commit 8b8a84c54aff4256d592dc18346c65ecf6811b45 upstream.
Commit 16fa3dc75c22 ("mfd: omap-usb-tll: HOST TLL platform driver")
added support for USB TLL, but uses OMAP_TLL_CHANNEL_CONF_ULPINOBITSTUFF
bit the wrong way. The comments in the code are correct, but the inverted
use of OMAP_TLL_CHANNEL_CONF_ULPINOBITSTUFF causes the register to be
enabled instead of disabled unlike what the comments say.
Without this change the Wrigley 3G LTE modem on droid 4 EHCI bus can
be only pinged few times before it stops responding.
Fixes: 16fa3dc75c22 ("mfd: omap-usb-tll: HOST TLL platform driver")
Acked-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Fix the warnings about the following functions not being
declared by including omap-usb.h which declares them:
drivers/mfd/omap-usb-tll.c:333:5: warning: symbol 'omap_tll_init' was not declared. Should it be static?
drivers/mfd/omap-usb-tll.c:408:5: warning: symbol 'omap_tll_enable' was not declared. Should it be static?
drivers/mfd/omap-usb-tll.c:442:5: warning: symbol 'omap_tll_disable' was not declared. Should it be static?
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
We shouldn't be calling clk_prepare_enable()/clk_prepare_disable()
in an atomic context.
Fixes the following issue:
[ 5.830970] ehci-omap: OMAP-EHCI Host Controller driver
[ 5.830974] driver_register 'ehci-omap'
[ 5.895849] driver_register 'wl1271_sdio'
[ 5.896870] BUG: scheduling while atomic: udevd/994/0x00000002
[ 5.896876] 4 locks held by udevd/994:
[ 5.896904] #0: (&dev->mutex){......}, at: [<c049597c>] __driver_attach+0x60/0xac
[ 5.896923] #1: (&dev->mutex){......}, at: [<c049598c>] __driver_attach+0x70/0xac
[ 5.896946] #2: (tll_lock){+.+...}, at: [<c04c2630>] omap_tll_enable+0x2c/0xd0
[ 5.896966] #3: (prepare_lock){+.+...}, at: [<c05ce9c8>] clk_prepare_lock+0x48/0xe0
[ 5.897042] Modules linked in: wlcore_sdio(+) ehci_omap(+) dwc3_omap snd_soc_ts3a225e leds_is31fl319x bq27xxx_battery_i2c tsc2007 bq27xxx_battery bq2429x_charger ina2xx tca8418_keypad as5013 leds_tca6507 twl6040_vibra gpio_twl6040 bmp085_i2c(+) palmas_gpadc usb3503 palmas_pwrbutton bmg160_i2c(+) bmp085 bma150(+) bmg160_core bmp280 input_polldev snd_soc_omap_mcbsp snd_soc_omap_mcpdm snd_soc_omap snd_pcm_dmaengine
[ 5.897048] Preemption disabled at:[< (null)>] (null)
[ 5.897051]
[ 5.897059] CPU: 0 PID: 994 Comm: udevd Not tainted 4.6.0-rc5-letux+ #233
[ 5.897062] Hardware name: Generic OMAP5 (Flattened Device Tree)
[ 5.897076] [<c010e714>] (unwind_backtrace) from [<c010af34>] (show_stack+0x10/0x14)
[ 5.897087] [<c010af34>] (show_stack) from [<c040aa7c>] (dump_stack+0x88/0xc0)
[ 5.897099] [<c040aa7c>] (dump_stack) from [<c020c558>] (__schedule_bug+0xac/0xd0)
[ 5.897111] [<c020c558>] (__schedule_bug) from [<c06f3d44>] (__schedule+0x88/0x7e4)
[ 5.897120] [<c06f3d44>] (__schedule) from [<c06f46d8>] (schedule+0x9c/0xc0)
[ 5.897129] [<c06f46d8>] (schedule) from [<c06f4904>] (schedule_preempt_disabled+0x14/0x20)
[ 5.897140] [<c06f4904>] (schedule_preempt_disabled) from [<c06f64e4>] (mutex_lock_nested+0x258/0x43c)
[ 5.897150] [<c06f64e4>] (mutex_lock_nested) from [<c05ce9c8>] (clk_prepare_lock+0x48/0xe0)
[ 5.897160] [<c05ce9c8>] (clk_prepare_lock) from [<c05d0e7c>] (clk_prepare+0x10/0x28)
[ 5.897169] [<c05d0e7c>] (clk_prepare) from [<c04c2668>] (omap_tll_enable+0x64/0xd0)
[ 5.897180] [<c04c2668>] (omap_tll_enable) from [<c04c1728>] (usbhs_runtime_resume+0x18/0x17c)
