* v4l_for_linus: (464 commits)
[media] uvcvideo: Set error_idx properly for S_EXT_CTRLS failures
[media] uvcvideo: Cleanup leftovers of partial revert
[media] uvcvideo: Return -EACCES when trying to set a read-only control
Linux 3.8-rc3
mm: reinstante dropped pmd_trans_splitting() check
cred: Remove tgcred pointer from struct cred
drm/ttm: fix fence locking in ttm_buffer_object_transfer
ARM: clps711x: Fix bad merge of clockevents setup
ARM: highbank: save and restore L2 cache and GIC on suspend
ARM: highbank: add a power request clear
ARM: highbank: fix secondary boot and hotplug
ARM: highbank: fix typos with hignbank in power request functions
ARM: dts: fix highbank cpu mpidr values
ARM: dts: add device_type prop to cpu nodes on Calxeda platforms
drm/prime: drop reference on imported dma-buf come from gem
xen/netfront: improve truesize tracking
ARM: mx5: Fix MX53 flexcan2 clock
ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array
sctp: fix Kconfig bug in default cookie hmac selection
EDAC: Cleanup device deregistering path
drivers/media/pci/dm1105/dm1105.c
drivers/media/platform/soc_camera/mx2_camera.c
Sometimes there is a problem when trying to access the non-existing registers
of the second demodulator path on the STV0903.
This change removes the calls in case the driver is used on a STV0903.
Signed-off-by: Andreas Regel <andreas.regel@gmx.de>
Acked-by: Manu Abraham <manu@linuxtv.org>
If, for any reason, all per-layers counters stop, remove the
corresponding global counter.
The logic here is similar to the preBER.
The logic that resets the device is wrong. It should be resetting
just the layer that got read. Also, stop is needed before updating
the counters.
the counters.
While there, rename it, as we'll soon introduce a postBER logic
there.
Add both per-layer and global block error count and block count,
for PER and UCB measurements.
If userspace calls a property that doesn't exist, it currently
just returns -EINVAL. However, this is more likely a problem at
the userspace application, calling it with a non-existing property.
So, add a debug message to help tracking it.
Add Signal/Noise ratio measurement. On this device, a global measure
is taken by the demod. It also provides per-layer CNR measurements,
based on Modulation Error measures (MER).
Reviewed-by: Antti Palosaari <crope@iki.fi>
Do a better job on setting the bit error counters, in order to
have all layer measures to happen in a little less than one
second.
Add the methods to read bit error/bit count measurements from
mb86a20s. On ISDB-T devices, those reads are done per layer.
However, as userspace applications may not be aware of that,
add a global measure that will sum the bit errors and bit
counts for each layer, storing them into a global value.
Instead of providing separate callbacks to read the several FE
stats properties, the better seems to use just one method that will:
- Read lock status;
- Read signal strength;
- if locked, get TMCC data;
- if locked, get DVB statistics.
As the DVB frontend thread will call this read_status callback
on every 3 seconds, and userspace can even call it earlier,
all stats data and layers layout will be updated together if
available, with is a good thing.
Add the logic to poll, reset counters and report the QoS stats
to the end user.
The idea is that the core will periodically poll the frontend for
the stats. The frontend may return -EBUSY, if the previous collect
didn't finish, or it may fill the cached data.
The value returned to the end user is always the cached data.
As reported by Feng's kbuild test:
Subject: drivers/media/dvb-frontends/mb86a20s.c:706 mb86a20s_attach() error: potential null dereference 'state'. (kzalloc returns null)
Date: Wed, 23 Jan 2013 19:30:43 +0800
commit: f66d81b54dac26d4e601d4d7faca53f3bdc98427 [media] mb86a20s: convert it to use dev_info/dev_err/dev_dbg
drivers/media/dvb-frontends/mb86a20s.c:706 mb86a20s_attach() error: we previously assumed 'state' could be null (see line 705)
As, at mb86a20s_attach(), we have an i2c pointer, use it for all printk
messages there, instead of state->i2c.
Instead of having its own set of macros, use the Kernel default
ones for debug, error and info.
While here, do some cleanup on the debug printk's.
Reorder functions to have everything related to stats/status read
close. That will make the file more organized as other stats
routines will be added.
No functional changes.
Split the logic that reads the status from the DVB callback. That
helps to properly return an error code, if status read fails.
Get the proper bits from the TMCC table registers.
It is recommented to change register 0x0440 value to 0, in order
to fix some AGC bug.
If an error happens, restore tuner I2C gate to the right
value.
The read/write errors are not handled well on get_frontend. Fix it,
by letting the frontend cached values to represent the DVB properties
that were successfully retrieved.
While here, use "c" for dtv_frontend_properties cache, instead of
"p", as this is more common.
The uvc_set_ctrl() calls don't write to the hardware. A failure at that
point thus leaves the device in a clean state, with no control modified.
Set the error_idx field to the count value to reflect that, as per the
V4L2 specification.
TRY_EXT_CTRLS is unchanged and the error_idx field must always be set to
the failed control index in that case.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Commit ba68c8530a263dc4de440fa10bb20a1c5b9d4ff5 (Partly revert "[media]
uvcvideo: Set error_idx properly for extended controls API failures")
missed two modifications. Clean them up.
also reverted part of commit 30ecb936cbcd83e3735625ac63e1b4466546f5fe
("uvcvideo: Return -EACCES when trying to access a read/write-only
control") by mistake. Fix it.
