path: root/drivers/memstick
2017-01-24drivers/memstick/core/memstick.c: avoid -Wnonnull warningArnd Bergmann
gcc-7 produces a harmless false-postive warning about a possible NULL pointer access: drivers/memstick/core/memstick.c: In function 'h_memstick_read_dev_id': drivers/memstick/core/memstick.c:309:3: error: argument 2 null where non-null expected [-Werror=nonnull] memcpy(mrq->data, buf, mrq->data_len); This can't happen because the caller sets the command to 'MS_TPC_READ_REG', which causes the data direction to be 'READ' and the NULL pointer not accessed. As a simple workaround for the warning, we can pass a pointer to the data that we actually want to read into. This is not needed here, but also harmless, and lets the compiler know that the access is ok. Link: http://lkml.kernel.org/r/20170111144143.548867-1-arnd@arndb.de Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-13Merge branch 'for-4.10/block' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer updates from Jens Axboe: "This is the main block pull request this series. Contrary to previous release, I've kept the core and driver changes in the same branch. We always ended up having dependencies between the two for obvious reasons, so makes more sense to keep them together. That said, I'll probably try and keep more topical branches going forward, especially for cycles that end up being as busy as this one. The major parts of this pull request is: - Improved support for O_DIRECT on block devices, with a small private implementation instead of using the pig that is fs/direct-io.c. From Christoph. - Request completion tracking in a scalable fashion. This is utilized by two components in this pull, the new hybrid polling and the writeback queue throttling code. - Improved support for polling with O_DIRECT, adding a hybrid mode that combines pure polling with an initial sleep. From me. - Support for automatic throttling of writeback queues on the block side. This uses feedback from the device completion latencies to scale the queue on the block side up or down. From me. - Support from SMR drives in the block layer and for SD. From Hannes and Shaun. - Multi-connection support for nbd. From Josef. - Cleanup of request and bio flags, so we have a clear split between which are bio (or rq) private, and which ones are shared. From Christoph. - A set of patches from Bart, that improve how we handle queue stopping and starting in blk-mq. - Support for WRITE_ZEROES from Chaitanya. - Lightnvm updates from Javier/Matias. - Supoort for FC for the nvme-over-fabrics code. From James Smart. - A bunch of fixes from a whole slew of people, too many to name here" * 'for-4.10/block' of git://git.kernel.dk/linux-block: (182 commits) blk-stat: fix a few cases of missing batch flushing blk-flush: run the queue when inserting blk-mq flush elevator: make the rqhash helpers exported blk-mq: abstract out blk_mq_dispatch_rq_list() helper blk-mq: add blk_mq_start_stopped_hw_queue() block: improve handling of the magic discard payload blk-wbt: don't throttle discard or write zeroes nbd: use dev_err_ratelimited in io path nbd: reset the setup task for NBD_CLEAR_SOCK nvme-fabrics: Add FC LLDD loopback driver to test FC-NVME nvme-fabrics: Add target support for FC transport nvme-fabrics: Add host support for FC transport nvme-fabrics: Add FC transport LLDD api definitions nvme-fabrics: Add FC transport FC-NVME definitions nvme-fabrics: Add FC transport error codes to nvme.h Add type 0x28 NVME type code to scsi fc headers nvme-fabrics: patch target code in prep for FC transport support nvme-fabrics: set sqe.command_id in core not transports parser: add u64 number parser nvme-rdma: align to generic ib_event logging helper ...
