path: root/drivers/message/fusion/mptlan.c
2006-02-27[SCSI] fusion - mptlan - remove wierd humor printMoore, Eric
Removes wierd humor, and bad language printk in mptlan. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[SCSI] fusion: kzalloc / kcalloc conversionChristoph Hellwig
Convert kmalloc + memset to kzalloc or kcalloc in fusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-07[PATCH] message: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: "Moore, Eric Dean" <Eric.Moore@lsil.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-19[SCSI] fusion SAS support (mptsas driver) updatesMoore, Eric Dean
Summary of Changes: * splitting mpt_interrupt per Christophs suggestion about a month ago * rename ScsiCfgData to SpiCfgData structure, then move all the raid related info into new structure called RaidCfgData. This is done because SAS supports RAID, as well as SPI, so the raid stuff should be seperate. * incorrect timeout calculation for cntdn inside WaitForDoorbellAck and WaitForDoortbellInt * add support for interpreting SAS Log Info * Increase Event Log Size from 0xA to 0x32 * Fix bug in mptsas/mptfc/mptspi - when controller has Initiator Mode Disabled, and only running in TargetMode, the mptctl would panic when loading. The fix is to return 0, instead of -ENODEV, in SCSI LLD respective probe routines * Fix bug in mptlan.c - driver will panic if there is host reset, due to dev being set to zero in mpt_lan_ioc_reset * Fix's for SPI - Echo Buffer * Several fix's in mptscsih_io_done - FCP Response info, RESIDUAL_MISMATCH, Data Underrun, etc. * Cleanup Error Handling - EH handlers, mptscsih_flush_cmds, and zeroing out ScsiLookup from mptscsih_qcmd * Cleanup asyn event handling from mptscsih -> mptscsih_event_process. Also added support for SAS Persistent Table Full, an asyn event Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] fusion-kfree-cleanupMoore, Eric Dean
This patch is originally From: Jesper Juhl <juhl-lkml@dif.dk> This patch gets rid of redundant NULL checks prior to calling kfree() in drivers/message/* There are also a few small whitespace changes in there. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: mptlan Remove credits and update copyrightMoore, Eric Dean
(1) mptlan.c: Remove credits and update copyright (2) mptlan.c: Remove -sralston references Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
