path: root/drivers/media
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial: (24 commits) DOC: A couple corrections and clarifications in USB doc. Generate a slightly more informative error msg for bad HZ fix typo "is" -> "if" in Makefile ext*: spelling fix prefered -> preferred DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs. KEYS: Fix the comment to match the file name in rxrpc-type.h. RAID: remove trailing space from printk line DMA engine: typo fixes Remove unused MAX_NODES_SHIFT MAINTAINERS: Clarify access to OCFS2 development mailing list. V4L: Storage class should be before const qualifier (sn9c102) V4L: Storage class should be before const qualifier sonypi: Storage class should be before const qualifier intel_menlow: Storage class should be before const qualifier DVB: Storage class should be before const qualifier arm: Storage class should be before const qualifier ALSA: Storage class should be before const qualifier acpi: Storage class should be before const qualifier firmware_sample_driver.c: fix coding style MAINTAINERS: Add ati_remote2 driver ... Fixed up trivial conflicts in firmware_sample_driver.c
2008-04-21V4L: Storage class should be before const qualifier (sn9c102)Tobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-04-21V4L: Storage class should be before const qualifierTobias Klauser
2008-04-21DVB: Storage class should be before const qualifierTobias Klauser
2008-04-18drivers: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-07pvrusb2: fix broken build due to patch order dependencyMichael Krufky
Fix broken build due to patch order dependency. A future patch requires the lines that break the current build. Disable those lines for now. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-06Merge branch 'pci_id_updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb * 'pci_id_updates' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: V4L/DVB (7497): pvrusb2: add new usb pid for 73xxx models V4L/DVB (7496): pvrusb2: add new usb pid for 75xxx models
2008-04-06V4L/DVB (7497): pvrusb2: add new usb pid for 73xxx modelsMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-06V4L/DVB (7496): pvrusb2: add new usb pid for 75xxx modelsMichael Krufky
2008-04-06V4L/DVB (7499): v4l/dvb Kconfig: Fix bugzilla #10067Mauro Carvalho Chehab
tda8290 breaks if tuner is selected, but CONFIG_DVB=n. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-06V4L/DVB (7495): s5h1409: fix blown-away bit in function s5h1409_set_gpioMichael Krufky
Preserve all other bits when setting gpio. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-06V4L/DVB (7460): bttv: Bt832 - fix possible NULL pointer derefCyrill Gorcunov
This patch does fix potential NULL pointer dereference Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-01V4L/DVB (7486): radio-cadet: wrap PNP probe code in #ifdef CONFIG_PNPBjorn Helgaas
Wrap PNP probe code in #ifdef CONFIG_PNP. Without this change, we'll have unresolved references to pnp_get_resource() function when CONFIG_PNP=n. (This is a new interface that's not in mainline yet.) Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-01V4L/DVB (7485): v4l2-int-device.c: add MODULE_LICENSEAdrian Bunk
Now that it's in an own module it needs a MODULE_LICENSE. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-01V4L/DVB (7466): Avoid minor model number warning when an OEM HVR1250 board ↵Steven Toth
is detected Avoid minor model number warning when an OEM HVR1250 board is detected. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-01V4L/DVB (7465): Fix eeprom parsing and errors on the HVR1800 productsSteven Toth
On some models, the valid Hauppauge eeprom data begins at a different offset. This patch avoid unfriendly 'corrupt' eeprom errors during driver load. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-01V4L/DVB (7464): Convert driver to use a single SRAM memory mapSteven Toth
This reduces the memory footprint and removes the need to manually configure each map, which lead to a bug where the Fusion EXP 5 board broke for a while. This also fixes digital support again for the DViCO FusionHDTV5Express. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-01V4L/DVB (7461): bttv: fix missed index checkCyrill Gorcunov
We should check for proper index first Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-01V4L/DVB (7400): bttv: Add a radio compat_ioctl file operationRobert Fitzsimons
Signed-off-by: Robert Fitzsimons <robfitz@273k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-01V4L/DVB (7278): bttv: Re-enable radio tuner support for ↵Robert Fitzsimons
