path: root/drivers/media
2008-05-18Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c/max6875: Really prevent 24RF08 corruption i2c-amd756: Fix functionality flags i2c: Kill the old driver matching scheme i2c: Convert remaining new-style drivers to use module aliasing i2c: Switch pasemi to the new device/driver matching scheme i2c: Clean up Blackfin BF527 I2C device declarations i2c-nforce2: Disable the second SMBus channel on the DFI Lanparty NF4 Expert i2c: New co-maintainer
2008-05-18i2c: Convert remaining new-style drivers to use module aliasingJean Delvare
Update all the remaining new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. Note that the tuner driver is a bit quirky at the moment, as it overwrites i2c_client.name with arbitrary strings. We write "tuner" back on remove, to make sure that driver cycling will work properly, but there may still be troublesome corner cases. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-16byteorder: don't directly include linux/byteorder/generic.hHarvey Harrison
Use asm/byteorder.h instead. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14V4L/DVB (7900): pvrusb: Fix Kconfig if DVB=m V4L_core=yMauro Carvalho Chehab
As reported by Ingo Molnar: x86.git testing found the following build failure: drivers/built-in.o: In function `pvr2_dvb_feed_thread': pvrusb2-dvb.c:(.text+0x127e78): undefined reference to `dvb_dmx_swfilter' drivers/built-in.o: In function `pvr2_dvb_adapter_exit': pvrusb2-dvb.c:(.text+0x128357): undefined reference to `dvb_net_release' pvrusb2-dvb.c:(.text+0x12836f): undefined reference to `dvb_dmxdev_release' [...] with this config: CONFIG_VIDEO_PVRUSB2=y CONFIG_DVB_CORE=m i.e. pvrusb2 is built-in, dvb-core is modular. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7899): Fixes a few remaining Kbuild issues at common/tunersMauro Carvalho Chehab
- MEDIA_ATTACH now applies also for V4L; - select a FW_LOADER dependent driver should happen only if HOTPLUG; - apply the common tuner dependency to all tuners. This helps to avoid latter issues. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7898): Fix VIDEO_MEDIA Kconfig logicMauro Carvalho Chehab
If one of DVB_CORE or VIDEO_DEV is a module, the modules that can be used by both DVB and V4L cores should also be a module, otherwise, it will break its dependencies. This Kconfig logic implements the following: CONFIG_VIDEO_DEV CONFIG_DVB_CORE CONFIG_VIDEO_MEDIA N N N N M M N Y Y M N M M M M M Y M Y N Y Y M M Y Y Y Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7895): tveeprom: update Hauppauge analog audio and video decodersMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7893): xc5000: bug-fix: allow multiple devices in a single systemMichael Krufky
The current code passes a context pointer in the xc5000_config struct. This context pointer is used in the tuner_callback function, used to reset the device after firmware download. The xc5000_config struct is a static structure, whose .priv member was being assigned before calling xc5000_attach(). If there are more than one of the same device type installed on a single system, the last one to assign xc5000_config.priv will "win", and all others will cease to function properly. This patch passes the context pointer in xc5000_attach() rather that storing it within the static struct xc5000_config. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7891): cx18/ivtv: fix open() kernel oopsAndy Walls
Upon error conditions in cx18/ivtv_probe(), the code at the 'err:' label leaves a NULL entry in cx18/ivtv_cards[]. This can cause a NULL pointer de-reference in cx18/ivtv_v4l2_open() which is fixed by this patch. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7890): cx18: removed bogus and confusing conditionalHans Verkuil
2008-05-14V4L/DVB (7889): cx18: improve HVR-1600 detection.Hans Verkuil
2008-05-14V4L/DVB (7888): cx18: minor card definition updates.Hans Verkuil
2008-05-14V4L/DVB (7887): cx18: fix Compro H900 analog support.Hans Verkuil
Tuner, S-Video and Composite are all working for the Compro H900. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7881): saa7134: fixed a compile warning in saa7134-core.cHartmut Hackmann
patch 779169257208 made the variable mask unnecessary. This patch just removes the declaration. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7880): saa7134: remove explicit GPIO initializationHartmut Hackmann
