path: root/drivers/mfd/Kconfig
2014-12-01mfd: atmel-hlcdc: Add Kconfig option description and nameBoris Brezillon
The MFD_ATMEL_HLCDC was first intended to be selected by its sub-devices but these sub-devices now depends on this option, we thus need to add a name and a description so that users can see it. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-11-25Revert "mfd: sec-core: Prepare regulators for suspend state to reduce ↵Javier Martinez Canillas
power-consumption" This reverts commit b7cde7078d2344073c310aa65fc2b0a845d2cb5b ("mfd: sec-core: Prepare regulators for suspend state to reduce power-consumption") Commit b7cde7078d23 called regulator_suspend_prepare() to prepare the regulators for a suspend state. But it did from the device pm suspend handler while the regulator suspend prepare function iterates over all regulators and not only the one managed by this device so it doesn't seems to be correct to call it from within a device driver. It is better to call the regulator suspend prepare/finish functions from platform code instead so this patch reverts the mentioned commit. Suggested-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-11-25mfd: Add atmel-hlcdc driverBoris Brezillon
The HLCDC IP available on some Atmel SoCs (i.e. at91sam9n12, at91sam9x5 family or sama5d3 family) exposes 2 subdevices: - a display controller (controlled by a DRM driver) - a PWM chip The MFD device provides a regmap and several clocks (those connected to this hardware block) to its subdevices. This way concurrent accesses to the iomem range are handled by the regmap framework, and each subdevice can safely access HLCDC registers. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Tested-by: Anthony Harivel <anthony.harivel@emtrion.de> Tested-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-11-25Merge branches 'ib-mfd-gpio-i2c-3.19', 'ib-mfd-iio-3.19' and ↵Lee Jones
'ib-mfd-regulator-v3.19', tag 'ib-mfd-regulator-clk-v3.19' into ibs-for-mfd-merged Immutable branch between MFD, Regulator and Clk, due for v3.19
2014-11-10mfd: Add support for Diolan DLN-2 devicesOctavian Purdila
This patch implements the USB part of the Diolan USB-I2C/SPI/GPIO Master Adapter DLN-2. Details about the device can be found here: https://www.diolan.com/i2c/i2c_interface.html. Information about the USB protocol can be found in the Programmer's Reference Manual [1], see section 1.7. Because the hardware has a single transmit endpoint and a single receive endpoint the communication between the various DLN2 drivers and the hardware will be muxed/demuxed by this driver. Each DLN2 module will be identified by the handle field within the DLN2 message header. If a DLN2 module issues multiple commands in parallel they will be identified by the echo counter field in the message header. The DLN2 modules can use the dln2_transfer() function to issue a command and wait for its response. They can also register a callback that is going to be called when a specific event id is generated by the device (e.g. GPIO interrupts). The device uses handle 0 for sending events. [1] https://www.diolan.com/downloads/dln-api-manual.pdf Signed-off-by: Octavian Purdila <octavian.purdila@intel.com> Reviewed-by: Johan Hovold <johan@kernel.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-10-07mfd: axp20x: Extend axp20x to support axp288 pmicJacob Pan
X-Powers AXP288 is a customized PMIC for Intel Baytrail-CR platforms. Similar to AXP202/209, AXP288 comes with USB charger, more LDO and BUCK channels, and AD converters. It also provides extended status and interrupt reporting capabilities than the devices currently supported in axp20x.c. In addition to feature extension, this patch also adds ACPI binding for enumeration. This consolidated driver should support more X-Powers' PMICs in both device tree and ACPI enumerated platforms. Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Reviewed-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-09-26mfd: Add support for Qualcomm SPMI PMICsJosh Cartwright
The Qualcomm SPMI PMIC chips are components used with the Snapdragon 800 series SoC family. This driver exists largely as a glue mfd component, it exists to be an owner of an SPMI regmap for children devices described in device tree. Signed-off-by: Josh Cartwright <joshc@codeaurora.org> Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-09-26mfd: Add HI6421 PMIC Core driverGuodong Xu
