path: root/drivers/mfd/ucb1x00.h
2008-01-24MCP_UCB1200: Convert from class_device to deviceTony Jones
struct class_device is going away, this converts the code to use struct device instead. Signed-off-by: Tony Jones <tonyj@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-11[ARM] 3727/1: fix ucb initialization on colliePavel Machek
Patch from Pavel Machek From: Dirk Opfer <Dirk@Opfer-Online.de> Fix ucb initialization on collie. Wrong frequency was used and that led to things not working quite correctly. (I had to actually disable checks in my tree to get it to boot). It now includes all the neccessary parts to get it to compile :-). Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-06[MFD] Fix gcc4 build errors in ucb1x00-core.cRussell King
drivers/mfd/ucb1x00-core.c:555: error: static declaration of 'ucb1x00_class' follows non-static declaration drivers/mfd/ucb1x00.h:109: error: previous declaration of 'ucb1x00_class' was here Since ucb1x00_class isn't used by anything, remove the extern declaration and the symbol export. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-11[MFD] Add code UCB1200/UCB1300 device supportRussell King
Add the core device support code for the Philips UCB1200 and UCB1300 devices. Also includes the following from Pavel: This fixes u32 vs. pm_message_t confusion and uses cleaner try_to_freeze() [fixing compilation as a side-effect on newer kernels.] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