2016-10-28block: split out request-only flags into a new namespaceChristoph Hellwig
A lot of the REQ_* flags are only used on struct requests, and only of use to the block layer and a few drivers that dig into struct request internals. This patch adds a new req_flags_t rq_flags field to struct request for them, and thus dramatically shrinks the number of common requests. It also removes the unfortunate situation where we have to fit the fields from the same enum into 32 bits for struct bio and 64 bits for struct request. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Shaun Tancheff <shaun.tancheff@seagate.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-10-17memstick: rtsx_usb_ms: Manage runtime PM when accessing the deviceUlf Hansson
Accesses to the rtsx usb device, which is the parent of the rtsx memstick device, must not be done unless it's runtime resumed. This is currently not the case and it could trigger various errors. Fix this by properly deal with runtime PM in this regards. This means making sure the device is runtime resumed, when serving requests via the ->request() callback or changing settings via the ->set_param() callbacks. Cc: <stable@vger.kernel.org> Cc: Ritesh Raj Sarraf <rrs@researchut.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2016-10-17memstick: rtsx_usb_ms: Runtime resume the device when polling for cardsAlan Stern
Accesses to the rtsx usb device, which is the parent of the rtsx memstick device, must not be done unless it's runtime resumed. Therefore when the rtsx_usb_ms driver polls for inserted memstick cards, let's add pm_runtime_get|put*() to make sure accesses is done when the rtsx usb device is runtime resumed. Reported-by: Ritesh Raj Sarraf <rrs@researchut.com> Tested-by: Ritesh Raj Sarraf <rrs@researchut.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: <stable@vger.kernel.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2016-08-02memstick: don't allocate unused major for ms_blockNeilBrown
When alloc_disk(0) is used the ->major number is completely ignored. All devices are allocated with a major of BLOCK_EXT_MAJOR. So remove registration and deregistration of 'major'. Link: http://lkml.kernel.org/r/20160602064318.4403.49955.stgit@noble Signed-off-by: NeilBrown <neilb@suse.com> Cc: Keith Busch <keith.busch@intel.com> Cc: Jens Axboe <axboe@fb.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-20memstick: don't allow REQ_TYPE_BLOCK_PC requestsChristoph Hellwig
There is no code to issue or handle REQ_TYPE_BLOCK_PC request in the memstick drivers, so remove the bogus conditional. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-06-27block: convert to device_add_disk()Dan Williams
For block drivers that specify a parent device, convert them to use device_add_disk(). This conversion was done with the following semantic patch: @@ struct gendisk *disk; expression E; @@ - disk->driverfs_dev = E; ... - add_disk(disk); + device_add_disk(E, disk); @@ struct gendisk *disk; expression E1, E2; @@ - disk->driverfs_dev = E1; ... E2 = disk; ... - add_disk(E2); + device_add_disk(E1, E2); ...plus some manual fixups for a few missed conversions. Cc: Jens Axboe <axboe@fb.com> Cc: Keith Busch <keith.busch@intel.com> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: David S. Miller <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@hansenpartnership.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2016-05-23drivers/memstick/core/mspro_block: use kmemdupMuhammad Falak R Wani
Use kmemdup when some other buffer is immediately copied into allocated region. It replaces call to allocation followed by memcpy, by a single call to kmemdup. [akpm@linux-foundation.org: remove unneeded cast to void*] Link: http://lkml.kernel.org/r/1463665743-16269-1-git-send-email-falakreyaz@gmail.com Signed-off-by: Muhammad Falak R Wani <falakreyaz@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23rtsx_usb_ms: use schedule_timeout_idle() in polling loopOleksandr Natalenko
First version of this patch has already been posted to LKML by Ben Hutchings ~6 months ago, but no further action were performed. Ben's original message: : rtsx_usb_ms creates a task that mostly sleeps, but tasks in : uninterruptible sleep still contribute to the load average (for : bug-compatibility with Unix). A load average of ~1 on a system that : should be idle is somewhat alarming. : : Change the sleep to be interruptible, but still ignore signals. References: https://bugs.debian.org/765717 Link: http://lkml.kernel.org/r/b49f95ae83057efa5d96f532803cba47@natalenko.name Signed-off-by: Oleksandr Natalenko <oleksandr@natalenko.name> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Lee Jones <lee.jones@linaro.org> Cc: Wolfram Sang <wsa@the-dreams.de> Cc: Roger Tseng <rogerable@realtek.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-28memstick: trivial fix of spelling mistake on managementColin Ian King
fix spelling mistake, managment -> management in literal strings, in a variable and a macro. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2016-03-25drivers/memstick/host/r592.c: avoid gcc-6 warningArnd Bergmann
