path: root/drivers/message
2007-05-05Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (87 commits) [SCSI] fusion: fix domain validation loops [SCSI] qla2xxx: fix regression on sparc64 [SCSI] modalias for scsi devices [SCSI] sg: cap reserved_size values at max_sectors [SCSI] BusLogic: stop using check_region [SCSI] tgt: fix rdma transfer bugs [SCSI] aacraid: fix aacraid not finding device [SCSI] aacraid: Correct SMC products in aacraid.txt [SCSI] scsi_error.c: Add EH Start Unit retry [SCSI] aacraid: [Fastboot] Panics for AACRAID driver during 'insmod' for kexec test. [SCSI] ipr: Driver version to 2.3.2 [SCSI] ipr: Faster sg list fetch [SCSI] ipr: Return better qc_issue errors [SCSI] ipr: Disrupt device error [SCSI] ipr: Improve async error logging level control [SCSI] ipr: PCI unblock config access fix [SCSI] ipr: Fix for oops following SATA request sense [SCSI] ipr: Log error for SAS dual path switch [SCSI] ipr: Enable logging of debug error data for all devices [SCSI] ipr: Add new PCI-E IDs to device table ...
2007-04-30[SCSI] fusion: fix domain validation loopsEric Moore
After host reset, the device are programmed to default asyn narrow nego. We need to reprogram the parameter back to previous values. If the host reset is called as a result of spi_dv_device() commands timing out, its possible to get into an infinite loop of dv to host reset. This will prevent that case, as we merely program old values. If host reset is called outside context of domain validation, then we can call spi_dv_device. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[SK_BUFF]: Introduce skb_mac_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the mac header, it is still legal to touch skb->mac.raw directly if just adding to, subtracting from or setting it to another layer header. This one also converts some more cases to skb_reset_mac_header() that my regex missed as it had no spaces before nor after '=', ugh. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_mac_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-01[SCSI] fusion: make mptspi_target_destroy() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-27Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] gdth: fix oops in gdth_copy_cmd() [SCSI] mptsas: Fix oops for insmod during kexec [SCSI] lpfc: avoid double-free during PCI error failure
2007-03-27[PATCH] i2o: block IO errors on i2o diskVasily Averin
I2O subsystem has been broken in mainstream several months ago (after 2.6.18). Commit 4aff5e2333c9a1609662f2091f55c3f6fffdad36 from Jens Axboe split struct request ->flags into two parts: cmd_type and cmd_flags. In i2o layer this patch has replaced flag REQ_SPECIAL by the according cmd_type. However i2o has used REQ_SPECIAL not as command type but as driver-specific flag for the debug purposes. As result all i2o requests have type "special" now, are not processed to the hardware and fail with I/O error: i2o/hda:<3>Buffer I/O error on device i2o/hda, logical block 0 Buffer I/O error on device i2o/hda, logical block 0 Buffer I/O error on device i2o/hda, logical block 0 unable to read partition table block-osm: device added (TID: 207): i2o/hda The following patch removes the extra debug checks without any drawbacks and restores the normal driver's work. Signed-off-by: Vasily Averin <vvs@sw.ru> Acked-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-20[SCSI] fusion: remove VMWare guest OS remounted as read only work aroundEric Moore
This address the issue of VMWare guest OS being remounted as read-only becuase the underlying device was held busy too long and at the same time address Engenio MPP driver concerns over infinite retries. This patch removes the code that snoops the SAM STATUS on busy, which would be returning DID_BUS_BUSY, instead we return the status as is. Retry hanlding seems to be properly handled in scsi_softirq_done, where a busy sam status would only occurr for the time specified by (cmd->allowed +1) * cmd->timeout_per_command. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] fusion: honour return value of pci_enable_device() in mpt_resume()Horms
Honour the return value of pci_enable_device(), which seems to be a desirable thing to do: 2.6.20-rc4 gcc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21) CC [M] drivers/message/fusion/mptbase.o drivers/message/fusion/mptbase.c: In function `mpt_resume': drivers/message/fusion/mptbase.c:1541: warning: ignoring return value of `pci_enable_device', declared with attribute warn_unused_result It also in turn has mptscsih_resume() honour the return value of mpt_resume() I'm not sure about the handling of the other potential error cases in mpt_resume(), of which there appear to be many. But this does seem to be a good start. Signed-off-by: Simon Horman <horms@verge.net.au> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] fusion: remove unnecessary code in mptscsih_resume()Horms
It seems that most of the code in mptscsih_resume() doesn't do anything. This patch removes that code. Signed-off-by: Simon Horman <horms@verge.net.au> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] fusion: kernel-doc warning fixesRandy Dunlap
Fix kernel-doc warnings in fusion driver code. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-11[SCSI] mptsas: Fix oops for insmod during kexecJudith Lebzelter
This fix's an oops during driver load time. mptsas_probe calls mpt_attach(over in mptbase.c). Inside that call, we read some manufacturing config pages to setup some defaults. While reading the config pages, the firmware doesn't complete the reply in time, and we have a timeout. The timeout results in hardreset handler being called. The hardreset handler calls all the fusion upper layer driver reset callback handlers. The mptsas_ioc_reset function is the callback handler in mptsas.c. So where I'm getting to, is mptsas_ioc_reset is getting called before scsi_host_alloc is called, and the pointer ioc->sh is NULL as well as the hostdata. Signed-off-by: Judith Lebzelter <judith@osdl.org> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-12[PATCH] mark struct file_operations const 5Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 4Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@sdl.org: dvb fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-02[SCSI] fusion - bump version - 3.04.04Eric Moore