[ 5.897192] [<c04c1728>] (usbhs_runtime_resume) from [<c049d404>] (pm_generic_runtime_resume+0x2c/0x40)
[ 5.897202] [<c049d404>] (pm_generic_runtime_resume) from [<c049f180>] (__rpm_callback+0x38/0x68)
[ 5.897210] [<c049f180>] (__rpm_callback) from [<c049f220>] (rpm_callback+0x70/0x88)
[ 5.897218] [<c049f220>] (rpm_callback) from [<c04a0a00>] (rpm_resume+0x4ec/0x7ec)
[ 5.897227] [<c04a0a00>] (rpm_resume) from [<c04a0f48>] (__pm_runtime_resume+0x4c/0x64)
[ 5.897236] [<c04a0f48>] (__pm_runtime_resume) from [<c04958dc>] (driver_probe_device+0x30/0x70)
[ 5.897246] [<c04958dc>] (driver_probe_device) from [<c04959a4>] (__driver_attach+0x88/0xac)
[ 5.897256] [<c04959a4>] (__driver_attach) from [<c04940f8>] (bus_for_each_dev+0x50/0x84)
[ 5.897267] [<c04940f8>] (bus_for_each_dev) from [<c0494e40>] (bus_add_driver+0xcc/0x1e4)
[ 5.897276] [<c0494e40>] (bus_add_driver) from [<c0496914>] (driver_register+0xac/0xf4)
[ 5.897286] [<c0496914>] (driver_register) from [<c01018e0>] (do_one_initcall+0x100/0x1b8)
[ 5.897296] [<c01018e0>] (do_one_initcall) from [<c01c7a54>] (do_init_module+0x58/0x1c0)
[ 5.897304] [<c01c7a54>] (do_init_module) from [<c01c8a3c>] (SyS_finit_module+0x88/0x90)
[ 5.897313] [<c01c8a3c>] (SyS_finit_module) from [<c0107120>] (ret_fast_syscall+0x0/0x1c)
[ 5.912697] ------------[ cut here ]------------
[ 5.912711] WARNING: CPU: 0 PID: 994 at kernel/sched/core.c:2996 _raw_spin_unlock+0x28/0x58
[ 5.912717] DEBUG_LOCKS_WARN_ON(val > preempt_count())
Cc: <stable@vger.kernel.org>
Reported-by: H. Nikolaus Schaller <hns@goldelico.com>
Tested-by: H. Nikolaus Schaller <hns@goldelico.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Static analysis from cppcheck issued the following warning:
[drivers/mfd/omap-usb-tll.c:255]: (warning) Found calculation
inside sizeof().
The current size calculation is not obvious and is easy to
miscomprehend, so re-work the size of the allocation based
on the size of the struct pointer and quantity to allocate.
pm_runtime_get/put_sync() can sleep so don't hold spinlock while
calling them.
This patch prevents a BUG() during system suspend when
CONFIG_DEBUG_ATOMIC_SLEEP is enabled.
Bug is present in Kernel versions v3.9 onwards.
Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Tested-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
All OMAP IP blocks expect LE data, but CPU may operate in BE mode.
Need to use endian neutral functions to read/write h/w registers.
I.e instead of __raw_read[lw] and __raw_write[lw] functions code
need to use read[lw]_relaxed and write[lw]_relaxed functions.
If the first simply reads/writes register, the second will byteswap
it if host operates in BE mode.
Changes are trivial sed like replacement of __raw_xxx functions
with xxx_relaxed variant.
Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org>
Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
This should fix the following warning at boot on OMAP5 uEVM
[ 8.783155] WARNING: CPU: 0 PID: 1 at drivers/clk/clk.c:883 __clk_enable+0x94/0xa4()
The data structure of_match_ptr() protects is always compiled in.
Hence of_match_ptr() is not needed.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Use the newly introduced devm_ioremap_resource() instead of
devm_request_and_ioremap() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages; so all explicit
error messages can be removed from the failure code paths.