VIDIOCGFREQ/VIDIOCSFREQ ioctls Signed-off-by: Robert Fitzsimons <robfitz@273k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-01V4L/DVB (7277): bttv: Re-enabling radio support requires the use of struct ↵Robert Fitzsimons
bttv_fh A number of the radio tuner ioctl functions are shared with the TV tuner, these functions require a struct bttv_fh data structure to be allocated and initialized. Signed-off-by: Robert Fitzsimons <robfitz@273k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-30zr364xx __user annotationsAl Viro
2008-03-30NULL noise: drivers/mediaAl Viro
Acked-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-20V4L/DVB (7367): bug #10211: Fix depencencies for cx2341xMauro Carvalho Chehab
Fix for build #408 Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7362): tvp5150.c: logical-bitwise and confusionRoel Kluin
logical-bitwise & confusion Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7334): usb video: add a device link to usbvideo devices, else hal ↵Pascal Terjan
will ignore them Signed-off-by: Pascal Terjan <pterjan@mandriva.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7330): V4L1 - fix v4l_compat_translate_ioctl possible NULL derefCyrill Gorcunov
There are possible NULL pointer derefs in case of kzalloc fails so fix them. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7328): usb/opera1.c: fix a memory leakAdrian Bunk
This patch fixes a memory leak in the "testval == 0x67" case spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7291): em28xx: correct use of and fixAndrew Morton
be less silly while we're there. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7285): em28xx: Correct use of ! and &Julia Lawall
In commit e6bafba5b4765a5a252f1b8d31cbf6d2459da337, a bug was fixed that involved converting !x & y to !(x & y). The code below shows the same pattern, and thus should perhaps be fixed in the same way. This is not tested and clearly changes the semantics, so it is only something to consider. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression E1,E2; @@ ( !E1 & !E2 | - !E1 & E2 + !(E1 & E2) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7279): ivtv: Add missing sg_init_table()Ian Armstrong
If a dma transfer is attempted for either yuv or framebuffer output, a missing sg_init_table() call causes a kernel BUG in scatterlist.h if CONFIG_DEBUG_SG is set. Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7268): saa7134: fix: tuner should be loaded before calling ↵Mauro Carvalho Chehab
saa7134_board_init2() There are several parts of saa7134_board_init2() that calls tuner modules. We should first load tuner, otherwise, the commands will fail. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7267): cx88: Fix: Loads tuner module before sending commands to itMauro Carvalho Chehab
2008-03-20V4L/DVB (7251): VIDEO_VIVI must depend on VIDEO_DEVAdrian Bunk
This patch fixes the following compile error with VIDEO_VIVI=y, VIDEO_DEV=m reported by Toralf Förster: <-- snip --> ... LD .tmp_vmlinux1 drivers/built-in.o: In function `vivi_release': vivi.c:(.text+0x322f5): undefined reference to `video_unregister_device' vivi.c:(.text+0x32337): undefined reference to `video_device_release' drivers/built-in.o: In function `vivi_open': vivi.c:(.text+0x32845): undefined reference to `v4l2_type_names' drivers/built-in.o: In function `vivi_init': vivi.c:(.init.text+0x1d20): undefined reference to `video_device_alloc' vivi.c:(.init.text+0x1d48): undefined reference to `video_register_device' drivers/built-in.o:(.rodata+0x1b40): undefined reference to `video_ioctl2'drivers/built-in.o:(.data+0x140c): undefined reference to `video_device_release' <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7242): ivtv: fix for yuv filter table checkIan Armstrong
As the result of a previous change that delayed the loading of the firmware, the driver can sometimes report a bogus error regarding the yuv output filter table not being found in the firmware. This patch moves the filter table check to ensure it's only done after the firmware has been loaded. Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7236): bttv: struct member initialized twiceHarvey Harrison
fixes sparse warning: drivers/media/video/bt8xx/bttv-driver.c:3391:3: warning: Initializer entry defined twice drivers/media/video/bt8xx/bttv-driver.c:3392:3: also defined here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-20V4L/DVB (7228): saa7134: fix FM radio support for the Pinnacle PCTV 110iYuri Funduryan
This also has some coding style fixes. Signed-off-by: Yuri Funduryan <yurifun@mail.ru> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Reviewed-by: Hermann Pitton <hermann-pitton@arcor.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7219): zoran: Fix namespace conflicts with Zoran 'GPIO_MAX' enumMauro Carvalho Chehab
