizona: Log if we fail to create the primary IRQ domain mfd: tps80031: MFD_TPS80031 needs to select REGMAP_IRQ mfd: tps80031: Add terminating entry for tps80031_id_table mfd: sta2x11: Fix potential NULL pointer dereference in __sta2x11_mfd_mask() mfd: wm5102: Add tuning for revision B mfd: arizona: Defer patch initialistation until after first device boot mfd: tps65910: Fix wrong ack_base register mfd: tps65910: Remove unused data mfd: stmpe: Get rid of irq_invert_polarity mfd: ab8500-core: Fix invalid free of devm_ allocated data mfd: wm5102: Mark DSP memory regions as volatile mfd: wm5102: Correct default for LDO1_CONTROL_2 mfd: arizona: Register haptics devices mfd: wm8994: Make current device behaviour the default mfd: tps65090: MFD_TPS65090 needs to select REGMAP_IRQ mfd: Fix stmpe.c build when OF is not enabled mfd: jz4740-adc: Use devm_kzalloc ...
2012-12-16Merge branch 'omap-for-v3.8/fixes-for-merge-window' into ↵Tony Lindgren
omap-for-v3.8/fixes-for-merge-window-v2
2012-12-14mfd: omap-usb-host: get rid of cpu_is_omap..() macrosRoger Quadros
Instead of using cpu_is_omap..() macros in the device driver we rely on information provided in the platform data. The only information we need is whether the USB Host module has a single ULPI bypass control bit for all ports or individual bypass control bits for each port. OMAP3 REV2.1 and earlier have the former. Signed-off-by: Roger Quadros <rogerq@ti.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> [tony@atomide.com: updated to remove plat/cpu.h] Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-12-13Merge tag 'for-v3.8-merged' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery subsystem updates from Anton Vorontsov: "Highlights: - Two new drivers from Pali Rohár and N900 hackers: rx51_battery and bq2415x_charger. The drivers are a part of a solution to replace the proprietary Nokia BME stack - Power supply core now registers devices with a thermal cooling subsystem, so we can now automatically throttle charging. Thanks to Ramakrishna Pallala! - Device tree support for ab8500 and max8925_power drivers - Random fixups and enhancements for a bunch of drivers." * tag 'for-v3.8-merged' of git://git.infradead.org/battery-2.6: (22 commits) max8925_power: Add support for device-tree initialization ab8500: Add devicetree support for chargalg ab8500: Add devicetree support for charger ab8500: Add devicetree support for btemp ab8500: Add devicetree support for fuelgauge twl4030_charger: Change TWL4030_MODULE_* ids to TWL_MODULE_* jz4740-battery: Use devm_request_and_ioremap jz4740-battery: Use devm_kzalloc bq27x00_battery: Fixup nominal available capacity reporting bq2415x_charger: Fix style issues bq2415x_charger: Add Kconfig/Makefile entries power_supply: Add bq2415x charger driver power_supply: Add new Nokia RX-51 (N900) power supply battery driver max17042_battery: Fix missing verify_model_lock() return value check ds2782_battery: Fix signedness bug in ds278x_read_reg16() lp8788-charger: Fix ADC channel names lp8788-charger: Fix wrong ADC conversion lp8788-charger: Use consumer device name on setting IIO channels power_supply: Register power supply for thermal cooling device power_supply: Add support for CHARGE_CONTROL_* attributes ...