Linux 3.8-rc3
* tag 'v3.8-rc3': (11110 commits)
Linux 3.8-rc3
EDAC: Fix EDAC Kconfig menu
EDAC: Fix kernel panic on module unloading
ALSA: hda - add mute LED for HP Pavilion 17 (Realtek codec)
Hi Mauro,
After merging the v4l-dvb tree, today's linux-next build (x86_64
allmodconfig) failed like this:
drivers/media/platform/sh_veu.c:1146:22: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'sh_veu_probe'
drivers/media/platform/sh_veu.c:1228:22: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'sh_veu_remove'
drivers/media/platform/sh_veu.c:1244:2: error: implicit declaration of function '__devexit_p' [-Werror=implicit-function-declaration]
drivers/media/platform/sh_veu.c:1244:25: error: 'sh_veu_remove' undeclared here (not in a function)
drivers/media/platform/sh_veu.c: In function 'sh_veu_init':
drivers/media/platform/sh_veu.c:1253:45: error: 'sh_veu_probe' undeclared (first use in this function)
drivers/media/platform/sh_veu.c:1253:45: note: each undeclared identifier is reported only once for each function it appears in
drivers/media/platform/sh_veu.c: At top level:
drivers/media/platform/sh_veu.c:1095:20: warning: 'sh_veu_bh' defined but not used [-Wunused-function]
drivers/media/platform/sh_veu.c:1109:20: warning: 'sh_veu_isr' defined but not used [-Wunused-function]
drivers/media/platform/sh_veu.c:1254:1: warning: control reaches end of non-void function [-Wreturn-type]
Caused by commit 05efa71bdc0e ("[media] media: add a VEU MEM2MEM format
conversion and scaling driver") interacting with commit 54b956b90360
("Remove __dev* markings from init.h") from the driver-core.current tree.
I have applied the following merge fix patch which could be applied
directly to the v4l-dvb tree (please):
CONFIG_HOTPLUG is always true now and the __dev* macros have meen removed.
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
The plat/*.h headers are not available to drivers in multiplatform
kernels. As the header isn't needed, just remove it.
Acked-by: Sakari Ailus <sakari.ailus@iki.fi>
Multistream support for stv0900. For Netup Dual S2 CI with STV0900BAC/AAC.
Signed-off-by: Evgeny Plehov <EvgenyPlehov@ukr.net>
Walking rbtree while it's modified is a Bad Idea(tm); besides,
the result of find_vma() can be freed just as it's getting returned
to caller. Fortunately, it's easy to fix - just take ->mmap_sem a bit
earlier (and don't bother with find_vma() at all if virtp >= PAGE_OFFSET -
in that case we don't even look at its result).
While we are at it, what prevents VIDIOC_PREPARE_BUF calling
v4l_prepare_buf() -> (e.g) vb2_ioctl_prepare_buf() -> vb2_prepare_buf() ->
__buf_prepare() -> __qbuf_userptr() -> vb2_vmalloc_get_userptr() -> find_vma(),
AFAICS without having taken ->mmap_sem anywhere in process? The code flow
is bloody convoluted and depends on a bunch of things done by initialization,
so I certainly might've missed something...
Cc: stable@vger.kernel.org [2.6.35]
Cc: Sakari Ailus <sakari.ailus@iki.fi>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Archit Taneja <archit@ti.com>
Cc: Prabhakar Lad <prabhakar.lad@ti.com>
Restore ds3000.c read_signal_strength.
Call tuner get_rf_strength from frontend read_signal_strength.
We are able to do a NULL check and doesn't limit the tuner
attach to the frontend attach area.
At the moment the lmedm04 tuner attach is stuck in frontend
attach area.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
Add a configuration option for v4l2-int-device so it is only compiled when
necessary, which is only by omap24xxcam and tcm825x drivers.
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
Remy Blank reported that audio over USB can be made working for the television
input if .amux is changed from EM28XX_AMUX_LINE_IN to EM28XX_AMUX_VIDEO.
An examination of his devices shows, that it is indeed supplied with an EM202
AC97 audio IC. We also use this setting for the Cinergy 200.
Remy Blank also provided the original version of this patch (many thanks !).
Fixes bug 14126 (see bug report for further device details).
Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com>
Signed-off-by: Remy Blank <remy.blank@pobox.com>
We recently pushed the locking down into this function, but there was
an error path where the unlock was missed.
Fixes corruption of fe->demodulator_priv
When mutex_lock_interruptible is used on paths where a signal can be
pending, the device is not closed properly and cannot be reused.
This usually happens when you start tzap for example and send it a
TERM signal. The signal is pending while tear-down routines are
called. Hence streaming is not properly stopped in that case. And
the device stops working from that moment on.
Signed-off-by: Antti Palosaari <crope@iki.fi>
Device with ID 1b80:d393 is the Gigabyte U7300 DVB-T dongle.
It contains decoder Realtek RTL2832U and tuner Fitipower FC0012.
[crope@iki.fi: fix trivial merge conflict]
Signed-off-by: Alexander Inyukhin <shurick@sectorb.msk.ru>
RF-tuner is Fitipower FC0013
Reported-by: Renato Gallo <renatogallo@unixproducts.com>
replace:
#if defined(CONFIG_RC_CORE) || defined(CONFIG_RC_CORE_MODULE)
with:
#if IS_ENABLED(CONFIG_RC_CORE)
Reported-by: Fabio Estevam <festevam@gmail.com>
Use own flag to mark when rc polling is active/deactive and make
decisions, like start/stop polling on suspend/resume, against that.
I think it is better (cheaper) to use dummy defines for functions
that has no meaning when remote controller is disabled by Kconfig.
Those are not needed anymore as all dvb-usb-v2 drivers has proper
dependency checks for RC-core.
Acked-by: Malcolm Priestley <tvboxspy@gmail.com>
Do not compile remote controller when RC-core is disabled by Kconfig.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Make it possible to compile dvb_usb_v2 driver without the remote
controller (RC-core).