bump version, and fix email addr for lsi support Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - error handling bug fix'sEric Moore
misc error handling bug fix's - properly interpret iocstatus returned after task management request - clear tmState after a failed doorbell - cleanup mptscsih_taskmgmt_complete Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - report wide port sas address's for hba physEric Moore
Return proper sas address to sas transport layer for parent phys that form a wide port. Current implementation returns a different address for each phy, incremented by one from the base address. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - serialize target resets in mptsas.cEric Moore
Fusion firmware requires target reset following hotplug removal event, with purpose to flush target outstanding request in fw. Current implementation does the target resets from delayed work tasks, that in heavy load conditions, take too long to be invoked, resulting in command time outs This patch will issue target reset immediately from ISR context, and will queue remaining target resets to be issued after the previous one completes. The delayed work tasks are spawned during the target reset completion. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - inactive raid support, and raid event bug fix'sEric Moore
inactive raid support, e.g. exposing hidden raid components belonging to a volume that are inactive. Also misc bug fix's for various raid asyn events. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - iocstatus, loginfo, and event debug updatesEric Moore
various string updates for iocstatus, logingo, and fw asyn events. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - added mptspi debugEric Moore
helpful debug for mptspi module Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - move SPI API over to mptspi.cEric Moore
Move some functions that only apply to the mptspi module over from mptscsih.c Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - Greater than 255 target and lun supportEric Moore
Add support for greater than 255 target and luns. Kill the hd->Target[] field, and change all references of bus_id/target_id, to channel/id. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-31Merge branch 'linus'James Bottomley
2007-01-27[SCSI] fusion: mpi header update - version 1.05.14Eric Moore
Here are the lastest mpi headers for mpt fusion driver, which defines the firmware to driver interface. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-13[SCSI] mptctl for mptsasDouglas Gilbert
This patch makes the mptctl pass through available if the mptsas driver is selected. Without this patch if mptsas is the only fusion driver chosen, then the mptctl is not presented as an option. smp_utils uses the mptctl driver to pass SAS SMP functions through a MPT SAS HBA. Signed-off-by: Douglas Gilbert <dougg@torque.net> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-06[SCSI] fusion: bump versionEric Moore
bump version Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-06[SCSI] fusion: MODULE_VERSION supportEric Moore
* Add modinfo driver version support. * Change copyright year to 2007. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-06[SCSI] fusion: power pc and miscellaneous bug fixsEric Moore
* Endian fix's for warnings found in ppc environment. * Fix compile time warning when calling scsi_device_reprobe, where in newer kernels this API expects its return value to be examined. * Fix compile errors when debug messages are enabled. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-06[SCSI] fusion: fibre channel: return DID_ERROR for ↵Eric Moore
MPI_IOCSTATUS_SCSI_IOC_TERMINATED A repost of a patch forwarded by Mikael Reed from 2006-12-20. The fibre channel IOC may kill a request for a variety of reasons, some of which may be recovered by a retry, some of which are unlikely to be recovered. Return DID_ERROR instead of DID_RESET to permit retry of the command, just not an infinite number of them. Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-12-22[PATCH] fix kernel-doc warnings in 2.6.20-rc1Randy Dunlap
Fix kernel-doc warnings in 2.6.20-rc1. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] i2o_exec_exit and i2o_driver_exit should not be __exit.Ralf Baechle
i2o_exec_exit and i2o_driver_exit were marked as __exit which is a bug because both are invoked from __init and __exit functions. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] kernel-doc: fix fusion and i2o docsRandy Dunlap
Correct lots of typos, kernel-doc warnings, & kernel-doc usage in fusion and i2o drivers. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] I2O: fix I2O_CONFIG without Adaptec extensionRandy Dunlap
With I2O_CONFIG=y and I2O_EXT_ADAPTEC=n, kernel build gets: drivers/message/i2o/i2o_config.c:1115: error: 'i2o_cfg_compat_ioctl' undeclared here (not in a function) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] I2O: handle __copy_from_userRandy Dunlap
Handle __copy_from_user() return value. Noticed by inspection, not from build warning. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] I2O: more error checkingJeff Garzik
i2o_scsi: handle sysfs failure i2o_device: * convert i2o_device_add() to return integer error code rather than pointer. Fortunately -nobody- checks the return code of this function, so changing has nil impact. * handle errors thrown by device_register() More work in i2o_device remains. Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-01Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (28 commits) PCI: make arch/i386/pci/common.c:pci_bf_sort static PCI: ibmphp_pci.c: fix NULL dereference pciehp: remove unnecessary pci_disable_msi pciehp: remove unnecessary free_irq PCI: rpaphp: change device tree examination PCI: Change memory allocation for acpiphp slots i2c-i801: SMBus patch for Intel ICH9 PCI: irq: irq and pci_ids patch for Intel ICH9 PCI: pci_{enable,disable}_device() nestable ports PCI: switch pci_{enable,disable}_device() to be nestable PCI: arch/i386/kernel/pci-dma.c: ioremap balanced with iounmap pci/i386: style cleanups PCI: Block on access to temporarily unavailable pci device pci: fix __pci_register_driver error handling pci: clear osc support flags if no _OSC method acpiphp: fix missing acpiphp_glue_exit() acpiphp: fix use of list_for_each macro Altix: Initial ACPI support - ROM shadowing. Altix: SN ACPI hotplug support. Altix: Add initial ACPI IO support ...