2012-12-13Merge tag 'regulator-3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates from Mark Brown: "A fairly quiet release again, a couple of relatively small new features and a bunch of driver specific work including yet more code elimination and fixes from Axel Lin. - Addidion of linear_min_sel for offsetting linear selectors in the helpers. - Support for continuous voltage ranges for regulators with extremely high resolution. - Drivers for AS3711, DA9055, MAX9873, TPS51632, TPS80031 and ARM vexpress." Fix up trivial conflict (due to typo fix) in palmas-regulator.c * tag 'regulator-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (80 commits) regulator: core: Fix logic to determinate if regulator can change voltage regulator: s5m8767: Fix to work even if no DVS gpio present regulator: s5m8767: Fix to read the first DVS register. regulator: s5m8767: Fix to work when platform registers less regulators regulator: gpio-regulator: gpio_set_value should use cansleep regulator: gpio-regulator: Fix logical error in for() loop regulator: anatop: Use regulator_[get|set]_voltage_sel_regmap regulator: anatop: Use linear_min_sel with linear mapping regulator: max1586: Implement get_voltage_sel callback regulator: lp8788-buck: Kill _gpio_request function regulator: tps80031: Convert tps80031_ldo_ops to linear_min_sel and list_voltage_linear regulator: lp8788-ldo: Remove val array in lp8788_config_ldo_enable_mode regulator: gpio-regulator: Add ifdef CONFIG_OF guard for regulator_gpio_of_match regulator: palmas: Convert palmas_ops_smps to regulator_[get|set]_voltage_sel_regmap regulator: palmas: Return raw register values as the selectors in [get|set]_voltage_sel regulators: add regulator_can_change_voltage() function regulator: tps51632: Ensure [base|max]_voltage_uV pdata settings are valid regulator: wm831x-dcdc: Add MODULE_ALIAS for wm831x-boostp regulator: wm831x-dcdc: Ensure selected voltage falls within requested range regulator: tps51632: Use linear_min_sel and regulator_[map|list]_voltage_linear ...
2012-12-13Merge tag 'sound-3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This update contains a fairly wide range of changes all over in sound subdirectory, mainly because of UAPI header moves by David and __dev* annotation removals by Bill. Other highlights are: - Introduced the support for wallclock timestamps in ALSA PCM core - Add the poll loop implementation for HD-audio jack detection - Yet more VGA-switcheroo fixes for HD-audio - New VIA HD-audio codec support - More fixes on resource management in USB audio and MIDI drivers - More quirks for USB-audio ASUS Xonar U3, Reloop Play, Focusrite, Roland VG-99, etc - Add support for FastTrack C400 usb-audio - Clean ups in many drivers regarding firmware loading - Add PSC724 Ultiimate Edge support to ice1712 - A few hdspm driver updates - New Stanton SCS.1d/1m FireWire driver - Standardisation of the logging in ASoC codes - DT and dmaengine support for ASoC Atmel - Support for Wolfson ADSP cores - New drivers for Freescale/iVeia P1022 and Maxim MAX98090 - Lots of other ASoC driver fixes and developments" Fix up trivial conflicts. And go out on a limb and assume the dts file 'status' field of one of the conflicting things was supposed to be "disabled", not "disable" like in pretty much all other cases. * tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (341 commits) ALSA: hda - Move runtime PM check to runtime_idle callback ALSA: hda - Add stereo-dmic fixup for Acer Aspire One 522 ALSA: hda - Avoid doubly suspend after vga switcheroo ALSA: usb-audio: Enable S/PDIF on the ASUS Xonar U3 ALSA: hda - Check validity of CORB/RIRB WP reads ALSA: hda - use usleep_range in link reset and change timeout check ALSA: HDA: VIA: Add support for codec VT1808. ALSA: HDA: VIA Add support for codec VT1705CF. ASoC: codecs: remove __dev* attributes ASoC: utils: remove __dev* attributes ASoC: ux500: remove __dev* attributes ASoC: txx9: remove __dev* attributes ASoC: tegra: remove __dev* attributes ASoC: spear: remove __dev* attributes ASoC: sh: remove __dev* attributes ASoC: s6000: remove __dev* attributes ASoC: OMAP: remove __dev* attributes ASoC: nuc900: remove __dev* attributes ASoC: mxs: remove __dev* attributes ASoC: kirkwood: remove __dev* attributes ...