This adds driver to support HiSilicon Hi6421 PMIC. Hi6421 includes multi- functions, such as regulators, codec, ADCs, Coulomb counter, etc. This driver includes core APIs _only_. Drivers for individul components, like voltage regulators, are implemented in corresponding driver directories and files. Registers in Hi6421 are memory mapped, so using regmap-mmio API. Signed-off-by: Guodong Xu <guodong.xu@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-09-26mfd: RK808: Add new mfd driver for RK808Chris Zhong
The RK808 chip is a power management IC for multimedia and handheld devices. It contains the following components: - Regulators - RTC - Clkout The RK808 core driver is registered as a platform driver and provides communication through I2C with the host device for the different components. Signed-off-by: Chris Zhong <zyw@rock-chips.com> Signed-off-by: Zhang Qing <zhangqing@rock-chips.com> Tested-by: Heiko <heiko@sntech.de> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-09-26mfd: Add Ricoh RN5T618 PMIC core driverBeniamino Galvani
Ricoh RN5T618 is a power management IC which integrates 3 step-down DCDC converters, 7 low-dropout regulators, a Li-ion battery charger, fuel gauge, ADC, GPIOs and a watchdog timer. This commit adds a MFD core driver to support the I2C communication with the device. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-09-26mfd: wm8994: Allow modular buildMark Brown
The interfaces that used to be built in only (interrupts IIRC) no longer are so allow the driver to be built as a module fixing arm64 allmodconfig builds. Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-09-24mfd: menf21bmc: Introduce MEN 14F021P00 BMC MFD Core driverAndreas Werner
The MEN 14F021P00 Board Management Controller provides an I2C interface to the host to access the feature implemented in the BMC. The BMC is a PIC Microntroller assembled on CPCI Card from MEN Mikroelektronik and on a few Box/Display Computer. Added MFD Core driver, supporting the I2C communication to the device. The MFD driver currently supports the following features: - Watchdog - LEDs - Hwmon (voltage monitoring) Signed-off-by: Andreas Werner <andreas.werner@men.de> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-07-25mfd: max77686: Add Maxim 77802 PMIC supportJavier Martinez Canillas
Maxim MAX77802 is a power management chip that contains 10 high efficiency Buck regulators, 32 Low-dropout (LDO) regulators used to power up application processors and peripherals, a 2-channel 32kHz clock outputs, a Real-Time-Clock (RTC) and a I2C interface to program the individual regulators, clocks outputs and the RTC. This patch adds support for MAX77802 to the MAX77686 driver and is based on a driver added to the Chrome OS kernel 3.8 by Simon Glass. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-07-21mfd: max77686: Convert to use regmap_irqJavier Martinez Canillas
By using the generic IRQ support in the Register map API, it is possible to get rid max77686-irq.c and simplify the code. Suggested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Doug Anderson <dianders@chromium.org> Tested-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-07-09mfd: sec-core: Prepare regulators for suspend state to reduce power-consumptionChanwoo Choi
This patch use regulator_suspend_prepare() function to prepare the proper state of regulators for suspend state to remove un-necessary leakage power-consumption. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-07-09mfd: mc13xxx: Use regmap irq framework for interruptsAlexander Shiyan
This patch convert mc13xxx MFD driver to use regmap irq framework for interrupt registration. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-07-09mfd: Fix cs5535 dependenciesJean Delvare
As far as I know, the CS5535 and CS5536 chipsets are companions of the Geode series of processors, which are 32-bit only. So the CS5535 drivers are not needed on x86-64, except for build testing purpose. This aligns the dependencies to what FB_GEODE already uses. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-07-09mfd: timberdale: Depend on X86_32Jean Delvare