2006-12-01PCI: pci_{enable,disable}_device() nestable portsInaky Perez-Gonzalez
Change drivers/message/i20 pci driver to simply do a nestable enable()/disable() instead of checking for it. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-30Fix typos in doc and commentsJan Engelhardt
Changes persistant -> persistent. www.dictionary.com does not know persistant (with an A), but should it be one of those things you can spell in more than one correct way, let me know. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-30[PATCH] lockdep: annotate DECLARE_WAIT_QUEUE_HEADPeter Zijlstra
kernel: INFO: trying to register non-static key. kernel: the code is fine but needs lockdep annotation. kernel: turning off the locking correctness validator. kernel: [<c04051ed>] show_trace_log_lvl+0x58/0x16a kernel: [<c04057fa>] show_trace+0xd/0x10 kernel: [<c0405913>] dump_stack+0x19/0x1b kernel: [<c043b1e2>] __lock_acquire+0xf0/0x90d kernel: [<c043bf70>] lock_acquire+0x4b/0x6b kernel: [<c061472f>] _spin_lock_irqsave+0x22/0x32 kernel: [<c04363d3>] prepare_to_wait+0x17/0x4b kernel: [<f89a24b6>] lpfc_do_work+0xdd/0xcc2 [lpfc] kernel: [<c04361b9>] kthread+0xc3/0xf2 kernel: [<c0402005>] kernel_thread_helper+0x5/0xb Another case of non-static lockdep keys; duplicate the paradigm set by DECLARE_COMPLETION_ONSTACK and introduce DECLARE_WAIT_QUEUE_HEAD_ONSTACK. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Greg KH <gregkh@suse.de> Cc: Markus Lidel <markus.lidel@shadowconnect.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-25Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (40 commits) [SCSI] aic79xx: Print out signalling [SCSI] aic7xxx: Remove slave_destroy [SCSI] aic79xx: set precompensation [SCSI] aic79xx: Fixup external device reset [SCSI] replace u8 and u32 with __u8 and __u32 in scsi.h for user space [SCSI] lpfc: fix printk format warning [SCSI] aic79xx: make ahd_set_tags() static [SCSI] aic7xxx: cleanups [SCSI] drivers/scsi: Handcrafted MIN/MAX macro removal [SCSI] scsi_debug: support REPORT TARGET PORT GROUPS [SCSI] qla1280 bus reset typo [SCSI] libiscsi: fix logout pdu processing [SCSI] libiscsi: fix aen support [SCSI] libiscsi: fix missed iscsi_task_put in xmit error path [SCSI] libiscsi: fix oops in connection create failure path [SCSI] iscsi class: fix slab corruption during restart [SCSI] Switch fdomain to the pci_get API [SCSI] add can_queue to host parameters [SCSI] megaraid_{mm,mbox}: 64-bit DMA capability fix [SCSI] aic94xx: Supermicro motherboards support ...
2006-10-25[SCSI] mptfc: stall eh handlers if resetting while rport blockedMichael Reed
Thanks to James Smart for the inspiration. Stall error handler if attempting recovery while an rport is blocked. This avoids device offline scenarios due to errors in the error handler. Also verify that VirtDevice is available before issuing scsi command. VirtDevice is removed when fc transport removes a target. See James Smart's patch of 08/17/2006 for greater detail. http://marc.theaimsgroup.com/?l=linux-scsi&m=115583213624803&w=2 Also bump version number per Eric's request. Signed-off-by: Michael Reed <mdr@sgi.com> Acked-by: Eric Moore <eric.moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-21[PATCH] i2o/exec-osm.c: use "unsigned long flags;"Alexey Dobriyan
Just like everyone else. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] I2O: handle a few sysfs errorsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