The r592 driver relies on behavior of the DMA mapping API that is normally observed but not guaranteed by the API. Instead it uses a runtime check to fail transfers if the API ever behaves When CONFIG_NEED_SG_DMA_LENGTH is not set, one of the checks turns into a comparison of a variable with itself, which gcc-6.0 now warns about: drivers/memstick/host/r592.c: In function 'r592_transfer_fifo_dma': drivers/memstick/host/r592.c:302:31: error: self-comparison always evaluates to false [-Werror=tautological-compare] (sg_dma_len(&dev->req->sg) < dev->req->sg.length)) { ^ The check itself is not a problem, so this patch just rephrases the condition in a way that gcc does not consider an indication of a mistake. We already know that dev->req->sg.length was initially R592_LFIFO_SIZE, so we can compare it to that constant again. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Quentin Lambert <lambert.quentin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20memstick: use sector_div instead of do_divArnd Bergmann
do_div is the wrong way to divide a sector_t, as it is less efficient when sector_t is 32-bit wide. With the upcoming do_div optimizations, the kernel starts warning about this: drivers/memstick/core/ms_block.c: In function 'msb_io_work': include/asm-generic/div64.h:207:28: warning: comparison of distinct pointer types lacks a cast This changes the code to use sector_div instead, which always produces optimal code. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30memstick: remove deprecated use of pci apiQuentin Lambert
Replace occurences of the pci api by appropriate call to the dma api. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr) @deprecated@ idexpression id; position p; @@ ( pci_dma_supported@p ( id, ...) | pci_alloc_consistent@p ( id, ...) ) @bad1@ idexpression id; position deprecated.p; @@ ...when != &id->dev when != pci_get_drvdata ( id ) when != pci_enable_device ( id ) ( pci_dma_supported@p ( id, ...) | pci_alloc_consistent@p ( id, ...) ) @depends on !bad1@ idexpression id; expression direction; position deprecated.p; @@ ( - pci_dma_supported@p ( id, + dma_supported ( &id->dev, ... + , GFP_ATOMIC ) | - pci_alloc_consistent@p ( id, + dma_alloc_coherent ( &id->dev, ... + , GFP_ATOMIC ) ) Signed-off-by: Quentin Lambert <lambert.quentin@gmail.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17memstick: mspro_block: add missing curly bracesDan Carpenter
Using the indenting we can see the curly braces were obviously intended. This is a static checker fix, but my guess is that we don't read enough bytes, because we don't calculate "t_len" correctly. Fixes: f1d82698029b ('memstick: use fully asynchronous request processing') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-20memstick: host: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-14memstick: r592: fix build warnings for !PM_SLEEPThierry Reding
When PM_SLEEP is not enabled, the r592_clear_interrupts() function is never used. If so, don't build it to prevent a compiler warning. Signed-off-by: Thierry Reding <treding@nvidia.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23drivers/memstick/host/rtsx_pci_ms.c: add cancel_work when remove driverMicky Ching
Add cancel_work_sync() in rtsx_pci_ms_drv_remove() to cancel pending request work when removing the driver. Signed-off-by: Micky Ching <micky_ching@realsil.com.cn> Cc: Samuel Ortiz <sameo@linux.intel.com> says: Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Alex Dubov <oakad@yahoo.com> Cc: Roger Tseng <rogerable@realtek.com> Cc: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-28memstick: Add realtek USB memstick host driverRoger Tseng
Realtek USB memstick host driver provides memstick host support based on the Realtek USB card reader MFD driver. Signed-off-by: Roger Tseng <rogerable@realtek.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-01-23drivers/memstick/host/rtsx_pci_ms.c: fix ms card data transfer bugMicky Ching
This patch is used to add support for ms card. The main difference between ms card and mspro card is long data transfer mode. mspro card can use auto mode DMA for long data transfer, but ms can not use this mode, it should use normal mode DMA. The memstick core added support for ms card, but the original driver will make ms card fail at initialization, because it uses auto mode DMA. This patch makes the ms card work properly. Signed-off-by: Micky Ching <micky_ching@realsil.com.cn> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15drivers/memstick/core/ms_block.c: fix spelling of MSB_RP_RECIVE_STATUS_REGAndrew Morton
2013-11-13drivers/memstick/core/ms_block.c: fix unreachable state in h_msb_read_page()Roger Tseng
In h_msb_read_page() in ms_block.c, flow never reaches case MSB_RP_RECIVE_STATUS_REG. This causes error when MEMSTICK_INT_ERR is encountered and status error bits are going to be examined, but the status will never be copied back. Fix it by transitioning to MSB_RP_RECIVE_STATUS_REG right after MSB_RP_SEND_READ_STATUS_REG. Signed-off-by: Roger Tseng <rogerable@realtek.com> Acked-by: Maxim Levitsky <maximlevitsky@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13drivers/memstick/core/mspro_block.c: fix attributes array allocationMichal Nazarewicz
