During v4l2 output playback, there is performance issue after below
commit:
UBUNTU: SAUCE: (upstream) netdev/fec: fix performance impact from
mdio poll operation
Use common workqueue cause this issue, so create an own workqueue for
v4l2 output.
Signed-off-by: Jason Chen <b02280@freescale.com>
Signed-off-by: Alejandro Gonzalez <alex.gonzalez@digi.com>
iMX53 was not in list of parts that include VDI, iMX53 was add.
Signed-off-by: Ran Ferderber r53561@freescale.com
Uncorrect bits_per_pixel will make wrong fb memaloc size, which will
cause Oops for filling black color operation.
(cherry picked from commit 1ac0858a4c6a384f039dfc3f8131d86040c14a58)
Enable fb display channel before buffer select, it avoid display frame
lost for small windows between timming of buffer select and channel
enalbe.
This patch supports camera's MCLK be derived from SSI_EXT1_CLK.
Signed-off-by: Liu Ying <b17645@freescale.com
For MX23, the maximum down scaling factor is 1/2.
For MX28, it's 1/4.
If the scaling factor is below the factor, PxP may not function as expected.
Signed-off-by: Robby Cai <R63905@freescale.com>
change rgbbuf to outbuf, etc. to eliminate confusion for MX28
correct the setting of HW_PXP_OLnSIZE and HW_PXP_RGBSIZE(or HW_PXP_OUTSIZE)
Copied back the pxp.[ch] from branch 2.6.31
pxp.[ch] to mxs_pxp.[ch]
Adjust PxP driver for MX23
Porting PxP(combined with V4L2) driver onto MX28
As CSI->MEM channel keeps on writing the buffer which is set to
ready latestly and raising up end of frame interrupts, the current
v4l2 capture realization mechanism is not appropriate for this channel.
This patch will update the idmac buffer to a dummy buffer whenever
there is no buffers queued by the user.
Signed-off-by: Liu Ying <b17645@freescale.com>
To preview with V4L2 overlay and capture at the same time may fail.
This patch implements workaround for this issue by enabling CSI after
PRP channels are setup.
There is a short show of previous played frame if not fill black color
to display fb.
Because fb device will unblank ahead of real data come.
if dqueue buffer before the third frame queue, dqueue will failed.
This change makes us get rid of DIx_SYNC_DISP_ERR. The error sometimes
causes the backgound framebuffer reinitialized automatically, even if
we preview captured video on overlay framebuffer.
After TV/LCD switch, PXP uses wrong old FB info to set RGBBUF/RGBSIZE.
This patch fixes this problem by notifying PXP to adjust when FB changed.
blank/unblank fb during v4l2 playback, unblank will cause current buffer
of display channel to be 1. This patch make the sequence of select
display buffer correct.
1. Blank BG during video play on FG:
./mxc_v4l2_output.out -iw 320 -ih 240 -ow 1024 -oh 768 -d 3 qvga.yuv
echo 1 > /sys/class/graphics/fb0/blank
echo 0 > /sys/class/graphics/fb0/blank
2. The same input and output (ic_bypass):
./mxc_v4l2_output.out -iw 320 -ih 240 -ow 320 -oh 240 -d 3 qvga.yuv
To use manually buffer select instead of channel link, which resolve fb
blank during v4l2 running issue.
Use DP to do CSC for preview on DPFG instead of using IC channel
so that we can get better performance. This change can make us
get rid of IC channel bandwidth limitation when using IC channel
to do upsizing from low resolution to high resolution and CSC.
This change doesn't touch V4L2 overlay for DPBG, because using DP
to do CSC will change the pixel format for DPBG(usually for GUI).
This change doesn't touch V4L2 capture, because users rarely do
upsizing with high multiple in this case.
Support YUYV and UYVY input pixel format for mxc V4L2 output.
when Cropping happen, for display 5(tvout), fb setting still need keep
as org.
Some kernel resource can be accessed in interrupt handler and user
controlled V4L2 ioctrls, so there is a race condition which makes
the kernel malfunction potentially.
Support NV12 output pixel format for still capture.
Use fbi screen_base as virtual addr instead of phys_to_virtual.
use PXP_NEXT register to implement double buffering schema.
There is one CSI crop improvement (engr117261) in v4l2 capture.
But the improvement is not suitable for tvin module since the
ACT_FRM_SIZE wouldn't be the same with the SENSOR_SIZE.
Signed-off-by: Miao Yu <r65093@freescale.com>
Fixing IC bypass behavoir for cropping
Signed-off-by: Mark Gutman <r58412@freescale.com>
Crop support for outgoing picture to TVE in 720P format
Signed-off-by: Mark.Gutman@freescale.com>
Crop support for outgoing picture to TVE in PAL and NTSC formats
Fix PXP compiling problem after V4L2 option turned on as well
Miss one header file which includes the definition of mxc_tvin_platform_data
Added mx25 new V4L2 ioctls(included VIDIOC_QBUF and VIDIOC_DQBUF etc).
Signed-off-by: Guoqing Jiang <b22156@freescale.com>
(cherry picked from commit f5658a339a5c6a9c2202b0c2bd7c99dd4eb19030)
Update CSI V4L2 capture driver for 2.6.31 kernel.
Signed-off-by: Sammy He <r62914@freescale.com>
Make the camera support D1(PAL/NTSC) resolution.
1) When using CSI->MEM to capture frames, the output frame resolution of
channel CSI->MEM should be the same with that of cropping input frame.
2) Enable to capture frames bigger than the cropped input frames.
(cherry picked from commit eee5a08306df7d9b1f23f463c9e9439e04293b57)
1)Update MXC V4L2 capture driver for 2.6.31 kernel.
2)Update ov3640 camera and ov2640 camera driver for 2.6.31 kernel.
Update MXC V4L2 output driver for 2.6.31 kernel.
Separate chromakey setting for s1 and s0.
Set chromakey for S1 via S_FMT
set chromakey for S0 via S_CTRL (with private CID)
Current V4l2 framework can not support this case with only S_FMT.
Signed-off-by: Robby Cai <r63905@freescale.com>
A new feature is added to support to upsizing by horizontal stripes
via IC PP channels double using.
1) Set camera iomux when initializing camera device, and reset camera iomux
when camera driver disconnects with v4l2 capture master.
2) Remove the forcing debug messages.
Putting PXP in reset state gains the lowest power.
Restrore the PXP regs once PXP comes out of reset state.
Use IC channel to do input cropping even when other conditions make the
V4L2 output driver to bypass IC channel.
This is i.MX BSP 5.0.0 release ported to 2.6.31
Signed-off-by: Rob Herring <r.herring@freescale.com>
Signed-off-by: Alan Tull <r80115@freescale.com>
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
use pgprot_writethru instead
Reported-by: Toralf Forster <toralf.foerster@gmx.de>
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
We should call em28xx_ir_init(dev) only when disable_ir is true.
Signed-off-by: Shine Liu <shinel@foxmail.com>
Reviewed-by: Devin Heitmueller <dheitmueller@kernellabs.com>
The order of indexes is reversed
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Antoine Jacquet <royale@zerezo.com>
