Bring the WM8350 IRQ API more in line with the generic IRQ API by
masking and unmasking interrupts as they are requested and freed.
This is mostly just a case of deleting the mask and unmask calls
from the individual drivers.
The RTC driver is changed to mask the periodic IRQ after requesting
it rather than only unmasking the alarm IRQ. If the periodic IRQ
fires in the period where it is reqested then there will be a
spurious notification but there should be no serious consequences
from this.
The CODEC drive is changed to explicitly disable headphone jack
detection prior to requesting the IRQs. This will avoid the IRQ
firing with no jack set up.
This is done as simple code transformation, the semantics of the
IRQ API provided by the core are are still very different to those
of genirq (mainly with regard to masking).
Rather than open coding individual IRQs in each function which
manipulates them store data for IRQs in a table which is then
referenced in the users.
This is a substantial code shrink and should be a performance win in
cases where only a single IRQ goes off at once since instead of
reading four of the second level IRQ registers for each interrupt
we read only the sub-registers which have had an interrupt flagged.
In preparation for refactoring - it's over 700 lines of well-isolated
code and having it in a file by itself makes things more managable.
While we're at it make sure that we clean up the IRQ if we fail after
acquiring it on init.