Allows the OMAP USB TLL module to be specified via device tree.
This is because we want to get rid of platform_data usage from probe().
The only information we need is PORT_MODE, and this can be supplied
to us by the user (i.e. omap-usb-host.c).
We also move channel clock management from runtime PM handlers into
omap_tll_enable/disable().
The TLL module on OMAP5 has 3 channels.
HSIC mode requires the TLL channel to be in Transparent UTMI mode.
Reviewed-by: Felipe Balbi <balbi@ti.com>
Get rid of the unnecessary spin_lock_irqsave/restore() as there is
no interrupt handler for this driver. Instead we serialize access
to tll_dev using a global spinlock.
omap_enable/disable_tll() can fail if TLL device is not
initialized. It could be due to multiple reasons and not only
due to missing platform data.
Also make local variables static and use 'struct device *'
instead of 'struct platform_device *' for global reference.
No need to check for missing platform data in runtime_suspend/resume
as it makes more sense to do it in the probe function.
This is a handy macro to check if the port requires the
USB TLL module or not. Use it to Enable the TLL module and manage
the clocks.
Every channel has a functional clock that is similarly named.
It makes sense to use a for loop to manage these clocks as OMAPs
can come with up to 3 channels.
Dynamically allocate and get channel clocks depending on the
number of clocks avaiable on the platform.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Use devm_ variants of kzalloc() and ioremap(). Simplify the error path.
Fix channel count detecion for REV2. Also, don't give up
if we don't recognize the IP Revision. We assume the default
number of channels (i.e. 3) for unrecognized IPs.
Let's have a single platform data structure for the OMAP's High-Speed
USB host subsystem instead of having 3 separate ones i.e. one for
board data, one for USB Host (UHH) module and one for USB-TLL module.
This makes the code much simpler and avoids creating multiple copies of
platform data.
For the ehci-omap.c part:
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Pull ARM SoC Header cleanups from Olof Johansson:
"This is a collection of header file cleanups, mostly for OMAP and
AT91, that keeps moving the platforms in the direction of
multiplatform by removing the need for mach-dependent header files
used in drivers and other places."
Fix up mostly trivial conflicts as per Olof.
* tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (106 commits)
ARM: OMAP2+: Move iommu/iovmm headers to platform_data
ARM: OMAP2+: Make some definitions local
ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.c
ARM: OMAP2+: Move plat/iovmm.h to include/linux/omap-iommu.h
ARM: OMAP2+: Move iopgtable header to drivers/iommu/
ARM: OMAP: Merge iommu2.h into iommu.h
atmel: move ATMEL_MAX_UART to platform_data/atmel.h
ARM: OMAP: Remove omap_init_consistent_dma_size()
arm: at91: move at91rm9200 rtc header in drivers/rtc
arm: at91: move reset controller header to arm/arm/mach-at91
arm: at91: move pit define to the driver
arm: at91: move at91_shdwc.h to arch/arm/mach-at91
arm: at91: move board header to arch/arm/mach-at91
arn: at91: move at91_tc.h to arch/arm/mach-at91
arm: at91 move at91_aic.h to arch/arm/mach-at91
arm: at91 move board.h to arch/arm/mach-at91
arm: at91: move platfarm_data to include/linux/platform_data/atmel.h
arm: at91: drop machine defconfig
ARM: OMAP: Remove NEED_MACH_GPIO_H
ARM: OMAP: Remove unnecessary mach and plat includes
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Acked-by: David Brown <davidb@codeaurora.org>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
In order to make single zImage work for ARM architecture,
we need to make sure we don't depend on private headers.
Move USB platform_data to <linux/platform_data/omap-usb.h>
and add a minimal drivers/mfd/usb-omap.h.
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Partha Basak <parthab@india.ti.com>
Cc: Keshava Munegowda <keshava_mgowda@ti.com>
Cc: linux-usb@vger.kernel.org
Signed-off-by: Felipe Balbi <balbi@ti.com>
[tony@atomide.com: updated for local mfd/usb-omap.h]
The platform driver for the TLL component of the OMAP USB host controller
is implemented. Depending on the TLL hardware revision , the TLL channels
are configured. The USB HS core driver uses this driver through exported
APIs from the TLL platform driver.
usb_tll_enable and usb_tll_disble are the exported APIs of the USB TLL
platform driver.
Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com>
Reviewed-by: Partha Basak <parthab@india.ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