2012-12-13Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform conversion patches from Olof Johansson: "Here are more patches in the progression towards multiplatform, sparse irq conversions in particular. Tegra has a handful of cleanups and general groundwork, but is not quite there yet on full enablement. Platforms that are enabled through this branch are VT8500 and Zynq. Note that i.MX was converted in one of the earlier cleanup branches as well (before we started a separate topic for multiplatform). And both new platforms for this merge window, sunxi and bcm, were merged with multiplatform support enabled." Fix up conflicts mostly as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: zynq: Remove all unused mach headers ARM: zynq: add support for ARCH_MULTIPLATFORM ARM: zynq: make use of debug_ll_io_init() ARM: zynq: remove TTC early mapping ARM: tegra: move debug-macro.S to include/debug ARM: tegra: don't include iomap.h from debug-macro.S ARM: tegra: decouple uncompress.h and debug-macro.S ARM: tegra: simplify DEBUG_LL UART selection options ARM: tegra: select SPARSE_IRQ ARM: tegra: enhance timer.c to get IO address from device tree ARM: tegra: enhance timer.c to get IRQ info from device tree ARM: timer: fix checkpatch warnings ARM: tegra: add TWD to device tree ARM: tegra: define DT bindings for and instantiate RTC ARM: tegra: define DT bindings for and instantiate timer clocksource/mtu-nomadik: use apb_pclk clk: ux500: Register mtu apb_pclocks ARM: plat-nomadik: convert platforms to SPARSE_IRQ mfd/db8500-prcmu: use the irq_domain_add_simple() mfd/ab8500-core: use irq_domain_add_simple() ...
2012-12-12Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates from Olof Johansson: "This contains the bulk of new SoC development for this merge window. Two new platforms have been added, the sunxi platforms (Allwinner A1x SoCs) by Maxime Ripard, and a generic Broadcom platform for a new series of ARMv7 platforms from them, where the hope is that we can keep the platform code generic enough to have them all share one mach directory. The new Broadcom platform is contributed by Christian Daudt. Highbank has grown support for Calxeda's next generation of hardware, ECX-2000. clps711x has seen a lot of cleanup from Alexander Shiyan, and he's also taken on maintainership of the platform. Beyond this there has been a bunch of work from a number of people on converting more platforms to IRQ domains, pinctrl conversion, cleanup and general feature enablement across most of the active platforms." Fix up trivial conflicts as per Olof. * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (174 commits) mfd: vexpress-sysreg: Remove LEDs code irqchip: irq-sunxi: Add terminating entry for sunxi_irq_dt_ids clocksource: sunxi_timer: Add terminating entry for sunxi_timer_dt_ids irq: versatile: delete dangling variable ARM: sunxi: add missing include for mdelay() ARM: EXYNOS: Avoid early use of of_machine_is_compatible() ARM: dts: add node for PL330 MDMA1 controller for exynos4 ARM: EXYNOS: Add support for secondary CPU bring-up on Exynos4412 ARM: EXYNOS: add UART3 to DEBUG_LL ports ARM: S3C24XX: Add clkdev entry for camif-upll clock ARM: SAMSUNG: Add s3c24xx/s3c64xx CAMIF GPIO setup helpers ARM: sunxi: Add missing sun4i.dtsi file pinctrl: samsung: Do not initialise statics to 0 ARM i.MX6: remove gate_mask from pllv3 ARM i.MX6: Fix ethernet PLL clocks ARM i.MX6: rename PLLs according to datasheet ARM i.MX6: Add pwm support ARM i.MX51: Add pwm support ARM i.MX53: Add pwm support ARM: mx5: Replace clk_register_clkdev with clock DT lookup ...
2012-12-12Merge tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC Header cleanups from Olof Johansson: "This is a collection of header file cleanups, mostly for OMAP and AT91, that keeps moving the platforms in the direction of multiplatform by removing the need for mach-dependent header files used in drivers and other places." Fix up mostly trivial conflicts as per Olof. * tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (106 commits) ARM: OMAP2+: Move iommu/iovmm headers to platform_data ARM: OMAP2+: Make some definitions local ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.c ARM: OMAP2+: Move plat/iovmm.h to include/linux/omap-iommu.h ARM: OMAP2+: Move iopgtable header to drivers/iommu/ ARM: OMAP: Merge iommu2.h into iommu.h atmel: move ATMEL_MAX_UART to platform_data/atmel.h ARM: OMAP: Remove omap_init_consistent_dma_size() arm: at91: move at91rm9200 rtc header in drivers/rtc arm: at91: move reset controller header to arm/arm/mach-at91 arm: at91: move pit define to the driver arm: at91: move at91_shdwc.h to arch/arm/mach-at91 arm: at91: move board header to arch/arm/mach-at91 arn: at91: move at91_tc.h to arch/arm/mach-at91 arm: at91 move at91_aic.h to arch/arm/mach-at91 arm: at91 move board.h to arch/arm/mach-at91 arm: at91: move platfarm_data to include/linux/platform_data/atmel.h arm: at91: drop machine defconfig ARM: OMAP: Remove NEED_MACH_GPIO_H ARM: OMAP: Remove unnecessary mach and plat includes ...