attrs field of attribute_group structure is a pointer to a pointer (as in an array of pointers) rather than pointer to attribute struct (as in an array of structures), so when allocating size of the pointer sholud be used instead of the structure it is pointing to. While at it, also change the call to use kcalloc rather than kzalloc. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Cc: Tejun Heo <tj@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Alex Dubov <oakad@yahoo.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16memstick: convert bus code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct bus_type is going away soon, dev_groups should be used instead. This converts the memstick bus code to use the correct field. Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-11memstick: add support for legacy memorysticksMaxim Levitsky
Based partially on MS standard spec quotes from Alex Dubov. As any code that works with user data this driver isn't recommended to use to write cards that contain valuable data. It tries its best though to avoid data corruption and possible damage to the card. Tested on MS DUO 64 MB card on Ricoh R592 card reader. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Cc: Jens Axboe <axboe@kernel.dk> Cc: Alex Dubov <oakad@yahoo.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11drivers/memstick/host/rtsx_pci_ms.c: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-30mmc: memstick: rtsx: Modify copyright commentsWei WANG
Update copyright date, and remove author address. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-07-03drivers/memstick/host/r592.c: convert to module_pci_driverLibo Chen
Signed-off-by: Libo Chen <libo.chen@huawei.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/memstick/host/jmb38x_ms: convert to module_pci_driverLibo Chen
Use module_pci_driver instead of init/exit, make code clean. Signed-off-by: Libo Chen <libo.chen@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07block_device_operations->release() should return voidAl Viro
The value passed is 0 in all but "it can never happen" cases (and those only in a couple of drivers) *and* it would've been lost on the way out anyway, even if something tried to pass something meaningful. Just don't bother. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-30drivers/memstick/host/r592.c: make r592_pm_ops staticJingoo Han
r592_pm_ops is not exported. Also, CONFIG_PM_SLEEP is used to remove unnecessary ifdefs. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27memstick: move the dereference below the NULL testWei Yongjun
The dereference should be moved below the NULL test. spatch with a semantic match is used to found this. (http://coccinelle.lip6.fr/) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27memstick: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-24Merge tag 'mfd-3.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFS updates from Samuel Ortiz: "This is the MFD pull request for the 3.9 merge window. No new drivers this time, but a bunch of fairly big cleanups: - Roger Quadros worked on a OMAP USBHS and TLL platform data consolidation, OMAP5 support and clock management code cleanup. - The first step of a major sync for the ab8500 driver from Lee Jones. In particular, the debugfs and the sysct interfaces got extended and improved. - Peter Ujfalusi sent a nice patchset for cleaning and fixing the twl-core driver, with a much needed module id lookup code improvement. - The regular wm5102 and arizona cleanups and fixes from Mark Brown. - Laxman Dewangan extended the palmas APIs in order to implement the palmas GPIO and rt drivers. - Laxman also added DT support for the tps65090 driver. - The Intel SCH and ICH drivers got a couple fixes from Aaron Sierra and Darren Hart. - Linus Walleij patchset for the ab8500 driver allowed ab8500 and ab9540 based devices to switch to the new abx500 pin-ctrl driver. - The max8925 now has device tree and irqdomain support thanks to Qing Xu. - The recently added rtsx driver got a few cleanups and fixes for a better card detection code path and now also supports the RTS5227 chipset, thanks to Wei Wang and Roger Tseng." * tag 'mfd-3.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (109 commits) mfd: lpc_ich: Use devres API to allocate private data mfd: lpc_ich: Add Device IDs for Intel Wellsburg PCH mfd: lpc_sch: Accomodate partial population of the MFD devices mfd: da9052-i2c: Staticize da9052_i2c_fix() mfd: syscon: Fix sparse warning mfd: twl-core: Fix kernel panic on boot mfd: rtsx: Fix issue that booting OS with SD card inserted mfd: ab8500: Fix compile error mfd: Add missing GENERIC_HARDIRQS dependecies Documentation: Add docs for max8925 dt mfd: max8925: Add dts mfd: max8925: Support dt for backlight mfd: max8925: Fix onkey driver irq base mfd: max8925: Fix mfd device register failure mfd: max8925: Add irqdomain for dt mfd: vexpress: Allow vexpress-sysreg to self-initialise mfd: rtsx: Support RTS5227 mfd: rtsx: Implement driving adjustment to device-dependent callbacks mfd: vexpress: Add pseudo-GPIO based LEDs mfd: ab8500: Rename ab8500 to abx500 for hwmon driver ...