As far as I know the Timberdale chip was only used as a companion for Intel Atom E600 series processors. As such, its drivers are only useful on X86_32. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-07-09Merge branches 'ib-mfd-extcon-regulator-3.17', 'ib-mfd-gpio-3.17' and ↵Lee Jones
'ib-mfd-mmc-3.17' into ibs-for-mfd-merged
2014-06-26mfd: davinci: Voicecodec needs regmap_mmioArnd Bergmann
Without REGMAP_MMIO, building that driver results in a link error: drivers/built-in.o: In function `davinci_vc_probe': :(.init.text+0x3c1c): undefined reference to `devm_regmap_init_mmio_clk' This adds a Kconfig 'select' statement as the usual way to ensure that REGMAP_MMIO is enabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-06-26mfd: STw481x: Allow modular buildArnd Bergmann
This driver depends on I2C, which may be a loadable module. While you'd probably want both to be built-in in practice, allowing a modular build avoids possible randconfig link errors. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-06-26mfd: UCB1x00: Enable modular buildArnd Bergmann
The UCB1200 / UCB1300 driver uses the MCP_SA11X0 driver, which can be a loadable module, but this results in a link error when UCB1200 itself is built-in: drivers/built-in.o: In function `ucb1x00_io_set_dir': :(.text+0x4a364): undefined reference to `mcp_reg_write' drivers/built-in.o: In function `ucb1x00_io_write': :(.text+0x4a3dc): undefined reference to `mcp_reg_write' drivers/built-in.o: In function `ucb1x00_io_read': :(.text+0x4a400): undefined reference to `mcp_reg_read' drivers/built-in.o: In function `ucb1x00_adc_enable': :(.text+0x4a460): undefined reference to `mcp_enable' ... This can easily be resolved by making CONFIG_MCP_UCB1200 itself a tristate option, since that causes Kconfig to track the dependency correctly. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-06-17mfd: intel_soc_pmic: Crystal Cove supportZhu, Lejun
This patch provides chip-specific support for Crystal Cove. Crystal Cove is the PMIC in Baytrail-T platform. Also adds Intel SoC PMIC support to the build files. Signed-off-by: Yang, Bin <bin.yang@intel.com> Signed-off-by: Zhu, Lejun <lejun.zhu@linux.intel.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-06-17mfd: max77693: Handle IRQs using regmapRobert Baldyga
This patch modifies mfd driver to use regmap for handling interrupts. It allows to simplify irq handling process. This modifications needed to make small changes in function drivers, which use interrupts. Signed-off-by: Robert Baldyga <r.baldyga@samsung.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-06-06Merge tag 'mfd-for-linus-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd into next Pull MFD updates from Lee Jones: "Changes to existing drivers: - increase DT coverage: arizona, mc13xxx, stmpe-i2c, syscon, sun6i-prcm - regmap use of and/or clean-up: tps65090, twl6040 - basic renaming: max14577 - use new cpufreq helpers: db8500-prcmu - increase regulator support: stmpe, arizona, wm5102 - reduce legacy GPIO overhead: stmpe - provide necessary remove path: bcm590xx - expand sysfs presence: kempld - move driver specific code out to drivers: rtc-s5m, arizona - clk handling: twl6040 - use managed (devm_*) resources: ipaq-micro - clean-up/remove unused/duplicated code: tps65218, sec, pm8921, abx500-core, db8500-prcmu, menelaus - build/boot/sematic bug fixes: rtsx_usb, stmpe, bcm590xx, abx500, mc13xxx, rdc321x-southbridge, mfd-core, sec, max14577, syscon, cros_ec_spi - constify stuff: sm501, tps65910, tps6507x, tps6586x, max77686, max8997, kempld, max77693, max8907, rtsx_usb, db8500-prcmu, max8998, wm8400, sec, lp3943, max14577, as3711, omap-usb-host, ipaq-micro Support for new devices: - add support for max77836 into max14577 - add support for tps658640 into tps6586x - add support for cros-ec-i2c-tunnel into cros_ec - add new driver for rtsx_usb_sdmmc and rtsx_usb_ms - add new driver for axp20x - add new driver for sun6i-prcm - add new driver for ipaq-micro" * tag 'mfd-for-linus-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (77 commits) mfd: wm5102: Correct default for LDO Control 2 register mfd: menelaus: Use module_i2c_driver mfd: tps65218: Terminate