2012-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linuxAnton Vorontsov
The merge is merely to fix conflicts before sending a pull request. Conflicts: drivers/power/ab8500_btemp.c drivers/power/ab8500_charger.c drivers/power/ab8500_fg.c drivers/power/abx500_chargalg.c drivers/power/max8925_power.c Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
2012-12-11Merge tag 'char-misc-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull Char/Misc driver merge from Greg Kroah-Hartman: "Here is the "big" char/misc driver patches for 3.8-rc1. I'm starting to put random driver subsystems that I had previously sent you through the driver-core tree in this tree, as it makes more sense to do so. Nothing major here, the various __dev* removals, some mei driver updates, and other random driver-specific things from the different maintainers and developers. Note, some MFD drivers got added through this tree, and they are also coming in through the "real" MFD tree as well, due to some major mis-communication between me and the different developers. If you have any merge conflicts, take the ones from the MFD tree, not these ones, sorry about that. All of this has been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up trivial conflict in drivers/mmc/host/Kconfig due to new drivers having been added (both at the end, as usual..) * tag 'char-misc-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (84 commits) MAINTAINERS: remove drivers/staging/hv/ misc/st_kim: Free resources in the error path of probe() drivers/char: for hpet, add count checking, and ~0UL instead of -1 w1-gpio: Simplify & get rid of defines w1-gpio: Pinctrl-fy extcon: remove use of __devexit_p extcon: remove use of __devinit extcon: remove use of __devexit drivers: uio: Only allocate new private data when probing device tree node drivers: uio_dmem_genirq: Allow partial success when opening device drivers: uio_dmem_genirq: Don't use DMA_ERROR_CODE to indicate unmapped regions drivers: uio_dmem_genirq: Don't mix address spaces for dynamic region vaddr uio: remove use of __devexit uio: remove use of __devinitdata uio: remove use of __devinit uio: remove use of __devexit_p char: remove use of __devexit char: remove use of __devinitconst char: remove use of __devinitdata char: remove use of __devinit ...
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-12-11Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull GPIO updates from Grant Likely: "GPIO follow up patch and type change for v3.5 merge window Primarily device driver additions, features and bug fixes. Not much touching gpio common subsystem support. Should not be scary." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits) gpio: Provide the STMPE GPIO driver with its own IRQ Domain gpio: add TS-5500 DIO blocks support gpio: pcf857x: use client->irq for gpio_to_irq() gpio: stmpe: Add DT support for stmpe gpio gpio: pl061 depends on ARM gpio/pl061: remove old comment gpio: SPEAr: add spi chipselect control driver gpio: gpio-max710x: Support device tree probing gpio: twl4030: Use only TWL4030_MODULE_LED for LED configuration gpio: tegra: read output value when gpio is set in direction_out gpio: pca953x: Add compatible strings to gpio-pca953x driver gpio: pca953x: Register an IRQ domain gpio: mvebu: Set free callback for gpio_chip gpio: tegra: Drop exporting static functions gpio: tegra: Staticize non-exported symbols gpio: tegra: fix suspend/resume apis gpio-pch: Set parent dev for gpio chip gpio: em: Fix build errors GPIO: clps711x: use platform_device_unregister in gpio_clps711x_init() gpio/tc3589x: convert to use the simple irqdomain ...