2013-02-14mfd: rtsx: Fix issue that booting OS with SD card insertedWei WANG
Realtek card reader supports both SD and MS card. According to the settings of rtsx MFD driver, SD host will be probed before MS host. If we boot/reboot Linux with SD card inserted, the resetting flow of SD card will succeed, and the following resetting flow of MS is sure to fail. Then MS upper-level driver will ask rtsx driver to turn power off. This request leads to the result that the following SD commands fail and SD card can't be accessed again. In this commit, Realtek's SD and MS host driver will check whether the card that upper driver requesting is the one existing in the slot. If not, Realtek's host driver will refuse the operation to make sure the exlusive accessing at the same time. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-21drivers/memstick: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-21drivers/memstick/host: remove depends on CONFIG_EXPERIMENTALKees Cook
2012-11-15drivers/memstick: Add realtek pcie memstick host driverWei WANG
Realtek PCI-E Memstick card host driver is used to access Memstick card, with the help of Realtek PCI-E card reader MFD driver. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Acked-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-20memstick: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-10-31drivers/memstick: Add module.h to the prev. implicit modular usersPaul Gortmaker
This is another group of drivers that simply assumed that module.h was everywhere. But it won't be once we clean up its presence from device.h Call out the real users of it in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-28memstick: make enable_dma less generic in r592Stephen Rothwell
Fixes this build error: drivers/memstick/host/r592.c:26: error: 'enable_dma' redeclared as different kind of symbol arch/powerpc/include/asm/dma.h:189: note: previous definition of 'enable_dma' was here Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Alex Dubov <oakad@yahoo.com> Acked-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-25memstick: add driver for Ricoh R5C592 card readerMaxim Levitsky
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Acked-by: Alex Dubov <oakad@yahoo.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17memstick: change to new flag variablematt mooney
The EXTRA_CFLAGS assignment in memstick/Makefile was not accomplishing anything because this flag only has effect on sources at the same level as the makefile (i.e., per directory). Since both core/ and host/ rely on MEMSTICK_DEBUG, the subdir-ccflags-y variant seems to be the appropriate choice. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-02-16workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable'Tejun Heo
There are two spellings in use for 'freeze' + 'able' - 'freezable' and 'freezeable'. The former is the more prominent one. The latter is mostly used by workqueue and in a few other odd places. Unify the spelling to 'freezable'. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alex Dubov <oakad@yahoo.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Steven Whitehouse <swhiteho@redhat.com>
2011-01-13memstick: factor out transfer initiating functionality in mspro_block.cAlex Dubov
Apart from currently used standard memstick data transfer method, Sony introduced several newer ones, to uncover full bandwidth/capacity of its Pro, HG and XC media formats. This patch lays a foundation to enable those methods as made possible by host/media capabilities. As a side effect of this patch, mspro_block_read_attributes became more streamlined and readable. [akpm@linux-foundation.org: fix printk warning] Signed-off-by: Alex Dubov <oakad@yahoo.com> Reported-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13memstick: remove mspro_block_mutexAlex Dubov
mspro_block_mutex is identical in scope to mspro_block_disk_lock and therefore unnecessary. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13memstick: avert possible race condition between idr_pre_get and idr_get_newAlex Dubov
Implement the usual pattern around idr_pre_get() and idr_get_new() to handlethe situation where another thread concurrently steals this thread's idr_pre_get() preallocation. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