of match table mfd: db8500-prcmu: Remove check for CONFIG_DBX500_PRCMU_DEBUG mfd: ti-keystone-devctrl: Add bindings for device state control mfd: palmas: Format the header file mfd: abx500-core: Remove unused function abx500_dump_all_banks() mfd: arizona: Correct addresses of always-on trigger registers mfd: max14577: Cast to architecture agnostic data type i2c: ChromeOS EC tunnel driver mfd: cros_ec: Sync to the latest cros_ec_commands.h from EC sources mfd: cros_ec: spi: Increase cros_ec_spi deadline from 5ms to 100ms mfd: cros_ec: spi: Make the cros_ec_spi timeout more reliable mfd: cros_ec: spi: Add mutex to cros_ec_spi mfd: cros_ec: spi: Calculate delay between transfers correctly mfd: arizona: Correct error message for addition of main IRQ chip mfd: wm8997: Add registers for high power mode mfd: arizona: Add MICVDD to mapped regulators mfd: ipaq-micro: Make mfd_cell array const mfd: ipaq-micro: Use devm_ioremap_resource() ...
2014-06-03Merge tag 'char-misc-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc into next Pull char/misc driver patches from Greg KH: "Here is the big char / misc driver update for 3.16-rc1. Lots of different driver updates for a variety of different drivers and minor driver subsystems. All have been in linux-next with no reported issues" * tag 'char-misc-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (79 commits) hv: use correct order when freeing monitor_pages spmi: of: fixup generic SPMI devicetree binding example applicom: dereferencing NULL on error path misc: genwqe: fix uninitialized return value in genwqe_free_sync_sgl() miscdevice.h: Simple syntax fix to make pointers consistent. MAINTAINERS: Add miscdevice.h to file list for char/misc drivers. mcb: Add support for shared PCI IRQs drivers: Remove duplicate conditionally included subdirs misc: atmel_pwm: only build for supported platforms mei: me: move probe quirk to cfg structure mei: add per device configuration mei: me: read H_CSR after asserting reset mei: me: drop harmful wait optimization mei: me: fix hw ready reset flow mei: fix memory leak of mei_clients array uio: fix vma io range check in mmap drivers: uio_dmem_genirq: Fix memory leak in uio_dmem_genirq_probe() w1: do not unlock unheld list_mutex in __w1_remove_master_device() w1: optional bundling of netlink kernel replies connector: allow multiple messages to be sent in one packet ...
2014-06-03mfd: Add driver for Atmel Microcontroller on iPaq h3xxxLinus Walleij
This adds a driver for the Atmel Microcontroller found on the iPAQ h3xxx series. This device handles some keys, the touchscreen, and the battery monitoring. This is a port of a driver from handhelds.org 2.6.21 kernel, written by Alessandro Gardich based on Andrew Christians original HAL-driver. It has been heavily cleaned and converted to mfd-core by Dmitry Artamonow and rewritten again for the v3.x series kernels by Linus Walleij, bringing back some of the functionality lost from Andrew's original driver. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Alessandro Gardich <gremlin@gremlin.it> Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-06-03mfd: Add support for sun6i PRCM (Power/Reset/Clock Management) unitBoris BREZILLON
The PRCM (Power/Reset/Clock Management) block exposes several subdevices in different subsystems (clk, reset ...) Add basic support for the PRCM unit with clk (AR100, AHB0, and APB0 clks) and reset controller subdevices. Other subdevices might be added later (if needed). Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-06-03mfd: AXP20x: Add mfd driver for AXP20x PMICCarlo Caione
This patch introduces the preliminary support for PMICs X-Powers AXP202 and AXP209. The AXP209 and AXP202 are the PMUs (Power Management Unit) used by A10, A13 and A20 SoCs and developed by X-Powers, a sister company of Allwinner. The core enables support for two subsystems: - PEK (Power Enable Key) - Regulators Signed-off-by: Carlo Caione <carlo@caione.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-06-03Merge branches 'ib-from-asoc-3.16', 'ib-from-pm-3.16', ↵Lee Jones
'ib-from-regulator-3.16', 'ib-mfd-gpio-3.16' and 'ib-mfd-mmc-memstick-3.16', tags 'ib-mfd-extcon-3.16', 'ib-mfd-omap-3.16' and 'ib-mfd-regulator-3.16' into ibs-for-mfd-merged