2012-12-11Merge tag 'clk-for-linus' of git://git.linaro.org/people/mturquette/linuxLinus Torvalds
Pull clock framework changes from Mike Turquette: "The common clock framework changes for 3.8 are comprised of lots of fixes for existing platforms as well as new ports for some ARM platforms. In addition there are new clk drivers for audio devices and MFDs." Fix up trivial conflict in <linux/clk-provider.h> (removal of 'inline' clashing with return type fixes) * tag 'clk-for-linus' of git://git.linaro.org/people/mturquette/linux: (51 commits) MAINTAINERS: bad email address for Mike Turquette clk: introduce optional disable_unused callback clk: ux500: fix bit error clk: clock multiplexers may register out of order clk: ux500: Initial support for abx500 clock driver CLK: SPEAr: Remove unused dummy apb_pclk CLK: SPEAr: Correct index scanning done for clock synths CLK: SPEAr: Update clock rate table CLK: SPEAr: Add missing clocks CLK: SPEAr: Set CLK_SET_RATE_PARENT for few clocks CLK: SPEAr13xx: fix parent names of multiple clocks CLK: SPEAr13xx: Fix mux clock names CLK: SPEAr: Fix dev_id & con_id for multiple clocks clk: move IM-PD1 clocks to drivers/clk clk: make ICST driver handle the VCO registers clk: add GPLv2 headers to the Versatile clock files clk: mxs: Use a better name for the USB PHY clock clk: spear: Add stub functions for spear3[0|1|2]0_clk_init() CLK: clk-twl6040: fix return value check in twl6040_clk_probe() clk: ux500: Register nomadik keypad clock lookups for u8500 ...
2012-12-10mfd: tps6507x: Convert to devm_kzallocAxel Lin
2012-12-10mfd: stmpe: Update DT support for stmpe driverVipul Kumar Samar
This patch extends existing DT support for stmpe devices. This updates: - missing header files in stmpe.c - stmpe_of_probe() with pwm, rotator and new bindings. - Bindings are updated in binding document. Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-12-10Merge remote-tracking branch 'regulator/topic/max8997' into regulator-nextMark Brown
2012-12-10Merge remote-tracking branch 'regulator/topic/hotplug' into regulator-nextMark Brown
2012-12-09mfd: wm5102: Add readback of DSP status 3 registerMark Brown
2012-12-09mfd: arizona: Log if we fail to create the primary IRQ domainMark Brown
This is the only thing in probe for which we don't log an error. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-12-09mfd: tps80031: MFD_TPS80031 needs to select REGMAP_IRQAxel Lin
This driver uses regmap_irq APIs, thus need to select REGMAP_IRQ. IRQ_DOMAIN will be selected if select REGMAP_IRQ, thus remove it here. This fixes below build errors: drivers/built-in.o: In function `tps80031_remove': drivers/mfd/tps80031.c:534: undefined reference to `regmap_del_irq_chip' drivers/built-in.o: In function `tps80031_irq_init': drivers/mfd/tps80031.c:305: undefined reference to `regmap_add_irq_chip' drivers/built-in.o: In function `tps80031_probe': drivers/mfd/tps80031.c:496: undefined reference to `regmap_irq_get_domain' drivers/mfd/tps80031.c:512: undefined reference to `regmap_del_irq_chip' make: *** [vmlinux] Error 1 Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-12-09mfd: tps80031: Add terminating entry for tps80031_id_tableAxel Lin
The i2c_device_id table is supposed to be zero-terminated. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-12-07mfd: vexpress-sysreg: Remove LEDs codePawel Moll
As the current LEDs code breaks other platform, remove it. It shall be replaced by a generic "MMIO LEDs" driver. Reported-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-12-03mfd: sta2x11: Fix potential NULL pointer dereference in __sta2x11_mfd_mask()Wei Yongjun
The dereference to 'mfd' should be moved below the NULL test. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-12-03mfd: wm5102: Add tuning for revision BMark Brown
Evaluation of revision B of WM5102 suggests updates to the register patch for optimal performance, and make this the default behaviour for new devices. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-12-03mfd: arizona: Defer patch initialistation until after first device bootMark Brown
Make sure that we don't race with the initial device boot by only doing the initialisation after we've waited for the boot to complete. The runtime PM code already waits for the boot to complete before it syncs the register patches so in most systems if a race does occur we will power down very soon afterwards and recover anyway. Reported-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-12-02Merge remote-tracking branch 'asoc/topic/wm8994' into asoc-nextMark Brown