This causes a problem with the audio mute on some cards and is done implictly in the audio initialization code. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7879): Adding cx18 Support for mxl5005sSteven Toth
Adding cx18 Support Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7878): mxl55005s: Makefile and Kconfig additionsSteven Toth
Makefile and Kconfig additions Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7877): mxl5005s: Ensure debug is offSteven Toth
Ensure debug is off Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7876): mxl5005s: Remove incorrect copyright holdersSteven Toth
I was informed by Jan Hoogenraad that two people needed to be removed from the original copyright comments. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7875): mxl5005s: Remove redundant functionsSteven Toth
Remove redundant functions Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7874): mxl5005s: Fix function staticsSteven Toth
Fix function statics Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7873): mxl5005s: Fix header includes.Steven Toth
Ensure we have the correct .h dependencies included. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7872): mxl5005s: checkpatch.pl complianceSteven Toth
4 exceptions where the code would read very ugly otherwise. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7871): mxl5005s: Re-org code and update copyrightsSteven Toth
Re-org code and update copyrights Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7870): mxl5005s: Basic digital support.Steven Toth
ATSC and QAM should be working but basic testing is required. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7869): mxl5005s: Cleanup #6Steven Toth
Cleanup #6 Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7868): mxl5005s: Cleanup #5Steven Toth
Cleanup #5 Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7867): mxl5005s: Cleanup #4Steven Toth
Cleanup #4 Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7866): mxl5005s: Cleanup #3Steven Toth
Cleanup #3 Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7865): mxl5005s: Cleanup #2Steven Toth
Cleanup #2 Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7864): mxl5005s: Cleanup #1Steven Toth
Cleanup #1 Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7862): Add mxl5505s driver for MaxiLinear 5505 chipsetsSteven Toth
Initial check-in of the original driver to establish history. Signed-off-by: Chia-Ling Lu Developer <chialing@realtek.com.tw> Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7861): mt312: Prefix functions only with mt312_, Add zl10313 to ↵Matthias Schwarzott
kconfig description This patch does some small cleanup to mt312. It changes kconfig description to also list the ZL10313. It does change some strange symbol names to be consistent with module name mt312 and naming of all other functions in there. * vp310_mt312_ops -> mt312_ops * vp310_mt312_attach -> mt312_attach Adds a MODULE_AUTHOR for me Signed-off-by: Matthias Schwarzott <zzam@gentoo.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7859): mt9v022: fix a copy-paste error in commentGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7858): video: build fix for drivers/media/video/mt9v022.cIngo Molnar
x86.git testing found the following build bug on latest -git: CC [M] drivers/media/video/mt9v022.o drivers/media/video/mt9v022.c: In function 'bus_switch_request': drivers/media/video/mt9v022.c:199: error: implicit declaration of function 'gpio_is_valid' drivers/media/video/mt9v022.c:201: error: implicit declaration of function 'gpio_request' drivers/media/video/mt9v022.c:207: error: implicit declaration of function 'gpio_direction_output' drivers/media/video/mt9v022.c:211: error: implicit declaration of function 'gpio_free' drivers/media/video/mt9v022.c: In function 'bus_switch_act': drivers/media/video/mt9v022.c:237: error: implicit declaration of function 'gpio_set_value_cansleep' make[2]: *** [drivers/media/video] Error 2 make[1]: *** [drivers/media] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [drivers] Error 2 with this config: http://redhat.com/~mingo/misc/config-Sat_May__3_16_08_39_CEST_2008.bad the bug was that the driver uses GPIO functionality but only includes the GPIO interface definitions for the CONFIG_MT9M001_PCA9536_SWITCH case, which was not set in this config. The quick fix seems to be to include linux/gpio.h unconditionally. (this seems like a small cleanup as well as it removes and #ifdef is more robust than an inclusion of asm/gpio.h) Not tested too much yet, so please have another look in any case. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7857): make itd1000_fre_values[] static constAdrian Bunk