2014-05-26ARM: vexpress: refine dependencies for new codeArnd Bergmann
The versatile express changes for 3.16 introduced a number of build regressions for randconfig kernels by not tracking dependencies between the components right. This patch tries to rectify that: * the mach-vexpress code cannot link without the syscfg driver, which in turn needs MFD_VEXPRESS_SYSREG * various drivers call devm_regmap_init_vexpress_config(), which has to be exported so it can be used by loadable modules * the configuration bus uses OF DT helper functions that are not available to platforms disable CONFIG_OF * The sysreg driver exports GPIOs through gpiolib, which can be disabled on some platforms. * The clocksource code cannot be built on platforms that don't use modern timekeeping but rely on gettimeoffset. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-05-15mfd: vexpress: Define the device as MFD cellsPawel Moll
This patch - finally, after over 6 months! :-( - addresses Samuel's request to split the vexpress-sysreg driver into smaller portions and define the device in a form of MFD cells: * LEDs code has been completely removed and replaced with "gpio-leds" nodes in the tree (referencing dedicated GPIO subnodes in sysreg - bindings documentation updated); this also better fits the reality as some variants of the motherboard don't have all the LEDs populated * syscfg bridge code has been extracted into a separate driver (placed in drivers/misc for no better place) * all the ID & MISC registers are defined as sysconf making them available for other drivers should they need to use them (and also to the user via /sys/kernel/debug/regmap which can be helpful in platform debugging) Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Lee Jones <lee.jones@linaro.org>
2014-05-09mfd: stmpe: Probe properly from the Device TreeLinus Walleij
The current STMPE I2C probing code does not really match the compatible strings - it matches node names happening to give the right device name. Instead, let's introduce some real compatible matching, more complex, more accurate. Make the driver depend on OF since all platforms using it are DT-only. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-04-23mfd: max77836: Add MAX77836 support to max14577 driverKrzysztof Kozlowski
Add Maxim 77836 support to max14577 driver. The chipsets have same MUIC component so the extcon, charger and regulators are almost the same. The MAX77836 however has also PMIC and Fuel Gauge. The MAX77836 uses three I2C slave addresses and has additional interrupts (related to PMIC and Fuel Gauge). It has also Interrupt Source register, just like MAX77686 and MAX77693. The MAX77836 PMIC's TOPSYS and INTSRC interrupts are reported in the PMIC block. The PMIC block has different I2C slave address and uses own regmap so another regmap_irq_chip is needed. Since we have two regmap_irq_chip, use shared interrupts on MAX77836. This patch adds additional defines and functions to the max14577 MFD core driver so the driver will handle both chipsets. Also this patch replaces "0x1 << N" with BIT(N) in defines for register masks. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: Remove obsolete ti-ssp driverArnd Bergmann
The tnetv107x platform is getting removed, so this driver is not needed any more. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: Add bcm590xx pmu driverMatt Porter
Add a driver for the BCM590xx PMU multi-function devices. The driver initially supports regmap initialization and instantiation of the voltage regulator device function of the PMU. Signed-off-by: Matt Porter <mporter@linaro.org> Reviewed-by: Tim Kryger <tim.kryger@linaro.org> Reviewed-by: Markus Mayer <markus.mayer@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: max14577: Select REGMAP_IRQKrzysztof Kozlowski
MAXIM 14577 MFD driver uses the regmap_irq_chip so it's Kconfig entry should select REGMAP_IRQ. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: tps65218: Fix reported randconfig errorLee Jones
Reported error was: ERROR: "regmap_del_irq_chip" [drivers/mfd/tps65218.ko] undefined! when CONFIG_REGMAP_IRQ is not enabled. Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: pm8921: Loosen Kconfig dependencyStephen Boyd