Thanks to Martin Michlmayr <tbm@cyrius.com> for reporting this issue: The zoran driver fails to compile on the ARM Orion platform with: In file included from drivers/media/video/zoran_procfs.c:50: drivers/media/video/zoran.h:232: error: expected identifier before numeric constant The reason is that drivers/media/video/zoran.h defines an enum with GPIO_MAX in it, but Orion contains a #define GPIO_MAX 32 in include/asm-arm/arch-orion/orion.h Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7205): tuner-xc2028 depends on FW_LOADERPaul Mundt
Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7201): cx88-mpeg: Fix race condition in variable accessRicardo Cerqueira
There was a possible race condition in the increment/decrement of the active device references counter. Thanks to Trent Piepho (xyzzy@speakeasy.org) for bringing it up. Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7200): Fix FM firmware loadingMauro Carvalho Chehab
There's no need to load SCode table for FM. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7197): bttv: Fix overlay divide errorRobert Fitzsimons
The initial work to convert the bttv driver to V4L2 "Partial conversion from V4L1 to V4L2" (e84619b17440ccca4e4db7583d126c4189b987e5), missed the line which set the appropriate overlay crop structure in the newly allocated bttv_buffer. This then causes a divide error in the bttv_calc_geo function. Signed-off-by: Robert Fitzsimons <robfitz@273k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7195): xc5000: fix build error when built as moduleTony Breeds
drivers/built-in.o: In function `set_type': tuner-core.c:(.text+0x8879d): undefined reference to `xc5000_attach' Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Reviewed-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7194): cx88-mpeg: Allow concurrent access to cx88-mpeg devicesRoland Stoll
It currently isn't possible to open the frontend device of cx88-mpeg devices (DVB or Blackbird) multiple times concurrently. (for instance, to attach a signal monitoring tool while reading a stream, or to send a frequency change ioctl) This patch fixes that condition. Signed-off-by: Roland Stoll <roland@xindex.de> Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Reviewed-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7193): tveeprom: Add proper tuner mapping for hauppauge eeprom id 133Ricardo Cerqueira
Do away with the need to set tuner=63 on cx88xx with recent HVR-1300 boards Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7192): Adds support for Genius TVGo A11MCEAdrian Pardini
Signed-off-by: Adrian Pardini <pardo.bsso@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7189): autosuspend supportTobias Lorenz
Together with Oliver Neukum from Novell, USB autosuspend support was added. Signed-off-by: Tobias Lorenz <tobias.lorenz@gmx.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7188): radio-si470x version 1.0.6Tobias Lorenz
This patch combines all the finished discussions and its resulting patches from the mailing list. The version 1.0.6 is mainly influenced by Oliver Neukum. He found a lot of small issues, that are fixed with this patch now. For me the most interesting thing is, that it's now safer to use it on other architectures. The history for version 1.0.6 is: - fixed coverity checker warnings in *_usb_driver_disconnect - probe()/open() race by correct ordering in probe() - DMA coherency rules by separate allocation of all buffers - use of endianness macros - abuse of spinlock, replaced by mutex - racy handling of timer in disconnect, replaced by delayed_work - racy interruptible_sleep_on(), replaced with wait_event_interruptible() - handle signals in read() The driver is tested with all Debian/testing radio programs and rdsd. The patch is tested against checkpatch.pl v1.12. Signed-off-by: Tobias Lorenz <tobias.lorenz@gmx.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7186): tda10086: make the 22kHz tone for DISEQC a config optionHartmut Hackmann
Some cards need the diseqc signal modulated, while some just need the envelope to control the LNB supply. This fixes Bug 9887 Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Acked-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7183): radio-si470x: fix build warningMichael Krufky
fix the following build warning: radio-si470x.c: In function 'si470x_get_rds_registers': radio-si470x.c:562: warning: format '%ld' expects type 'long int', but argument 3 has type 'unsigned int' Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