itd1000_fre_values[] can become static const. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7856): cx18/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - cx18-i2c.c should #include "cx18-i2c.h" for getting the prototypes of it's global functions - make the following needlessly global functions static: - cx18-fileops.c:cx18_claim_stream() - cx18-fileops.c:cx18_release_stream() - cx18-queue.c:cx18_queue_move() - remove the following unused functions: - cx18-driver.c:cx18_waitq() - cx18-queue.c:cx18_buf_copy_from_user() Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7854): cx18/ivtv: improve and fix out-of-memory handlingHans Verkuil
- don't show kernel backtrace when the allocation of the buffers fails: the normal ivtv/cx18 messages are clear enough and the backtrace scares users. - fix cleanup after the buffer allocation fails (caused kernel panic). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7853): ivtv/cx18: fix compile warningsHans Verkuil
Fix compile warnings if MODULE is not defined. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7852): ivtv: prefix ivtv external functions with ivtv_Hans Verkuil
Fix conflict with cx18 driver. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7851): Fix FW_LOADER depencency at v4l/dvbMauro Carvalho Chehab
Since: 1) FW_LOADER is defined as: config FW_LOADER tristate "Userspace firmware loading support" depends on HOTPLUG 2) several V4L/DVB driver just selects it; 3) select is not smart enough to auto-select HOTPLUG, if select FW_LOADER. So, All drivers that select FW_LOADER should also depend on HOTPLUG. An easier solution (for the end-user perspective) would be to "select HOTPLUG". However, live is not simple. This would cause recursive dependency issues like this one: drivers/usb/Kconfig:62:error: found recursive dependency: USB -> USB_OHCI_HCD -> I2C -> MEDIA_TUNER -> MEDIA_TUNER_XC2028 -> HOTPLUG -> PCCARD -> PCMCIA -> USB_ARCH_HAS_HCD -> MOUSE_APPLETOUCH -> USB Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7849): cx88: fix Kconfig depencencies for FW_LOADERMauro Carvalho Chehab
cx88 doesn't need support for FW_LOADER. Instead, this is required only for cx88-blackbird. Also, cx88-blackbird depends on HOTPLUG, due to FW_LOADER dependency. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7848): Fix dependencies for tuner-xc2028 and em28xx-dvbMauro Carvalho Chehab
em28xx-dvb doesn't need FW_LOADER. Instead, tuner-xc2028 needs to select FW_LOADER. Also, this can happen only if HOTPLUG is selected, since FW_LOADER is dependent on HOTPLUG. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7847): Simplifies Kconfig rulesMauro Carvalho Chehab
Since all tuners are dependent of I2C, move I2C dependency to MEDIA_TUNER. Also, simplifies the dependencies for the other Kconfig items. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7846): Re-creates VIDEO_TUNERMauro Carvalho Chehab
VIDEO_TUNER is responsible for compilation of tuners.ko module. This were the previous behaviour before the creation of MEDIA_TUNER. Before this patch, tuner.ko were created even for drivers that don't need a tuner (like webcam drivers). Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7844): tda18271: add tda_fail macro to log error casesMichael Krufky
2008-05-14V4L/DVB (7843): tda18271: fix error handling in ↵Michael Krufky
tda18271c1_rf_tracking_filter_calibration Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7842): tda18271: fix error handling in ↵Michael Krufky
tda18271c2_rf_tracking_filters_correction Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7841): tda18271: fix error handling in tda18271_channel_configurationMichael Krufky
2008-05-14V4L/DVB (7840): tda18271: make tda18271_set_standby_mode less verbose for ↵Michael Krufky
basic debug Only show debug from tda18271_set_standby_mode if DBG_ADV is set. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