Allow this driver to be compiled on all ARM builds as it doesn't rely on anything within arm/mach-msm. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: pm8921: Use ssbi regmapStephen Boyd
Use a regmap so that the pm8xxx read/write APIs can be removed once all consumer drivers are converted. Reviewed-by: Mark Brown <broonie@linaro.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: pm8921: Migrate to irqdomainsStephen Boyd
Convert this driver to use irqdomains so that the PMIC's child devices can be converted to devicetree. Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2014-03-19mfd: pm8921: Update for genirq changesStephen Boyd
Since this code has been marked broken for some time a few genirq tree wide changes weren't made. set_irq_wake() was renamed to irq_set_irq_wake() in commit a0cd9ca2b (genirq: Namespace cleanup, 2011-02-10) and commit 10a8c383 (irq: introduce entry and exit functions for chained handlers) introduced the chained irq functions but this driver wasn't updated to use them. Fix these problems and remove the BROKEN marking on this driver. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: pm8xxx: Move pm8xxx-irq.c contents into only driver that uses itStephen Boyd
The pm8xxx-irq.c code is practically mandatory given that the pm8921-core driver will WARN about it missing and the Kconfig marks it as default y when a PM8xxx chips is enabled. The only reason the file was split out was because we planned to support other pm8xxx chips with different pm8xxx-core.c files. Now that we have DT on ARM this isn't necessary because we should be able to support all the ssbi based PM8xxx chips in one driver and one file with no data bloat. Let's move this code into the only driver that uses it right now (pm8921) so that it's always compiled when needed. In the future we can rename pm8921-core.c to something more generic. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: kempld: Add support for COMe-mBT10, COMe-cBT6 and COMe-cHL6 to Kontron ↵Michael Brunner
PLD driver This patch adds DMI system IDs for the Kontron modules COMe-mBT10, COMe-cBT6 and COMe-cHL6 to the Kontron PLD driver. The list of supported products in the module description is also updated. Signed-off-by: Michael Brunner <michael.brunner@kontron.com> Acked-by: Christian Rauch <christian.rauch@kontron.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: Add realtek USB card reader driverRoger Tseng
Realtek USB card reader provides a channel to transfer command or data to flash memory cards. This driver exports host instances for mmc and memstick subsystems and handles basic works. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Roger Tseng <rogerable@realtek.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: Trivial: Fix a grammar issues in MFD KconfigLaszlo Papp
s/to support for/to add support for/ Signed-off-by: Laszlo Papp <lpapp@kde.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: tps65218: Add driver for the TPS65218 PMICKeerthy
The TPS65218 chip is a power management IC for Portable Navigation Systems and Tablet Computing devices. It contains the following components: - Regulators. - Over Temperature warning and Shut down. This patch adds support for tps65218 mfd device. At this time only the regulator functionality is made available. Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-19mfd: Include all drivers in subsystem menuLinus Walleij
It is currently not possible to select the SA1100 or Vexpress drivers in the MFD subsystem, because the menu for the entire subsystem ends before these options are presented. Move the main menu closing and the endif for HAS_IOMEM to the end of the file so these are selectable again. Cc: stable@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-03-18mfd: twl4030-madc: Move driver to drivers/iio/adcSebastian Reichel
This is a driver for an A/D converter, which belongs into drivers/iio/adc. Signed-off-by: Sebastian Reichel <sre@debian.org> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-01-21mfd: mc13xxx: Remove useless symbol MFD_MC13783Alexander Shiyan
Symbol MFD_MC13783 always selected by MFD_MC13XXX, so no need to keep additional symbol. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Lee Jones <lee.jones@linaro.org>
