This patch improves support for the flash cell of
max77693 mfd by adding relevant of_compatible field
and a structure for caching related platform data.
Added are also FLASH registers related macro definitions.
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
This patch modifies mfd driver to use regmap for handling interrupts.
It allows to simplify irq handling process. This modifications needed
to make small changes in function drivers, which use interrupts.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Chanwoo Choi <cw00.choi@samsung.com>
This patch removes wrapper functions used to access regmap, and
make driver using regmap_*() functions instead.
Acked-by: Mark Brown <broonie@linaro.org>
Array of struct of_device_id may be be const as expected by
of_match_table field.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
During probe the driver allocates dummy I2C devices for MUIC and haptic
with i2c_new_dummy() but it does not check the return value of this
calls.
In case of error (i2c_new_device(): memory allocation failure or I2C
address cannot be used) this function returns NULL which is later used
by devm_regmap_init_i2c() and i2c_unregister_device().
If i2c_new_dummy() fails for MUIC or haptic devices, fail also the probe
for main MFD driver.
Cc: stable@vger.kernel.org
The MUIC block in max77693 has different I2C address than PMIC. The
driver allocated two regmaps: for PMIC and MUIC. However it used the
same regmap_config (with max_register field) for both regmaps. Actual
maximum address of register for MUIC is different than for PMIC.
Define another regmap_config for MUIC with proper max_register value.
As of commit 03e361b25ee8dfb1fd9b890072c23c4aae01c6c7 ("mfd: Stop setting
refcounting pointers in original mfd_cell arrays"), the "cell" parameter of
mfd_add_devices() is "const" again. Hence make all cell data passed to
mfd_add_devices() const where possible.
'of_match_ptr' is defined in linux/of.h. Include it explicitly to
avoid build breakage in the future.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
This patch adds only of_match_table. There are no device specific
properties.
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
The patch removes wakeup related code from the driver and plaftorm
data - it is already handled by i2c core using I2C_CLIENT_WAKE flag
from struct i2c_board_info. As a result MFD itself do not requires
platform data.
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Current code uses max77693->dev in the dev_err call before setting it to
&i2c->dev. Fix it.
This patch also includes below cleanups:
- Move checking pdata earlier and show dev_err if no platform data found.
- Remove unnecessary err_regmap goto label.
- Unregister i2c devices if regmap init for muic fails.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
This patch initialize register map of MUIC device because mfd driver
of Maxim MAX77693 use regmap-muic instance of MUIC device when irqs of
Maxim MAX77693 is initialized before call max77693-muic probe() function.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
Reported-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Currently the MFD core supports remapping MFD cell interrupts using an
irqdomain but only if the MFD is being instantiated using device tree
and only if the device tree bindings use the pattern of registering IPs
in the device tree with compatible properties. This will be actively
harmful for drivers which support non-DT platforms and use this pattern
for their DT bindings as it will mean that the core will silently change
remapping behaviour and it is also limiting for drivers which don't do
DT with this particular pattern. There is also a potential fragility if
there are interrupts not associated with MFD cells and all the cells are
omitted from the device tree for some reason.
Instead change the code to take an IRQ domain as an optional argument,
allowing drivers to take the decision about the parent domain for their
interrupts. The one current user of this feature is ab8500-core, it has
the domain lookup pushed out into the driver.
We need to call max77693_irq_exit() in max77693_i2c_probe error patch and
max77693_i2c_remove.
Current code already uses devm_kzalloc() to allocate memory for max77693.
Thus we should not call kfree(max77693), otherwise we got double free.
They're not referenced outside this file.
Now this driver is using regmap APIs, the iolock mutex is not used and can be
removed.
This patch supports IRQ handling for MAX77693.
This patch adds MFD driver for MAX77693 to enable its sub devices.
The MAX77693 is a multi-function devices. It includes PMIC,
MUIC(Micro USB Interface Controller), flash LED control and
haptic motor control.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
