path: root/drivers/mfd/max8998-irq.c
2015-08-11mfd: max899x: Avoid redundant irq_data lookupThomas Gleixner
It's pretty silly to do irq_data *d = irq_get_irq_data(irq_data->irq); because that results in d = irq_data, but goes through a lookup of the irq_data. Use irq_data directly. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-08-11mfd: Kill off set_irq_flags usageRob Herring
set_irq_flags is ARM specific with custom flags which have genirq equivalents. Convert drivers to use the genirq interfaces directly, so we can kill off set_irq_flags. The translation of flags is as follows: IRQF_VALID -> !IRQ_NOREQUEST IRQF_PROBE -> !IRQ_NOPROBE IRQF_NOAUTOEN -> IRQ_NOAUTOEN For IRQs managed by an irqdomain, the irqdomain core code handles clearing and setting IRQ_NOREQUEST already, so there is no need to do this in .map() functions and we can simply remove the set_irq_flags calls. Some users also modify IRQ_NOPROBE and this has been maintained although it is not clear that is really needed. There appears to be a great deal of blind copy and paste of this code. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-06-22mfd: Constify regmap and irq configuration dataKrzysztof Kozlowski
Constify in various drivers configuration data which is not modified: - regmap_irq_chip, - individual regmap_irq's in array, - regmap_config, - irq_domain_ops, Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-06-30mfd: max8998: Add irq domain supportTomasz Figa
This patch adds irq domain support for max8998 interrupts. To keep both non-DT and DT worlds happy, simple domain is used, which is linear when no explicit IRQ base is specified and legacy, with static mapping, otherwise. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-27mfd: Cleanup irq namespaceThomas Gleixner
Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-01-14mfd: MAX8998/LP3974 hibernation supportMyungJoo Ham
This patch makes the driver to save and restore register values for hibernation. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-01-14mfd: Convert MAX8998 driver to irq_ APIMark Brown
The genirq core is being updated to pass struct irq_data to interrupt operations, update the MAX8998 driver to the new API. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add free max8998->ono irq in max8998_irq_exit()Axel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Add MAX8998 interrupts supportJoonyoung Shim
Use genirq and provide seperated file for interrupts support. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
