The twl irqchip uses the dummy irq chip ack functions, which is NULL
now. Switch it over to use irq_ack.
Reported-and-tested-by: Grazvydas Ignotas <notasas@gmail.com>
struct irq_data is the preferred name for the data associated to an
interrupt in the core code.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Fix the names of twl5031 specific sih modules to match
the documentation.
Signed-off-by: Ilkka Koskinen <ilkka.koskinen@nokia.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Commit 239007b844 ("genirq: Convert irq_desc.lock to raw_spinlock")
seems to have missed this driver, leaving it to use the normal spin-lock
functions for the irq descriptor lock, which is now a raw lock.
Reported-and-compile-tested-by: Stephen Rothwell <sfr@canb.auug.org.au>
This patch adds support for phoenix interrupt framework. New iInterrupt
status register A, B, C are introduced in Phoenix and are cleared on write.
Due to the differences in interrupt handling with respect to TWL4030,
twl6030-irq.c is created for TWL6030 PMIC
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Balaji T K <balajitk@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Reviewed-by: Tony Lindgren <tony@atomide.com>
This patch renames function names like twl4030_i2c_write_u8,
twl4030_i2c_read_u8 to twl_i2c_write_u8, twl_i2c_read_u8
and also common variable in twl-core.c
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
The upcoming TWL6030 is companion chip for OMAP4 like the current TWL4030
for OMAP3. The common modules like RTC, Regulator creates opportunity
to re-use the most of the code from twl4030.
This patch renames few common drivers twl4030* files to twl* to enable
the code re-use.
Signed-off-by: Alan Cox <alan@linux.intel.com>
TWL5031 introduces two new interrupts in PIH. Moreover, BCI
has changed remarkably and, thus, it's disabled when TWL5031
is in use.
The TWL4030 IRQ handler has a bug which leads to spinlock lock-up. It is
calling the 'unmask' function in a process context. :The mask/unmask/ack
functions are only designed to be called from the IRQ handler code,
or the proper API interfaces found in linux/interrupt.h.
Also there is no need to have IRQ chaining mechanism. The right way to
handle this is to claim the parent interrupt as a standard interrupt
and arrange for handle_twl4030_pih to take care of the rest of the devices.
Mail thread on this issue can be found at:
http://marc.info/?l=linux-arm-kernel&m=124629940123396&w=2
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have
been kept around for migration reasons. After more than two years it's
time to remove them finally.
This patch cleans up one of the remaining users. When all such patches
hit mainline we can remove the defines and typedefs finally.
Impact: cleanup
Convert the last remaining users and remove the typedef.
Cc: David Brownell <dbrownell@users.sourceforge.net>
The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the beginning
of the declaration specifiers in a declaration is an obsolescent
feature.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
The global irq_desc array is soon going to be accessible only with
!CONFIG_SPARSE_IRQ. We should start using the generic irq_to_desc()
routines instead.
- Move it into a separate file; clean and streamline it
- Restructure the init code for reuse during secondary dispatch
- Support both levels (primary, secondary) of IRQ dispatch
- Use a workqueue for irq mask/unmask and trigger configuration
Code for two subchips currently share that secondary handler code.
One is the power subchip; its IRQs are now handled by this core,
courtesy of this patch. The other is the GPIO module, which will
be supported through a later patch.
There are also minor changes to the header file, mostly related
to GPIO support; nothing yet in mainline cares about those. A
few references to OMAP-specific symbols are disabled; when they
can all be removed, the TWL4030 support ceases being OMAP-specific.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
